[MPICH2-dev] mpich2 booting problem
Rajeev Thakur
thakur at mcs.anl.gov
Mon Jul 18 08:37:45 CDT 2005
The MPICH2 Installer's Guide in the doc/installguide directory has some
instructions on what to do if MPD does not run, such as running mpdcheck.
Have you tried those steps?
Rajeev
_____
From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-dev at mcs.anl.gov] On
Behalf Of peeyush
Sent: Monday, July 18, 2005 7:19 AM
To: mpich2-dev at mcs.anl.gov
Subject: [MPICH2-dev] mpich2 booting problem
hello,
I have installed mpich2 and intel fortran compiler but when i try to do
mpdboot on sample example on more than 2 processors , I got the following
error:
$ mpdboot -n 2
mpdboot_pg_0 (mpdboot 393): error trying to start mpd(boot) at 1 {'host':
'172.27.22.184', 'ncpus': 1, 'ifhn': ''}; output:
mpdboot_localhost_1 (err_exit 415): mpd failed to start correctly on
localhost
reason: 1: unable to ping local mpd;
invalid msg from mpd :{}:
** mpd may have disappeared, perhaps due to mismatched secretwords
** see msgs logged in syslog and /tmp/mpd2.logfile* on localhost
last printed output from mpd before becoming a daemon:
33151
mpdboot_localhost_1 (err_exit 421): contents of mpd logfile in /tmp:
logfile for mpd with pid 8832
localhost_33151: conn error in connect_lhs: Connection refused
localhost_33151 (connect_lhs 542): failed to connect to lhs at pg
33166
localhost_33151 (enter_ring 500): lhs connect failed
localhost_33151 (run 215): failed to enter ring
mpdboot_pg_0 (err_exit 415): mpd failed to start correctly on pg
It works fine with one processor. I am using ssh without password with nfs
on two processor and it works quite fine.
can u tell me what the problem is. Your help will be highly appreciable.
Looking Forward to ur reply.
Peeyush Jain
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20050718/67c1b8c9/attachment.htm>
More information about the mpich2-dev
