[MPICH2-dev] mpich2 booting problem
peeyush peeyushj at iitk.ac.in
Mon Jul 18 07:19:22 CDT 2005
hello,
    I have installed mpich2 and intel fortran compiler but when i try to do
mpdboot on sample example on more than 2 processors , I got the following
error:
$ mpdboot -n 2
mpdboot_pg_0 (mpdboot 393): error trying to start mpd(boot) at 1 {'host': '172.27.22.184', 'ncpus': 1, 'ifhn': ''}; output:
   mpdboot_localhost_1 (err_exit 415): mpd failed to start correctly on localhost
     reason: 1: unable to ping local mpd;
   invalid msg from mpd :{}:
   ** mpd may have disappeared, perhaps due to mismatched secretwords
   ** see msgs logged in syslog and /tmp/mpd2.logfile* on localhost
   last printed output from mpd before becoming a daemon:
   33151
   mpdboot_localhost_1 (err_exit 421):   contents of mpd logfile in /tmp:
        logfile for mpd with pid 8832
        localhost_33151: conn error in connect_lhs: Connection refused
        localhost_33151 (connect_lhs 542): failed to connect to lhs at pg 33166
        localhost_33151 (enter_ring 500): lhs connect failed
        localhost_33151 (run 215): failed to enter ring
mpdboot_pg_0 (err_exit 415): mpd failed to start correctly on pg
It works fine with one processor. I am using ssh without password with nfs on two processor and it works quite fine.
can u tell me what the problem is. Your help will be highly appreciable.
Looking Forward to ur reply.
Peeyush Jain
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20050718/a09cb9ee/attachment.htm>
More information about the mpich2-dev mailing list
