[mpich-discuss] MPI_Comm_spawn / MPI_Info question
Pavan Balaji balaji at mcs.anl.gov
Sun Sep 16 19:20:23 CDT 2012
Hydra does respect the "hosts" environment variable.  However, it might
have been added after 1.4.1p1 was released.  You can pick the 1.5rc1
release of Hydra and use it with mpich2-1.4.1p1 (it's backward compatible).
Note that "host" is a part of the MPI standard, while "hosts" is not.
So you'll be using a Hydra-specific option.
  -- Pavan
On 09/16/2012 07:18 PM, Christoph Sprenger wrote:
> doh accidently pressed ctrl-enter.
> it seems that hydra passes envall by default to spawned nodes which
> solves pretty much my previous issue.
> i am trying to figure out if its possible to do the following:
> MPI_Info_set(info, "hosts", "node1,node2");
> seems that they all get launched on the original node where mpiexec was run.
> MPI_Info_set(info, "host", "node2");
> seems to work fine and it spawns as expected on the other machine.
> preferably i wanted to avoid generating a hostfile and was curious if
> thats possible to supply multiple machines directly in the MPI_Info.
> Cheers,
> Christoph
> On 17/09/12 12:06, Christoph Sprenger wrote:
>> Thanks for that Pavan.
>> Just installed and upgraded and super happy how smooth that went.
>> On 16/09/12 17:19, Pavan Balaji wrote:
>>> Can you upgrade to the latest version of mpich2?  1.2.1p1 is too old;
>>> it uses a different process manager which is not supported anymore.
>>>   -- Pavan
>>> On 09/15/2012 09:23 PM, Christoph Sprenger wrote:
>>>> Hi,
>>>> I've been trying to get MPI_Info to work with the Spawn interface, but
>>>> seems like the env vars aren't supplied to the new processes.
>>>> I've been searching the docs and source, but can't find the list of
>>>> hints for mpich2, so i am not sure if "envlist" is the right key for
>>>> the
>>>> mpd.
>>>> not sure if i missed the obvious. is there an overview somewhere of all
>>>> the reserved keys ( eg envall,... )
>>>> MPI_Info info;
>>>> MPI_Info_create(&info);
>>>> MPI_Info_set(info, "envlist", "CUSTOM_VAR");
>>>> MPI_Comm_spawn(argv[0], &argv[1] , n, info, 0, MPI_COMM_WORLD,
>>>> &intracomm, MPI_ERRCODES_IGNORE);
>>>> i currently use mpich2-1.2.1
>>>> Cheers,
>>>> Christoph
>>>> _______________________________________________
>>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>> To manage subscription options or unsubscribe:
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
