[mpich-discuss] MPI_Comm_spawn / MPI_Info question
    Christoph Sprenger
    csprenger at wetafx.co.nz
    Sun Sep 16 19:33:28 CDT 2012
excellent, thanks a lot !
On 17/09/12 12:20, Pavan Balaji wrote:
> Hydra does respect the "hosts" environment variable.  However, it
> might have been added after 1.4.1p1 was released.  You can pick the
> 1.5rc1 release of Hydra and use it with mpich2-1.4.1p1 (it's backward
> compatible).
> Note that "host" is a part of the MPI standard, while "hosts" is not.
> So you'll be using a Hydra-specific option.
>  -- Pavan
> On 09/16/2012 07:18 PM, Christoph Sprenger wrote:
>> doh accidently pressed ctrl-enter.
>> it seems that hydra passes envall by default to spawned nodes which
>> solves pretty much my previous issue.
>> i am trying to figure out if its possible to do the following:
>> MPI_Info_set(info, "hosts", "node1,node2");
>> seems that they all get launched on the original node where mpiexec
>> was run.
>> MPI_Info_set(info, "host", "node2");
>> seems to work fine and it spawns as expected on the other machine.
>> preferably i wanted to avoid generating a hostfile and was curious if
>> thats possible to supply multiple machines directly in the MPI_Info.
>> Cheers,
>> Christoph
>> On 17/09/12 12:06, Christoph Sprenger wrote:
>>> Thanks for that Pavan.
>>> Just installed and upgraded and super happy how smooth that went.
>>> On 16/09/12 17:19, Pavan Balaji wrote:
>>>> Can you upgrade to the latest version of mpich2?  1.2.1p1 is too old;
>>>> it uses a different process manager which is not supported anymore.
>>>>   -- Pavan
>>>> On 09/15/2012 09:23 PM, Christoph Sprenger wrote:
>>>>> Hi,
>>>>> I've been trying to get MPI_Info to work with the Spawn interface,
>>>>> but
>>>>> seems like the env vars aren't supplied to the new processes.
>>>>> I've been searching the docs and source, but can't find the list of
>>>>> hints for mpich2, so i am not sure if "envlist" is the right key for
>>>>> the
>>>>> mpd.
>>>>> not sure if i missed the obvious. is there an overview somewhere
>>>>> of all
>>>>> the reserved keys ( eg envall,... )
>>>>> MPI_Info info;
>>>>> MPI_Info_create(&info);
>>>>> MPI_Info_set(info, "envlist", "CUSTOM_VAR");
>>>>> MPI_Comm_spawn(argv[0], &argv[1] , n, info, 0, MPI_COMM_WORLD,
>>>>> &intracomm, MPI_ERRCODES_IGNORE);
>>>>> i currently use mpich2-1.2.1
>>>>> Cheers,
>>>>> Christoph
>>>>> _______________________________________________
>>>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>>> To manage subscription options or unsubscribe:
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
