[mpich-discuss] Newbie getting started question?
John Chludzinski
john.chludzinski at gmail.com
Fri Sep 14 21:37:21 CDT 2012
Just ran: yum install mpich2-devel
# ls -l /usr/lib/mpich2/lib/
total 7484
-rw-r--r--. 1 root root 25459 Jan 2 2012 clog2print.jar
-rw-r--r--. 1 root root 127339 Jan 2 2012 clog2TOdrawable.jar
-rw-r--r--. 1 root root 183747 Jan 2 2012 clog2TOslog2.jar
-rw-r--r--. 1 root root 17400 Jan 2 2012 clogprint.jar
-rw-r--r--. 1 root root 108290 Jan 2 2012 clogTOdrawable.jar
-rw-r--r--. 1 root root 164701 Jan 2 2012 clogTOslog2.jar
-rw-r--r--. 1 root root 2449314 Jan 2 2012 jumpshot.jar
-rw-r--r--. 1 root root 7140 Jan 2 2012 jumpshot_launcher.jar
-rw-r--r--. 1 root root 16278 Jan 2 2012 libampe.a
lrwxrwxrwx. 1 root root 16 Sep 14 22:33 libfmpich.so ->
libfmpich.so.3.3
lrwxrwxrwx. 1 root root 16 Sep 14 16:20 libfmpich.so.3 ->
libfmpich.so.3.3
-rwxr-xr-x. 1 root root 121604 Jan 2 2012 libfmpich.so.3.3
-rw-r--r--. 1 root root 271832 Jan 2 2012 liblmpe.a
-rw-r--r--. 1 root root 237292 Jan 2 2012 libmpe.a
-rw-r--r--. 1 root root 182660 Jan 2 2012 libmpe_collchk.a
-rw-r--r--. 1 root root 36448 Jan 2 2012 libmpe_f2cmpi.a
-rw-r--r--. 1 root root 219056 Jan 2 2012 libmpe_nompi.a
-rw-r--r--. 1 root root 20776 Jan 2 2012 libmpe_nompi_null.a
-rw-r--r--. 1 root root 10356 Jan 2 2012 libmpe_null.a
lrwxrwxrwx. 1 root root 18 Sep 14 22:33 libmpichcxx.so ->
libmpichcxx.so.3.3
lrwxrwxrwx. 1 root root 18 Sep 14 16:20 libmpichcxx.so.3 ->
libmpichcxx.so.3.3
-rwxr-xr-x. 1 root root 116756 Jan 2 2012 libmpichcxx.so.3.3
lrwxrwxrwx. 1 root root 18 Sep 14 22:33 libmpichf90.so ->
libmpichf90.so.3.3
lrwxrwxrwx. 1 root root 18 Sep 14 16:20 libmpichf90.so.3 ->
libmpichf90.so.3.3
-rwxr-xr-x. 1 root root 5644 Jan 2 2012 libmpichf90.so.3.3
lrwxrwxrwx. 1 root root 15 Sep 14 22:33 libmpich.so -> libmpich.so.3.3
lrwxrwxrwx. 1 root root 15 Sep 14 16:20 libmpich.so.3 ->
libmpich.so.3.3
-rwxr-xr-x. 1 root root 1861652 Jan 2 2012 libmpich.so.3.3
lrwxrwxrwx. 1 root root 15 Sep 14 22:33 libmpl.so -> libmpl.so.1.1.0
lrwxrwxrwx. 1 root root 15 Sep 14 16:20 libmpl.so.1 -> libmpl.so.1.1.0
-rwxr-xr-x. 1 root root 15612 Jan 2 2012 libmpl.so.1.1.0
lrwxrwxrwx. 1 root root 15 Sep 14 22:33 libopa.so -> libopa.so.1.0.0
lrwxrwxrwx. 1 root root 15 Sep 14 16:20 libopa.so.1 -> libopa.so.1.0.0
-rwxr-xr-x. 1 root root 3940 Jan 2 2012 libopa.so.1.0.0
-rw-r--r--. 1 root root 86000 Jan 2 2012 libtmpe.a
-rw-r--r--. 1 root root 265485 Jan 2 2012 logconvertor.jar
-rw-r--r--. 1 root root 10760 Jan 2 2012 mpe_prof.o
-rw-r--r--. 1 root root 173622 Jan 2 2012 slog2filter.jar
-rw-r--r--. 1 root root 136084 Jan 2 2012 slog2navigator.jar
-rw-r--r--. 1 root root 136091 Jan 2 2012 slog2printrecur.jar
-rw-r--r--. 1 root root 136086 Jan 2 2012 slog2printserial.jar
-rw-r--r--. 1 root root 261610 Jan 2 2012 slog2update205to206.jar
-rw-r--r--. 1 root root 67742 Jan 2 2012 traceprint.jar
drwxr-xr-x. 2 root root 4096 Sep 14 22:33 trace_rlog
-rw-r--r--. 1 root root 124160 Jan 2 2012 traceTOslog2.jar
On Fri, Sep 14, 2012 at 8:08 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> This package is missing the symlinks libmpich.so -> libmpich.so.3.3. Is
> there a separate mpich2-devel package?
> On Fri, Sep 14, 2012 at 6:57 PM, John Chludzinski <
> john.chludzinski at gmail.com> wrote:
>> $ ls -l /usr/lib/mpich2/lib
>> total 6412
>> libfmpich.so.3.3
>> libmpichcxx.so.3.3
>> libmpichf90.so.3.3
>> libmpich.so.3.3
>> libmpl.so.1.1.0
>> libopa.so.1.0.0
>> $ mpif90 -show
>> gfortran -m32 -O2 -fPIC -Wl,-z,noexecstack -I/usr/include/mpich2-i386
>> -I/usr/include/mpich2-i386 -L/usr/lib/mpich2/lib -lmpichf90 -lmpichf90
>> -lmpich
>> On Fri, Sep 14, 2012 at 7:54 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> On Fri, Sep 14, 2012 at 6:41 PM, John Chludzinski <
>>>> MPICH2 Version: 1.4.1p1
>>>> MPICH2 Release date: Thu Sep 1 13:53:02 CDT 2011
>>>> MPICH2 Device: ch3:nemesis
>>>> MPICH2 configure: --build=i386-redhat-linux-gnu
>>>> --host=i386-redhat-linux-gnu --program-prefix=
>>>> --disable-dependency-tracking --prefix=/usr --exec-prefix=/usr
>>>> --bindir=/usr/bin --sbindir=/usr/sbin --sysconfdir=/etc
>>>> --datadir=/usr/share --includedir=/usr/include --libdir=/usr/lib
>>>> --libexecdir=/usr/libexec --localstatedir=/var --sharedstatedir=/var/lib
>>>> --mandir=/usr/share/man --infodir=/usr/share/info --enable-sharedlibs=gcc
>>>> --enable-shared --enable-lib-depend --disable-rpath
>>> Because of this option, you will need
>>> LD_LIBRARY_PATH=/usr/lib/mpich2/lib to run executables.
>>>> --enable-fc --with-device=ch3:nemesis --with-pm=hydra:gforker
>>>> --sysconfdir=/etc/mpich2-i386 --includedir=/usr/include/mpich2-i386
>>>> --bindir=/usr/lib/mpich2/bin --libdir=/usr/lib/mpich2/lib
>>> According to the output you showed above, this option was either missed
>>> or the distribution packaged it differently on install. What system is this
>>> on? What is the output of
>>> $ mpif90 -show
>>>> --datadir=/usr/share/mpich2 --mandir=/usr/share/man/mpich2
>>>> --docdir=/usr/share/mpich2/doc --htmldir=/usr/share/mpich2/doc
>>>> --with-hwloc-prefix=system --with-java=/etc/alternatives/java_sdk
>>>> FC=gfortran F77=gfortran CFLAGS=-m32 -O2 -fPIC CXXFLAGS=-m32 -O2 -fPIC
>>>> FCFLAGS=-m32 -O2 -fPIC FFLAGS=-m32 -O2 -fPIC LDFLAGS=-Wl,-z,noexecstack
>>>> MPICH2LIB_CFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
>>>> -fstack-protector --param=ssp-buffer-size=4 -m32 -march=i686 -mtune=atom
>>>> -fasynchronous-unwind-tables MPICH2LIB_CXXFLAGS=-O2 -g -pipe -Wall
>>>> -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
>>>> -fasynchronous-unwind-tables MPICH2LIB_FCFLAGS=-O2 -g -pipe -Wall
>>>> -fasynchronous-unwind-tables MPICH2LIB_FFLAGS=-O2 -g -pipe -Wall
>>>> MPICH2 CC: gcc -m32 -O2 -fPIC -O2 -g -pipe -Wall
>>>> -fasynchronous-unwind-tables -O2
>>>> MPICH2 CXX: c++ -m32 -O2 -fPIC -O2 -g -pipe -Wall
>>>> MPICH2 F77: gfortran -m32 -O2 -fPIC -O2 -g -pipe -Wall
>>>> MPICH2 FC: gfortran -m32 -O2 -fPIC -O2 -g -pipe -Wall
>>>> On Fri, Sep 14, 2012 at 7:31 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>> On Fri, Sep 14, 2012 at 6:23 PM, John Chludzinski <
>>>>>> Why is this installation of MPICH2 ("compiler wrapper") trying to
>>>>>> statically link against "mpichf90" and "mpich" ? Versus dynamically link
>>>>>> against the shared object files in the lib directory.
>>>>> It's not trying to "statically link", it's just trying to link. The
>>>>> correct path is not being specified, but we'd have to see output of
>>>>> mpich2version to say for sure. It's a waste of time to speculate.
>>>>>> How do I get the compiler wrapper to recognize this ?
>>>>>> I assume I need to define: LD_LIBRARY_PATH=/usr/lib/mpich2/lib/ ?
>>>>> This problem comes sooner.
>>>>> _______________________________________________
>>>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>>>> To manage subscription options or unsubscribe:
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120914/b5d67728/attachment-0001.html>
