[mpich-discuss] Newbie getting started question?
Jed Brown
jedbrown at mcs.anl.gov
Fri Sep 14 19:08:29 CDT 2012
This package is missing the symlinks libmpich.so -> libmpich.so.3.3. Is
there a separate mpich2-devel package?
On Fri, Sep 14, 2012 at 6:57 PM, John Chludzinski <
john.chludzinski at gmail.com> wrote:
> $ ls -l /usr/lib/mpich2/lib
> total 6412
> -rw-r--r--. 1 root root 25459 Jan 2 2012 clog2print.jar
> -rw-r--r--. 1 root root 127339 Jan 2 2012 clog2TOdrawable.jar
> -rw-r--r--. 1 root root 183747 Jan 2 2012 clog2TOslog2.jar
> -rw-r--r--. 1 root root 17400 Jan 2 2012 clogprint.jar
> -rw-r--r--. 1 root root 108290 Jan 2 2012 clogTOdrawable.jar
> -rw-r--r--. 1 root root 164701 Jan 2 2012 clogTOslog2.jar
> -rw-r--r--. 1 root root 2449314 Jan 2 2012 jumpshot.jar
> -rw-r--r--. 1 root root 7140 Jan 2 2012 jumpshot_launcher.jar
> lrwxrwxrwx. 1 root root 16 Sep 14 16:20 libfmpich.so.3 ->
> libfmpich.so.3.3
> -rwxr-xr-x. 1 root root 121604 Jan 2 2012 libfmpich.so.3.3
> lrwxrwxrwx. 1 root root 18 Sep 14 16:20 libmpichcxx.so.3 ->
> libmpichcxx.so.3.3
> -rwxr-xr-x. 1 root root 116756 Jan 2 2012 libmpichcxx.so.3.3
> lrwxrwxrwx. 1 root root 18 Sep 14 16:20 libmpichf90.so.3 ->
> libmpichf90.so.3.3
> -rwxr-xr-x. 1 root root 5644 Jan 2 2012 libmpichf90.so.3.3
> lrwxrwxrwx. 1 root root 15 Sep 14 16:20 libmpich.so.3 ->
> libmpich.so.3.3
> -rwxr-xr-x. 1 root root 1861652 Jan 2 2012 libmpich.so.3.3
> lrwxrwxrwx. 1 root root 15 Sep 14 16:20 libmpl.so.1 -> libmpl.so.1.1.0
> -rwxr-xr-x. 1 root root 15612 Jan 2 2012 libmpl.so.1.1.0
> lrwxrwxrwx. 1 root root 15 Sep 14 16:20 libopa.so.1 -> libopa.so.1.0.0
> -rwxr-xr-x. 1 root root 3940 Jan 2 2012 libopa.so.1.0.0
> -rw-r--r--. 1 root root 265485 Jan 2 2012 logconvertor.jar
> -rw-r--r--. 1 root root 10760 Jan 2 2012 mpe_prof.o
> -rw-r--r--. 1 root root 173622 Jan 2 2012 slog2filter.jar
> -rw-r--r--. 1 root root 136084 Jan 2 2012 slog2navigator.jar
> -rw-r--r--. 1 root root 136091 Jan 2 2012 slog2printrecur.jar
> -rw-r--r--. 1 root root 136086 Jan 2 2012 slog2printserial.jar
> -rw-r--r--. 1 root root 261610 Jan 2 2012 slog2update205to206.jar
> -rw-r--r--. 1 root root 67742 Jan 2 2012 traceprint.jar
> -rw-r--r--. 1 root root 124160 Jan 2 2012 traceTOslog2.jar
> $ mpif90 -show
> gfortran -m32 -O2 -fPIC -Wl,-z,noexecstack -I/usr/include/mpich2-i386
> -I/usr/include/mpich2-i386 -L/usr/lib/mpich2/lib -lmpichf90 -lmpichf90
> -lmpich
> On Fri, Sep 14, 2012 at 7:54 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Fri, Sep 14, 2012 at 6:41 PM, John Chludzinski <
>>> MPICH2 Version: 1.4.1p1
>>> MPICH2 Release date: Thu Sep 1 13:53:02 CDT 2011
>>> MPICH2 Device: ch3:nemesis
>>> MPICH2 configure: --build=i386-redhat-linux-gnu
>>> --host=i386-redhat-linux-gnu --program-prefix=
>>> --disable-dependency-tracking --prefix=/usr --exec-prefix=/usr
>>> --bindir=/usr/bin --sbindir=/usr/sbin --sysconfdir=/etc
>>> --datadir=/usr/share --includedir=/usr/include --libdir=/usr/lib
>>> --libexecdir=/usr/libexec --localstatedir=/var --sharedstatedir=/var/lib
>>> --mandir=/usr/share/man --infodir=/usr/share/info --enable-sharedlibs=gcc
>>> --enable-shared --enable-lib-depend --disable-rpath
>> Because of this option, you will need LD_LIBRARY_PATH=/usr/lib/mpich2/lib
>> to run executables.
>>> --enable-fc --with-device=ch3:nemesis --with-pm=hydra:gforker
>>> --sysconfdir=/etc/mpich2-i386 --includedir=/usr/include/mpich2-i386
>>> --bindir=/usr/lib/mpich2/bin --libdir=/usr/lib/mpich2/lib
>> According to the output you showed above, this option was either missed
>> or the distribution packaged it differently on install. What system is this
>> on? What is the output of
>> $ mpif90 -show
>>> --datadir=/usr/share/mpich2 --mandir=/usr/share/man/mpich2
>>> --docdir=/usr/share/mpich2/doc --htmldir=/usr/share/mpich2/doc
>>> --with-hwloc-prefix=system --with-java=/etc/alternatives/java_sdk
>>> FC=gfortran F77=gfortran CFLAGS=-m32 -O2 -fPIC CXXFLAGS=-m32 -O2 -fPIC
>>> FCFLAGS=-m32 -O2 -fPIC FFLAGS=-m32 -O2 -fPIC LDFLAGS=-Wl,-z,noexecstack
>>> MPICH2LIB_CFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
>>> -fstack-protector --param=ssp-buffer-size=4 -m32 -march=i686 -mtune=atom
>>> -fasynchronous-unwind-tables MPICH2LIB_CXXFLAGS=-O2 -g -pipe -Wall
>>> -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
>>> -fasynchronous-unwind-tables MPICH2LIB_FCFLAGS=-O2 -g -pipe -Wall
>>> -fasynchronous-unwind-tables MPICH2LIB_FFLAGS=-O2 -g -pipe -Wall
>>> MPICH2 CC: gcc -m32 -O2 -fPIC -O2 -g -pipe -Wall
>>> -fasynchronous-unwind-tables -O2
>>> MPICH2 CXX: c++ -m32 -O2 -fPIC -O2 -g -pipe -Wall
>>> MPICH2 F77: gfortran -m32 -O2 -fPIC -O2 -g -pipe -Wall
>>> MPICH2 FC: gfortran -m32 -O2 -fPIC -O2 -g -pipe -Wall
>>> On Fri, Sep 14, 2012 at 7:31 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>> On Fri, Sep 14, 2012 at 6:23 PM, John Chludzinski <
>>>>> Why is this installation of MPICH2 ("compiler wrapper") trying to
>>>>> statically link against "mpichf90" and "mpich" ? Versus dynamically link
>>>>> against the shared object files in the lib directory.
>>>> It's not trying to "statically link", it's just trying to link. The
>>>> correct path is not being specified, but we'd have to see output of
>>>> mpich2version to say for sure. It's a waste of time to speculate.
>>>>> How do I get the compiler wrapper to recognize this ?
>>>>> I assume I need to define: LD_LIBRARY_PATH=/usr/lib/mpich2/lib/ ?
>>>> This problem comes sooner.
>>>> _______________________________________________
>>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>>> To manage subscription options or unsubscribe:
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120914/9023b3eb/attachment.html>
