[mpich-discuss] FW: MPICH2 MPI_Comm_Dub
    Matthew G. Carey
    mgcarey at radsafety.com
    Fri Oct 19 12:28:40 CDT 2012
Hello Jayesh,
I've seen some improvement in communication, yet am stuck at:
Master starting          18 tasks with        1 threads each 10/19/12 13:26:33
Master sending static commons...
It doesn't seem to move past this point, any ideas?
Thanks again,
Matt
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Friday, October 19, 2012 12:31
Cc: Adam Kryskow
Subject: Re: [mpich-discuss] FW: MPICH2 MPI_Comm_Dub
# Can you run the sample MPI program (C:\Program Files\MPICH2\examples\cpi.exe) using the same mpiexec command?
# Can you run a non-MPI program using the same command?
Jayesh
----- Original Message -----
From: "Matthew G. Carey" <mgcarey at radsafety.com>
Cc: "Adam Kryskow" <apkryskow at radsafety.com>
Sent: Wednesday, October 17, 2012 3:17:11 PM
Subject: [mpich-discuss] FW: MPICH2 MPI_Comm_Dub
Hello,
I was wondering if you could help with the attached error, I’ve look around google and haven’t been able to figure out how to fix it.
In addition, there is an attached log file which mpi in verbose mode.
Any suggestions are greatly appreciated.
Matthew Carey
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain Privileged or Confidential information. If you are not the intended recipient, please advise the sender by immediate reply and delete the original message with any attachments.
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
