[mpich-discuss] FW: MPICH2 MPI_Comm_Dub
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Oct 19 11:30:33 CDT 2012
# Can you run the sample MPI program (C:\Program Files\MPICH2\examples\cpi.exe) using the same mpiexec command?
# Can you run a non-MPI program using the same command?
Jayesh
----- Original Message -----
From: "Matthew G. Carey" <mgcarey at radsafety.com>
Cc: "Adam Kryskow" <apkryskow at radsafety.com>
Sent: Wednesday, October 17, 2012 3:17:11 PM
Subject: [mpich-discuss] FW: MPICH2 MPI_Comm_Dub
Hello,
I was wondering if you could help with the attached error, I’ve look around google and haven’t been able to figure out how to fix it.
In addition, there is an attached log file which mpi in verbose mode.
Any suggestions are greatly appreciated.
Matthew Carey
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain Privileged or Confidential information. If you are not the intended recipient, please advise the sender by immediate reply and delete the original message with any attachments.
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
