[mpich-discuss] FW: MPICH2 MPI_Comm_Dub
    Matthew G. Carey
    mgcarey at radsafety.com
    Fri Oct 19 12:41:44 CDT 2012
Hello,
The attached text file should provide more information.  I have turned off my firewall and can see that the other computers have increased cpu usage.  Another computer is capable of controlling the cluster, yet when I use my computer to be a slave or host, we run into errors.
Any suggestions are greatly appreciated.
Matt
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Matthew G. Carey
Sent: Friday, October 19, 2012 13:29
Subject: Re: [mpich-discuss] FW: MPICH2 MPI_Comm_Dub
Hello Jayesh,
I've seen some improvement in communication, yet am stuck at:
Master starting          18 tasks with        1 threads each 10/19/12 13:26:33
Master sending static commons...
It doesn't seem to move past this point, any ideas?
Thanks again,
Matt
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Friday, October 19, 2012 12:31
Cc: Adam Kryskow
# Can you run the sample MPI program (C:\Program Files\MPICH2\examples\cpi.exe) using the same mpiexec command?
# Can you run a non-MPI program using the same command?
Jayesh
----- Original Message -----
From: "Matthew G. Carey" <mgcarey at radsafety.com>
Cc: "Adam Kryskow" <apkryskow at radsafety.com>
Sent: Wednesday, October 17, 2012 3:17:11 PM
Subject: [mpich-discuss] FW: MPICH2 MPI_Comm_Dub
Hello,
I was wondering if you could help with the attached error, I’ve look around google and haven’t been able to figure out how to fix it.
In addition, there is an attached log file which mpi in verbose mode.
Matthew Carey
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain Privileged or Confidential information. If you are not the intended recipient, please advise the sender by immediate reply and delete the original message with any attachments.
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
An embedded and charset-unspecified text was scrubbed...
Name: New Text Document.txt
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20121019/aaa0b52a/attachment.txt>
