[mpich-discuss] MPICH2 configure
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Oct 19 11:28:08 CDT 2012
 We recommend that you use the x86_64 installer to install MPICH2 on your system (Win7, x64).
 The issue that you see during configure (wmpiconfig not recognizing the installation) is a known bug in wmpiconfig.exe. We just don't have the resources right now to fix this bug. However your MPICH2 installation should work correctly. Try running the sample mpi program, C:\Program Files\MPICH2\examples\cpi.exe, to see if MPICH2 works for you.
(PS: Follow instructions in Section 9.4, not 9.1, of the MPICH2 installer's guide to install MPICH2 on Win7)
Jayesh
----- Original Message -----
Sent: Tuesday, October 16, 2012 6:22:33 AM
Subject: [mpich-discuss] MPICH2 configure
hello:
I'm now using the MPICH2 on my computer, and I have several questions about it, my computer is windows7 x64 , and I'm using intel fortran + vs2010 , the problems are as follows:
1, since my computer is 64-bit, so I try to install the x86-64 one downloaded from your website, but I failed to configure it on my computer, my smpd service is open, and I have registered ,but by clicking the scan hosts in the wmpiconfig the version section won't become green
2, since the 64-bit MPI is configure failed, I tried to install the 32-bit software, and this time I succeed. and I also can compi l e it in IVF, then set it running, but when I add IMSL to my codes, though the compile is succeed , but when I click the execute in the WMPIEXEC, it does not work, there is no reaction, but I must use the IMSL, so I hope you can help me.
very thanks
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
