[mpich-discuss] MPICH2 configure
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Oct 22 12:35:28 CDT 2012
 Can you explain in detail the current issue that you have with MPICH2?
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Saturday, October 20, 2012 7:53:03 AM
Subject: Re: [mpich-discuss] MPICH2 configure
thanks for your answer, my MPICH2 is working now, I have already tested the sample mpi program, it's working. And it also working well on my codes, but when imsl is added to my codes, it still not working, it has no reaction when the execute button is clicked.
2012/10/20 Jayesh Krishna < jayesh at mcs.anl.gov >
We recommend that you use the x86_64 installer to install MPICH2 on your system (Win7, x64).
The issue that you see during configure (wmpiconfig not recognizing the installation) is a known bug in wmpiconfig.exe. We just don't have the resources right now to fix this bug. However your MPICH2 installation should work correctly. Try running the sample mpi program, C:\Program Files\MPICH2\examples\cpi.exe, to see if MPICH2 works for you.
(PS: Follow instructions in Section 9.4, not 9.1, of the MPICH2 installer's guide to install MPICH2 on Win7)
Jayesh
Sent: Tuesday, October 16, 2012 6:22:33 AM
Subject: [mpich-discuss] MPICH2 configure
hello:
I'm now using the MPICH2 on my computer, and I have several questions about it, my computer is windows7 x64 , and I'm using intel fortran + vs2010 , the problems are as follows:
1, since my computer is 64-bit, so I try to install the x86-64 one downloaded from your website, but I failed to configure it on my computer, my smpd service is open, and I have registered ,but by clicking the scan hosts in the wmpiconfig the version section won't become green
2, since the 64-bit MPI is configure failed, I tried to install the 32-bit software, and this time I succeed. and I also can compi l e it in IVF, then set it running, but when I add IMSL to my codes, though the compile is succeed , but when I click the execute in the WMPIEXEC, it does not work, there is no reaction, but I must use the IMSL, so I hope you can help me.
very thanks
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
