[mpich-discuss] make[7]: *** [all-postamble] Error 1
Haoyan Liu
haoyanliu1988 at gmail.com
Mon Nov 5 20:35:57 CST 2012
I have tried mvapich2 1.9a and 1.8.1, the problem sitll persists. In the
directory of .lib, there are libhwloc_embedded.a and
libhwloc_embedded.la<http://libhwloc_embedded.la/> and
no *o.
2012/11/6 Haoyan Liu <haoyanliu1988 at gmail.com>
> The options is --prefix. I use this version because the PGI Site use the
> same version.
> So which version you advise me, 1.9a or 1.8.1?
> 2012/11/6 Jonathan Perkins <perkinjo at cse.ohio-state.edu>
>> Hi, I'm cc'ing this to the mvapich-discuss list since its related to
>> MVAPICH. What options are you using for the build at configure time?
>> This could be something that was resolved for the 1.8 release. Can you
>> try downloading the latest stable release and see if this problem still
>> persists?
>> https://mvapich.cse.ohio-state.edu/download/mvapich2/
>> On Tue, Nov 06, 2012 at 09:05:20AM +0800, Haoyan Liu wrote:
>> > Hi,
>> > I am building mvapich2-1.8a1p1 with pgi-10.6-0 64-bit on x86-64 Linux. I
>> > get Errors when "make" and the information is as follows:
>> > make all-postamble
>> > make[7]: Entering directory
>> `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid/ch3/channels/mrail/src'
>> > test "xyes" = "xno" ||\
>> > { ar crv
>> > /home/hyliu/software/mvapich2/mvapich2-1.8a1p1/lib/libmpich.a
>> hwloc/src/*.o
>> > && ar crv
>> /home/hyliu/software/mvapich2/mvapich2-1.8a1p1/lib/libmpich.lahwloc/src/.libs/*.o;
>> > a - hwloc/src/bind.o
>> > a - hwloc/src/cpuset.o
>> > a - hwloc/src/distances.o
>> > a - hwloc/src/misc.o
>> > a - hwloc/src/topology-libpci.o
>> > a - hwloc/src/topology-linux.o
>> > a - hwloc/src/topology.o
>> > a - hwloc/src/topology-synthetic.o
>> > a - hwloc/src/topology-x86.o
>> > a - hwloc/src/topology-xml.o
>> > a - hwloc/src/traversal.o
>> > ar: hwloc/src/.libs/*.o: No such file or directory
>> > make[7]: Leaving directory
>> > make[6]: *** [all-redirect] Error 2
>> > make[6]: Leaving directory
>> > make[5]: *** [all-redirect] Error 2
>> > make[5]: Leaving directory
>> `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid/ch3/channels/mrail'
>> > make[4]: *** [all-redirect] Error 1
>> > make[4]: Leaving directory
>> > `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid/ch3/channels'
>> > make[3]: *** [all-redirect] Error 2
>> > make[3]: Leaving directory
>> > `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid/ch3'
>> > make[2]: *** [all-redirect] Error 1
>> > make[2]: Leaving directory
>> > `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid'
>> > make[1]: *** [all-redirect] Error 2
>> > make[1]: Leaving directory
>> > `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src'
>> > make: *** [all-redirect] Error 2
>> > My environment variable:
>> > export CC=pgcc
>> > export CXX=pgCC
>> > export FC=pgf90
>> > export F77=pgf77
>> > export F90=pgf90
>> > export LD=pgf90
>> > export CPP="pgCC -E"
>> > export CXXFLAGS"=-mcmodel=medium"
>> > export FCFLAGS="-mcmodel=medium"
>> > export CFLAGS="-mcmodel=medium"
>> > export FFLAGS="-mcmodel=medium"
>> > export LDFLAGS="-mcmodel=medium"
>> > How can I solve that?
>> > Thanks a lot.
>> > _______________________________________________
>> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> > To manage subscription options or unsubscribe:
>> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> Jonathan Perkins
>> http://www.cse.ohio-state.edu/~perkinjo
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20121106/94f0290a/attachment.html>
