[mpich-discuss] make[7]: *** [all-postamble] Error 1
Jonathan Perkins perkinjo at cse.ohio-state.edu
Mon Nov 5 20:14:35 CST 2012
You can try 1.8.1.
On Tue, Nov 06, 2012 at 09:58:11AM +0800, Haoyan Liu wrote:
> The options is --prefix. I use this version because the PGI Site use the
> same version.
> So which version you advise me, 1.9a or 1.8.1?
> 2012/11/6 Jonathan Perkins <perkinjo at cse.ohio-state.edu>
> > Hi, I'm cc'ing this to the mvapich-discuss list since its related to
> > MVAPICH.  What options are you using for the build at configure time?
> > This could be something that was resolved for the 1.8 release.  Can you
> > try downloading the latest stable release and see if this problem still
> > persists?
> > https://mvapich.cse.ohio-state.edu/download/mvapich2/
> > On Tue, Nov 06, 2012 at 09:05:20AM +0800, Haoyan Liu wrote:
> > > Hi,
> > > I am building mvapich2-1.8a1p1 with pgi-10.6-0 64-bit on x86-64 Linux. I
> > > get Errors when "make" and the information is as follows:
> > > make all-postamble
> > > make[7]: Entering directory
> > `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid/ch3/channels/mrail/src'
> > > test "xyes" = "xno" ||\
> > >             { ar crv
> > > /home/hyliu/software/mvapich2/mvapich2-1.8a1p1/lib/libmpich.a
> > hwloc/src/*.o
> > > && ar crv
> > /home/hyliu/software/mvapich2/mvapich2-1.8a1p1/lib/libmpich.lahwloc/src/.libs/*.o;
> > > a - hwloc/src/bind.o
> > > a - hwloc/src/cpuset.o
> > > a - hwloc/src/distances.o
> > > a - hwloc/src/misc.o
> > > a - hwloc/src/topology-libpci.o
> > > a - hwloc/src/topology-linux.o
> > > a - hwloc/src/topology.o
> > > a - hwloc/src/topology-synthetic.o
> > > a - hwloc/src/topology-x86.o
> > > a - hwloc/src/topology-xml.o
> > > a - hwloc/src/traversal.o
> > > ar: hwloc/src/.libs/*.o: No such file or directory
> > > make[7]: Leaving directory
> > > make[6]: *** [all-redirect] Error 2
> > > make[6]: Leaving directory
> > > make[5]: *** [all-redirect] Error 2
> > > make[5]: Leaving directory
> > `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid/ch3/channels/mrail'
> > > make[4]: *** [all-redirect] Error 1
> > > make[4]: Leaving directory
> > > `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid/ch3/channels'
> > > make[3]: *** [all-redirect] Error 2
> > > make[3]: Leaving directory
> > > `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid/ch3'
> > > make[2]: *** [all-redirect] Error 1
> > > make[2]: Leaving directory
> > > `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid'
> > > make[1]: *** [all-redirect] Error 2
> > > make[1]: Leaving directory
> > > `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src'
> > > make: *** [all-redirect] Error 2
> > > My environment variable:
> > > export CC=pgcc
> > > export CXX=pgCC
> > > export FC=pgf90
> > > export F77=pgf77
> > > export F90=pgf90
> > > export LD=pgf90
> > > export CPP="pgCC -E"
> > > export CXXFLAGS"=-mcmodel=medium"
> > > export FCFLAGS="-mcmodel=medium"
> > > export CFLAGS="-mcmodel=medium"
> > > export FFLAGS="-mcmodel=medium"
> > > export LDFLAGS="-mcmodel=medium"
> > > How can I solve that?
> > > Thanks a lot.
> > > _______________________________________________
> > > mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> > > To manage subscription options or unsubscribe:
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> > Jonathan Perkins
> > http://www.cse.ohio-state.edu/~perkinjo
Jonathan Perkins
