[mpich-discuss] Credentials rejected
Jayesh Krishna
jayesh at mcs.anl.gov
Fri Mar 9 10:52:26 CST 2012
"Recompiled and, magically it worked..." - "Recompiled" must be the key here.
I would recommend disabling firewall altogether or follow instructions in Section 9.5 of the "Windows developer's guide" (http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs).
Jayesh
----- Original Message -----
From: "Alejandro Allievi" <alejandro.allievi at gmail.com>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Friday, March 9, 2012 10:47:26 AM
Subject: Re: [mpich-discuss] Credentials rejected
Hi Jayesh,
I uninstalled MPICH2, cleaned registry and re-installed. Run cpi.exe test and worked fine, same with mpiexec -n 2 hostname. However, for my Helloworld_MPI example, it was still giving me the error
Error posting writev, An established connection was aborted by the software in your host machine.(10053)
unable to post a write for the next command,
sock error: Error = 10053
unable to post a write of the close command to tear down the job tree as part of the abort process.
unable to post an abort command.
So, I went to ControlPanel->Programs and "repaired" MPICH2. Then, and only then, a window pops up and asked that my program needed to go through the Firewall (allowed everything). Recompiled and, magically, it now works.
I think I have an issue with Windows Firewall, but cannot solve it because when I do "ControlPanel->WindowsFirewall->Allow programs to communicate through firewall" , there is a message saying "The page cannot be loaded" (see attached). I know this is not the forum for this question, but have you/anybody ever seen this?? I could not find anything on the web regarding this issue.
Thanks a million again!!
Alex
On Fri, Mar 9, 2012 at 12:23 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
The wmpiconfig seems to have a bug that prevents it from correctly querying the status of SMPD (process manager) on different hosts. Ignore the message for now.
Can you run an MPI program using mpiexec from the command line (on 1 host, on multiple hosts)?
Jayesh
From: "Alejandro Allievi" < alejandro.allievi at gmail.com >
To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
Sent: Thursday, March 8, 2012 4:05:42 PM
I have admin. rights. I have tried installing as "just me" and "everyone" with identical ill fate. When I run wmpiconfig I see "ace.eggnog: MPICH2 not installed or unable to query the host", where ace.eggnog is the name of my computer. The wierd thing is that it was running just fine a couple of days ago.
Thank you for your help.
Alex
On Thu, Mar 8, 2012 at 6:11 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
Do you have an admin account on the machine? Did you install MPICH2 for "Everyone" (the default option during install process)?
Jayesh
Sent: Thursday, March 8, 2012 2:42:12 PM
Hi Jayesh,
Thanks for your help. I did register but I get this
D:\Canada_Laptop\Teaching\ParallelComputing\Books\IntroToParallelProgramming_Pacheco\MyExamples\Hello>mpiexec -n 4 Helloworld_MPI
launch failed: CreateProcess(Helloworld_MPI) on ' ACE-eggnog.wds.mun.ca ' failed, error 5 - Access is denied.
Alex
On Thu, Mar 8, 2012 at 5:00 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
You should register a valid Windows username/password with mpiexec.
Jayesh
Sent: Thursday, March 8, 2012 2:08:20 PM
Subject: [mpich-discuss] Credentials rejected
I'm trying to run an MPI simple code but get this error
Credentials for MEMORIAL\aallievi rejected connecting to ACE-eggnog.wds.mun.ca
Aborting: Unable to connect to ACE-eggnog.wds.mun.ca
Which password do I need to enter here as my credentials?? The one I created when I installed MPICH2 or my own Windows password??
Thank you.
Alex
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
Dr Alejandro Allievi, PhD, PEng
"Tenez, mon ami, si vous y pensez bien, vous trouverez qu'en tout, notre véritable sentiment n'est pas celui dans lequel nous n'avons jamais vacillé; mais celui auquel nous sommes le plus habituellement revenus". Denis Diderot.
This email and its attachments are for the sole use of the addressee and may contain information which is confidential and/or legally privileged. This email and its attachments are subject to copyright and should not be partly or wholly reproduced without the consent of the copyright owner. If you receive this email in error, please immediately delete it from your system and notify the sender by return email.
