[mpich-discuss] Credentials rejected
Alejandro Allievi alejandro.allievi at gmail.com
Fri Mar 9 14:02:24 CST 2012
Hi Jayesh,
I agree with you, disabling the Firewall should do it. In my system, it
doesn't. The only solution is allowing mpiexec through the firewall.
Thank you for the link to the 1.4 docs, I was reading version 1.3.
Have a great week end.
Alex
On Fri, Mar 9, 2012 at 1:22 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
>  "Recompiled and, magically it worked..." - "Recompiled" must be the key
> here.
>  I would recommend disabling firewall altogether or follow instructions in
> Section 9.5 of the "Windows developer's guide" (
> http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs
> Regards,
> Jayesh
> From: "Alejandro Allievi" <alejandro.allievi at gmail.com>
> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Friday, March 9, 2012 10:47:26 AM
> Subject: Re: [mpich-discuss] Credentials rejected
> Hi Jayesh,
> I uninstalled MPICH2, cleaned registry and re-installed. Run cpi.exe test
> and worked fine, same with mpiexec -n 2 hostname. However, for my
> Helloworld_MPI example, it was still giving me the error
> Error posting writev, An established connection was aborted by the
> software in your host machine.(10053)
> unable to post a write for the next command,
> sock error: Error = 10053
> unable to post a write of the close command to tear down the job tree as
> part of the abort process.
> unable to post an abort command.
> So, I went to ControlPanel->Programs and "repaired" MPICH2. Then, and only
> then, a window pops up and asked that my program needed to go through the
> Firewall (allowed everything). Recompiled and, magically, it now works.
> I think I have an issue with Windows Firewall, but cannot solve it because
> when I do "ControlPanel->WindowsFirewall->Allow programs to communicate
> through firewall" , there is a message saying "The page cannot be loaded"
> (see attached). I know this is not the forum for this question, but have
> you/anybody ever seen this?? I could not find anything on the web regarding
> this issue.
> Thanks a million again!!
> Alex
> On Fri, Mar 9, 2012 at 12:23 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> The wmpiconfig seems to have a bug that prevents it from correctly
> querying the status of SMPD (process manager) on different hosts. Ignore
> the message for now.
> Can you run an MPI program using mpiexec from the command line (on 1 host,
> on multiple hosts)?
> Regards,
> Jayesh
> From: "Alejandro Allievi" < alejandro.allievi at gmail.com >
> To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
> Sent: Thursday, March 8, 2012 4:05:42 PM
> Hi,
> I have admin. rights. I have tried installing as "just me" and "everyone"
> with identical ill fate. When I run wmpiconfig I see "ace.eggnog: MPICH2
> not installed or unable to query the host", where ace.eggnog is the name of
> my computer. The wierd thing is that it was running just fine a couple of
> days ago.
> Thank you for your help.
> Alex
> On Thu, Mar 8, 2012 at 6:11 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> Do you have an admin account on the machine? Did you install MPICH2 for
> "Everyone" (the default option during install process)?
> Regards,
> Jayesh
> Sent: Thursday, March 8, 2012 2:42:12 PM
> Hi Jayesh,
> Thanks for your help. I did register but I get this
> D:\Canada_Laptop\Teaching\ParallelComputing\Books\IntroToParallelProgramming_Pacheco\MyExamples\Hello>mpiexec
> -n 4 Helloworld_MPI
> launch failed: CreateProcess(Helloworld_MPI) on ' ACE-eggnog.wds.mun.ca '
> failed, error 5 - Access is denied.
> Alex
> On Thu, Mar 8, 2012 at 5:00 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> You should register a valid Windows username/password with mpiexec.
> Regards,
> Jayesh
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, March 8, 2012 2:08:20 PM
> Subject: [mpich-discuss] Credentials rejected
> Hi,
> I'm trying to run an MPI simple code but get this error
> -n 4 Helloworld_MPI
> Credentials for MEMORIAL\aallievi rejected connecting to
> Aborting: Unable to connect to ACE-eggnog.wds.mun.ca
> Which password do I need to enter here as my credentials?? The one I
> created when I installed MPICH2 or my own Windows password??
> Thank you.
> Alex
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
> Dr Alejandro Allievi, PhD, PEng
> "Tenez, mon ami, si vous y pensez bien, vous trouverez qu'en tout, notre
> véritable sentiment n'est pas celui dans lequel nous n'avons jamais
> vacillé; mais celui auquel nous sommes le plus habituellement revenus".
> Denis Diderot.
> This email and its attachments are for the sole use of the addressee and
> may contain information which is confidential and/or legally privileged.
> This email and its attachments are subject to copyright and should not be
> partly or wholly reproduced without the consent of the copyright owner. If
> you receive this email in error, please immediately delete it from your
> system and notify the sender by return email.
> Denis Diderot.
> Denis Diderot.
*Dr Alejandro Allievi, PhD, PEng*
*"Tenez, mon ami, si vous y pensez bien, vous trouverez qu'en tout, notre
Denis Diderot.*
*This email and its attachments are for the sole use of the addressee and
system and notify the sender by return email.*
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120309/63afbdd4/attachment.htm>
