[mpich-discuss] Credentials rejected
    Alejandro Allievi
    alejandro.allievi at gmail.com
    Fri Mar  9 10:47:26 CST 2012
Hi Jayesh,
I uninstalled MPICH2, cleaned registry and re-installed. Run cpi.exe test
and worked fine, same with mpiexec -n 2 hostname. However, for my
Helloworld_MPI example, it was still giving me the error
*Error posting writev, An established connection was aborted by the
software in your host machine.(10053)
unable to post a write for the next command,
sock error: Error = 10053*
*unable to post a write of the close command to tear down the job tree as
part of the abort process.
unable to post an abort command.*
So, I went to ControlPanel->Programs and "repaired" MPICH2. Then, and only
then, a window pops up and asked that my program needed to go through the
Firewall (allowed everything). Recompiled and, magically, it now works.
I think I have an issue with Windows Firewall, but cannot solve it because
when I do "ControlPanel->WindowsFirewall->Allow programs to communicate
through firewall" , there is a message saying "The page cannot be loaded"
(see attached). I know this is not the forum for this question, but have
you/anybody ever seen this?? I could not find anything on the web regarding
this issue.
Thanks a million again!!
Alex
On Fri, Mar 9, 2012 at 12:23 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
>  The wmpiconfig seems to have a bug that prevents it from correctly
> querying the status of SMPD (process manager) on different hosts. Ignore
> the message for now.
>  Can you run an MPI program using mpiexec from the command line (on 1
> host, on multiple hosts)?
> Regards,
> Jayesh
> From: "Alejandro Allievi" <alejandro.allievi at gmail.com>
> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Thursday, March 8, 2012 4:05:42 PM
> Subject: Re: [mpich-discuss] Credentials rejected
> Hi,
> I have admin. rights. I have tried installing as "just me" and "everyone"
> with identical ill fate. When I run wmpiconfig I see "ace.eggnog: MPICH2
> not installed or unable to query the host", where ace.eggnog is the name of
> my computer. The wierd thing is that it was running just fine a couple of
> days ago.
> Thank you for your help.
> Alex
> On Thu, Mar 8, 2012 at 6:11 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> Do you have an admin account on the machine? Did you install MPICH2 for
> "Everyone" (the default option during install process)?
> Regards,
> Jayesh
> From: "Alejandro Allievi" < alejandro.allievi at gmail.com >
> To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
> Sent: Thursday, March 8, 2012 2:42:12 PM
> Hi Jayesh,
> Thanks for your help. I did register but I get this
> D:\Canada_Laptop\Teaching\ParallelComputing\Books\IntroToParallelProgramming_Pacheco\MyExamples\Hello>mpiexec
> -n 4 Helloworld_MPI
> launch failed: CreateProcess(Helloworld_MPI) on ' ACE-eggnog.wds.mun.ca '
> failed, error 5 - Access is denied.
> Alex
> On Thu, Mar 8, 2012 at 5:00 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> You should register a valid Windows username/password with mpiexec.
> Regards,
> Jayesh
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, March 8, 2012 2:08:20 PM
> Subject: [mpich-discuss] Credentials rejected
> Hi,
> I'm trying to run an MPI simple code but get this error
> -n 4 Helloworld_MPI
> Credentials for MEMORIAL\aallievi rejected connecting to
> Aborting: Unable to connect to ACE-eggnog.wds.mun.ca
> Which password do I need to enter here as my credentials?? The one I
> created when I installed MPICH2 or my own Windows password??
> Thank you.
> Alex
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
> Dr Alejandro Allievi, PhD, PEng
> "Tenez, mon ami, si vous y pensez bien, vous trouverez qu'en tout, notre
> véritable sentiment n'est pas celui dans lequel nous n'avons jamais
> vacillé; mais celui auquel nous sommes le plus habituellement revenus".
> Denis Diderot.
> This email and its attachments are for the sole use of the addressee and
> may contain information which is confidential and/or legally privileged.
> This email and its attachments are subject to copyright and should not be
> partly or wholly reproduced without the consent of the copyright owner. If
> you receive this email in error, please immediately delete it from your
> system and notify the sender by return email.
> Denis Diderot.
*Dr Alejandro Allievi, PhD, PEng*
*"Tenez, mon ami, si vous y pensez bien, vous trouverez qu'en tout, notre
Denis Diderot.*
*This email and its attachments are for the sole use of the addressee and
system and notify the sender by return email.*
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120309/28248f0c/attachment-0001.htm>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120309/28248f0c/attachment-0001.pdf>
