[mpich-discuss] MPICH2 test not running properly
    Alejandro Allievi
    alejandro.allievi at gmail.com
    Fri Mar  2 11:42:43 CST 2012
Robert. Please see below lines starting with capitals. Thanks. Alex
On Thu, Mar 1, 2012 at 7:05 PM, McBroom, Robert C <McBroomRC at oro.doe.gov>wrote:
>  Alex****
> **A)     **For you, just an example of an code to be installed.****
> **B)      **When you installed did you right click on the command window
> icon and click on “run as administrator”?  On the configuration settings
> there is a checkbox for hosts, checking it and the next line will let you
> enter your computer name.  There is another set of checkboxes  for
> localonly where you enter “yes”.
YES I DID uses "Run as Administrator". However, when I use the command
"msiexec /I mpich2-1.4.1p1-win-x86-64.msi" a series of windows come up.
They are shown in attached file MPICH2_Install.pdf. As you can see, at no
time there is a configuartion setting option. Also, when I run the MPICH2
examples they do fine, see attached MPICH2_Example.pdf . I do not see any
configuartion settings. Am I missing something here??
> **C)      **“Ctrl alt delete” and click on task manager,  start the
> graphic display of system usage and there is a button for display a window
> for each processor.
OK , there are 8 windows (quad core, two threads each). The INITIAL
percentage of the total CPU for 2/n, 4/n and 8/n are 5.27, 3.44 and 2.39
respectvely. After a little while they all show 12% regardless of n. Are
these results correct??
> **D)     **Typically there has to be a compiler option that points to the
> include files not just the path.  Depends on your compiler.
I USE GCC. When I run my Helloworld_MPI.c example I run into problems, see
attached Helloworld_MPI.pdf . I have run my code in Unix using mpicc and it
runs just fine. Any suggestions?? What compiler do you use to be able to
include mpi.h??
> **E)      **“User Access Control” is doing something to you.
THE MESSAGE  "The page cannot be loaded" is still there when I click on
"Allow a program or feature to go through a firewall". COULD not solve it
even by completely removing Windows Firewall. Have no way to access
"Allowed Programs and Features".
> *From:* mpich-discuss-bounces at mcs.anl.gov [mailto:
> mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Alejandro Allievi
> *Sent:* Thursday, March 01, 2012 12:59 PM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [mpich-discuss] MPICH2 test not running properly****
> Hi Robert,****
> Thank you for your reply. I'm not accessing a network, I'm only trying to
> run MPI code on my quad core machine. Have some questions regarding your
> attached file****
> A) Points (1) and (2) of your file. I did not do the creation of MCNPDATA
> and MCNP, I just followed instructions in MPICH2 installer's guide, page 20
> (Windows version). However, all example seem to run correctly.****
> B) Point (7) of your file. I attached a file with "MPICH2 configuration
> settings", something does not look right with my computer name "MPICH2 not
> installed....". Will that be related to (E) below??****
> C) Point (9) of your file, I managed to successfully run the example for
> cpi.exe. I do not understand what you mean by total CPU = 2/total number of
> bars showing in taskbar.****
> D) When I compile my own HelloWorld MPI code the compile error message is
> "Helloworld_MPI.c:20:50: fatal error: mpi.h: No such file or directory". My
> path DOES point at MPICH2/bin and MPICH2/include .****
> E) My Windows Firewall under Control Panel says "The page cannot be
> loaded" when I click on "Allow a program or feature to go through a
> firewall". I do have Administrator rights.****
> Thanks again for your help.****
> Alex****
> On Thu, Mar 1, 2012 at 1:06 PM, McBroom, Robert C <McBroomRC at oro.doe.gov>
> wrote:****
> Alex****
> There are some tricks involved.  The attached file will give you some
> clues.  The scheme works for both the 32 bit install and the 64 bit with
> the appropriate source file changes.  Note the installation as
> administrator and the use of the command line options on the installer.***
> Robert McBroom****
> *Sent:* Wednesday, February 29, 2012 5:26 PM
> *Subject:* [mpich-discuss] MPICH2 test not running properly****
> Hi. ****
> I'm new to this list and would appreciate some help with this
> beginners issue. I just installed MPICH2 and am running the recommended
> test. The output is as follows. ****
> D:\mpiexec -n 2 cpi.exe
> Error while connecting to host, No connection could be made because the
> target machine actively refused it. (10061)
> Connect on sock (host=ACE-eggnog.wds.mun.ca, port=8676) failed, exhaused
> all end points
> Unable to connect to 'ACE-eggnog.wds.mun.ca:8676',
> sock error: Error = -1
> Has anybody encountered this problem before??****
> Thank you.****
> Alex****
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss****
> *Dr Alejandro Allievi, PhD, PEng*****
> *"Tenez, mon ami, si vous y pensez bien, vous trouverez qu'en tout, notre
> véritable sentiment n'est pas celui dans lequel nous n'avons jamais
> vacillé; mais celui auquel nous sommes le plus habituellement revenus".
> Denis Diderot.*****
> *This email and its attachments are for the sole use of the addressee and
> may contain information which is confidential and/or legally privileged.
> This email and its attachments are subject to copyright and should not be
> partly or wholly reproduced without the consent of the copyright owner. If
> you receive this email in error, please immediately delete it from your
> system and notify the sender by return email.*****
Denis Diderot.*
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120302/232a5a12/attachment-0001.htm>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120302/232a5a12/attachment-0003.pdf>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120302/232a5a12/attachment-0004.pdf>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120302/232a5a12/attachment-0005.pdf>
