[mpich-discuss] mpich2 compilation with intel only
Anthony Chan
chan at mcs.anl.gov
Wed Jun 27 16:56:47 CDT 2012
Yes, the icc somehow passes the configure GNU test.
It is harmless.
----- Original Message -----
> Whoops...you're right, that was supposed to be ifort.
> Here's the actual successful configure script:
> #! bin/sh
> CDIR=/opt/intel/
> FDIR=/opt/intel/fc/10.1.008/
> sh ${CDIR}/bin/iccvars.sh ia32
> sh ${CDIR}/bin/compilervars.sh ia32
> sh ${FDIR}/bin/ifortvars.sh
> ./configure \
> --prefix=/Volumes/SecondHD/rieth/mpich2_intel \
> CC=icc \
> CFLAGS="-m32 -I${CDIR}/include" \
> CXX=icpc \
> CXXFLAGS="-m32 -I${CDIR}/include" \
> FC=ifort \
> FCFLAGS="-m32 -I${FDIR}/include" \
> F77=ifort \
> FFLAGS="-m32 -I${FDIR}/include" \
> LDFLAGS="-L${CDIR}/lib -L${FDIR}/lib" \
> 2>&1 | tee c.txt
> But my previous question still stands; even though I see the line
> "checking whether we are using the GNU C compiler... yes" in my
> configure output, have I still actually built an Intel version of
> mpich2?
> Thanks,
> Dave
> On Jun 27, 2012, at 5:30 PM, Anthony Chan wrote:
> > I find odd that you configure with cc=icc F77=ifort and FC=gfortran.
> > Is there any reason you choose FC to be gfortran instead of ifort ?
> > A.Chan
> >> Hmmm, actually now that I try it, I am not able to compile a "hello
> >> world" program with -no-gcc and #include <stdarg.h> together.
> >> If I remove -no-gcc from my configure shell script, the configure
> >> is
> >> successful, which leads me to my next question:
> >> Is this still considered a true Intel build, even if I've used gcc
> >> to
> >> build it? From here on will the Intel compilers will run my mpi
> >> calls,
> >> or will the GNU compiler set continue to be used?
> >> Thanks,
> >> Dave
> >> On Jun 26, 2012, at 4:48 PM, Dave Goodell wrote:
> >>> Looks like your intel compiler is broken somehow when compiling
> >>> under "-no-gcc". The "icc" compiler is finding the system-
> >>> installed, gcc-specific stdarg.h which is blowing up with a
> >>> "__MWERKS_" error message. My guess is that it won't complain if
> >>> you drop "-no-gcc" because this will cause icc to #define
> >>> "__GNUC__"
> >>> and similar symbols that will make the system header happier.
> >>> Are you *sure* that the "-no-gcc" option is what you want? Will it
> >>> compile simple C programs that "#include <stdarg.h>" without any
> >>> involvement with MPICH2?
> >>> -Dave
> >>> On Jun 25, 2012, at 4:50 PM MDT, David Riethmiller wrote:
> >>>> Hi -
> >>>> I'm having trouble compiling mpich2 version 1.4.1p1 on a Mac OSX
> >>>> 10.5 system, using only the Intel compilers. I specifically want
> >>>> to avoid the GNU compilers, in order to match the software
> >>>> available on a supercomputer to which I will port later.
> >>>> When running my configure script, I hit the following error:
> >>>> checking for size of Fortran type integer... configure: WARNING:
> >>>> Unable to compile the C routine for finding the size of a integer
> >>>> checking for size of Fortran type real... configure: WARNING:
> >>>> Unable to compile the C routine for finding the size of a real
> >>>> checking for size of Fortran type double precision... configure:
> >>>> WARNING: Unable to compile the C routine for finding the size of
> >>>> a
> >>>> double precision
> >>>> checking whether integer*1 is supported... yes
> >>>> checking whether integer*2 is supported... yes
> >>>> checking whether integer*4 is supported... yes
> >>>> checking whether integer*8 is supported... yes
> >>>> checking whether integer*16 is supported... no
> >>>> checking whether real*4 is supported... yes
> >>>> checking whether real*8 is supported... yes
> >>>> checking whether real*16 is supported... yes
> >>>> configure: error: Unable to configure with Fortran support
> >>>> because
> >>>> configure could not determine the size of a Fortran INTEGER.
> >>>> Consider setting CROSS_F77_SIZEOF_INTEGER to the length in bytes
> >>>> of
> >>>> a Fortran INTEGER
> >>>> I've saved my configure command as a shell script:
> >>>> #! bin/sh
> >>>> CDIR=/opt/intel/
> >>>> ./configure \
> >>>> CC=icc \
> >>>> CFLAGS="-m32 -no-gcc -I${CDIR}/include -L${DYLD_LIBRARY_PATH}" \
> >>>> LDFLAGS="-L${CDIR}/lib -L${FDIR}/lib -L${DYLD_LIBRARY_PATH}" \
> >>>> F77=ifort \
> >>>> FFLAGS="-m32 -no-gfortran -I${FDIR}/include -L$
> >>>> CXX=icpc \
> >>>> CXXFLAGS="-m32 -no-gcc -I${CDIR}/include -L${DYLD_LIBRARY_PATH}"
> >>>> 2>&1 | tee c.txt
> >>>> I'm attaching the output files. Can anyone see what I'm doing
> >>>> wrong?
> >>>> Thanks very much,
> >>>> Dave
> >>>> <c.txt><config.log><config.system>
> >>>> David A. Riethmiller
> >>>> Ph.D. Candidate, Astrophysical Institute
> >>>> Ohio University
> >>>> Clippinger Labs 338
> >>>> http://www.phy.ohiou.edu/~rieth/
> >>>> _______________________________________________
> >>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> >>>> To manage subscription options or unsubscribe:
> >>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> >> Ohio University
> >> Clippinger Labs 338
