[mpich-discuss] Questions About using g95 to install MPICH2
    Rajeev Thakur
    thakur at mcs.anl.gov
    Wed Jun 13 01:51:24 CDT 2012
Your configure step failed. Can you try configuring without the --with-pm=smpd option. That will use the default hydra process manager.
Rajeev
On Jun 13, 2012, at 1:46 AM, 謝奇哲 wrote:
> Hi,
> I'm a new user about MPICH2, and using WindosXP, Cygwin and g95.
> Then I install MPICH2-1.4 to my computers.
> Using the command
> User at 980622-05 /cygdrive/c/cygwin/mpich2-1.4
> $./configure F77=g95 FC=g95 2>&1 | tee c.txt
> $make 2>&1 | tee m.txt
> $make install 2>&1 | tee mi.txt
> $PATH=/cygdrive/cygwin/usr/local/bin:$PATH ; export PATH
> The MPICH2 installed to the default location /usr/local/
> And then I got errors message(saved in mtest.test), when I used command make testing in test file.
> But I could run the cpi in examples file.
> Can you give me some advices to solve the problem?
> Thank you for your help
> Best regards,
> Chi-Che Hsieh
> <mtest.txt><c.txt><config.log><m.txt><mi.txt>_______________________________________________
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
