[mpich-discuss] Questions About using g95 to install MPICH2
    謝奇哲
    991546107 at stu.nkmu.edu.tw
    Wed Jun 13 01:46:10 CDT 2012
I'm a new user about MPICH2, and using WindosXP, Cygwin and g95.
Then I install MPICH2-1.4 to my computers.
Using the command
User at 980622-05 /cygdrive/c/cygwin/mpich2-1.4
$./configure F77=g95 FC=g95 2>&1 | tee c.txt
$make 2>&1 | tee m.txt
$make install 2>&1 | tee mi.txt
$PATH=/cygdrive/cygwin/usr/local/bin:$PATH ; export PATH
The MPICH2 installed to the default location /usr/local/
And then I got errors message(saved in mtest.test), when I used command
make testing in test file.
But I could run the cpi in examples file.
Can you give me some advices to solve the problem?
Thank you for your help
Best regards,
Chi-Che Hsieh
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120613/9c56600f/attachment-0001.html>
(NOXMLCLOSE=YES && export NOXMLCLOSE && cd mpi && make testing)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi'
./runtests -srcdir=. -tests=testlist \
		   -mpiexec=/usr/local/bin/mpiexec \
		   -xmlfile=summary.xml
Looking in ./testlist
Processing directory attr
Looking in ./attr/testlist
Unexpected output in attrend: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in attrend: MPIR_Init_thread(388).................:
Unexpected output in attrend: MPID_Init(139)........................: channel initialization failed
Unexpected output in attrend: MPIDI_CH3_Init(38)....................:
Unexpected output in attrend: MPID_nem_init(196)....................:
Unexpected output in attrend: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in attrend: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in attrend: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in attrend: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program attrend exited without No Errors
Processing directory coll
Looking in ./coll/testlist
Unexpected output in allred: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allred: MPIR_Init_thread(388).................:
Unexpected output in allred: MPID_Init(139)........................: channel initialization failed
Unexpected output in allred: MPIDI_CH3_Init(38)....................:
Unexpected output in allred: MPID_nem_init(196)....................:
Unexpected output in allred: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in allred: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in allred: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program allred exited without No Errors
Unexpected output in allredmany: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in allredmany: MPIR_Init_thread(388).................:
Unexpected output in allredmany: MPID_Init(139)........................: channel initialization failed
Unexpected output in allredmany: MPIDI_CH3_Init(38)....................:
Unexpected output in allredmany: MPID_nem_init(196)....................:
Unexpected output in allredmany: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allredmany: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allredmany: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allredmany: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allredmany exited without No Errors
Unexpected output in allred5: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allred5: MPIR_Init_thread(388).................:
Unexpected output in allred5: MPID_Init(139)........................: channel initialization failed
Unexpected output in allred5: MPIDI_CH3_Init(38)....................:
Unexpected output in allred5: MPID_nem_init(196)....................:
Unexpected output in allred5: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allred5: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allred5: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allred5: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allred5 exited without No Errors
Unexpected output in allred5: [mpiexec at 980622-05] HYDU_sock_read (./utils/sock/sock.c:272): read error (Software caused connection abort)
Unexpected output in allred5: [mpiexec at 980622-05] control_cb (./pm/pmiserv/pmiserv_cb.c:214): unable to read command from proxy
Unexpected output in allred5: [mpiexec at 980622-05] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in allred5: [mpiexec at 980622-05] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:179): error waiting for event
Unexpected output in allred5: [mpiexec at 980622-05] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Unexpected output in reduce: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in reduce: MPIR_Init_thread(388).................:
Unexpected output in reduce: MPID_Init(139)........................: channel initialization failed
Unexpected output in reduce: MPIDI_CH3_Init(38)....................:
Unexpected output in reduce: MPID_nem_init(196)....................:
Unexpected output in reduce: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in reduce: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in reduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in reduce: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in reduce: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in reduce: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in reduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program reduce exited without No Errors
Unexpected output in red3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in red3: MPIR_Init_thread(388).................:
Unexpected output in red3: MPID_Init(139)........................: channel initialization failed
Unexpected output in red3: MPIDI_CH3_Init(38)....................:
Unexpected output in red3: MPID_nem_init(196)....................:
Unexpected output in red3: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in red3: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in red3: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in red3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program red3 exited without No Errors
Unexpected output in alltoall1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in alltoall1: MPIR_Init_thread(388).................:
Unexpected output in alltoall1: MPID_Init(139)........................: channel initialization failed
Unexpected output in alltoall1: MPIDI_CH3_Init(38)....................:
Unexpected output in alltoall1: MPID_nem_init(196)....................:
Unexpected output in alltoall1: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in alltoall1: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in alltoall1: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in alltoall1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in alltoall1: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in alltoall1: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in alltoall1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program alltoall1 exited without No Errors
Unexpected output in alltoallv0: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in alltoallv0: MPIR_Init_thread(388).................:
Unexpected output in alltoallv0: MPID_Init(139)........................: channel initialization failed
Unexpected output in alltoallv0: MPIDI_CH3_Init(38)....................:
Unexpected output in alltoallv0: MPID_nem_init(196)....................:
Unexpected output in alltoallv0: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in alltoallv0: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in alltoallv0: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in alltoallv0: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program alltoallv0 exited without No Errors
Unexpected output in alltoallw1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in alltoallw1: MPIR_Init_thread(388).................:
Unexpected output in alltoallw1: MPID_Init(139)........................: channel initialization failed
Unexpected output in alltoallw1: MPIDI_CH3_Init(38)....................:
Unexpected output in alltoallw1: MPID_nem_init(196)....................:
Unexpected output in alltoallw1: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in alltoallw1: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in alltoallw1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program alltoallw1 exited without No Errors
Unexpected output in alltoallw_zeros: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in alltoallw_zeros: MPIR_Init_thread(388).................:
Unexpected output in alltoallw_zeros: MPID_Init(139)........................: channel initialization failed
Unexpected output in alltoallw_zeros: MPIDI_CH3_Init(38)....................:
Unexpected output in alltoallw_zeros: MPID_nem_init(196)....................:
Unexpected output in alltoallw_zeros: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in alltoallw_zeros: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in alltoallw_zeros: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in alltoallw_zeros: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program alltoallw_zeros exited without No Errors
Unexpected output in allgather2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allgather2: MPIR_Init_thread(388).................:
Unexpected output in allgather2: MPID_Init(139)........................: channel initialization failed
Unexpected output in allgather2: MPIDI_CH3_Init(38)....................:
Unexpected output in allgather2: MPID_nem_init(196)....................:
Unexpected output in allgather2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allgather2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allgather2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allgather2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allgather2 exited without No Errors
Unexpected output in allgatherv2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allgatherv2: MPIR_Init_thread(388).................:
Unexpected output in allgatherv2: MPID_Init(139)........................: channel initialization failed
Unexpected output in allgatherv2: MPIDI_CH3_Init(38)....................:
Unexpected output in allgatherv2: MPID_nem_init(196)....................:
Unexpected output in allgatherv2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in allgatherv2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in allgatherv2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in allgatherv2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allgatherv2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allgatherv2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allgatherv2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program allgatherv2 exited without No Errors
Unexpected output in allgatherv4: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allgatherv4: MPIR_Init_thread(388).................:
Unexpected output in allgatherv4: MPID_Init(139)........................: channel initialization failed
Unexpected output in allgatherv4: MPIDI_CH3_Init(38)....................:
Unexpected output in allgatherv4: MPID_nem_init(196)....................:
Unexpected output in allgatherv4: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allgatherv4: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allgatherv4: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allgatherv4: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allgatherv4 exited without No Errors
Unexpected output in bcasttest: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in bcasttest: MPIR_Init_thread(388).................:
Unexpected output in bcasttest: MPID_Init(139)........................: channel initialization failed
Unexpected output in bcasttest: MPIDI_CH3_Init(38)....................:
Unexpected output in bcasttest: MPID_nem_init(196)....................:
Unexpected output in bcasttest: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in bcasttest: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in bcasttest: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program bcasttest exited without No Errors
Unexpected output in bcast2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in bcast2: MPIR_Init_thread(388).................:
Unexpected output in bcast2: MPID_Init(139)........................: channel initialization failed
Unexpected output in bcast2: MPIDI_CH3_Init(38)....................:
Unexpected output in bcast2: MPID_nem_init(196)....................:
Unexpected output in bcast2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in bcast2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in bcast2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in bcast2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in bcast2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in bcast2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in bcast2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program bcast2 exited without No Errors
Unexpected output in coll2: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in coll2: MPIR_Init_thread(388).................:
Unexpected output in coll2: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll2: MPIDI_CH3_Init(38)....................:
Unexpected output in coll2: MPID_nem_init(196)....................:
Unexpected output in coll2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in coll2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in coll2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in coll2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program coll2 exited without No Errors
Unexpected output in coll4: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in coll4: MPIR_Init_thread(388).................:
Unexpected output in coll4: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll4: MPIDI_CH3_Init(38)....................:
Unexpected output in coll4: MPID_nem_init(196)....................:
Unexpected output in coll4: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in coll4: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in coll4: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in coll4: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program coll4 exited without No Errors
Unexpected output in coll6: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in coll6: MPIR_Init_thread(388).................:
Unexpected output in coll6: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll6: MPIDI_CH3_Init(38)....................:
Unexpected output in coll6: MPID_nem_init(196)....................:
Unexpected output in coll6: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in coll6: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in coll6: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in coll6: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in coll6: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in coll6: MPIU_SHMW_Seg_attach(925).............:
Program coll6 exited without No Errors
Unexpected output in coll7: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in coll7: MPIR_Init_thread(388).................:
Unexpected output in coll7: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll7: MPIDI_CH3_Init(38)....................:
Unexpected output in coll7: MPID_nem_init(196)....................:
Unexpected output in coll7: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in coll7: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in coll7: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program coll7 exited without No Errors
Unexpected output in coll9: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in coll9: MPIR_Init_thread(388).................:
Unexpected output in coll9: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll9: MPIDI_CH3_Init(38)....................:
Unexpected output in coll9: MPID_nem_init(196)....................:
Unexpected output in coll9: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in coll9: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in coll9: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in coll9: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program coll9 exited without No Errors
Unexpected output in coll10: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in coll10: MPIR_Init_thread(388).................:
Unexpected output in coll10: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll10: MPIDI_CH3_Init(38)....................:
Unexpected output in coll10: MPID_nem_init(196)....................:
Unexpected output in coll10: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in coll10: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in coll10: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Permission denied
Unexpected output in coll10: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in coll10: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in coll10: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in coll10: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program coll10 exited without No Errors
Unexpected output in coll12: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in coll12: MPIR_Init_thread(388).................:
Unexpected output in coll12: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll12: MPIDI_CH3_Init(38)....................:
Unexpected output in coll12: MPID_nem_init(196)....................:
Unexpected output in coll12: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in coll12: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in coll12: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in coll12: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program coll12 exited without No Errors
Unexpected output in longuser: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in longuser: MPIR_Init_thread(388).................:
Unexpected output in longuser: MPID_Init(139)........................: channel initialization failed
Unexpected output in longuser: MPIDI_CH3_Init(38)....................:
Unexpected output in longuser: MPID_nem_init(196)....................:
Unexpected output in longuser: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in longuser: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in longuser: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in longuser: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in longuser: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in longuser: MPIU_SHMW_Seg_open(863)...............:
Program longuser exited without No Errors
Unexpected output in redscat2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in redscat2: MPIR_Init_thread(388).................:
Unexpected output in redscat2: MPID_Init(139)........................: channel initialization failed
Unexpected output in redscat2: MPIDI_CH3_Init(38)....................:
Unexpected output in redscat2: MPID_nem_init(196)....................:
Unexpected output in redscat2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in redscat2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in redscat2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in redscat2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in redscat2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in redscat2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in redscat2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program redscat2 exited without No Errors
Unexpected output in redscatinter: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in redscatinter: MPIR_Init_thread(388).................:
Unexpected output in redscatinter: MPID_Init(139)........................: channel initialization failed
Unexpected output in redscatinter: MPIDI_CH3_Init(38)....................:
Unexpected output in redscatinter: MPID_nem_init(196)....................:
Unexpected output in redscatinter: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in redscatinter: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in redscatinter: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program redscatinter exited without No Errors
Unexpected output in red_scat_block2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in red_scat_block2: MPIR_Init_thread(388).................:
Unexpected output in red_scat_block2: MPID_Init(139)........................: channel initialization failed
Unexpected output in red_scat_block2: MPIDI_CH3_Init(38)....................:
Unexpected output in red_scat_block2: MPID_nem_init(196)....................:
Unexpected output in red_scat_block2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in red_scat_block2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in red_scat_block2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in red_scat_block2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program red_scat_block2 exited without No Errors
Unexpected output in redscatblk3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in redscatblk3: MPIR_Init_thread(388).................:
Unexpected output in redscatblk3: MPID_Init(139)........................: channel initialization failed
Unexpected output in redscatblk3: MPIDI_CH3_Init(38)....................:
Unexpected output in redscatblk3: MPID_nem_init(196)....................:
Unexpected output in redscatblk3: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in redscatblk3: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in redscatblk3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in redscatblk3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in redscatblk3: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in redscatblk3: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in redscatblk3: MPIU_SHMW_Seg_open(863)...............:
Program redscatblk3 exited without No Errors
Unexpected output in exscan: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in exscan: MPIR_Init_thread(388).................:
Unexpected output in exscan: MPID_Init(139)........................: channel initialization failed
Unexpected output in exscan: MPIDI_CH3_Init(38)....................:
Unexpected output in exscan: MPID_nem_init(196)....................:
Unexpected output in exscan: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in exscan: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in exscan: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program exscan exited without No Errors
Unexpected output in exscan2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in exscan2: MPIR_Init_thread(388).................:
Unexpected output in exscan2: MPID_Init(139)........................: channel initialization failed
Unexpected output in exscan2: MPIDI_CH3_Init(38)....................:
Unexpected output in exscan2: MPID_nem_init(196)....................:
Unexpected output in exscan2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in exscan2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in exscan2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in exscan2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program exscan2 exited without No Errors
Unexpected output in gather: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in gather: MPIR_Init_thread(388).................:
Unexpected output in gather: MPID_Init(139)........................: channel initialization failed
Unexpected output in gather: MPIDI_CH3_Init(38)....................:
Unexpected output in gather: MPID_nem_init(196)....................:
Unexpected output in gather: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in gather: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in gather: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in gather: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in gather: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program gather exited without No Errors
Unexpected output in gather2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in gather2: MPIR_Init_thread(388).................:
Unexpected output in gather2: MPID_Init(139)........................: channel initialization failed
Unexpected output in gather2: MPIDI_CH3_Init(38)....................:
Unexpected output in gather2: MPID_nem_init(196)....................:
Unexpected output in gather2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in gather2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in gather2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in gather2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program gather2 exited without No Errors
Unexpected output in scattern: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in scattern: MPIR_Init_thread(388).................:
Unexpected output in scattern: MPID_Init(139)........................: channel initialization failed
Unexpected output in scattern: MPIDI_CH3_Init(38)....................:
Unexpected output in scattern: MPID_nem_init(196)....................:
Unexpected output in scattern: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in scattern: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in scattern: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in scattern: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program scattern exited without No Errors
Unexpected output in scatterv: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in scatterv: MPIR_Init_thread(388).................:
Unexpected output in scatterv: MPID_Init(139)........................: channel initialization failed
Unexpected output in scatterv: MPIDI_CH3_Init(38)....................:
Unexpected output in scatterv: MPID_nem_init(196)....................:
Unexpected output in scatterv: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in scatterv: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in scatterv: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in scatterv: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in scatterv: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in scatterv: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in scatterv: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busyProgram scatterv exited without No Errors
Unexpected output in icbcast: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icbcast: MPIR_Init_thread(388).................:
Unexpected output in icbcast: MPID_Init(139)........................: channel initialization failed
Unexpected output in icbcast: MPIDI_CH3_Init(38)....................:
Unexpected output in icbcast: MPID_nem_init(196)....................:
Unexpected output in icbcast: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icbcast: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icbcast: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in icbcast: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icbcast: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icbcast: MPIU_SHMW_Seg_open(863)...............:
Program icbcast exited without No Errors
Unexpected output in icreduce: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icreduce: MPIR_Init_thread(388).................:
Unexpected output in icreduce: MPID_Init(139)........................: channel initialization failed
Unexpected output in icreduce: MPIDI_CH3_Init(38)....................:
Unexpected output in icreduce: MPID_nem_init(196)....................:
Unexpected output in icreduce: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icreduce: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icreduce: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in icreduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icreduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in icreduce: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icreduce: MPIU_SHMW_Seg_attach(925).............:
Program icreduce exited without No Errors
Unexpected output in icscatter: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icscatter: MPIR_Init_thread(388).................:
Unexpected output in icscatter: MPID_Init(139)........................: channel initialization failed
Unexpected output in icscatter: MPIDI_CH3_Init(38)....................:
Unexpected output in icscatter: MPID_nem_init(196)....................:
Unexpected output in icscatter: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icscatter: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icscatter: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program icscatter exited without No Errors
Unexpected output in icbarrier: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icbarrier: MPIR_Init_thread(388).................:
Unexpected output in icbarrier: MPID_Init(139)........................: channel initialization failed
Unexpected output in icbarrier: MPIDI_CH3_Init(38)....................:
Unexpected output in icbarrier: MPID_nem_init(196)....................:
Unexpected output in icbarrier: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icbarrier: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icbarrier: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in icbarrier: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program icbarrier exited without No Errors
Unexpected output in icbarrier: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icbarrier: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icbarrier: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in icallgatherv: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icallgatherv: MPIR_Init_thread(388).................:
Unexpected output in icallgatherv: MPID_Init(139)........................: channel initialization failed
Unexpected output in icallgatherv: MPIDI_CH3_Init(38)....................:
Unexpected output in icallgatherv: MPID_nem_init(196)....................:
Unexpected output in icallgatherv: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icallgatherv: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icallgatherv: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in icallgatherv: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program icallgatherv exited without No Errors
Unexpected output in icgatherv: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icgatherv: MPIR_Init_thread(388).................:
Unexpected output in icgatherv: MPID_Init(139)........................: channel initialization failed
Unexpected output in icgatherv: MPIDI_CH3_Init(38)....................:
Unexpected output in icgatherv: MPID_nem_init(196)....................:
Unexpected output in icgatherv: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icgatherv: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icgatherv: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program icgatherv exited without No Errors
Unexpected output in icgatherv: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icscatterv: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icscatterv: MPIR_Init_thread(388).................:
Unexpected output in icscatterv: MPID_Init(139)........................: channel initialization failed
Unexpected output in icscatterv: MPIDI_CH3_Init(38)....................:
Unexpected output in icscatterv: MPID_nem_init(196)....................:
Unexpected output in icscatterv: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icscatterv: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icscatterv: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in icscatterv: [proxy:0:0 at 980622-05] HYDU_sock_read (./utils/sock/sock.c:272): read error (Software caused connection abort)
Unexpected output in icscatterv: [proxy:0:0 at 980622-05] pmi_cb (./pm/pmiserv/pmip_cb.c:228): unable to read PMI command
Unexpected output in icscatterv: [proxy:0:0 at 980622-05] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in icscatterv: [proxy:0:0 at 980622-05] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in icscatterv: [mpiexec at 980622-05] control_cb (./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
Unexpected output in icscatterv: [mpiexec at 980622-05] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in icscatterv: [mpiexec at 980622-05] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:179): error waiting for event
Unexpected output in icscatterv: [mpiexec at 980622-05] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program icscatterv exited without No Errors
Unexpected output in icalltoall: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icalltoall: MPIR_Init_thread(388).................:
Unexpected output in icalltoall: MPID_Init(139)........................: channel initialization failed
Unexpected output in icalltoall: MPIDI_CH3_Init(38)....................:
Unexpected output in icalltoall: MPID_nem_init(196)....................:
Unexpected output in icalltoall: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icalltoall: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icalltoall: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icalltoall: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icalltoall: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icalltoall: MPIU_SHMW_Seg_open(863)...............:
Program icalltoall exited without No Errors
Unexpected output in icalltoallw: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icalltoallw: MPIR_Init_thread(388).................:
Unexpected output in icalltoallw: MPID_Init(139)........................: channel initialization failed
Unexpected output in icalltoallw: MPIDI_CH3_Init(38)....................:
Unexpected output in icalltoallw: MPID_nem_init(196)....................:
Unexpected output in icalltoallw: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icalltoallw: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icalltoallw: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program icalltoallw exited without No Errors
Unexpected output in opland: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in opland: MPIR_Init_thread(388).................:
Unexpected output in opland: MPID_Init(139)........................: channel initialization failed
Unexpected output in opland: MPIDI_CH3_Init(38)....................:
Unexpected output in opland: MPID_nem_init(196)....................:
Unexpected output in opland: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in opland: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in opland: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in opland: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program opland exited without No Errors
Unexpected output in oplxor: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in oplxor: MPIR_Init_thread(388).................:
Unexpected output in oplxor: MPID_Init(139)........................: channel initialization failed
Unexpected output in oplxor: MPIDI_CH3_Init(38)....................:
Unexpected output in oplxor: MPID_nem_init(196)....................:
Unexpected output in oplxor: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in oplxor: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in oplxor: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in oplxor: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program oplxor exited without No Errors
Unexpected output in oplxor: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in oplxor: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in oplxor: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in opband: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in opband: MPIR_Init_thread(388).................:
Unexpected output in opband: MPID_Init(139)........................: channel initialization failed
Unexpected output in opband: MPIDI_CH3_Init(38)....................:
Unexpected output in opband: MPID_nem_init(196)....................:
Unexpected output in opband: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in opband: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in opband: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in opband: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program opband exited without No Errors
Unexpected output in opbxor: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in opbxor: MPIR_Init_thread(388).................:
Unexpected output in opbxor: MPID_Init(139)........................: channel initialization failed
Unexpected output in opbxor: MPIDI_CH3_Init(38)....................:
Unexpected output in opbxor: MPID_nem_init(196)....................:
Unexpected output in opbxor: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in opbxor: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in opbxor: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in opbxor: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program opbxor exited without No Errors
Unexpected output in opsum: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in opsum: MPIR_Init_thread(388).................:
Unexpected output in opsum: MPID_Init(139)........................: channel initialization failed
Unexpected output in opsum: MPIDI_CH3_Init(38)....................:
Unexpected output in opsum: MPID_nem_init(196)....................:
Unexpected output in opsum: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in opsum: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in opsum: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in opsum: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program opsum exited without No Errors
Unexpected output in opmin: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in opmin: MPIR_Init_thread(388).................:
Unexpected output in opmin: MPID_Init(139)........................: channel initialization failed
Unexpected output in opmin: MPIDI_CH3_Init(38)....................:
Unexpected output in opmin: MPID_nem_init(196)....................:
Unexpected output in opmin: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in opmin: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in opmin: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in opmin: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program opmin exited without No Errors
Unexpected output in opminloc: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in opminloc: MPIR_Init_thread(388).................:
Unexpected output in opminloc: MPID_Init(139)........................: channel initialization failed
Unexpected output in opminloc: MPIDI_CH3_Init(38)....................:
Unexpected output in opminloc: MPID_nem_init(196)....................:
Unexpected output in opminloc: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in opminloc: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in opminloc: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in opminloc: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in opminloc: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in opminloc: MPIU_SHMW_Seg_open(863)...............:
Program opminloc exited without No Errors
Unexpected output in opmax: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in opmax: MPIR_Init_thread(388).................:
Unexpected output in opmax: MPID_Init(139)........................: channel initialization failed
Unexpected output in opmax: MPIDI_CH3_Init(38)....................:
Unexpected output in opmax: MPID_nem_init(196)....................:
Unexpected output in opmax: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in opmax: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in opmax: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in opmax: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program opmax exited without No Errors
Unexpected output in opmaxloc: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in opmaxloc: MPIR_Init_thread(388).................:
Unexpected output in opmaxloc: MPID_Init(139)........................: channel initialization failed
Unexpected output in opmaxloc: MPIDI_CH3_Init(38)....................:
Unexpected output in opmaxloc: MPID_nem_init(196)....................:
Unexpected output in opmaxloc: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in opmaxloc: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in opmaxloc: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in opmaxloc: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in opmaxloc: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in opmaxloc: MPIU_SHMW_Seg_attach(925).............:
Program opmaxloc exited without No Errors
Processing directory comm
Looking in ./comm/testlist
Unexpected output in commname: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in commname: MPIR_Init_thread(388).................:
Unexpected output in commname: MPID_Init(139)........................: channel initialization failed
Unexpected output in commname: MPIDI_CH3_Init(38)....................:
Unexpected output in commname: MPID_nem_init(196)....................:
Unexpected output in commname: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in commname: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in commname: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in commname: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program commname exited without No Errors
Unexpected output in ic1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in ic1: MPIR_Init_thread(388).................:
Unexpected output in ic1: MPID_Init(139)........................: channel initialization failed
Unexpected output in ic1: MPIDI_CH3_Init(38)....................:
Unexpected output in ic1: MPID_nem_init(196)....................:
Unexpected output in ic1: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in ic1: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in ic1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program ic1 exited without No Errors
Unexpected output in icm: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icm: MPIR_Init_thread(388).................:
Unexpected output in icm: MPID_Init(139)........................: channel initialization failed
Unexpected output in icm: MPIDI_CH3_Init(38)....................:
Unexpected output in icm: MPID_nem_init(196)....................:
Unexpected output in icm: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icm: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icm: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program icm exited without No Errors
Unexpected output in iccreate: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in iccreate: MPIR_Init_thread(388).................:
Unexpected output in iccreate: MPID_Init(139)........................: channel initialization failed
Unexpected output in iccreate: MPIDI_CH3_Init(38)....................:
Unexpected output in iccreate: MPID_nem_init(196)....................:
Unexpected output in iccreate: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in iccreate: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in iccreate: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in iccreate: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in iccreate: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in iccreate: MPIU_SHMW_Seg_attach(925).............:
Program iccreate exited without No Errors
Unexpected output in ctxsplit: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in ctxsplit: MPIR_Init_thread(388).................:
Unexpected output in ctxsplit: MPID_Init(139)........................: channel initialization failed
Unexpected output in ctxsplit: MPIDI_CH3_Init(38)....................:
Unexpected output in ctxsplit: MPID_nem_init(196)....................:
Unexpected output in ctxsplit: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in ctxsplit: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in ctxsplit: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in ctxsplit: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program ctxsplit exited without No Errors
Processing directory datatype
Looking in ./datatype/testlist
Unexpected output in darray-pack: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in darray-pack: MPIR_Init_thread(388).................:
Unexpected output in darray-pack: MPID_Init(139)........................: channel initialization failed
Unexpected output in darray-pack: MPIDI_CH3_Init(38)....................:
Unexpected output in darray-pack: MPID_nem_init(196)....................:
Unexpected output in darray-pack: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in darray-pack: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in darray-pack: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in darray-pack: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program darray-pack exited without No Errors
Processing directory errhan
Looking in ./errhan/testlist
Processing directory group
Looking in ./group/testlist
Unexpected output in groupcreate: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in groupcreate: MPIR_Init_thread(388).................:
Unexpected output in groupcreate: MPID_Init(139)........................: channel initialization failed
Unexpected output in groupcreate: MPIDI_CH3_Init(38)....................:
Unexpected output in groupcreate: MPID_nem_init(196)....................:
Unexpected output in groupcreate: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in groupcreate: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in groupcreate: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in groupcreate: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in groupcreate: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in groupcreate: MPIU_SHMW_Seg_open(863)...............:
Program groupcreate exited without No Errors
Unexpected output in grouptest2: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in grouptest2: MPIR_Init_thread(388).................:
Unexpected output in grouptest2: MPID_Init(139)........................: channel initialization failed
Unexpected output in grouptest2: MPIDI_CH3_Init(38)....................:
Unexpected output in grouptest2: MPID_nem_init(196)....................:
Unexpected output in grouptest2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in grouptest2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in grouptest2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program grouptest2 exited without No Errors
Unexpected output in gtranks: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in gtranks: MPIR_Init_thread(388).................:
Unexpected output in gtranks: MPID_Init(139)........................: channel initialization failed
Unexpected output in gtranks: MPIDI_CH3_Init(38)....................:
Unexpected output in gtranks: MPID_nem_init(196)....................:
Unexpected output in gtranks: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in gtranks: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in gtranks: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in gtranks: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in gtranks: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in gtranks: MPIU_SHMW_Seg_open(863)...............:
Program gtranks exited without No Errors
Unexpected output in gtranksperf: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in gtranksperf: MPIR_Init_thread(388).................:
Unexpected output in gtranksperf: MPID_Init(139)........................: channel initialization failed
Unexpected output in gtranksperf: MPIDI_CH3_Init(38)....................:
Unexpected output in gtranksperf: MPID_nem_init(196)....................:
Unexpected output in gtranksperf: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in gtranksperf: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in gtranksperf: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in gtranksperf: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in gtranksperf: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program gtranksperf exited without No Errors
Processing directory info
Looking in ./info/testlist
Processing directory init
Looking in ./init/testlist
Processing directory pt2pt
Looking in ./pt2pt/testlist
Unexpected output in sendflood: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in sendflood: MPIR_Init_thread(388).................:
Unexpected output in sendflood: MPID_Init(139)........................: channel initialization failed
Unexpected output in sendflood: MPIDI_CH3_Init(38)....................:
Unexpected output in sendflood: MPID_nem_init(196)....................:
Unexpected output in sendflood: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in sendflood: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in sendflood: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in sendflood: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program sendflood exited without No Errors
Unexpected output in icsend: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icsend: MPIR_Init_thread(388).................:
Unexpected output in icsend: MPID_Init(139)........................: channel initialization failed
Unexpected output in icsend: MPIDI_CH3_Init(38)....................:
Unexpected output in icsend: MPID_nem_init(196)....................:
Unexpected output in icsend: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icsend: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icsend: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in icsend: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program icsend exited without No Errors
Unexpected output in probe-unexp: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in probe-unexp: MPIR_Init_thread(388).................:
Unexpected output in probe-unexp: MPID_Init(139)........................: channel initialization failed
Unexpected output in probe-unexp: MPIDI_CH3_Init(38)....................:
Unexpected output in probe-unexp: MPID_nem_init(196)....................:
Unexpected output in probe-unexp: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in probe-unexp: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in probe-unexp: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in probe-unexp: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program probe-unexp exited without No Errors
Unexpected output in large_message: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in large_message: MPIR_Init_thread(388).................:
Unexpected output in large_message: MPID_Init(139)........................: channel initialization failed
Unexpected output in large_message: MPIDI_CH3_Init(38)....................:
Unexpected output in large_message: MPID_nem_init(196)....................:
Unexpected output in large_message: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in large_message: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in large_message: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in large_message: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program large_message exited without No Errors
Processing directory rma
Looking in ./rma/testlist
Unexpected output in putfence1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in putfence1: MPIR_Init_thread(388).................:
Unexpected output in putfence1: MPID_Init(139)........................: channel initialization failed
Unexpected output in putfence1: MPIDI_CH3_Init(38)....................:
Unexpected output in putfence1: MPID_nem_init(196)....................:
Unexpected output in putfence1: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in putfence1: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in putfence1: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in putfence1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in putfence1: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in putfence1: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in putfence1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in putfence1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Permission denied
Program putfence1 exited without No Errors
Unexpected output in putfidx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in putfidx: MPIR_Init_thread(388).................:
Unexpected output in putfidx: MPID_Init(139)........................: channel initialization failed
Unexpected output in putfidx: MPIDI_CH3_Init(38)....................:
Unexpected output in putfidx: MPID_nem_init(196)....................:
Unexpected output in putfidx: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in putfidx: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in putfidx: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in putfidx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program putfidx exited without No Errors
Unexpected output in getfence1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in getfence1: MPIR_Init_thread(388).................:
Unexpected output in getfence1: MPID_Init(139)........................: channel initialization failed
Unexpected output in getfence1: MPIDI_CH3_Init(38)....................:
Unexpected output in getfence1: MPID_nem_init(196)....................:
Unexpected output in getfence1: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in getfence1: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in getfence1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in getfence1: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in getfence1: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in getfence1: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in getfence1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program getfence1 exited without No Errors
Unexpected output in accfence1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in accfence1: MPIR_Init_thread(388).................:
Unexpected output in accfence1: MPID_Init(139)........................: channel initialization failed
Unexpected output in accfence1: MPIDI_CH3_Init(38)....................:
Unexpected output in accfence1: MPID_nem_init(196)....................:
Unexpected output in accfence1: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in accfence1: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in accfence1: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in accfence1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program accfence1 exited without No Errors
Unexpected output in adlb_mimic1: [mpiexec at 980622-05] APPLICATION TIMED OUT
Unexpected output in adlb_mimic1: [proxy:0:0 at 980622-05] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:906): assert (!closed) failed
Unexpected output in adlb_mimic1: [proxy:0:0 at 980622-05] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in adlb_mimic1: [proxy:0:0 at 980622-05] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in adlb_mimic1: [mpiexec at 980622-05] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
Unexpected output in adlb_mimic1: [mpiexec at 980622-05] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
Unexpected output in adlb_mimic1: [mpiexec at 980622-05] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:189): launcher returned error waiting for completion
Unexpected output in adlb_mimic1: [mpiexec at 980622-05] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program adlb_mimic1 exited without No Errors
Unexpected output in putpscw1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in putpscw1: MPIR_Init_thread(388).................:
Unexpected output in putpscw1: MPID_Init(139)........................: channel initialization failed
Unexpected output in putpscw1: MPIDI_CH3_Init(38)....................:
Unexpected output in putpscw1: MPID_nem_init(196)....................:
Unexpected output in putpscw1: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in putpscw1: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in putpscw1: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in putpscw1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program putpscw1 exited without No Errors
Unexpected output in getgroup: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in getgroup: MPIR_Init_thread(388).................:
Unexpected output in getgroup: MPID_Init(139)........................: channel initialization failed
Unexpected output in getgroup: MPIDI_CH3_Init(38)....................:
Unexpected output in getgroup: MPID_nem_init(196)....................:
Unexpected output in getgroup: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in getgroup: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in getgroup: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in getgroup: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program getgroup exited without No Errors
Unexpected output in lockcontention2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in lockcontention2: MPIR_Init_thread(388).................:
Unexpected output in lockcontention2: MPID_Init(139)........................: channel initialization failed
Unexpected output in lockcontention2: MPIDI_CH3_Init(38)....................:
Unexpected output in lockcontention2: MPID_nem_init(196)....................:
Unexpected output in lockcontention2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in lockcontention2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in lockcontention2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in lockcontention2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in lockcontention2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in lockcontention2: MPIU_SHMW_Seg_open(863)...............:
Program lockcontention2 exited without No Errors
Unexpected output in fetchandadd: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in fetchandadd: MPIR_Init_thread(388).................:
Unexpected output in fetchandadd: MPID_Init(139)........................: channel initialization failed
Unexpected output in fetchandadd: MPIDI_CH3_Init(38)....................:
Unexpected output in fetchandadd: MPID_nem_init(196)....................:
Unexpected output in fetchandadd: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in fetchandadd: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in fetchandadd: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in fetchandadd: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program fetchandadd exited without No Errors
Unexpected output in fetchandadd_tree: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in fetchandadd_tree: MPIR_Init_thread(388).................:
Unexpected output in fetchandadd_tree: MPID_Init(139)........................: channel initialization failed
Unexpected output in fetchandadd_tree: MPIDI_CH3_Init(38)....................:
Unexpected output in fetchandadd_tree: MPID_nem_init(196)....................:
Unexpected output in fetchandadd_tree: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in fetchandadd_tree: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in fetchandadd_tree: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program fetchandadd_tree exited without No Errors
Unexpected output in fetchandadd_tree_am: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in fetchandadd_tree_am: MPIR_Init_thread(388).................:
Unexpected output in fetchandadd_tree_am: MPID_Init(139)........................: channel initialization failed
Unexpected output in fetchandadd_tree_am: MPIDI_CH3_Init(38)....................:
Unexpected output in fetchandadd_tree_am: MPID_nem_init(196)....................:
Unexpected output in fetchandadd_tree_am: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in fetchandadd_tree_am: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in fetchandadd_tree_am: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in fetchandadd_tree_am: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in fetchandadd_tree_am: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in fetchandadd_tree_am: MPIU_SHMW_Seg_open(863)...............:
Program fetchandadd_tree_am exited without No Errors
Unexpected output in nullpscw: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in nullpscw: MPIR_Init_thread(388).................:
Unexpected output in nullpscw: MPID_Init(139)........................: channel initialization failed
Unexpected output in nullpscw: MPIDI_CH3_Init(38)....................:
Unexpected output in nullpscw: MPID_nem_init(196)....................:
Unexpected output in nullpscw: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in nullpscw: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in nullpscw: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program nullpscw exited without No Errors
Unexpected output in epochtest: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in epochtest: MPIR_Init_thread(388).................:
Unexpected output in epochtest: MPID_Init(139)........................: channel initialization failed
Unexpected output in epochtest: MPIDI_CH3_Init(38)....................:
Unexpected output in epochtest: MPID_nem_init(196)....................:
Unexpected output in epochtest: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in epochtest: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in epochtest: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in epochtest: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program epochtest exited without No Errors
Unexpected output in contention_put: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in contention_put: MPIR_Init_thread(388).................:
Unexpected output in contention_put: MPID_Init(139)........................: channel initialization failed
Unexpected output in contention_put: MPIDI_CH3_Init(38)....................:
Unexpected output in contention_put: MPID_nem_init(196)....................:
Unexpected output in contention_put: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in contention_put: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in contention_put: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in contention_put: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program contention_put exited without No Errors
Processing directory spawn
Looking in ./spawn/testlist
Unexpected output in taskmaster: [mpiexec at 980622-05] APPLICATION TIMED OUT
Unexpected output in taskmaster: [proxy:118:0 at 980622-05] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:906): assert (!closed) failed
Unexpected output in taskmaster: [proxy:118:0 at 980622-05] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in taskmaster: [proxy:118:0 at 980622-05] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in taskmaster: [proxy:0:0 at 980622-05] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:906): assert (!closed) failed
Unexpected output in taskmaster: [proxy:0:0 at 980622-05] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in taskmaster: [proxy:0:0 at 980622-05] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in taskmaster: [mpiexec at 980622-05] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
Unexpected output in taskmaster: [mpiexec at 980622-05] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
Unexpected output in taskmaster: [mpiexec at 980622-05] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:189): launcher returned error waiting for completion
Unexpected output in taskmaster: [mpiexec at 980622-05] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program taskmaster exited without No Errors
Unexpected output in taskmaster: Fatal error in MPI_Init: Invalid port, error stack:
Unexpected output in taskmaster: MPIR_Init_thread(388).............:
Unexpected output in taskmaster: MPID_Init(264)....................: spawned process group was unable to connect back to the parent on port <tag#0$description#980622-05$port#1438$ifname#10.67.254.208$>
Unexpected output in taskmaster: MPID_Comm_connect(191)............:
Unexpected output in taskmaster: MPIDI_Comm_connect(546)...........: Named port tag#0$description#980622-05$port#1438$ifname#10.67.254.208$ does not exist
Unexpected output in taskmaster: MPIDI_Comm_connect(401)...........:
Unexpected output in taskmaster: MPIC_Sendrecv(192)................:
Unexpected output in taskmaster: MPIC_Wait(540)....................:
Unexpected output in taskmaster: MPIDI_CH3I_Progress(402)..........:
Unexpected output in taskmaster: MPID_nem_mpich2_blocking_recv(905):
Unexpected output in taskmaster: MPID_nem_tcp_connpoll(1838).......:
Unexpected output in taskmaster: state_c_tmpvcsent_handler(1264)...: Failure during connection protocol
Unexpected output in taskmaster: recv_cmd_pkt(739).................: read from socket failed - Connection reset by peer
Unexpected output in disconnect_reconnect: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in disconnect_reconnect: MPIR_Init_thread(388).................:
Unexpected output in disconnect_reconnect: MPID_Init(139)........................: channel initialization failed
Unexpected output in disconnect_reconnect: MPIDI_CH3_Init(38)....................:
Unexpected output in disconnect_reconnect: MPID_nem_init(196)....................:
Unexpected output in disconnect_reconnect: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in disconnect_reconnect: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in disconnect_reconnect: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in disconnect_reconnect: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program disconnect_reconnect exited without No Errors
Unexpected output in disconnect_reconnect2: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in disconnect_reconnect2: MPIR_Init_thread(388).................:
Unexpected output in disconnect_reconnect2: MPID_Init(139)........................: channel initialization failed
Unexpected output in disconnect_reconnect2: MPIDI_CH3_Init(38)....................:
Unexpected output in disconnect_reconnect2: MPID_nem_init(196)....................:
Unexpected output in disconnect_reconnect2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in disconnect_reconnect2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in disconnect_reconnect2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in disconnect_reconnect2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in disconnect_reconnect2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in disconnect_reconnect2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in disconnect_reconnect2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program disconnect_reconnect2 exited without No Errors
Unexpected output in multiple_ports2: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in multiple_ports2: MPIR_Init_thread(388).................:
Unexpected output in multiple_ports2: MPID_Init(139)........................: channel initialization failed
Unexpected output in multiple_ports2: MPIDI_CH3_Init(38)....................:
Unexpected output in multiple_ports2: MPID_nem_init(196)....................:
Unexpected output in multiple_ports2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in multiple_ports2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in multiple_ports2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program multiple_ports2 exited without No Errors
Unexpected output in disconnect: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in disconnect: MPIR_Init_thread(388).................:
Unexpected output in disconnect: MPID_Init(139)........................: channel initialization failed
Unexpected output in disconnect: MPIDI_CH3_Init(38)....................:
Unexpected output in disconnect: MPID_nem_init(196)....................:
Unexpected output in disconnect: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in disconnect: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in disconnect: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in disconnect: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program disconnect exited without No Errors
Unexpected output in disconnect2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in disconnect2: MPIR_Init_thread(388).................:
Unexpected output in disconnect2: MPID_Init(139)........................: channel initialization failed
Unexpected output in disconnect2: MPIDI_CH3_Init(38)....................:
Unexpected output in disconnect2: MPID_nem_init(196)....................:
Unexpected output in disconnect2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in disconnect2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in disconnect2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in disconnect2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in disconnect2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in disconnect2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in disconnect2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program disconnect2 exited without No Errors
Unexpected output in pgroup_intercomm_test: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in pgroup_intercomm_test: MPIR_Init_thread(388).................:
Unexpected output in pgroup_intercomm_test: MPID_Init(139)........................: channel initialization failed
Unexpected output in pgroup_intercomm_test: MPIDI_CH3_Init(38)....................:
Unexpected output in pgroup_intercomm_test: MPID_nem_init(196)....................:
Unexpected output in pgroup_intercomm_test: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in pgroup_intercomm_test: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in pgroup_intercomm_test: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in pgroup_intercomm_test: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in pgroup_intercomm_test: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program pgroup_intercomm_test exited without No Errors
Processing directory topo
Looking in ./topo/testlist
Unexpected output in cartmap1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in cartmap1: MPIR_Init_thread(388).................:
Unexpected output in cartmap1: MPID_Init(139)........................: channel initialization failed
Unexpected output in cartmap1: MPIDI_CH3_Init(38)....................:
Unexpected output in cartmap1: MPID_nem_init(196)....................:
Unexpected output in cartmap1: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in cartmap1: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in cartmap1: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in cartmap1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program cartmap1 exited without No Errors
Unexpected output in cartshift1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in cartshift1: MPIR_Init_thread(388).................:
Unexpected output in cartshift1: MPID_Init(139)........................: channel initialization failed
Unexpected output in cartshift1: MPIDI_CH3_Init(38)....................:
Unexpected output in cartshift1: MPID_nem_init(196)....................:
Unexpected output in cartshift1: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in cartshift1: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in cartshift1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program cartshift1 exited without No Errors
Unexpected output in cartsuball: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in cartsuball: MPIR_Init_thread(388).................:
Unexpected output in cartsuball: MPID_Init(139)........................: channel initialization failed
Unexpected output in cartsuball: MPIDI_CH3_Init(38)....................:
Unexpected output in cartsuball: MPID_nem_init(196)....................:
Unexpected output in cartsuball: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in cartsuball: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in cartsuball: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in cartsuball: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in cartsuball: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in cartsuball: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in cartsuball: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program cartsuball exited without No Errors
Unexpected output in cartcreates: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in cartcreates: MPIR_Init_thread(388).................:
Unexpected output in cartcreates: MPID_Init(139)........................: channel initialization failed
Unexpected output in cartcreates: MPIDI_CH3_Init(38)....................:
Unexpected output in cartcreates: MPID_nem_init(196)....................:
Unexpected output in cartcreates: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in cartcreates: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in cartcreates: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in cartcreates: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program cartcreates exited without No Errors
Unexpected output in dims1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in dims1: MPIR_Init_thread(388).................:
Unexpected output in dims1: MPID_Init(139)........................: channel initialization failed
Unexpected output in dims1: MPIDI_CH3_Init(38)....................:
Unexpected output in dims1: MPID_nem_init(196)....................:
Unexpected output in dims1: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in dims1: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in dims1: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in dims1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program dims1 exited without No Errors
Unexpected output in dgraph_unwgt: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in dgraph_unwgt: MPIR_Init_thread(388).................:
Unexpected output in dgraph_unwgt: MPID_Init(139)........................: channel initialization failed
Unexpected output in dgraph_unwgt: MPIDI_CH3_Init(38)....................:
Unexpected output in dgraph_unwgt: MPID_nem_init(196)....................:
Unexpected output in dgraph_unwgt: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in dgraph_unwgt: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in dgraph_unwgt: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in dgraph_unwgt: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program dgraph_unwgt exited without No Errors
Processing directory io
Looking in ./io/testlist
Unexpected output in setinfo: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in setinfo: MPIR_Init_thread(388).................:
Unexpected output in setinfo: MPID_Init(139)........................: channel initialization failed
Unexpected output in setinfo: MPIDI_CH3_Init(38)....................:
Unexpected output in setinfo: MPID_nem_init(196)....................:
Unexpected output in setinfo: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in setinfo: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in setinfo: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in setinfo: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in setinfo: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in setinfo: MPIU_SHMW_Seg_open(863)...............:
Program setinfo exited without No Errors
Unexpected output in setviewcur: [mpiexec at 980622-05] APPLICATION TIMED OUT
Unexpected output in setviewcur: [proxy:0:0 at 980622-05] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:906): assert (!closed) failed
Unexpected output in setviewcur: [proxy:0:0 at 980622-05] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in setviewcur: [proxy:0:0 at 980622-05] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Configuring MPICH2 version 1.4.1 with  '--with-pm=smpd' 'F77=g95' 'FC=g95'
Running on system: CYGWIN_NT-5.1 980622-05 1.7.7(0.230/5/3) 2010-08-31 09:58 i686 Cygwin
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.exe
checking for suffix of executables... .exe
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking build system type... i686-pc-cygwin
checking host system type... i686-pc-cygwin
checking for grep that handles long lines and -e... /usr/bin/grep
checking for fgrep... /usr/bin/grep -F
Executing mpich2prereq in /cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3 with
Executing mpich2prereq in /cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis
configure: ===== configuring src/mpl =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/configure  '--with-pm=smpd' 'F77=g95' 'FC=g95' --disable-option-checking
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /usr/bin/sed
checking for egrep... /usr/bin/grep -E
checking for ld used by gcc... /usr/i686-pc-cygwin/bin/ld.exe
checking if the linker (/usr/i686-pc-cygwin/bin/ld.exe) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 8192
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/i686-pc-cygwin/bin/ld.exe option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... file_magic ^x86 archive import|^x86 DLL
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -DDLL_EXPORT -DPIC
checking if gcc PIC flag -DDLL_EXPORT -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/i686-pc-cygwin/bin/ld.exe) supports shared libraries... yes
checking dynamic linker characteristics... Win32 ld.exe
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking for variable argument list macro functionality... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... no
checking valgrind/valgrind.h presence... no
checking for valgrind/valgrind.h... no
checking valgrind/memcheck.h usability... no
checking valgrind/memcheck.h presence... no
checking for valgrind/memcheck.h... no
checking helgrind.h usability... no
checking helgrind.h presence... no
checking for helgrind.h... no
checking valgrind/helgrind.h usability... no
checking valgrind/helgrind.h presence... no
checking for valgrind/helgrind.h... no
checking drd.h usability... no
checking drd.h presence... no
checking for drd.h... no
checking valgrind/drd.h usability... no
checking valgrind/drd.h presence... no
checking for valgrind/drd.h... no
checking whether the valgrind headers are broken or too old... yes
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for strncmp... yes
checking whether strncmp needs a declaration... no
checking for putenv... yes
checking whether putenv needs a declaration... no
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating localdefs
config.status: creating include/config.h
config.status: include/config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h defines
config.status: include/mplconfig.h is unchanged
configure: ===== done with src/mpl configure =====
configure: ===== configuring src/openpa =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/configure --with-atomic-primitives=auto_allow_emulation '--with-pm=smpd' 'F77=g95' 'FC=g95' --disable-option-checking
checking for gcc... (cached) gcc
checking whether to enable assertions... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for inline... inline
checking for pthread_create in -lpthread... yes
checking for pthread_yield... no
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking for sched_yield... yes
checking if 100 threads can be run at once... yes
checking size of void *... 4
checking size of int... 4
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 primitives... yes
checking for support for gcc x86 primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: src/config.h is unchanged
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
config.status: src/opa_config.h is unchanged
configure: ===== done with src/openpa configure =====
sourcing /cygdrive/c/cygwin/mpich2-1.4.1/src/pm/smpd/mpich2prereq
sourcing /cygdrive/c/cygwin/mpich2-1.4.1/src/pm/smpd/setup_pm
RUNNING SETUP FOR THE SMPD PROCESS MANAGER
RUNNING SETUP FOR THE SMPD SOCK INTERFACE
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O2... yes
checking whether C compiler option -O2 works with an invalid prototype program... yes
checking whether routines compiled with -O2 can be linked with ones compiled without -O2... yes
checking for type of weak symbol alias support... pragma weak accepted but does not work (probably creates two non-weak entries)
no
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute__ ((weak_import)) allowed... yes
checking whether __attribute__((weak,alias(...))) allowed... no
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether g95 accepts -g... yes
checking whether Fortran 77 compiler accepts option -O2... yes
checking how to get verbose linking output from g95... -v
checking for Fortran 77 libraries of g95...  -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1 -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/lib/gcc// -L/lib// -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/lib// -lf95 -lm -lws2_32 -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32
checking whether g95 accepts the FLIBS found by autoconf... yes
checking whether gcc links with FLIBS found by autoconf... yes
checking whether Fortran 77 and C objects are compatible... yes
checking for linker for Fortran main program... Use Fortran to link programs
checking for Fortran 77 name mangling... lower 2uscore
checking for libraries to link Fortran main with C stdio routines... none
checking whether Fortran init will work with C... yes
checking whether we are using the GNU Fortran compiler... yes
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (g95    ) works... yes
checking whether the Fortran 90 compiler (g95    ) is a cross-compiler... no
checking whether Fortran 90 compiler works with Fortran 77 compiler... yes
checking whether Fortran 77 accepts ! for comments... yes
checking for include directory flag for Fortran... -I
checking for Fortran 77 flag for library directories... -L
checking whether Fortran 77 compiler processes .F files with C preprocessor... yes
checking whether we are using the GNU Fortran compiler... (cached) yes
checking whether g95 accepts -g... (cached) yes
checking for Fortran 90 module extension... mod
checking for Fortran 90 module include flag... -I
checking whether Fortran 90 compiler accepts option -O2... yes
checking whether Fortran 90 compiler processes .F90 files with C preprocessor... yes
checking what libraries are needed to link Fortran90 programs with C routines that use stdio... none
checking for Fortran 90 compiler vendor... gnu
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking whether the C++ compiler c++ can build an executable... yes
checking whether C++ compiler works with string... yes
checking whether the compiler supports exceptions... yes
checking whether the compiler recognizes bool as a built-in type... yes
checking whether the compiler implements namespaces... yes
checking whether <iostream> available... yes
checking whether the compiler implements the namespace std... yes
checking whether <math> available... no
checking for GNU g++ version... 3 . 4
checking whether C++ compiler accepts option -O2... yes
checking for perl... /usr/bin/perl
checking for killall... no
checking whether install works... yes
checking whether install breaks libraries... no
checking whether mkdir -p works... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for bash... /usr/bin/bash
checking whether /usr/bin/bash supports arrays... yes
checking for doctext... false
checking for location of doctext style files... unavailable
checking for working volatile... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether gcc supports __func__... yes
Using gcc to determine dependencies
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... eight
checking for max C struct floating point alignment... four
checking for max C struct alignment of structs with doubles... eight
checking for max C struct floating point alignment with long doubles... four
configure: WARNING: Structures containing long doubles may be aligned differently from structures with floats or longs.  MPICH2 does not handle this case automatically and you should avoid assumed extents for structures containing float types.
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking size of char... 1
checking size of unsigned char... 1
checking size of short... 2
checking size of unsigned short... 2
checking size of unsigned int... 4
checking size of long... 4
checking size of unsigned long... 4
checking size of long long... 8
checking size of unsigned long long... 8
checking size of float... 4
checking size of double... 8
checking size of long double... 12
checking for ANSI C header files... (cached) yes
checking size of wchar_t... 2
checking size of float_int... 8
checking size of double_int... 16
checking size of long_int... 8
checking size of short_int... 8
checking size of two_int... 8
checking size of long_double_int... 16
checking sys/bitypes.h usability... no
checking sys/bitypes.h presence... no
checking for sys/bitypes.h... no
checking inttypes.h usability... yes
checking inttypes.h presence... yes
checking stdint.h usability... yes
checking stdint.h presence... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking stdbool.h usability... yes
checking stdbool.h presence... yes
checking for stdbool.h... yes
checking complex.h usability... no
checking complex.h presence... no
checking for complex.h... no
checking size of _Bool... 1
checking size of float _Complex... 8
checking size of double _Complex... 16
checking size of long double _Complex... 24
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking for size of Fortran type integer... 4
checking for size of Fortran type real... 4
checking for size of Fortran type double precision... 8
checking whether integer*1 is supported... yes
checking whether integer*2 is supported... yes
checking whether integer*4 is supported... yes
checking whether integer*8 is supported... yes
checking whether integer*16 is supported... no
checking whether real*4 is supported... yes
checking whether real*8 is supported... yes
checking whether real*16 is supported... yes
checking for C type matching Fortran integer... int
checking for size of MPI_Status... 20
checking for values of Fortran logicals... True is 1 and False is 0
checking for BSD/POSIX style global symbol lister... no
checking for multiple __attribute__((alias)) support... yes
checking the minimum alignment of Fortran common block of 1 integers... 4
checking the minimum alignment of Fortran common block of 5 integers... 4, too small! reset to 32
checking for Fortran 90 integer kind for 4-byte integers... 4
checking for Fortran 90 integer kind for 8-byte integers... 8
checking if real*8 is supported in Fortran 90... yes
checking size of bool... 1
checking how to run the C++ preprocessor... c++ -E
checking complex usability... yes
checking complex presence... yes
checking for complex... yes
checking size of Complex... 8
checking size of DoubleComplex... 16
checking size of LongDoubleComplex... 24
checking if char * pointers use byte addresses... yes
checking for alignment restrictions on ... no
checking for alignment restrictions on int32_t... no
checking size of MPIR_Bsend_data_t... 56
checking for gcc __asm__ and pentium cmpxchgl instruction... yes
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... no
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking stdlib.h usability... yes
checking stdlib.h presence... yes
checking sys/types.h usability... yes
checking sys/types.h presence... yes
checking string.h usability... yes
checking string.h presence... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stddef.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking unistd.h usability... yes
checking unistd.h presence... yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/uio.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for strncasecmp... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... yes
checking whether strerror_r needs a declaration... no
checking for qsort... yes
checking for va_copy... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for fdopen... yes
checking whether fdopen needs a declaration... yes
checking for clock_gettime... yes
checking for clock_getres... yes
checking for gethrtime... no
checking for mach_absolute_time... no
checking for gettimeofday... yes
checking for library containing clock_gettime... none required
checking for library containing clock_getres... none required
checking whether struct timespec is defined in time.h... yes
checking for CLOCK_REALTIME defined in time.h... yes
sourcing /cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/setup_channel
RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
checking for pthread_key_create in -lpthread... yes
checking for pthread_key_create... yes
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE_NP... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK_NP... no
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK... yes
checking for thread local storage specifier... __thread
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking for getpid... yes
checking for sched_setaffinity... no
checking for sched_getaffinity... no
checking for bindprocessor... no
checking for thread_policy_set... no
configure: ===== configuring src/mpid/ch3 =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/configure  '--with-pm=smpd' 'F77=g95' 'FC=g95' --disable-option-checking
RUNNING CONFIGURE FOR CH3 DEVICE
checking for sys/types.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking uuid/uuid.h usability... yes
checking uuid/uuid.h presence... yes
checking for uuid/uuid.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for unistd.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking whether CPP accepts variable length argument lists... yes
checking whether we can use struct ifconf... yes
configure: ===== configuring channels/nemesis =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/configure  '--with-pm=smpd' 'F77=g95' 'FC=g95' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers' --disable-option-checking
RUNNING CONFIGURE FOR THE NEMESIS CHANNEL
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking for netinet/in.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for signal... yes
checking for rand... yes
checking for srand... yes
checking for OpenPA atomic primitive availability... yes
checking for mmap... yes
checking for munmap... yes
configure: Using a memory-mapped file for shared memory
checking whether struct hostent contains h_addr_list... yes
checking knem_io.h usability... no
checking knem_io.h presence... no
checking for knem_io.h... no
config.status: creating nemesis/Makefile
config.status: creating nemesis/src/Makefile
config.status: creating nemesis/utils/Makefile
config.status: creating nemesis/utils/replacements/Makefile
config.status: creating nemesis/utils/monitor/Makefile
config.status: creating nemesis/netmod/Makefile
config.status: creating nemesis/netmod/elan/Makefile
config.status: creating nemesis/netmod/gm/Makefile
config.status: creating nemesis/netmod/mx/Makefile
config.status: creating nemesis/netmod/tcp/Makefile
config.status: creating nemesis/netmod/psm/Makefile
config.status: creating nemesis/netmod/newmad/Makefile
config.status: creating nemesis/netmod/none/Makefile
config.status: creating nemesis/include/mpid_nem_net_module_defs.h
config.status: creating nemesis/src/mpid_nem_net_array.c
config.status: creating include/mpidi_ch3i_nemesis_conf.h
config.status: include/mpidi_ch3i_nemesis_conf.h is unchanged
configure: ===== done with channels/nemesis configure =====
config.status: creating util/Makefile
config.status: creating channels/Makefile
config.status: creating util/ftb/Makefile
config.status: creating include/mpid_thread.h
config.status: creating include/mpidi_ch3_conf.h
config.status: include/mpidi_ch3_conf.h is unchanged
config.status: executing default-1 commands
copying ./../common/thread/mpid_thread_mpe.c to src/mpid_thread.c
configure: ===== done with src/mpid/ch3 configure =====
configure: ===== configuring src/pm/smpd/sock =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4.1/src/pm/smpd/sock/configure  '--with-pm=smpd' 'F77=g95' 'FC=g95' --disable-option-checking
RUNNING CONFIGURE FOR THE SMPD SOCK INTERFACE
configure: ===== configuring poll =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4.1/src/pm/smpd/sock/poll/configure  '--with-pm=smpd' 'F77=g95' 'FC=g95' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers' --disable-option-checking
RUNNING CONFIGURE FOR THE POLL IMPLEMENTATION OF SOCK
checking for poll... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking poll.h usability... yes
checking poll.h presence... yes
checking for poll.h... yes
checking sys/poll.h usability... yes
checking sys/poll.h presence... yes
checking for sys/poll.h... yes
checking if struct poll is defined... yes
checking if a simple program using poll() can be compiled... yes
checking whether bit fields work in ip.h... no
Adding -D_NO_BITFIELDS to CFLAGS
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking whether socklen_t is defined (in sys/socket.h if present)... yes
config.status: creating smpdu_socki_conf.h
configure: ===== done with poll configure =====
config.status: creating smpdu_sock_conf.h
configure: ===== done with src/pm/smpd/sock configure =====
configure: ===== configuring src/mpi/romio =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/configure  '--with-pm=smpd' 'F77=g95' 'FC=g95' --disable-option-checking
Configuring with args --with-pm=smpd F77=g95 FC=g95 --disable-option-checking
checking for architecture... i686
configure: WARNING: Unknown architecture ... proceeding anyway
ROMIO home directory is /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio
checking for memalign... yes
checking Fortran external names
Fortran externals are lower case and have two trailing underscores
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking for int large enough for pointers... yes
checking for Fortran 90 KIND parameter for 8-byte integers...  8
checking that we can use integer*8 to declare MPI_DISPLACMENT_CURRENT... yes
Overriding Array test for MPICH2
checking for weak symbol support... pragma weak
checking that weak symbols are visible to other files... no
no
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
configure: WARNING: File locks may not work with NFS.  See the Installation and
users manual for instructions on testing and if necessary fixing this
checking for library containing aio_write... no
checking for library containing pthread_create... none required
checking for library containing aio_write... (cached) no
checking if aio.h exists and can be compiled... no
checking if sys/aio.h exists and can be compiled... no
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for large file defines... no
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... no
checking for large file defines... none
checking spi/kernel_interface.h usability... no
checking spi/kernel_interface.h presence... no
checking for spi/kernel_interface.h... no
checking for Kernel_GetMemorySize... no
setting SYSDEP_INC to
setting CC to gcc
setting F77 to g95
setting TEST_CC to /cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc
setting TEST_F77 to /cygdrive/c/cygwin/mpich2-1.4.1/bin/mpif77
setting CFLAGS to    -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_bgl/Makefile
config.status: creating adio/ad_bglockless/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating adio/ad_lustre/Makefile
config.status: creating adio/ad_zoidfs/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating common/dataloop/Makefile
config.status: creating adio/include/romioconf.h
configure: ===== done with src/mpi/romio configure =====
configure: ===== configuring src/pmi/smpd =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4.1/src/pmi/smpd/configure  '--with-pm=smpd' 'F77=g95' 'FC=g95' --disable-option-checking
RUNNING CONFIGURE FOR THE SMPD PMI
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking mach-o/dyld.h usability... no
checking mach-o/dyld.h presence... no
checking for mach-o/dyld.h... no
checking for dlopen... yes
checking for NSLinkModule... no
checking for library containing dlopen... none required
smpd_sock_name = poll
config.status: creating pmiconf.h
configure: ===== done with src/pmi/smpd configure =====
configure: ===== configuring src/pm/smpd =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4.1/src/pm/smpd/configure  '--with-pm=smpd' 'F77=g95' 'FC=g95' --disable-option-checking
checking sys/wait.h usability... yes
checking sys/wait.h presence... yes
checking for sys/wait.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking math.h usability... yes
checking math.h presence... yes
checking for math.h... yes
checking termios.h usability... yes
checking termios.h presence... yes
checking for termios.h... yes
checking md5.h usability... no
checking md5.h presence... no
checking for md5.h... no
checking openssl/md5.h usability... no
checking openssl/md5.h presence... no
checking for openssl/md5.h... no
checking for sigaction... yes
checking for setenv... yes
checking for md5_calc... no
checking for library containing uuid_generate... -luuid
checking for poll stdin capability... yes
checking for library containing MD5... no
checking for MD5... no
checking for library containing md5_calc... no
checking for md5_calc function... no
configure: error: SMPD requires MD5 support, and configure could not find either md5_calc in md5.h or MD5 in openssl/md5.h
configure: error: src/pm/smpd configure failed
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120613/9c56600f/attachment-0001.obj>
Beginning make
Using variables CC='gcc' CFLAGS='   -O2' LDFLAGS=' ' F77='g95' FFLAGS='  -O2' FC='g95' FCFLAGS='  -O2' CXX='c++' CXXFLAGS='  -O2' AR='ar' CPP='gcc -E' CPPFLAGS=' -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers'
make all-local
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1'
make clean && cd test && make clean
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1'
make cleanlibs
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1'
rm -f lib/libmpich.a lib/libpmpich.a
rm -f lib/libmpichcxx.a
rm -f lib/libfmpich.a lib/libmpichf90.a
rm -f lib/libmpich.dll*
rm -f lib/libpmpich.dll*
rm -f lib/libmpichcxx.dll*
rm -f lib/libfmpich.dll*
rm -f lib/libmpichf90.dll*
rm -f lib/libmpichf90.*.dll*
rm -f lib/libmpich.*.dll*
rm -f lib/libpmpich.*.dll*
rm -f lib/libmpichcxx.*.dll*
rm -f lib/libfmpich.*.dll*
rm -f lib/libmpich.la* lib/libpmpich.la*
rm -f lib/libmpichf90.la*
rm -f lib/libmpichcxx.la*
rm -f lib/libfmpich.la*
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1'
for dir in  src/mpl src/openpa src - ; do \
		if [ "$dir" = "-" ] ; then break ; fi ; \
		(cd $dir && make clean ) ; done
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
 rm -f strsep.exe
 rm -f strsep
test -z "libmpl.la" || rm -f libmpl.la
rm -f "./so_locations"
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
Making clean in test
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/test'
 rm -f sanity.exe test_primitives.exe test_barriers.exe test_queue.exe
 rm -f sanity test_primitives test_barriers test_queue
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/test'
Making clean in src
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
test -z "libopa.la" || rm -f libopa.la
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
Making clean in .
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
rm -rf .libs _libs
rm -f *.lo
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src'
for dir in mpl mpid mpi mpix util nameserv binding env packaging mpe2 pmi pm - ; do \
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
 rm -f strsep.exe
 rm -f strsep
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid'
for dir in common ch3 - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common'
(cd datatype && make clean )
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype'
(cd dataloop && make clean )
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype/dataloop'
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype/dataloop'
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3'
for dir in channels src util ; do \
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels'
for dir in nemesis - ; do \
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis'
(cd nemesis && make clean )
make[9]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis'
(cd src && make clean )
make[10]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/src'
make[10]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/src'
(cd netmod && make clean )
make[10]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/netmod'
for dir in tcp - ; do \
make[11]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[11]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[10]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/netmod'
(cd utils && make clean )
make[10]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils'
(cd monitor && make clean )
make[11]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
make[11]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
(cd replacements && make clean )
make[11]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[11]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[10]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[9]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis'
make[9]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/src'
make[9]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/src'
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis'
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/src'
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/src'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/util'
for dir in   - ; do \
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/util'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi'
for dir in attr coll comm datatype errhan group init misc pt2pt rma spawn timer topo romio  - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/attr'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/attr'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/coll'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/coll'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/comm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/comm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/datatype'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/datatype'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/errhan'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/errhan'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/group'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/group'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/init'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/init'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/misc'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/misc'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/pt2pt'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/pt2pt'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/rma'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/rma'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/spawn'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/spawn'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/timer'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/timer'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/topo'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/topo'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio'
cleaning directory mpi-io
cleaning directory adio/common
cleaning directory mpi-io/glue/mpich2
cleaning directory adio/ad_testfs
cleaning directory adio/ad_ufs
cleaning directory adio/ad_nfs
cleaning directory test-internal
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/test-internal'
rm -f .P* PI* *.o
rm -f file_realms_test io_bounds_test heap_test
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/test-internal'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/test'
rm -f .P* PI* *.o
rm -f simple perf async coll_test coll_perf misc file_info excl large_array atomicity noncontig i_noncontig noncontig_coll split_coll shared_fp large_file psimple error status noncontig_coll2 aggregation1 aggregation2 async-multiple ordered_fp hindexed fcoll_test fperf fmisc pfcoll_test
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/test'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpix'
(cd comm && make clean )
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpix/comm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpix/comm'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpix'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util'
for dir in mem info msgs instrm thread dbg param osserv procmap other  - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/mem'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/mem'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/info'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/info'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/msgs'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/msgs'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/instrm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/instrm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/thread'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/thread'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/dbg'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/dbg'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/param'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/param'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/osserv'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/osserv'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/procmap'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/procmap'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/other'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/other'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/nameserv'
for dir in file - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/nameserv/file'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/nameserv/file'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/nameserv'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding'
for dir in  f77 f90 cxx - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f77'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f77'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f90'
rm -f *.mod
rm -f mpimod.pcl mpimod.pc
rm -f libmpichf90.a
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f90'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/cxx'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/cxx'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/env'
make clean-postamble
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/env'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/env'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/env'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging'
(cd pkgconfig && make clean )
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging/pkgconfig'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging/pkgconfig'
(cd envmods && make clean )
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging/envmods'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging/envmods'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2'
rm -f /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/lib*
rm -f /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/*.jar
rm -f /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/*.o
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pmi'
for dir in simple - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pmi/simple'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pmi/simple'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pmi'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm'
for dir in hydra  - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
Making clean in ../../mpl
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
 rm -f strsep.exe
 rm -f strsep
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
Making clean in .
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
 rm -f hydra_persist.exe hydra_nameserver.exe hydra_pmi_proxy.exe mpiexec.hydra.exe
 rm -f hydra_persist hydra_nameserver hydra_pmi_proxy mpiexec.hydra
rm -rf .libs _libs
test -z "libhydra.la libpm.la" || rm -f libhydra.la libpm.la
rm -f *.o
rm -f *.lo
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src'
cd examples && make clean
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/examples'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/examples'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test'
for dir in mpi mpid util basic commands ; do \
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi'
rm -f summary.xml
for dir in util attr basic datatype coll comm errhan group info init pt2pt rma spawn topo io  f77 f90 cxx threads errors manual perf - ; do \
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/util'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/util'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/attr'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/attr'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/basic'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/basic'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/datatype'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/datatype'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/coll'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/coll'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/comm'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/comm'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errhan'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errhan'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/group'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/group'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/info'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/info'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/init'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/init'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/pt2pt'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/pt2pt'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/rma'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/rma'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/spawn'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/spawn'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/topo'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/topo'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/io'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/io'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77'
for dir in util attr datatype coll pt2pt info init comm topo rma spawn io ext ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/util'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/util'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/attr'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/attr'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/datatype'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/datatype'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/coll'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/coll'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/pt2pt'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/pt2pt'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/info'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/info'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/init'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/init'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/comm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/comm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/topo'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/topo'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/rma'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/rma'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/spawn'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/spawn'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/io'
rm -f .iotest.txt.*
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/io'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/ext'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77/ext'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f77'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90'
for dir in util timer attr coll datatype pt2pt info comm rma spawn topo io ext init misc f90types ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/util'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/util'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/timer'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/timer'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/attr'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/attr'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/coll'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/coll'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/datatype'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/datatype'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/pt2pt'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/pt2pt'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/info'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/info'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/comm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/comm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/rma'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/rma'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/spawn'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/spawn'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/topo'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/topo'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/io'
rm -f .iotest.txt.*
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/io'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/ext'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/ext'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/init'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/init'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/misc'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/misc'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/f90types'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90/f90types'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/f90'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx'
for dir in util attr pt2pt init info comm coll datatype errhan io rma spawn ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/util'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/util'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/attr'
rm -f summary.xml
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/attr'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/pt2pt'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/pt2pt'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/init'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/init'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/info'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/info'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/comm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/comm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/coll'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/coll'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/datatype'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/datatype'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/errhan'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/errhan'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/io'
rm -f .iotest.txt.*
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/io'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/rma'
rm -f summary.xml
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/rma'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/spawn'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx/spawn'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/cxx'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/threads'
rm -f summary.xml
for dir in util pt2pt comm init spawn ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/threads/util'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/threads/util'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/threads/pt2pt'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/threads/pt2pt'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/threads/comm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/threads/comm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/threads/init'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/threads/init'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/threads/spawn'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/threads/spawn'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/threads'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors'
for dir in attr coll comm group pt2pt rma spawn topo io  f77 f90 cxx basic faults - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/attr'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/attr'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/coll'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/coll'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/comm'
rm -f summary.xml
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/comm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/group'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/group'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/pt2pt'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/pt2pt'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/rma'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/rma'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/spawn'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/spawn'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/topo'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/topo'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/io'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/io'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/f77'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/f77'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/f90'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/f90'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/cxx'
(cd io && make clean )
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/cxx/io'
rm -f summary.xml
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/cxx/io'
(cd errhan && make clean )
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/cxx/errhan'
rm -f summary.xml
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/cxx/errhan'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/cxx'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/basic'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/basic'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/faults'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors/faults'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/errors'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/manual'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/manual'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/perf'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi/perf'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpi'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpid'
(cd ch3 && make clean )
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpid/ch3'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpid/ch3'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/mpid'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/util'
(cd timer && make clean )
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/util/timer'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/util/timer'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/util'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/basic'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/basic'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/commands'
rm -f err.txt out.log out.txt stdintest stdintest2 sdtiotest a.out
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test/commands'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/test'
rm -f lib/newconfig
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
  CC     mplstr.lo
  CC     mpltrmem.lo
  CC     mplenv.lo
  CCLD   libmpl.la
libtool: link: warning: undefined symbols not allowed in i686-pc-cygwin shared libraries
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
Making all in src
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
make  all-am
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo opa_primitives.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c opa_primitives.c -o opa_primitives.o
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c opa_queue.c -o opa_queue.o
mv -f .deps/opa_queue.Tpo .deps/opa_queue.Plo
/bin/sh ../libtool --tag=CC   --mode=link gcc   -version-info 1:0  -o libopa.la -rpath /usr/local/lib opa_primitives.lo opa_queue.lo  -lpthread
libtool: link: ar cru .libs/libopa.a  opa_primitives.o opa_queue.o
libtool: link: ranlib .libs/libopa.a
libtool: link: ( cd ".libs" && rm -f "libopa.la" && ln -s "../libopa.la" "libopa.la" )
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
Making all in test
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/test'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/test'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype/dataloop'
  CC              dataloop.c
  CC              segment.c
  CC              segment_packunpack.c
  CC              segment_flatten.c
  CC              segment_count.c
  CC              dataloop_create.c
  CC              dataloop_create_contig.c
  CC              dataloop_create_vector.c
  CC              dataloop_create_blockindexed.c
  CC              dataloop_create_indexed.c
  CC              dataloop_create_struct.c
  CC              dataloop_create_pairtype.c
  CC              subarray_support.c
  CC              darray_support.c
  AR cr ../../../../../lib/libmpich.a dataloop.o segment.o segment_packunpack.o segment_flatten.o segment_count.o dataloop_create.o dataloop_create_contig.o dataloop_create_vector.o dataloop_create_blockindexed.o dataloop_create_indexed.o dataloop_create_struct.o dataloop_create_pairtype.o subarray_support.o darray_support.o
  RANLIB          libmpich.a
date > .libstamp0
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype/dataloop'
make all-local
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype'
  CC              mpid_type_debug.c
  CC              mpid_segment.c
  CC              mpid_ext32_segment.c
  CC              mpid_ext32_datatype.c
  CC              mpid_type_dup.c
  CC              mpir_type_get_contig_blocks.c
  CC              mpir_type_flatten.c
  CC              mpid_type_commit.c
  CC              mpid_type_zerolen.c
  CC              mpid_type_vector.c
  CC              mpid_type_contiguous.c
  CC              mpid_type_create_resized.c
  CC              mpid_type_blockindexed.c
  CC              mpid_type_indexed.c
  CC              mpid_type_struct.c
  CC              mpid_type_get_envelope.c
  CC              mpid_datatype_free.c
  CC              mpid_datatype_contents.c
  CC              mpid_type_get_contents.c
  CC              mpid_type_create_pairtype.c
  CC              mpid_contents_support.c
  AR cr ../../../../lib/libmpich.a mpid_type_debug.o mpid_segment.o mpid_ext32_segment.o mpid_ext32_datatype.o mpid_type_dup.o mpir_type_get_contig_blocks.o mpir_type_flatten.o mpid_type_commit.o mpid_type_zerolen.o mpid_type_vector.o mpid_type_contiguous.o mpid_type_create_resized.o mpid_type_blockindexed.o mpid_type_indexed.o mpid_type_struct.o mpid_type_get_envelope.o mpid_datatype_free.o mpid_datatype_contents.o mpid_type_get_contents.o mpid_type_create_pairtype.o mpid_contents_support.o
  RANLIB          libmpich.a
date > .libstamp0
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/src'
  CC              mpid_nem_alloc.c
  CC              mpid_nem_init.c
  CC              mpid_nem_queue.c
  CC              mpid_nem_barrier.c
  CC              mpid_nem_mpich2.c
  CC              mpid_nem_ckpt.c
  CC              mpid_nem_finalize.c
  CC              mpid_nem_network_poll.c
  CC              mpid_nem_network.c
  CC              mpid_nem_debug.c
  CC              mpid_nem_lmt.c
  CC              mpid_nem_lmt_shm.c
  CC              mpid_nem_net_array.c
  CC              mpid_nem_lmt_dma.c
  CC              mpid_nem_lmt_vmsplice.c
  AR cr ../../../../../../../lib/libmpich.a mpid_nem_alloc.o mpid_nem_init.o mpid_nem_queue.o mpid_nem_barrier.o mpid_nem_mpich2.o mpid_nem_ckpt.o mpid_nem_finalize.o mpid_nem_network_poll.o mpid_nem_network.o mpid_nem_debug.o mpid_nem_lmt.o mpid_nem_lmt_shm.o mpid_nem_net_array.o mpid_nem_lmt_dma.o mpid_nem_lmt_vmsplice.o
  RANLIB          libmpich.a
date > .libstamp0
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/src'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
  CC              tcp_finalize.c
  CC              tcp_init.c
  CC              tcp_send.c
  CC              tcp_utility.c
  CC              socksm.c
  CC              tcp_getip.c
  CC              tcp_ckpt.c
  AR cr ../../../../../../../../lib/libmpich.a tcp_finalize.o tcp_init.o tcp_send.o tcp_utility.o socksm.o tcp_getip.o tcp_ckpt.o
  RANLIB          libmpich.a
date > .libstamp0
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
  CC              papi_defs.c
  AR cr ../../../../../../../../lib/libmpich.a papi_defs.o
  RANLIB          libmpich.a
date > .libstamp0
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
  CC              mkstemp.c
  AR cr ../../../../../../../../lib/libmpich.a mkstemp.o
  RANLIB          libmpich.a
date > .libstamp0
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/src'
  CC              ch3_finalize.c
  CC              ch3_init.c
  CC              ch3_isend.c
  CC              ch3_isendv.c
  CC              ch3_istartmsg.c
  CC              ch3_istartmsgv.c
  CC              ch3_progress.c
  CC              ch3_abort.c
  CC              ch3i_comm.c
  CC              ch3i_eagernoncontig.c
  AR cr ../../../../../../lib/libmpich.a ch3_finalize.o ch3_init.o ch3_isend.o ch3_isendv.o ch3_istartmsg.o ch3_istartmsgv.o ch3_progress.o ch3_abort.o ch3i_comm.o ch3i_eagernoncontig.o
  RANLIB          libmpich.a
date > .libstamp0
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/src'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/src'
  CC              ch3u_buffer.c
  CC              ch3u_comm_spawn_multiple.c
  CC              ch3u_handle_connection.c
  CC              ch3u_handle_recv_pkt.c
  CC              ch3u_handle_recv_req.c
  CC              ch3u_handle_send_req.c
  CC              ch3u_port.c
  CC              ch3u_recvq.c
  CC              ch3u_request.c
  CC              ch3u_rma_ops.c
  CC              ch3u_rma_sync.c
  CC              ch3u_rndv.c
  CC              ch3u_eager.c
  CC              ch3u_eagersync.c
  CC              mpid_abort.c
  CC              mpid_cancel_recv.c
  CC              mpid_cancel_send.c
  CC              mpid_comm_disconnect.c
  CC              mpid_comm_spawn_multiple.c
  CC              mpid_finalize.c
  CC              mpid_get_universe_size.c
  CC              mpid_getpname.c
  CC              mpid_init.c
  CC              mpid_iprobe.c
  CC              mpid_irecv.c
  CC              mpid_irsend.c
  CC              mpid_isend.c
  CC              mpid_issend.c
  CC              mpid_port.c
  CC              mpid_probe.c
  CC              mpid_recv.c
  CC              mpid_rsend.c
  CC              mpid_send.c
  CC              mpid_ssend.c
  CC              mpid_startall.c
  CC              mpid_vc.c
  CC              mpid_rma.c
  CC              mpidi_isend_self.c
  CC              mpidi_pg.c
  CC              mpidi_printf.c
  AR cr ../../../../lib/libmpich.a ch3u_buffer.o ch3u_comm_spawn_multiple.o ch3u_handle_connection.o ch3u_handle_recv_pkt.o ch3u_handle_recv_req.o ch3u_handle_send_req.o ch3u_port.o ch3u_recvq.o ch3u_request.o ch3u_rma_ops.o ch3u_rma_sync.o ch3u_rndv.o ch3u_eager.o ch3u_eagersync.o mpid_abort.o mpid_cancel_recv.o mpid_cancel_send.o mpid_comm_disconnect.o mpid_comm_spawn_multiple.o mpid_finalize.o mpid_get_universe_size.o mpid_getpname.o mpid_init.o mpid_iprobe.o mpid_irecv.o mpid_irsend.o mpid_isend.o mpid_issend.o mpid_port.o mpid_probe.o mpid_recv.o mpid_rsend.o mpid_send.o mpid_ssend.o mpid_startall.o mpid_vc.o mpid_rma.o mpidi_isend_self.o mpidi_pg.o mpidi_printf.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/src'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/util'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/util'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/attr'
  CC              attr_delete.c
  CC              attr_get.c
  CC              attr_put.c
  CC              comm_create_keyval.c
  CC              comm_delete_attr.c
  CC              comm_free_keyval.c
  CC              comm_get_attr.c
  CC              comm_set_attr.c
  CC              keyval_create.c
  CC              keyval_free.c
  CC              type_create_keyval.c
  CC              type_delete_attr.c
  CC              type_free_keyval.c
  CC              type_get_attr.c
  CC              type_set_attr.c
  CC              win_create_keyval.c
  CC              win_delete_attr.c
  CC              win_free_keyval.c
  CC              win_get_attr.c
  CC              win_set_attr.c
  CC              attrutil.c
  CC              dup_fn.c
  AR cr ../../../lib/libmpich.a attr_delete.o attr_get.o attr_put.o comm_create_keyval.o comm_delete_attr.o comm_free_keyval.o comm_get_attr.o comm_set_attr.o keyval_create.o keyval_free.o type_create_keyval.o type_delete_attr.o type_free_keyval.o type_get_attr.o type_set_attr.o win_create_keyval.o win_delete_attr.o win_free_keyval.o win_get_attr.o win_set_attr.o attrutil.o dup_fn.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/attr'
  CC             -D<profiling> ./attr_delete.c
  CC             -D<profiling> ./attr_get.c
  CC             -D<profiling> ./attr_put.c
  CC             -D<profiling> ./comm_create_keyval.c
  CC             -D<profiling> ./comm_delete_attr.c
  CC             -D<profiling> ./comm_free_keyval.c
  CC             -D<profiling> ./comm_get_attr.c
  CC             -D<profiling> ./comm_set_attr.c
  CC             -D<profiling> ./keyval_create.c
  CC             -D<profiling> ./keyval_free.c
  CC             -D<profiling> ./type_create_keyval.c
  CC             -D<profiling> ./type_delete_attr.c
  CC             -D<profiling> ./type_free_keyval.c
  CC             -D<profiling> ./type_get_attr.c
  CC             -D<profiling> ./type_set_attr.c
  CC             -D<profiling> ./win_create_keyval.c
  CC             -D<profiling> ./win_delete_attr.c
  CC             -D<profiling> ./win_free_keyval.c
  CC             -D<profiling> ./win_get_attr.c
  CC             -D<profiling> ./win_set_attr.c
  AR cr ../../../lib/libpmpich.a _attr_delete.o _attr_get.o _attr_put.o _comm_create_keyval.o _comm_delete_attr.o _comm_free_keyval.o _comm_get_attr.o _comm_set_attr.o _keyval_create.o _keyval_free.o _type_create_keyval.o _type_delete_attr.o _type_free_keyval.o _type_get_attr.o _type_set_attr.o _win_create_keyval.o _win_delete_attr.o _win_free_keyval.o _win_get_attr.o _win_set_attr.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/attr'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/attr'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/coll'
  CC              allreduce.c
  CC              barrier.c
  CC              op_create.c
  CC              op_free.c
  CC              bcast.c
  CC              alltoall.c
  CC              alltoallv.c
  CC              reduce.c
  CC              scatter.c
  CC              gather.c
  CC              scatterv.c
  CC              gatherv.c
  CC              scan.c
  CC              exscan.c
  CC              allgather.c
  CC              allgatherv.c
  CC              red_scat.c
  CC              alltoallw.c
  CC              reduce_local.c
  CC              op_commutative.c
  CC              red_scat_block.c
  CC              helper_fns.c
  CC              opsum.c
  CC              opmax.c
  CC              opmin.c
  CC              opband.c
  CC              opbor.c
  CC              opbxor.c
  CC              opland.c
  CC              oplor.c
  CC              oplxor.c
  CC              opprod.c
  CC              opminloc.c
  CC              opmaxloc.c
  AR cr ../../../lib/libmpich.a allreduce.o barrier.o op_create.o op_free.o bcast.o alltoall.o alltoallv.o reduce.o scatter.o gather.o scatterv.o gatherv.o scan.o exscan.o allgather.o allgatherv.o red_scat.o alltoallw.o reduce_local.o op_commutative.o red_scat_block.o helper_fns.o opsum.o opmax.o opmin.o opband.o opbor.o opbxor.o opland.o oplor.o oplxor.o opprod.o opminloc.o opmaxloc.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/coll'
  CC             -D<profiling> ./allreduce.c
  CC             -D<profiling> ./barrier.c
  CC             -D<profiling> ./op_create.c
  CC             -D<profiling> ./op_free.c
  CC             -D<profiling> ./bcast.c
  CC             -D<profiling> ./alltoall.c
  CC             -D<profiling> ./alltoallv.c
  CC             -D<profiling> ./reduce.c
  CC             -D<profiling> ./scatter.c
  CC             -D<profiling> ./gather.c
  CC             -D<profiling> ./scatterv.c
  CC             -D<profiling> ./gatherv.c
  CC             -D<profiling> ./scan.c
  CC             -D<profiling> ./exscan.c
  CC             -D<profiling> ./allgather.c
  CC             -D<profiling> ./allgatherv.c
  CC             -D<profiling> ./red_scat.c
  CC             -D<profiling> ./alltoallw.c
  CC             -D<profiling> ./reduce_local.c
  CC             -D<profiling> ./op_commutative.c
  CC             -D<profiling> ./red_scat_block.c
  AR cr ../../../lib/libpmpich.a _allreduce.o _barrier.o _op_create.o _op_free.o _bcast.o _alltoall.o _alltoallv.o _reduce.o _scatter.o _gather.o _scatterv.o _gatherv.o _scan.o _exscan.o _allgather.o _allgatherv.o _red_scat.o _alltoallw.o _reduce_local.o _op_commutative.o _red_scat_block.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/coll'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/coll'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/comm'
  CC              comm_compare.c
  CC              comm_create.c
  CC              comm_dup.c
  CC              comm_free.c
  CC              comm_get_name.c
  CC              comm_group.c
  CC              comm_rank.c
  CC              comm_size.c
  CC              comm_remote_group.c
  CC              comm_remote_size.c
  CC              comm_set_name.c
  CC              comm_split.c
  CC              comm_test_inter.c
  CC              intercomm_create.c
  CC              intercomm_merge.c
  CC              commutil.c
  AR cr ../../../lib/libmpich.a comm_compare.o comm_create.o comm_dup.o comm_free.o comm_get_name.o comm_group.o comm_rank.o comm_size.o comm_remote_group.o comm_remote_size.o comm_set_name.o comm_split.o comm_test_inter.o intercomm_create.o intercomm_merge.o commutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/comm'
  CC             -D<profiling> ./comm_compare.c
  CC             -D<profiling> ./comm_create.c
  CC             -D<profiling> ./comm_dup.c
  CC             -D<profiling> ./comm_free.c
  CC             -D<profiling> ./comm_get_name.c
  CC             -D<profiling> ./comm_group.c
  CC             -D<profiling> ./comm_rank.c
  CC             -D<profiling> ./comm_size.c
  CC             -D<profiling> ./comm_remote_group.c
  CC             -D<profiling> ./comm_remote_size.c
  CC             -D<profiling> ./comm_set_name.c
  CC             -D<profiling> ./comm_split.c
  CC             -D<profiling> ./comm_test_inter.c
  CC             -D<profiling> ./intercomm_create.c
  CC             -D<profiling> ./intercomm_merge.c
  AR cr ../../../lib/libpmpich.a _comm_compare.o _comm_create.o _comm_dup.o _comm_free.o _comm_get_name.o _comm_group.o _comm_rank.o _comm_size.o _comm_remote_group.o _comm_remote_size.o _comm_set_name.o _comm_split.o _comm_test_inter.o _intercomm_create.o _intercomm_merge.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/comm'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/comm'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/datatype'
  CC              address.c
  CC              get_address.c
  CC              get_count.c
  CC              get_elements.c
  CC              pack.c
  CC              unpack.c
  CC              pack_size.c
  CC              status_set_elements.c
  CC              type_get_name.c
  CC              type_set_name.c
  CC              type_size.c
  CC              type_extent.c
  CC              type_vector.c
  CC              type_commit.c
  CC              type_indexed.c
  CC              type_hindexed.c
  CC              type_struct.c
  CC              type_contiguous.c
  CC              type_free.c
  CC              type_hvector.c
  CC              type_dup.c
  CC              type_get_envelope.c
  CC              type_get_contents.c
  CC              type_ub.c
  CC              type_lb.c
  CC              type_get_extent.c
  CC              type_get_true_extent.c
  CC              type_match_size.c
  CC              type_create_struct.c
  CC              type_create_hindexed.c
  CC              type_create_hvector.c
  CC              pack_external.c
  CC              pack_external_size.c
  CC              unpack_external.c
  CC              type_create_indexed_block.c
  CC              type_create_resized.c
  CC              type_create_darray.c
  CC              type_create_subarray.c
  CC              typeutil.c
  AR cr ../../../lib/libmpich.a address.o get_address.o get_count.o get_elements.o pack.o unpack.o pack_size.o status_set_elements.o type_get_name.o type_set_name.o type_size.o type_extent.o type_vector.o type_commit.o type_indexed.o type_hindexed.o type_struct.o type_contiguous.o type_free.o type_hvector.o type_dup.o type_get_envelope.o type_get_contents.o type_ub.o type_lb.o type_get_extent.o type_get_true_extent.o type_match_size.o type_create_struct.o type_create_hindexed.o type_create_hvector.o pack_external.o pack_external_size.o unpack_external.o type_create_indexed_block.o type_create_resized.o type_create_darray.o type_create_subarray.o typeutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/datatype'
  CC             -D<profiling> ./address.c
  CC             -D<profiling> ./get_address.c
  CC             -D<profiling> ./get_count.c
  CC             -D<profiling> ./get_elements.c
  CC             -D<profiling> ./pack.c
  CC             -D<profiling> ./unpack.c
  CC             -D<profiling> ./pack_size.c
  CC             -D<profiling> ./status_set_elements.c
  CC             -D<profiling> ./type_get_name.c
  CC             -D<profiling> ./type_set_name.c
  CC             -D<profiling> ./type_size.c
  CC             -D<profiling> ./type_extent.c
  CC             -D<profiling> ./type_vector.c
  CC             -D<profiling> ./type_commit.c
  CC             -D<profiling> ./type_indexed.c
  CC             -D<profiling> ./type_hindexed.c
  CC             -D<profiling> ./type_struct.c
  CC             -D<profiling> ./type_contiguous.c
  CC             -D<profiling> ./type_free.c
  CC             -D<profiling> ./type_hvector.c
  CC             -D<profiling> ./type_dup.c
  CC             -D<profiling> ./type_get_envelope.c
  CC             -D<profiling> ./type_get_contents.c
  CC             -D<profiling> ./type_ub.c
  CC             -D<profiling> ./type_lb.c
  CC             -D<profiling> ./type_get_extent.c
  CC             -D<profiling> ./type_get_true_extent.c
  CC             -D<profiling> ./type_match_size.c
  CC             -D<profiling> ./type_create_struct.c
  CC             -D<profiling> ./type_create_hindexed.c
  CC             -D<profiling> ./type_create_hvector.c
  CC             -D<profiling> ./pack_external.c
  CC             -D<profiling> ./pack_external_size.c
  CC             -D<profiling> ./unpack_external.c
  CC             -D<profiling> ./type_create_indexed_block.c
  CC             -D<profiling> ./type_create_resized.c
  CC             -D<profiling> ./type_create_darray.c
  CC             -D<profiling> ./type_create_subarray.c
  AR cr ../../../lib/libpmpich.a _address.o _get_address.o _get_count.o _get_elements.o _pack.o _unpack.o _pack_size.o _status_set_elements.o _type_get_name.o _type_set_name.o _type_size.o _type_extent.o _type_vector.o _type_commit.o _type_indexed.o _type_hindexed.o _type_struct.o _type_contiguous.o _type_free.o _type_hvector.o _type_dup.o _type_get_envelope.o _type_get_contents.o _type_ub.o _type_lb.o _type_get_extent.o _type_get_true_extent.o _type_match_size.o _type_create_struct.o _type_create_hindexed.o _type_create_hvector.o _pack_external.o _pack_external_size.o _unpack_external.o _type_create_indexed_block.o _type_create_resized.o _type_create_darray.o _type_create_subarray.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/datatype'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/datatype'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/errhan'
  CC              add_error_code.c
  CC              add_error_class.c
  CC              add_error_string.c
  CC              comm_call_errhandler.c
  CC              comm_create_errhandler.c
  CC              comm_get_errhandler.c
  CC              comm_set_errhandler.c
  CC              errhandler_create.c
  CC              errhandler_free.c
  CC              errhandler_get.c
  CC              errhandler_set.c
  CC              error_class.c
  CC              error_string.c
  CC              file_create_errhandler.c
  CC              file_get_errhandler.c
  CC              file_set_errhandler.c
  CC              file_call_errhandler.c
  CC              win_create_errhandler.c
  CC              win_call_errhandler.c
  CC              win_get_errhandler.c
  CC              win_set_errhandler.c
  CC              errutil.c
  CC              dynerrutil.c
  AR cr ../../../lib/libmpich.a add_error_code.o add_error_class.o add_error_string.o comm_call_errhandler.o comm_create_errhandler.o comm_get_errhandler.o comm_set_errhandler.o errhandler_create.o errhandler_free.o errhandler_get.o errhandler_set.o error_class.o error_string.o file_create_errhandler.o file_get_errhandler.o file_set_errhandler.o file_call_errhandler.o win_create_errhandler.o win_call_errhandler.o win_get_errhandler.o win_set_errhandler.o errutil.o dynerrutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/errhan'
  CC             -D<profiling> ./add_error_code.c
  CC             -D<profiling> ./add_error_class.c
  CC             -D<profiling> ./add_error_string.c
  CC             -D<profiling> ./comm_call_errhandler.c
  CC             -D<profiling> ./comm_create_errhandler.c
  CC             -D<profiling> ./comm_get_errhandler.c
  CC             -D<profiling> ./comm_set_errhandler.c
  CC             -D<profiling> ./errhandler_create.c
  CC             -D<profiling> ./errhandler_free.c
  CC             -D<profiling> ./errhandler_get.c
  CC             -D<profiling> ./errhandler_set.c
  CC             -D<profiling> ./error_class.c
  CC             -D<profiling> ./error_string.c
  CC             -D<profiling> ./file_create_errhandler.c
  CC             -D<profiling> ./file_get_errhandler.c
  CC             -D<profiling> ./file_set_errhandler.c
  CC             -D<profiling> ./file_call_errhandler.c
  CC             -D<profiling> ./win_create_errhandler.c
  CC             -D<profiling> ./win_call_errhandler.c
  CC             -D<profiling> ./win_get_errhandler.c
  CC             -D<profiling> ./win_set_errhandler.c
  AR cr ../../../lib/libpmpich.a _add_error_code.o _add_error_class.o _add_error_string.o _comm_call_errhandler.o _comm_create_errhandler.o _comm_get_errhandler.o _comm_set_errhandler.o _errhandler_create.o _errhandler_free.o _errhandler_get.o _errhandler_set.o _error_class.o _error_string.o _file_create_errhandler.o _file_get_errhandler.o _file_set_errhandler.o _file_call_errhandler.o _win_create_errhandler.o _win_call_errhandler.o _win_get_errhandler.o _win_set_errhandler.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/errhan'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/errhan'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/group'
  CC              group_compare.c
  CC              group_difference.c
  CC              group_excl.c
  CC              group_free.c
  CC              group_incl.c
  CC              group_intersection.c
  CC              group_range_excl.c
  CC              group_range_incl.c
  CC              group_rank.c
  CC              group_size.c
  CC              group_translate_ranks.c
  CC              group_union.c
  CC              grouputil.c
  AR cr ../../../lib/libmpich.a group_compare.o group_difference.o group_excl.o group_free.o group_incl.o group_intersection.o group_range_excl.o group_range_incl.o group_rank.o group_size.o group_translate_ranks.o group_union.o grouputil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/group'
  CC             -D<profiling> ./group_compare.c
  CC             -D<profiling> ./group_difference.c
  CC             -D<profiling> ./group_excl.c
  CC             -D<profiling> ./group_free.c
  CC             -D<profiling> ./group_incl.c
  CC             -D<profiling> ./group_intersection.c
  CC             -D<profiling> ./group_range_excl.c
  CC             -D<profiling> ./group_range_incl.c
  CC             -D<profiling> ./group_rank.c
  CC             -D<profiling> ./group_size.c
  CC             -D<profiling> ./group_translate_ranks.c
  CC             -D<profiling> ./group_union.c
  AR cr ../../../lib/libpmpich.a _group_compare.o _group_difference.o _group_excl.o _group_free.o _group_incl.o _group_intersection.o _group_range_excl.o _group_range_incl.o _group_rank.o _group_size.o _group_translate_ranks.o _group_union.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/group'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/group'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/init'
  CC              abort.c
  CC              init.c
  CC              initialized.c
  CC              initthread.c
  CC              ismain.c
  CC              finalize.c
  CC              finalized.c
  CC              querythread.c
  CC              initinfo.c
  CC              async.c
  AR cr ../../../lib/libmpich.a abort.o init.o initialized.o initthread.o ismain.o finalize.o finalized.o querythread.o initinfo.o async.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/init'
  CC             -D<profiling> ./abort.c
  CC             -D<profiling> ./init.c
  CC             -D<profiling> ./initialized.c
  CC             -D<profiling> ./initthread.c
  CC             -D<profiling> ./ismain.c
  CC             -D<profiling> ./finalize.c
  CC             -D<profiling> ./finalized.c
  CC             -D<profiling> ./querythread.c
  AR cr ../../../lib/libpmpich.a _abort.o _init.o _initialized.o _initthread.o _ismain.o _finalize.o _finalized.o _querythread.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/init'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/init'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/misc'
  CC              getpname.c
  CC              pcontrol.c
  CC              version.c
  AR cr ../../../lib/libmpich.a getpname.o pcontrol.o version.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/misc'
  CC             -D<profiling> ./getpname.c
  CC             -D<profiling> ./pcontrol.c
  CC             -D<profiling> ./version.c
  AR cr ../../../lib/libpmpich.a _getpname.o _pcontrol.o _version.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/misc'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/misc'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/pt2pt'
  CC              bsend.c
  CC              bsend_init.c
  CC              bufattach.c
  CC              buffree.c
  CC              cancel.c
  CC              greq_start.c
  CC              greq_complete.c
  CC              ibsend.c
  CC              iprobe.c
  CC              irecv.c
  CC              irsend.c
  CC              isend.c
  CC              issend.c
  CC              probe.c
  CC              recv.c
  CC              recv_init.c
  CC              request_free.c
  CC              request_get_status.c
  CC              rsend.c
  CC              rsend_init.c
  CC              send.c
  CC              send_init.c
  CC              sendrecv.c
  CC              sendrecv_rep.c
  CC              status_set_cancelled.c
  CC              ssend.c
  CC              ssend_init.c
  CC              start.c
  CC              startall.c
  CC              test.c
  CC              test_cancelled.c
  CC              testall.c
  CC              testany.c
  CC              testsome.c
  CC              wait.c
  CC              waitall.c
  CC              waitany.c
  CC              waitsome.c
  CC              bsendutil.c
  CC              mpir_request.c
  AR cr ../../../lib/libmpich.a bsend.o bsend_init.o bufattach.o buffree.o cancel.o greq_start.o greq_complete.o ibsend.o iprobe.o irecv.o irsend.o isend.o issend.o probe.o recv.o recv_init.o request_free.o request_get_status.o rsend.o rsend_init.o send.o send_init.o sendrecv.o sendrecv_rep.o status_set_cancelled.o ssend.o ssend_init.o start.o startall.o test.o test_cancelled.o testall.o testany.o testsome.o wait.o waitall.o waitany.o waitsome.o bsendutil.o mpir_request.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/pt2pt'
  CC             -D<profiling> ./bsend.c
  CC             -D<profiling> ./bsend_init.c
  CC             -D<profiling> ./bufattach.c
  CC             -D<profiling> ./buffree.c
  CC             -D<profiling> ./cancel.c
  CC             -D<profiling> ./greq_start.c
  CC             -D<profiling> ./greq_complete.c
  CC             -D<profiling> ./ibsend.c
  CC             -D<profiling> ./iprobe.c
  CC             -D<profiling> ./irecv.c
  CC             -D<profiling> ./irsend.c
  CC             -D<profiling> ./isend.c
  CC             -D<profiling> ./issend.c
  CC             -D<profiling> ./probe.c
  CC             -D<profiling> ./recv.c
  CC             -D<profiling> ./recv_init.c
  CC             -D<profiling> ./request_free.c
  CC             -D<profiling> ./request_get_status.c
  CC             -D<profiling> ./rsend.c
  CC             -D<profiling> ./rsend_init.c
  CC             -D<profiling> ./send.c
  CC             -D<profiling> ./send_init.c
  CC             -D<profiling> ./sendrecv.c
  CC             -D<profiling> ./sendrecv_rep.c
  CC             -D<profiling> ./status_set_cancelled.c
  CC             -D<profiling> ./ssend.c
  CC             -D<profiling> ./ssend_init.c
  CC             -D<profiling> ./start.c
  CC             -D<profiling> ./startall.c
  CC             -D<profiling> ./test.c
  CC             -D<profiling> ./test_cancelled.c
  CC             -D<profiling> ./testall.c
  CC             -D<profiling> ./testany.c
  CC             -D<profiling> ./testsome.c
  CC             -D<profiling> ./wait.c
  CC             -D<profiling> ./waitall.c
  CC             -D<profiling> ./waitany.c
  CC             -D<profiling> ./waitsome.c
  AR cr ../../../lib/libpmpich.a _bsend.o _bsend_init.o _bufattach.o _buffree.o _cancel.o _greq_start.o _greq_complete.o _ibsend.o _iprobe.o _irecv.o _irsend.o _isend.o _issend.o _probe.o _recv.o _recv_init.o _request_free.o _request_get_status.o _rsend.o _rsend_init.o _send.o _send_init.o _sendrecv.o _sendrecv_rep.o _status_set_cancelled.o _ssend.o _ssend_init.o _start.o _startall.o _test.o _test_cancelled.o _testall.o _testany.o _testsome.o _wait.o _waitall.o _waitany.o _waitsome.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/pt2pt'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/pt2pt'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/rma'
  CC              accumulate.c
  CC              alloc_mem.c
  CC              free_mem.c
  CC              get.c
  CC              put.c
  CC              win_complete.c
  CC              win_create.c
  CC              win_fence.c
  CC              win_free.c
  CC              win_get_group.c
  CC              win_get_name.c
  CC              win_lock.c
  CC              win_post.c
  CC              win_set_name.c
  CC              win_start.c
  CC              win_unlock.c
  CC              win_wait.c
  CC              win_test.c
  CC              winutil.c
  AR cr ../../../lib/libmpich.a accumulate.o alloc_mem.o free_mem.o get.o put.o win_complete.o win_create.o win_fence.o win_free.o win_get_group.o win_get_name.o win_lock.o win_post.o win_set_name.o win_start.o win_unlock.o win_wait.o win_test.o winutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/rma'
  CC             -D<profiling> ./accumulate.c
  CC             -D<profiling> ./alloc_mem.c
  CC             -D<profiling> ./free_mem.c
  CC             -D<profiling> ./get.c
  CC             -D<profiling> ./put.c
  CC             -D<profiling> ./win_complete.c
  CC             -D<profiling> ./win_create.c
  CC             -D<profiling> ./win_fence.c
  CC             -D<profiling> ./win_free.c
  CC             -D<profiling> ./win_get_group.c
  CC             -D<profiling> ./win_get_name.c
  CC             -D<profiling> ./win_lock.c
  CC             -D<profiling> ./win_post.c
  CC             -D<profiling> ./win_set_name.c
  CC             -D<profiling> ./win_start.c
  CC             -D<profiling> ./win_unlock.c
  CC             -D<profiling> ./win_wait.c
  CC             -D<profiling> ./win_test.c
  AR cr ../../../lib/libpmpich.a _accumulate.o _alloc_mem.o _free_mem.o _get.o _put.o _win_complete.o _win_create.o _win_fence.o _win_free.o _win_get_group.o _win_get_name.o _win_lock.o _win_post.o _win_set_name.o _win_start.o _win_unlock.o _win_wait.o _win_test.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/rma'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/rma'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/spawn'
  CC              comm_disconnect.c
  CC              comm_get_parent.c
  CC              comm_join.c
  CC              comm_spawn.c
  CC              comm_spawn_multiple.c
  CC              lookup_name.c
  CC              publish_name.c
  CC              unpublish_name.c
  CC              open_port.c
  CC              close_port.c
  CC              comm_connect.c
  CC              comm_accept.c
  AR cr ../../../lib/libmpich.a comm_disconnect.o comm_get_parent.o comm_join.o comm_spawn.o comm_spawn_multiple.o lookup_name.o publish_name.o unpublish_name.o open_port.o close_port.o comm_connect.o comm_accept.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/spawn'
  CC             -D<profiling> ./comm_disconnect.c
  CC             -D<profiling> ./comm_get_parent.c
  CC             -D<profiling> ./comm_join.c
  CC             -D<profiling> ./comm_spawn.c
  CC             -D<profiling> ./comm_spawn_multiple.c
  CC             -D<profiling> ./lookup_name.c
  CC             -D<profiling> ./publish_name.c
  CC             -D<profiling> ./unpublish_name.c
  CC             -D<profiling> ./open_port.c
  CC             -D<profiling> ./close_port.c
  CC             -D<profiling> ./comm_connect.c
  CC             -D<profiling> ./comm_accept.c
  AR cr ../../../lib/libpmpich.a _comm_disconnect.o _comm_get_parent.o _comm_join.o _comm_spawn.o _comm_spawn_multiple.o _lookup_name.o _publish_name.o _unpublish_name.o _open_port.o _close_port.o _comm_connect.o _comm_accept.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/spawn'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/spawn'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/timer'
  CC              wtime.c
  CC              wtick.c
  CC              mpidtime.c
  AR cr ../../../lib/libmpich.a wtime.o wtick.o mpidtime.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/timer'
  CC             -D<profiling> ./wtime.c
  CC             -D<profiling> ./wtick.c
  AR cr ../../../lib/libpmpich.a _wtime.o _wtick.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/timer'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/timer'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/topo'
  CC              cart_coords.c
  CC              cart_create.c
  CC              cart_get.c
  CC              cart_map.c
  CC              cart_rank.c
  CC              cart_shift.c
  CC              cart_sub.c
  CC              dims_create.c
  CC              graph_get.c
  CC              graph_map.c
  CC              graph_nbr.c
  CC              graphcreate.c
  CC              graphdimsget.c
  CC              graphnbrcnt.c
  CC              cartdim_get.c
  CC              topo_test.c
  CC              dist_gr_create_adj.c
  CC              dist_gr_create.c
  CC              dist_gr_neighb_count.c
  CC              dist_gr_neighb.c
  CC              topoutil.c
  AR cr ../../../lib/libmpich.a cart_coords.o cart_create.o cart_get.o cart_map.o cart_rank.o cart_shift.o cart_sub.o dims_create.o graph_get.o graph_map.o graph_nbr.o graphcreate.o graphdimsget.o graphnbrcnt.o cartdim_get.o topo_test.o dist_gr_create_adj.o dist_gr_create.o dist_gr_neighb_count.o dist_gr_neighb.o topoutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/topo'
  CC             -D<profiling> ./cart_coords.c
  CC             -D<profiling> ./cart_create.c
  CC             -D<profiling> ./cart_get.c
  CC             -D<profiling> ./cart_map.c
  CC             -D<profiling> ./cart_rank.c
  CC             -D<profiling> ./cart_shift.c
  CC             -D<profiling> ./cart_sub.c
  CC             -D<profiling> ./dims_create.c
  CC             -D<profiling> ./graph_get.c
  CC             -D<profiling> ./graph_map.c
  CC             -D<profiling> ./graph_nbr.c
  CC             -D<profiling> ./graphcreate.c
  CC             -D<profiling> ./graphdimsget.c
  CC             -D<profiling> ./graphnbrcnt.c
  CC             -D<profiling> ./cartdim_get.c
  CC             -D<profiling> ./topo_test.c
  CC             -D<profiling> ./dist_gr_create_adj.c
  CC             -D<profiling> ./dist_gr_create.c
  CC             -D<profiling> ./dist_gr_neighb_count.c
  CC             -D<profiling> ./dist_gr_neighb.c
  AR cr ../../../lib/libpmpich.a _cart_coords.o _cart_create.o _cart_get.o _cart_map.o _cart_rank.o _cart_shift.o _cart_sub.o _dims_create.o _graph_get.o _graph_map.o _graph_nbr.o _graphcreate.o _graphdimsget.o _graphnbrcnt.o _cartdim_get.o _topo_test.o _dist_gr_create_adj.o _dist_gr_create.o _dist_gr_neighb_count.o _dist_gr_neighb.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/topo'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/topo'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio'
make mpiolib
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio'
compiling ROMIO in directory mpi-io
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io'
  CC              close.c
  CC              read.c
  CC              open.c
  CC              write.c
  CC              set_view.c
  CC              iread.c
  CC              iwrite.c
  CC              seek.c
  CC              get_posn.c
  CC              delete.c
  CC              read_all.c
  CC              read_at.c
  CC              read_atall.c
  CC              iread_at.c
  CC              iwrite_at.c
  CC              write_all.c
  CC              get_bytoff.c
  CC              write_at.c
  CC              write_atall.c
  CC              get_view.c
  CC              get_group.c
  CC              get_amode.c
  CC              get_extent.c
  CC              fsync.c
  CC              get_atom.c
  CC              set_atom.c
  CC              set_size.c
  CC              get_size.c
  CC              prealloc.c
  CC              file_f2c.c
  CC              file_c2f.c
  CC              set_info.c
  CC              get_info.c
  CC              rd_atallb.c
  CC              rd_atalle.c
  CC              read_allb.c
  CC              read_alle.c
  CC              wr_atallb.c
  CC              wr_atalle.c
  CC              write_allb.c
  CC              write_alle.c
  CC              get_posn_sh.c
  CC              iread_sh.c
  CC              read_sh.c
  CC              write_sh.c
  CC              iwrite_sh.c
  CC              seek_sh.c
  CC              read_ord.c
  CC              read_orde.c
  CC              write_ordb.c
  CC              read_ordb.c
  CC              write_ord.c
  CC              write_orde.c
  CC              mpiu_greq.c
  CC              mpich2_fileutil.c
  CC              register_datarep.c
  CC              mpir-mpioinit.c
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpich.a close.o read.o open.o write.o set_view.o iread.o iwrite.o seek.o get_posn.o delete.o read_all.o read_at.o read_atall.o iread_at.o iwrite_at.o write_all.o get_bytoff.o write_at.o write_atall.o get_view.o get_group.o get_amode.o get_extent.o fsync.o get_atom.o set_atom.o set_size.o get_size.o prealloc.o file_f2c.o file_c2f.o set_info.o get_info.o rd_atallb.o rd_atalle.o read_allb.o read_alle.o wr_atallb.o wr_atalle.o write_allb.o write_alle.o get_posn_sh.o iread_sh.o read_sh.o write_sh.o iwrite_sh.o seek_sh.o read_ord.o read_orde.o write_ordb.o read_ordb.o write_ord.o write_orde.o mpiu_greq.o mpich2_fileutil.o register_datarep.o mpir-mpioinit.o
ranlib /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpich.a
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io'
compiling ROMIO in directory adio/common
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/adio/common'
  CC              ad_close.c
  CC              ad_init.c
  CC              ad_end.c
  CC              ad_open.c
  CC              flatten.c
  CC              malloc.c
  CC              ad_read_coll.c
  CC              eof_offset.c
  CC              ad_write_coll.c
  CC              lock.c
  CC              ad_read_str.c
  CC              ad_write_str.c
  CC              iscontig.c
  CC              get_fp_posn.c
  CC              ad_seek.c
  CC              ad_delete.c
  CC              ad_flush.c
  CC              ad_hints.c
  CC              error.c
  CC              ad_fstype.c
  CC              ad_get_sh_fp.c
  CC              ad_set_sh_fp.c
  CC              shfp_fname.c
  CC              byte_offset.c
  CC              status_setb.c
  CC              ad_aggregate.c
  CC              cb_config_list.c
  CC              ad_read_str_naive.c
  CC              ad_set_view.c
  CC              ad_iopen.c
  CC              ad_write_str_naive.c
  CC              ad_resize.c
  CC              ad_read.c
  CC              ad_write.c
  CC              ad_iread.c
  CC              ad_iwrite.c
  CC              ad_done.c
  CC              ad_wait.c
  CC              adi_close.c
  CC              ad_prealloc.c
  CC              ad_fcntl.c
  CC              ad_iread_fake.c
  CC              ad_iwrite_fake.c
  CC              ad_done_fake.c
  CC              ad_wait_fake.c
  CC              ad_subarray.c
  CC              ad_darray.c
  CC              strfns.c
  CC              greq_fns.c
  CC              system_hints.c
  CC              ad_write_nolock.c
  CC              ad_coll_exch_new.c
  CC              ad_coll_build_req_new.c
  CC              ad_io_coll.c
  CC              ad_aggregate_new.c
  CC              heap-sort.c
  CC              ad_opencoll.c
  CC              ad_opencoll_scalable.c
  CC              ad_opencoll_failsafe.c
  CC              ad_features.c
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpich.a ad_close.o ad_init.o ad_end.o ad_open.o flatten.o malloc.o ad_read_coll.o eof_offset.o ad_write_coll.o lock.o ad_read_str.o ad_write_str.o iscontig.o get_fp_posn.o ad_seek.o ad_delete.o ad_flush.o ad_hints.o error.o ad_fstype.o ad_get_sh_fp.o ad_set_sh_fp.o shfp_fname.o byte_offset.o status_setb.o ad_aggregate.o cb_config_list.o ad_read_str_naive.o ad_set_view.o ad_iopen.o ad_write_str_naive.o ad_resize.o ad_read.o ad_write.o ad_iread.o ad_iwrite.o ad_done.o ad_wait.o adi_close.o ad_prealloc.o ad_fcntl.o ad_iread_fake.o ad_iwrite_fake.o ad_done_fake.o ad_wait_fake.o ad_subarray.o ad_darray.o strfns.o greq_fns.o system_hints.o ad_write_nolock.o ad_coll_exch_new.o ad_coll_build_req_new.o ad_io_coll.o ad_aggregate_new.o heap-sort.o ad_opencoll.o ad_opencoll_scalable.o ad_opencoll_failsafe.o ad_features.o
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/adio/common'
compiling ROMIO in directory mpi-io/glue/mpich2
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/glue/mpich2'
  CC              mpio_file.c
  CC              mpio_err.c
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpich.a mpio_file.o mpio_err.o
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/glue/mpich2'
compiling ROMIO in directory adio/ad_testfs
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/adio/ad_testfs'
  CC              ad_testfs_close.c
  CC              ad_testfs_read.c
  CC              ad_testfs_rdcoll.c
  CC              ad_testfs_wrcoll.c
  CC              ad_testfs_open.c
  CC              ad_testfs_write.c
  CC              ad_testfs_done.c
  CC              ad_testfs_fcntl.c
  CC              ad_testfs_iread.c
  CC              ad_testfs_iwrite.c
  CC              ad_testfs_wait.c
  CC              ad_testfs_flush.c
  CC              ad_testfs_seek.c
  CC              ad_testfs_resize.c
  CC              ad_testfs_hints.c
  CC              ad_testfs_delete.c
  CC              ad_testfs.c
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpich.a ad_testfs_close.o ad_testfs_read.o ad_testfs_rdcoll.o ad_testfs_wrcoll.o ad_testfs_open.o ad_testfs_write.o ad_testfs_done.o ad_testfs_fcntl.o ad_testfs_iread.o ad_testfs_iwrite.o ad_testfs_wait.o ad_testfs_flush.o ad_testfs_seek.o ad_testfs_resize.o ad_testfs_hints.o ad_testfs_delete.o ad_testfs.o
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/adio/ad_testfs'
compiling ROMIO in directory adio/ad_ufs
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/adio/ad_ufs'
  CC              ad_ufs_open.c
  CC              ad_ufs.c
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpich.a ad_ufs_open.o ad_ufs.o
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/adio/ad_ufs'
compiling ROMIO in directory adio/ad_nfs
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/adio/ad_nfs'
  CC              ad_nfs_read.c
  CC              ad_nfs_open.c
  CC              ad_nfs_write.c
  CC              ad_nfs_done.c
  CC              ad_nfs_fcntl.c
  CC              ad_nfs_iread.c
  CC              ad_nfs_iwrite.c
  CC              ad_nfs_wait.c
  CC              ad_nfs_setsh.c
  CC              ad_nfs_getsh.c
  CC              ad_nfs.c
  CC              ad_nfs_resize.c
  CC              ad_nfs_features.c
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpich.a ad_nfs_read.o ad_nfs_open.o ad_nfs_write.o ad_nfs_done.o ad_nfs_fcntl.o ad_nfs_iread.o ad_nfs_iwrite.o ad_nfs_wait.o ad_nfs_setsh.o ad_nfs_getsh.o ad_nfs.o ad_nfs_resize.o ad_nfs_features.o
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/adio/ad_nfs'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio'
building profiling interface in directory mpi-io
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/close.c -o _close.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/read.c -o _read.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/open.c -o _open.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/get_extent.c -o _get_extent.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/write.c -o _write.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/set_view.c -o _set_view.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/seek.c -o _seek.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/read_at.c -o _read_at.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/prealloc.c -o _prealloc.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/iread.c -o _iread.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/iwrite.c -o _iwrite.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/get_posn.c -o _get_posn.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/delete.c -o _delete.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/read_all.c -o _read_all.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/get_bytoff.c -o _get_bytoff.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/read_atall.c -o _read_atall.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/iread_at.c -o _iread_at.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/iwrite_at.c -o _iwrite_at.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/get_group.c -o _get_group.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/get_amode.c -o _get_amode.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/write_all.c -o _write_all.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/write_at.c -o _write_at.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/write_atall.c -o _write_atall.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/get_view.c -o _get_view.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/fsync.c -o _fsync.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/get_atom.c -o _get_atom.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/set_atom.c -o _set_atom.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/set_size.c -o _set_size.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/get_size.c -o _get_size.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/file_f2c.c -o _file_f2c.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/file_c2f.c -o _file_c2f.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/set_info.c -o _set_info.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/get_info.c -o _get_info.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/rd_atallb.c -o _rd_atallb.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/rd_atalle.c -o _rd_atalle.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/read_allb.c -o _read_allb.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/read_alle.c -o _read_alle.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/wr_atallb.c -o _wr_atallb.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/wr_atalle.c -o _wr_atalle.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/write_allb.c -o _write_allb.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/write_alle.c -o _write_alle.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/get_posn_sh.c -o _get_posn_sh.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/iread_sh.c -o _iread_sh.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/read_sh.c -o _read_sh.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/write_sh.c -o _write_sh.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/iwrite_sh.c -o _iwrite_sh.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/seek_sh.c -o _seek_sh.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/read_ord.c -o _read_ord.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/read_orde.c -o _read_orde.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/write_ordb.c -o _write_ordb.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/read_ordb.c -o _read_ordb.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/write_ord.c -o _write_ord.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/write_orde.c -o _write_orde.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4.1/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io/register_datarep.c -o _register_datarep.o
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpich.a _close.o _read.o _open.o _get_extent.o _write.o _set_view.o _seek.o _read_at.o _prealloc.o _iread.o _iwrite.o _get_posn.o _delete.o _read_all.o _get_bytoff.o _read_atall.o _iread_at.o _iwrite_at.o _get_group.o _get_amode.o _write_all.o _write_at.o _write_atall.o _get_view.o _fsync.o _get_atom.o _set_atom.o _set_size.o _get_size.o _file_f2c.o _file_c2f.o _set_info.o _get_info.o _rd_atallb.o _rd_atalle.o _read_allb.o _read_alle.o _wr_atallb.o _wr_atalle.o _write_allb.o _write_alle.o _get_posn_sh.o _iread_sh.o _read_sh.o _write_sh.o _iwrite_sh.o _seek_sh.o _read_ord.o _read_orde.o _write_ordb.o _read_ordb.o _write_ord.o _write_orde.o _register_datarep.o
ranlib /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpich.a
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio/mpi-io'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi/romio'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpi'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpix'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpix/comm'
  CC              group_comm.c
  AR cr ../../../lib/libmpich.a group_comm.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpix/comm'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpix'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/mem'
  CC              trmem.c
  CC              handlemem.c
  CC              safestr.c
  CC              argstr.c
  CC              strerror.c
  AR cr ../../../lib/libmpich.a trmem.o handlemem.o safestr.o argstr.o strerror.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/mem'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/info'
  CC              infoutil.c
  CC              info_create.c
  CC              info_delete.c
  CC              info_dup.c
  CC              info_free.c
  CC              info_get.c
  CC              info_getn.c
  CC              info_getnth.c
  CC              info_getvallen.c
  CC              info_set.c
  AR cr ../../../lib/libmpich.a infoutil.o info_create.o info_delete.o info_dup.o info_free.o info_get.o info_getn.o info_getnth.o info_getvallen.o info_set.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/info'
  CC             -D<profiling> ./info_create.c
  CC             -D<profiling> ./info_delete.c
  CC             -D<profiling> ./info_dup.c
  CC             -D<profiling> ./info_free.c
  CC             -D<profiling> ./info_get.c
  CC             -D<profiling> ./info_getn.c
  CC             -D<profiling> ./info_getnth.c
  CC             -D<profiling> ./info_getvallen.c
  CC             -D<profiling> ./info_set.c
  AR cr ../../../lib/libpmpich.a _info_create.o _info_delete.o _info_dup.o _info_free.o _info_get.o _info_getn.o _info_getnth.o _info_getvallen.o _info_set.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/info'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/info'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/msgs'
  CC              msgprint.c
  AR cr ../../../lib/libmpich.a msgprint.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/msgs'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/instrm'
  CC              states.c
  CC              instr.c
  AR cr ../../../lib/libmpich.a states.o instr.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/instrm'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/thread'
  CC              mpiu_thread.c
  AR cr ../../../lib/libmpich.a mpiu_thread.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/thread'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/dbg'
  CC              dbg_printf.c
  CC              timelimit.c
  CC              exit.c
  AR cr ../../../lib/libmpich.a dbg_printf.o timelimit.o exit.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/dbg'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/param'
  CC              param_vals.c
  AR cr ../../../lib/libmpich.a param_vals.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/param'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/osserv'
  CC              dl.c
  AR cr ../../../lib/libmpich.a dl.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/osserv'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/procmap'
  CC              local_proc.c
  AR cr ../../../lib/libmpich.a local_proc.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/procmap'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/other'
  CC              outliers.c
  CC              assert.c
  AR cr ../../../lib/libmpich.a outliers.o assert.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util/other'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/util'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/nameserv'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/nameserv/file'
  CC              file_nameserv.c
  AR cr ../../../lib/libmpich.a file_nameserv.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/nameserv/file'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/nameserv'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f77'
  CC             -o _wsendf.o -c -D... ./sendf.c
  CC             -o _wrecvf.o -c -D... ./recvf.c
  CC             -o _wget_countf.o -c -D... ./get_countf.c
  CC             -o _wbsendf.o -c -D... ./bsendf.c
  CC             -o _wssendf.o -c -D... ./ssendf.c
  CC             -o _wrsendf.o -c -D... ./rsendf.c
  CC             -o _wbufattachf.o -c -D... ./bufattachf.c
  CC             -o _wbufdetachf.o -c -D... ./bufdetachf.c
  CC             -o _wisendf.o -c -D... ./isendf.c
  CC             -o _wibsendf.o -c -D... ./ibsendf.c
  CC             -o _wissendf.o -c -D... ./issendf.c
  CC             -o _wirsendf.o -c -D... ./irsendf.c
  CC             -o _wirecvf.o -c -D... ./irecvf.c
  CC             -o _wwaitf.o -c -D... ./waitf.c
  CC             -o _wtestf.o -c -D... ./testf.c
  CC             -o _wrequest_freef.o -c -D... ./request_freef.c
  CC             -o _wwaitanyf.o -c -D... ./waitanyf.c
  CC             -o _wtestanyf.o -c -D... ./testanyf.c
  CC             -o _wwaitallf.o -c -D... ./waitallf.c
  CC             -o _wtestallf.o -c -D... ./testallf.c
  CC             -o _wwaitsomef.o -c -D... ./waitsomef.c
  CC             -o _wtestsomef.o -c -D... ./testsomef.c
  CC             -o _wiprobef.o -c -D... ./iprobef.c
  CC             -o _wprobef.o -c -D... ./probef.c
  CC             -o _wcancelf.o -c -D... ./cancelf.c
  CC             -o _wtestcancelf.o -c -D... ./testcancelf.c
  CC             -o _wsend_initf.o -c -D... ./send_initf.c
  CC             -o _wbsend_initf.o -c -D... ./bsend_initf.c
  CC             -o _wssend_initf.o -c -D... ./ssend_initf.c
  CC             -o _wrsend_initf.o -c -D... ./rsend_initf.c
  CC             -o _wrecv_initf.o -c -D... ./recv_initf.c
  CC             -o _wstartf.o -c -D... ./startf.c
  CC             -o _wstartallf.o -c -D... ./startallf.c
  CC             -o _wsendrecvf.o -c -D... ./sendrecvf.c
  CC             -o _wsndrcvrplf.o -c -D... ./sndrcvrplf.c
  CC             -o _wtypecontigf.o -c -D... ./typecontigf.c
  CC             -o _wtype_vectorf.o -c -D... ./type_vectorf.c
  CC             -o _wtype_hvectorf.o -c -D... ./type_hvectorf.c
  CC             -o _wtype_indexedf.o -c -D... ./type_indexedf.c
  CC             -o _wtype_hindexedf.o -c -D... ./type_hindexedf.c
  CC             -o _wtype_structf.o -c -D... ./type_structf.c
  CC             -o _wtype_extentf.o -c -D... ./type_extentf.c
  CC             -o _wtype_sizef.o -c -D... ./type_sizef.c
  CC             -o _wtype_lbf.o -c -D... ./type_lbf.c
  CC             -o _wtype_ubf.o -c -D... ./type_ubf.c
  CC             -o _wtype_commitf.o -c -D... ./type_commitf.c
  CC             -o _wtype_freef.o -c -D... ./type_freef.c
  CC             -o _wget_elementsf.o -c -D... ./get_elementsf.c
  CC             -o _wpackf.o -c -D... ./packf.c
  CC             -o _wunpackf.o -c -D... ./unpackf.c
  CC             -o _wpack_sizef.o -c -D... ./pack_sizef.c
  CC             -o _wbarrierf.o -c -D... ./barrierf.c
  CC             -o _wbcastf.o -c -D... ./bcastf.c
  CC             -o _wgatherf.o -c -D... ./gatherf.c
  CC             -o _wgathervf.o -c -D... ./gathervf.c
  CC             -o _wscatterf.o -c -D... ./scatterf.c
  CC             -o _wscattervf.o -c -D... ./scattervf.c
  CC             -o _wallgatherf.o -c -D... ./allgatherf.c
  CC             -o _wallgathervf.o -c -D... ./allgathervf.c
  CC             -o _walltoallf.o -c -D... ./alltoallf.c
  CC             -o _walltoallvf.o -c -D... ./alltoallvf.c
  CC             -o _wreducef.o -c -D... ./reducef.c
  CC             -o _wop_createf.o -c -D... ./op_createf.c
  CC             -o _wop_freef.o -c -D... ./op_freef.c
  CC             -o _wallreducef.o -c -D... ./allreducef.c
  CC             -o _wredscatf.o -c -D... ./redscatf.c
  CC             -o _wscanf.o -c -D... ./scanf.c
  CC             -o _wgroup_sizef.o -c -D... ./group_sizef.c
  CC             -o _wgroup_rankf.o -c -D... ./group_rankf.c
  CC             -o _wgrouptranksf.o -c -D... ./grouptranksf.c
  CC             -o _wgroup_comparef.o -c -D... ./group_comparef.c
  CC             -o _wcomm_groupf.o -c -D... ./comm_groupf.c
  CC             -o _wgroup_unionf.o -c -D... ./group_unionf.c
  CC             -o _wgroupinterf.o -c -D... ./groupinterf.c
  CC             -o _wgroupdifff.o -c -D... ./groupdifff.c
  CC             -o _wgroup_inclf.o -c -D... ./group_inclf.c
  CC             -o _wgroup_exclf.o -c -D... ./group_exclf.c
  CC             -o _wgrouprinclf.o -c -D... ./grouprinclf.c
  CC             -o _wgrouprexclf.o -c -D... ./grouprexclf.c
  CC             -o _wgroup_freef.o -c -D... ./group_freef.c
  CC             -o _wcomm_sizef.o -c -D... ./comm_sizef.c
  CC             -o _wcomm_rankf.o -c -D... ./comm_rankf.c
  CC             -o _wcomm_comparef.o -c -D... ./comm_comparef.c
  CC             -o _wcomm_dupf.o -c -D... ./comm_dupf.c
  CC             -o _wcomm_createf.o -c -D... ./comm_createf.c
  CC             -o _wcomm_splitf.o -c -D... ./comm_splitf.c
  CC             -o _wcomm_freef.o -c -D... ./comm_freef.c
  CC             -o _wcommtesticf.o -c -D... ./commtesticf.c
  CC             -o _wcommrsizef.o -c -D... ./commrsizef.c
  CC             -o _wcommrgroupf.o -c -D... ./commrgroupf.c
  CC             -o _wiccreatef.o -c -D... ./iccreatef.c
  CC             -o _wicmergef.o -c -D... ./icmergef.c
  CC             -o _wkeyval_freef.o -c -D... ./keyval_freef.c
  CC             -o _wattr_putf.o -c -D... ./attr_putf.c
  CC             -o _wattr_getf.o -c -D... ./attr_getf.c
  CC             -o _wattr_deletef.o -c -D... ./attr_deletef.c
  CC             -o _wtopo_testf.o -c -D... ./topo_testf.c
  CC             -o _wcart_createf.o -c -D... ./cart_createf.c
  CC             -o _wdims_createf.o -c -D... ./dims_createf.c
  CC             -o _wgraph_createf.o -c -D... ./graph_createf.c
  CC             -o _wgraphdims_getf.o -c -D... ./graphdims_getf.c
  CC             -o _wgraph_getf.o -c -D... ./graph_getf.c
  CC             -o _wcartdim_getf.o -c -D... ./cartdim_getf.c
  CC             -o _wcart_getf.o -c -D... ./cart_getf.c
  CC             -o _wcart_rankf.o -c -D... ./cart_rankf.c
  CC             -o _wcart_coordsf.o -c -D... ./cart_coordsf.c
  CC             -o _wgrfnbcountf.o -c -D... ./grfnbcountf.c
  CC             -o _wgrfnbrsf.o -c -D... ./grfnbrsf.c
  CC             -o _wcart_shiftf.o -c -D... ./cart_shiftf.c
  CC             -o _wcart_subf.o -c -D... ./cart_subf.c
  CC             -o _wcart_mapf.o -c -D... ./cart_mapf.c
  CC             -o _wgraph_mapf.o -c -D... ./graph_mapf.c
  CC             -o _wgetpnamef.o -c -D... ./getpnamef.c
  CC             -o _wget_versionf.o -c -D... ./get_versionf.c
  CC             -o _werrhcreatef.o -c -D... ./errhcreatef.c
  CC             -o _werrhsetf.o -c -D... ./errhsetf.c
  CC             -o _werrhgetf.o -c -D... ./errhgetf.c
  CC             -o _werrhfreef.o -c -D... ./errhfreef.c
  CC             -o _werror_stringf.o -c -D... ./error_stringf.c
  CC             -o _werror_classf.o -c -D... ./error_classf.c
  CC             -o _wfinalizef.o -c -D... ./finalizef.c
  CC             -o _winitializedf.o -c -D... ./initializedf.c
  CC             -o _wabortf.o -c -D... ./abortf.c
  CC             -o _wclose_portf.o -c -D... ./close_portf.c
  CC             -o _wcomm_acceptf.o -c -D... ./comm_acceptf.c
  CC             -o _wcomm_connectf.o -c -D... ./comm_connectf.c
  CC             -o _wcommdiscf.o -c -D... ./commdiscf.c
  CC             -o _wcommparentf.o -c -D... ./commparentf.c
  CC             -o _wcomm_joinf.o -c -D... ./comm_joinf.c
  CC             -o _wcomm_spawnf.o -c -D... ./comm_spawnf.c
  CC             -o _wspawnmultf.o -c -D... ./spawnmultf.c
  CC             -o _wlookup_namef.o -c -D... ./lookup_namef.c
  CC             -o _wopen_portf.o -c -D... ./open_portf.c
  CC             -o _wpublish_namef.o -c -D... ./publish_namef.c
  CC             -o _wunpubnamef.o -c -D... ./unpubnamef.c
  CC             -o _waccumulatef.o -c -D... ./accumulatef.c
  CC             -o _wgetf.o -c -D... ./getf.c
  CC             -o _wputf.o -c -D... ./putf.c
  CC             -o _wwin_completef.o -c -D... ./win_completef.c
  CC             -o _wwin_createf.o -c -D... ./win_createf.c
  CC             -o _wwin_fencef.o -c -D... ./win_fencef.c
  CC             -o _wwin_freef.o -c -D... ./win_freef.c
  CC             -o _wwin_get_groupf.o -c -D... ./win_get_groupf.c
  CC             -o _wwin_lockf.o -c -D... ./win_lockf.c
  CC             -o _wwin_postf.o -c -D... ./win_postf.c
  CC             -o _wwin_startf.o -c -D... ./win_startf.c
  CC             -o _wwin_testf.o -c -D... ./win_testf.c
  CC             -o _wwin_unlockf.o -c -D... ./win_unlockf.c
  CC             -o _wwin_waitf.o -c -D... ./win_waitf.c
  CC             -o _walltoallwf.o -c -D... ./alltoallwf.c
  CC             -o _wexscanf.o -c -D... ./exscanf.c
  CC             -o _wadderrclassf.o -c -D... ./adderrclassf.c
  CC             -o _wadderrcodef.o -c -D... ./adderrcodef.c
  CC             -o _wadderrstringf.o -c -D... ./adderrstringf.c
  CC             -o _wcommcallerrf.o -c -D... ./commcallerrf.c
  CC             -o _wcommnewkeyf.o -c -D... ./commnewkeyf.c
  CC             -o _wcommdelattrf.o -c -D... ./commdelattrf.c
  CC             -o _wcommfreekeyf.o -c -D... ./commfreekeyf.c
  CC             -o _wcomm_get_attrf.o -c -D... ./comm_get_attrf.c
  CC             -o _wcommgetnamf.o -c -D... ./commgetnamf.c
  CC             -o _wcomm_set_attrf.o -c -D... ./comm_set_attrf.c
  CC             -o _wcomm_set_namef.o -c -D... ./comm_set_namef.c
  CC             -o _wfilecallerrf.o -c -D... ./filecallerrf.c
  CC             -o _wgreqcompletef.o -c -D... ./greqcompletef.c
  CC             -o _wgreqstartf.o -c -D... ./greqstartf.c
  CC             -o _wisthrmainf.o -c -D... ./isthrmainf.c
  CC             -o _wquery_threadf.o -c -D... ./query_threadf.c
  CC             -o _wstatgetclf.o -c -D... ./statgetclf.c
  CC             -o _wstatsetelf.o -c -D... ./statsetelf.c
  CC             -o _wtypenewkeyf.o -c -D... ./typenewkeyf.c
  CC             -o _wtypedelattrf.o -c -D... ./typedelattrf.c
  CC             -o _wtype_dupf.o -c -D... ./type_dupf.c
  CC             -o _wtypefreekeyf.o -c -D... ./typefreekeyf.c
  CC             -o _wtype_get_attrf.o -c -D... ./type_get_attrf.c
  CC             -o _wtypegetcntsf.o -c -D... ./typegetcntsf.c
  CC             -o _wtypegetenvf.o -c -D... ./typegetenvf.c
  CC             -o _wtypegnamef.o -c -D... ./typegnamef.c
  CC             -o _wtypesetattrf.o -c -D... ./typesetattrf.c
  CC             -o _wtypesetnamef.o -c -D... ./typesetnamef.c
  CC             -o _wtype_match_sizef.o -c -D... ./type_match_sizef.c
  CC             -o _wwincallerrf.o -c -D... ./wincallerrf.c
  CC             -o _wwinnewkeyf.o -c -D... ./winnewkeyf.c
  CC             -o _wwindelattrf.o -c -D... ./windelattrf.c
  CC             -o _wwinfreekeyf.o -c -D... ./winfreekeyf.c
  CC             -o _wwin_get_attrf.o -c -D... ./win_get_attrf.c
  CC             -o _wwin_get_namef.o -c -D... ./win_get_namef.c
  CC             -o _wwin_set_attrf.o -c -D... ./win_set_attrf.c
  CC             -o _wwin_set_namef.o -c -D... ./win_set_namef.c
  CC             -o _walloc_memf.o -c -D... ./alloc_memf.c
  CC             -o _wcommcreerrf.o -c -D... ./commcreerrf.c
  CC             -o _wcommgeterrf.o -c -D... ./commgeterrf.c
  CC             -o _wcommseterrf.o -c -D... ./commseterrf.c
  CC             -o _wfilecreerrf.o -c -D... ./filecreerrf.c
  CC             -o _wfilegeterrf.o -c -D... ./filegeterrf.c
  CC             -o _wfileseterrf.o -c -D... ./fileseterrf.c
  CC             -o _wfinalizedf.o -c -D... ./finalizedf.c
  CC             -o _wfree_memf.o -c -D... ./free_memf.c
  CC             -o _winfo_createf.o -c -D... ./info_createf.c
  CC             -o _winfo_deletef.o -c -D... ./info_deletef.c
  CC             -o _winfo_dupf.o -c -D... ./info_dupf.c
  CC             -o _winfo_freef.o -c -D... ./info_freef.c
  CC             -o _winfo_getf.o -c -D... ./info_getf.c
  CC             -o _winfognkf.o -c -D... ./infognkf.c
  CC             -o _winfognthkf.o -c -D... ./infognthkf.c
  CC             -o _winfovallenf.o -c -D... ./infovallenf.c
  CC             -o _winfo_setf.o -c -D... ./info_setf.c
  CC             -o _wpack_externalf.o -c -D... ./pack_externalf.c
  CC             -o _wpackesizef.o -c -D... ./packesizef.c
  CC             -o _wreqgetstatf.o -c -D... ./reqgetstatf.c
  CC             -o _wtypedarrayf.o -c -D... ./typedarrayf.c
  CC             -o _wtypechindf.o -c -D... ./typechindf.c
  CC             -o _wtypechvecf.o -c -D... ./typechvecf.c
  CC             -o _wtypecindbf.o -c -D... ./typecindbf.c
  CC             -o _wtypecresizef.o -c -D... ./typecresizef.c
  CC             -o _wtypecstructf.o -c -D... ./typecstructf.c
  CC             -o _wtypecsubarrf.o -c -D... ./typecsubarrf.c
  CC             -o _wtypegetextentf.o -c -D... ./typegetextentf.c
  CC             -o _wtypegtextf.o -c -D... ./typegtextf.c
  CC             -o _wunpackextf.o -c -D... ./unpackextf.c
  CC             -o _wwincreerrf.o -c -D... ./wincreerrf.c
  CC             -o _wwingeterrf.o -c -D... ./wingeterrf.c
  CC             -o _wwinseterrf.o -c -D... ./winseterrf.c
  CC             -o _wreduce_localf.o -c -D... ./reduce_localf.c
  CC             -o _wop_commutativef.o -c -D... ./op_commutativef.c
  CC             -o _wreduce_scatter_blockf.o -c -D... ./reduce_scatter_blockf.c
  CC             -o _wdist_graph_create_adjacentf.o -c -D... ./dist_graph_create_adjacentf.c
  CC             -o _wdist_graph_createf.o -c -D... ./dist_graph_createf.c
  CC             -o _wdist_graph_neighbors_countf.o -c -D... ./dist_graph_neighbors_countf.c
  CC             -o _wdist_graph_neighborsf.o -c -D... ./dist_graph_neighborsf.c
  CC             -o _wfile_openf.o -c -D... ./file_openf.c
  CC             -o _wfile_closef.o -c -D... ./file_closef.c
  CC             -o _wfile_deletef.o -c -D... ./file_deletef.c
  CC             -o _wfile_set_sizef.o -c -D... ./file_set_sizef.c
  CC             -o _wfile_preallocatef.o -c -D... ./file_preallocatef.c
  CC             -o _wfile_get_sizef.o -c -D... ./file_get_sizef.c
  CC             -o _wfile_get_groupf.o -c -D... ./file_get_groupf.c
  CC             -o _wfile_get_amodef.o -c -D... ./file_get_amodef.c
  CC             -o _wfile_set_infof.o -c -D... ./file_set_infof.c
  CC             -o _wfile_get_infof.o -c -D... ./file_get_infof.c
  CC             -o _wfile_set_viewf.o -c -D... ./file_set_viewf.c
  CC             -o _wfile_get_viewf.o -c -D... ./file_get_viewf.c
  CC             -o _wfile_read_atf.o -c -D... ./file_read_atf.c
  CC             -o _wfile_read_at_allf.o -c -D... ./file_read_at_allf.c
  CC             -o _wfile_write_atf.o -c -D... ./file_write_atf.c
  CC             -o _wfile_write_at_allf.o -c -D... ./file_write_at_allf.c
  CC             -o _wfile_iread_atf.o -c -D... ./file_iread_atf.c
  CC             -o _wfile_iwrite_atf.o -c -D... ./file_iwrite_atf.c
  CC             -o _wfile_readf.o -c -D... ./file_readf.c
  CC             -o _wfile_read_allf.o -c -D... ./file_read_allf.c
  CC             -o _wfile_writef.o -c -D... ./file_writef.c
  CC             -o _wfile_write_allf.o -c -D... ./file_write_allf.c
  CC             -o _wfile_ireadf.o -c -D... ./file_ireadf.c
  CC             -o _wfile_iwritef.o -c -D... ./file_iwritef.c
  CC             -o _wfile_seekf.o -c -D... ./file_seekf.c
  CC             -o _wfile_get_positionf.o -c -D... ./file_get_positionf.c
  CC             -o _wfile_get_byte_offsetf.o -c -D... ./file_get_byte_offsetf.c
  CC             -o _wfile_read_sharedf.o -c -D... ./file_read_sharedf.c
  CC             -o _wfile_write_sharedf.o -c -D... ./file_write_sharedf.c
  CC             -o _wfile_iread_sharedf.o -c -D... ./file_iread_sharedf.c
  CC             -o _wfile_iwrite_sharedf.o -c -D... ./file_iwrite_sharedf.c
  CC             -o _wfile_read_orderedf.o -c -D... ./file_read_orderedf.c
  CC             -o _wfile_write_orderedf.o -c -D... ./file_write_orderedf.c
  CC             -o _wfile_seek_sharedf.o -c -D... ./file_seek_sharedf.c
  CC             -o _wfile_get_position_sharedf.o -c -D... ./file_get_position_sharedf.c
  CC             -o _wfile_read_at_all_beginf.o -c -D... ./file_read_at_all_beginf.c
  CC             -o _wfile_read_at_all_endf.o -c -D... ./file_read_at_all_endf.c
  CC             -o _wfile_write_at_all_beginf.o -c -D... ./file_write_at_all_beginf.c
  CC             -o _wfile_write_at_all_endf.o -c -D... ./file_write_at_all_endf.c
  CC             -o _wfile_read_all_beginf.o -c -D... ./file_read_all_beginf.c
  CC             -o _wfile_read_all_endf.o -c -D... ./file_read_all_endf.c
  CC             -o _wfile_write_all_beginf.o -c -D... ./file_write_all_beginf.c
  CC             -o _wfile_write_all_endf.o -c -D... ./file_write_all_endf.c
  CC             -o _wfile_read_ordered_beginf.o -c -D... ./file_read_ordered_beginf.c
  CC             -o _wfile_read_ordered_endf.o -c -D... ./file_read_ordered_endf.c
  CC             -o _wfile_write_ordered_beginf.o -c -D... ./file_write_ordered_beginf.c
  CC             -o _wfile_write_ordered_endf.o -c -D... ./file_write_ordered_endf.c
  CC             -o _wfile_get_type_extentf.o -c -D... ./file_get_type_extentf.c
  CC             -o _wregister_datarepf.o -c -D... ./register_datarepf.c
  CC             -o _wfile_set_atomicityf.o -c -D... ./file_set_atomicityf.c
  CC             -o _wfile_get_atomicityf.o -c -D... ./file_get_atomicityf.c
  CC             -o _wfile_syncf.o -c -D... ./file_syncf.c
  CC             -o _winitf.o -c -D... ./initf.c
  CC             -o _winitthreadf.o -c -D... ./initthreadf.c
  CC             -o _wpcontrolf.o -c -D... ./pcontrolf.c
  CC             -o _waddressf.o -c -D... ./addressf.c
  CC             -o _wgetaddressf.o -c -D... ./getaddressf.c
  CC             -o _wwtimef.o -c -D... ./wtimef.c
  CC             -o _wwtickf.o -c -D... ./wtickf.c
  CC             -o _wkeyval_createf.o -c -D... ./keyval_createf.c
  CC             -o _wdup_fnf.o -c -D... ./dup_fnf.c
  CC             -o _wnull_del_fnf.o -c -D... ./null_del_fnf.c
  CC             -o _wnull_copy_fnf.o -c -D... ./null_copy_fnf.c
  CC             -o _wdup_comm_fnf.o -c -D... ./dup_comm_fnf.c
  CC             -o _wnull_comm_del_fnf.o -c -D... ./null_comm_del_fnf.c
  CC             -o _wnull_comm_copy_fnf.o -c -D... ./null_comm_copy_fnf.c
  CC             -o _wdup_win_fnf.o -c -D... ./dup_win_fnf.c
  CC             -o _wnull_win_del_fnf.o -c -D... ./null_win_del_fnf.c
  CC             -o _wnull_win_copy_fnf.o -c -D... ./null_win_copy_fnf.c
  CC             -o _wdup_type_fnf.o -c -D... ./dup_type_fnf.c
  CC             -o _wnull_type_del_fnf.o -c -D... ./null_type_del_fnf.c
  CC             -o _wnull_type_copy_fnf.o -c -D... ./null_type_copy_fnf.c
  CC             -o _wstatusf2c.o -c -D... ./statusf2c.c
  CC             -o _wstatusc2f.o -c -D... ./statusc2f.c
  AR cr ../../../lib/libfmpich.a _wsendf.o _wrecvf.o _wget_countf.o _wbsendf.o _wssendf.o _wrsendf.o _wbufattachf.o _wbufdetachf.o _wisendf.o _wibsendf.o _wissendf.o _wirsendf.o _wirecvf.o _wwaitf.o _wtestf.o _wrequest_freef.o _wwaitanyf.o _wtestanyf.o _wwaitallf.o _wtestallf.o _wwaitsomef.o _wtestsomef.o _wiprobef.o _wprobef.o _wcancelf.o _wtestcancelf.o _wsend_initf.o _wbsend_initf.o _wssend_initf.o _wrsend_initf.o _wrecv_initf.o _wstartf.o _wstartallf.o _wsendrecvf.o _wsndrcvrplf.o _wtypecontigf.o _wtype_vectorf.o _wtype_hvectorf.o _wtype_indexedf.o _wtype_hindexedf.o _wtype_structf.o _wtype_extentf.o _wtype_sizef.o _wtype_lbf.o _wtype_ubf.o _wtype_commitf.o _wtype_freef.o _wget_elementsf.o _wpackf.o _wunpackf.o _wpack_sizef.o _wbarrierf.o _wbcastf.o _wgatherf.o _wgathervf.o _wscatterf.o _wscattervf.o _wallgatherf.o _wallgathervf.o _walltoallf.o _walltoallvf.o _wreducef.o _wop_createf.o _wop_freef.o _wallreducef.o _wredscatf.o _wscanf.o _wgroup_sizef.o _wgroup_rankf.o _wgrouptranksf.o _wgroup_comparef.o _wcomm_groupf.o _wgroup_unionf.o _wgroupinterf.o _wgroupdifff.o _wgroup_inclf.o _wgroup_exclf.o _wgrouprinclf.o _wgrouprexclf.o _wgroup_freef.o _wcomm_sizef.o _wcomm_rankf.o _wcomm_comparef.o _wcomm_dupf.o _wcomm_createf.o _wcomm_splitf.o _wcomm_freef.o _wcommtesticf.o _wcommrsizef.o _wcommrgroupf.o _wiccreatef.o _wicmergef.o _wkeyval_freef.o _wattr_putf.o _wattr_getf.o _wattr_deletef.o _wtopo_testf.o _wcart_createf.o _wdims_createf.o _wgraph_createf.o _wgraphdims_getf.o _wgraph_getf.o _wcartdim_getf.o _wcart_getf.o _wcart_rankf.o _wcart_coordsf.o _wgrfnbcountf.o _wgrfnbrsf.o _wcart_shiftf.o _wcart_subf.o _wcart_mapf.o _wgraph_mapf.o _wgetpnamef.o _wget_versionf.o _werrhcreatef.o _werrhsetf.o _werrhgetf.o _werrhfreef.o _werror_stringf.o _werror_classf.o _wfinalizef.o _winitializedf.o _wabortf.o _wclose_portf.o _wcomm_acceptf.o _wcomm_connectf.o _wcommdiscf.o _wcommparentf.o _wcomm_joinf.o _wcomm_spawnf.o _wspawnmultf.o _wlookup_namef.o _wopen_portf.o _wpublish_namef.o _wunpubnamef.o _waccumulatef.o _wgetf.o _wputf.o _wwin_completef.o _wwin_createf.o _wwin_fencef.o _wwin_freef.o _wwin_get_groupf.o _wwin_lockf.o _wwin_postf.o _wwin_startf.o _wwin_testf.o _wwin_unlockf.o _wwin_waitf.o _walltoallwf.o _wexscanf.o _wadderrclassf.o _wadderrcodef.o _wadderrstringf.o _wcommcallerrf.o _wcommnewkeyf.o _wcommdelattrf.o _wcommfreekeyf.o _wcomm_get_attrf.o _wcommgetnamf.o _wcomm_set_attrf.o _wcomm_set_namef.o _wfilecallerrf.o _wgreqcompletef.o _wgreqstartf.o _wisthrmainf.o _wquery_threadf.o _wstatgetclf.o _wstatsetelf.o _wtypenewkeyf.o _wtypedelattrf.o _wtype_dupf.o _wtypefreekeyf.o _wtype_get_attrf.o _wtypegetcntsf.o _wtypegetenvf.o _wtypegnamef.o _wtypesetattrf.o _wtypesetnamef.o _wtype_match_sizef.o _wwincallerrf.o _wwinnewkeyf.o _wwindelattrf.o _wwinfreekeyf.o _wwin_get_attrf.o _wwin_get_namef.o _wwin_set_attrf.o _wwin_set_namef.o _walloc_memf.o _wcommcreerrf.o _wcommgeterrf.o _wcommseterrf.o _wfilecreerrf.o _wfilegeterrf.o _wfileseterrf.o _wfinalizedf.o _wfree_memf.o _winfo_createf.o _winfo_deletef.o _winfo_dupf.o _winfo_freef.o _winfo_getf.o _winfognkf.o _winfognthkf.o _winfovallenf.o _winfo_setf.o _wpack_externalf.o _wpackesizef.o _wreqgetstatf.o _wtypedarrayf.o _wtypechindf.o _wtypechvecf.o _wtypecindbf.o _wtypecresizef.o _wtypecstructf.o _wtypecsubarrf.o _wtypegetextentf.o _wtypegtextf.o _wunpackextf.o _wwincreerrf.o _wwingeterrf.o _wwinseterrf.o _wreduce_localf.o _wop_commutativef.o _wreduce_scatter_blockf.o _wdist_graph_create_adjacentf.o _wdist_graph_createf.o _wdist_graph_neighbors_countf.o _wdist_graph_neighborsf.o _wfile_openf.o _wfile_closef.o _wfile_deletef.o _wfile_set_sizef.o _wfile_preallocatef.o _wfile_get_sizef.o _wfile_get_groupf.o _wfile_get_amodef.o _wfile_set_infof.o _wfile_get_infof.o _wfile_set_viewf.o _wfile_get_viewf.o _wfile_read_atf.o _wfile_read_at_allf.o _wfile_write_atf.o _wfile_write_at_allf.o _wfile_iread_atf.o _wfile_iwrite_atf.o _wfile_readf.o _wfile_read_allf.o _wfile_writef.o _wfile_write_allf.o _wfile_ireadf.o _wfile_iwritef.o _wfile_seekf.o _wfile_get_positionf.o _wfile_get_byte_offsetf.o _wfile_read_sharedf.o _wfile_write_sharedf.o _wfile_iread_sharedf.o _wfile_iwrite_sharedf.o _wfile_read_orderedf.o _wfile_write_orderedf.o _wfile_seek_sharedf.o _wfile_get_position_sharedf.o _wfile_read_at_all_beginf.o _wfile_read_at_all_endf.o _wfile_write_at_all_beginf.o _wfile_write_at_all_endf.o _wfile_read_all_beginf.o _wfile_read_all_endf.o _wfile_write_all_beginf.o _wfile_write_all_endf.o _wfile_read_ordered_beginf.o _wfile_read_ordered_endf.o _wfile_write_ordered_beginf.o _wfile_write_ordered_endf.o _wfile_get_type_extentf.o _wregister_datarepf.o _wfile_set_atomicityf.o _wfile_get_atomicityf.o _wfile_syncf.o _winitf.o _winitthreadf.o _wpcontrolf.o _waddressf.o _wgetaddressf.o _wwtimef.o _wwtickf.o _wkeyval_createf.o _wdup_fnf.o _wnull_del_fnf.o _wnull_copy_fnf.o _wdup_comm_fnf.o _wnull_comm_del_fnf.o _wnull_comm_copy_fnf.o _wdup_win_fnf.o _wnull_win_del_fnf.o _wnull_win_copy_fnf.o _wdup_type_fnf.o _wnull_type_del_fnf.o _wnull_type_copy_fnf.o _wstatusf2c.o _wstatusc2f.o
  RANLIB          libfmpich.a
date > .libstamp0
  CC              sendf.c
  CC              recvf.c
  CC              get_countf.c
  CC              bsendf.c
  CC              ssendf.c
  CC              rsendf.c
  CC              bufattachf.c
  CC              bufdetachf.c
  CC              isendf.c
  CC              ibsendf.c
  CC              issendf.c
  CC              irsendf.c
  CC              irecvf.c
  CC              waitf.c
  CC              testf.c
  CC              request_freef.c
  CC              waitanyf.c
  CC              testanyf.c
  CC              waitallf.c
  CC              testallf.c
  CC              waitsomef.c
  CC              testsomef.c
  CC              iprobef.c
  CC              probef.c
  CC              cancelf.c
  CC              testcancelf.c
  CC              send_initf.c
  CC              bsend_initf.c
  CC              ssend_initf.c
  CC              rsend_initf.c
  CC              recv_initf.c
  CC              startf.c
  CC              startallf.c
  CC              sendrecvf.c
  CC              sndrcvrplf.c
  CC              typecontigf.c
  CC              type_vectorf.c
  CC              type_hvectorf.c
  CC              type_indexedf.c
  CC              type_hindexedf.c
  CC              type_structf.c
  CC              type_extentf.c
  CC              type_sizef.c
  CC              type_lbf.c
  CC              type_ubf.c
  CC              type_commitf.c
  CC              type_freef.c
  CC              get_elementsf.c
  CC              packf.c
  CC              unpackf.c
  CC              pack_sizef.c
  CC              barrierf.c
  CC              bcastf.c
  CC              gatherf.c
  CC              gathervf.c
  CC              scatterf.c
  CC              scattervf.c
  CC              allgatherf.c
  CC              allgathervf.c
  CC              alltoallf.c
  CC              alltoallvf.c
  CC              reducef.c
  CC              op_createf.c
  CC              op_freef.c
  CC              allreducef.c
  CC              redscatf.c
  CC              scanf.c
  CC              group_sizef.c
  CC              group_rankf.c
  CC              grouptranksf.c
  CC              group_comparef.c
  CC              comm_groupf.c
  CC              group_unionf.c
  CC              groupinterf.c
  CC              groupdifff.c
  CC              group_inclf.c
  CC              group_exclf.c
  CC              grouprinclf.c
  CC              grouprexclf.c
  CC              group_freef.c
  CC              comm_sizef.c
  CC              comm_rankf.c
  CC              comm_comparef.c
  CC              comm_dupf.c
  CC              comm_createf.c
  CC              comm_splitf.c
  CC              comm_freef.c
  CC              commtesticf.c
  CC              commrsizef.c
  CC              commrgroupf.c
  CC              iccreatef.c
  CC              icmergef.c
  CC              keyval_freef.c
  CC              attr_putf.c
  CC              attr_getf.c
  CC              attr_deletef.c
  CC              topo_testf.c
  CC              cart_createf.c
  CC              dims_createf.c
  CC              graph_createf.c
  CC              graphdims_getf.c
  CC              graph_getf.c
  CC              cartdim_getf.c
  CC              cart_getf.c
  CC              cart_rankf.c
  CC              cart_coordsf.c
  CC              grfnbcountf.c
  CC              grfnbrsf.c
  CC              cart_shiftf.c
  CC              cart_subf.c
  CC              cart_mapf.c
  CC              graph_mapf.c
  CC              getpnamef.c
  CC              get_versionf.c
  CC              errhcreatef.c
  CC              errhsetf.c
  CC              errhgetf.c
  CC              errhfreef.c
  CC              error_stringf.c
  CC              error_classf.c
  CC              finalizef.c
  CC              initializedf.c
  CC              abortf.c
  CC              close_portf.c
  CC              comm_acceptf.c
  CC              comm_connectf.c
  CC              commdiscf.c
  CC              commparentf.c
  CC              comm_joinf.c
  CC              comm_spawnf.c
  CC              spawnmultf.c
  CC              lookup_namef.c
  CC              open_portf.c
  CC              publish_namef.c
  CC              unpubnamef.c
  CC              accumulatef.c
  CC              getf.c
  CC              putf.c
  CC              win_completef.c
  CC              win_createf.c
  CC              win_fencef.c
  CC              win_freef.c
  CC              win_get_groupf.c
  CC              win_lockf.c
  CC              win_postf.c
  CC              win_startf.c
  CC              win_testf.c
  CC              win_unlockf.c
  CC              win_waitf.c
  CC              alltoallwf.c
  CC              exscanf.c
  CC              adderrclassf.c
  CC              adderrcodef.c
  CC              adderrstringf.c
  CC              commcallerrf.c
  CC              commnewkeyf.c
  CC              commdelattrf.c
  CC              commfreekeyf.c
  CC              comm_get_attrf.c
  CC              commgetnamf.c
  CC              comm_set_attrf.c
  CC              comm_set_namef.c
  CC              filecallerrf.c
  CC              greqcompletef.c
  CC              greqstartf.c
  CC              isthrmainf.c
  CC              query_threadf.c
  CC              statgetclf.c
  CC              statsetelf.c
  CC              typenewkeyf.c
  CC              typedelattrf.c
  CC              type_dupf.c
  CC              typefreekeyf.c
  CC              type_get_attrf.c
  CC              typegetcntsf.c
  CC              typegetenvf.c
  CC              typegnamef.c
  CC              typesetattrf.c
  CC              typesetnamef.c
  CC              type_match_sizef.c
  CC              wincallerrf.c
  CC              winnewkeyf.c
  CC              windelattrf.c
  CC              winfreekeyf.c
  CC              win_get_attrf.c
  CC              win_get_namef.c
  CC              win_set_attrf.c
  CC              win_set_namef.c
  CC              alloc_memf.c
  CC              commcreerrf.c
  CC              commgeterrf.c
  CC              commseterrf.c
  CC              filecreerrf.c
  CC              filegeterrf.c
  CC              fileseterrf.c
  CC              finalizedf.c
  CC              free_memf.c
  CC              info_createf.c
  CC              info_deletef.c
  CC              info_dupf.c
  CC              info_freef.c
  CC              info_getf.c
  CC              infognkf.c
  CC              infognthkf.c
  CC              infovallenf.c
  CC              info_setf.c
  CC              pack_externalf.c
  CC              packesizef.c
  CC              reqgetstatf.c
  CC              typedarrayf.c
  CC              typechindf.c
  CC              typechvecf.c
  CC              typecindbf.c
  CC              typecresizef.c
  CC              typecstructf.c
  CC              typecsubarrf.c
  CC              typegetextentf.c
  CC              typegtextf.c
  CC              unpackextf.c
  CC              wincreerrf.c
  CC              wingeterrf.c
  CC              winseterrf.c
  CC              reduce_localf.c
  CC              op_commutativef.c
  CC              reduce_scatter_blockf.c
  CC              dist_graph_create_adjacentf.c
  CC              dist_graph_createf.c
  CC              dist_graph_neighbors_countf.c
  CC              dist_graph_neighborsf.c
  CC              file_openf.c
  CC              file_closef.c
  CC              file_deletef.c
  CC              file_set_sizef.c
  CC              file_preallocatef.c
  CC              file_get_sizef.c
  CC              file_get_groupf.c
  CC              file_get_amodef.c
  CC              file_set_infof.c
  CC              file_get_infof.c
  CC              file_set_viewf.c
  CC              file_get_viewf.c
  CC              file_read_atf.c
  CC              file_read_at_allf.c
  CC              file_write_atf.c
  CC              file_write_at_allf.c
  CC              file_iread_atf.c
  CC              file_iwrite_atf.c
  CC              file_readf.c
  CC              file_read_allf.c
  CC              file_writef.c
  CC              file_write_allf.c
  CC              file_ireadf.c
  CC              file_iwritef.c
  CC              file_seekf.c
  CC              file_get_positionf.c
  CC              file_get_byte_offsetf.c
  CC              file_read_sharedf.c
  CC              file_write_sharedf.c
  CC              file_iread_sharedf.c
  CC              file_iwrite_sharedf.c
  CC              file_read_orderedf.c
  CC              file_write_orderedf.c
  CC              file_seek_sharedf.c
  CC              file_get_position_sharedf.c
  CC              file_read_at_all_beginf.c
  CC              file_read_at_all_endf.c
  CC              file_write_at_all_beginf.c
  CC              file_write_at_all_endf.c
  CC              file_read_all_beginf.c
  CC              file_read_all_endf.c
  CC              file_write_all_beginf.c
  CC              file_write_all_endf.c
  CC              file_read_ordered_beginf.c
  CC              file_read_ordered_endf.c
  CC              file_write_ordered_beginf.c
  CC              file_write_ordered_endf.c
  CC              file_get_type_extentf.c
  CC              register_datarepf.c
  CC              file_set_atomicityf.c
  CC              file_get_atomicityf.c
  CC              file_syncf.c
  CC              initf.c
  CC              initthreadf.c
  CC              pcontrolf.c
  CC              addressf.c
  CC              getaddressf.c
  CC              wtimef.c
  CC              wtickf.c
  CC              keyval_createf.c
  CC              dup_fnf.c
  CC              null_del_fnf.c
  CC              null_copy_fnf.c
  CC              dup_comm_fnf.c
  CC              null_comm_del_fnf.c
  CC              null_comm_copy_fnf.c
  CC              dup_win_fnf.c
  CC              null_win_del_fnf.c
  CC              null_win_copy_fnf.c
  CC              dup_type_fnf.c
  CC              null_type_del_fnf.c
  CC              null_type_copy_fnf.c
  CC              statusf2c.c
  CC              statusc2f.c
  CC              setbot.c
  F77             setbotf.f
  AR cr ../../../lib/libmpich.a sendf.o recvf.o get_countf.o bsendf.o ssendf.o rsendf.o bufattachf.o bufdetachf.o isendf.o ibsendf.o issendf.o irsendf.o irecvf.o waitf.o testf.o request_freef.o waitanyf.o testanyf.o waitallf.o testallf.o waitsomef.o testsomef.o iprobef.o probef.o cancelf.o testcancelf.o send_initf.o bsend_initf.o ssend_initf.o rsend_initf.o recv_initf.o startf.o startallf.o sendrecvf.o sndrcvrplf.o typecontigf.o type_vectorf.o type_hvectorf.o type_indexedf.o type_hindexedf.o type_structf.o type_extentf.o type_sizef.o type_lbf.o type_ubf.o type_commitf.o type_freef.o get_elementsf.o packf.o unpackf.o pack_sizef.o barrierf.o bcastf.o gatherf.o gathervf.o scatterf.o scattervf.o allgatherf.o allgathervf.o alltoallf.o alltoallvf.o reducef.o op_createf.o op_freef.o allreducef.o redscatf.o scanf.o group_sizef.o group_rankf.o grouptranksf.o group_comparef.o comm_groupf.o group_unionf.o groupinterf.o groupdifff.o group_inclf.o group_exclf.o grouprinclf.o grouprexclf.o group_freef.o comm_sizef.o comm_rankf.o comm_comparef.o comm_dupf.o comm_createf.o comm_splitf.o comm_freef.o commtesticf.o commrsizef.o commrgroupf.o iccreatef.o icmergef.o keyval_freef.o attr_putf.o attr_getf.o attr_deletef.o topo_testf.o cart_createf.o dims_createf.o graph_createf.o graphdims_getf.o graph_getf.o cartdim_getf.o cart_getf.o cart_rankf.o cart_coordsf.o grfnbcountf.o grfnbrsf.o cart_shiftf.o cart_subf.o cart_mapf.o graph_mapf.o getpnamef.o get_versionf.o errhcreatef.o errhsetf.o errhgetf.o errhfreef.o error_stringf.o error_classf.o finalizef.o initializedf.o abortf.o close_portf.o comm_acceptf.o comm_connectf.o commdiscf.o commparentf.o comm_joinf.o comm_spawnf.o spawnmultf.o lookup_namef.o open_portf.o publish_namef.o unpubnamef.o accumulatef.o getf.o putf.o win_completef.o win_createf.o win_fencef.o win_freef.o win_get_groupf.o win_lockf.o win_postf.o win_startf.o win_testf.o win_unlockf.o win_waitf.o alltoallwf.o exscanf.o adderrclassf.o adderrcodef.o adderrstringf.o commcallerrf.o commnewkeyf.o commdelattrf.o commfreekeyf.o comm_get_attrf.o commgetnamf.o comm_set_attrf.o comm_set_namef.o filecallerrf.o greqcompletef.o greqstartf.o isthrmainf.o query_threadf.o statgetclf.o statsetelf.o typenewkeyf.o typedelattrf.o type_dupf.o typefreekeyf.o type_get_attrf.o typegetcntsf.o typegetenvf.o typegnamef.o typesetattrf.o typesetnamef.o type_match_sizef.o wincallerrf.o winnewkeyf.o windelattrf.o winfreekeyf.o win_get_attrf.o win_get_namef.o win_set_attrf.o win_set_namef.o alloc_memf.o commcreerrf.o commgeterrf.o commseterrf.o filecreerrf.o filegeterrf.o fileseterrf.o finalizedf.o free_memf.o info_createf.o info_deletef.o info_dupf.o info_freef.o info_getf.o infognkf.o infognthkf.o infovallenf.o info_setf.o pack_externalf.o packesizef.o reqgetstatf.o typedarrayf.o typechindf.o typechvecf.o typecindbf.o typecresizef.o typecstructf.o typecsubarrf.o typegetextentf.o typegtextf.o unpackextf.o wincreerrf.o wingeterrf.o winseterrf.o reduce_localf.o op_commutativef.o reduce_scatter_blockf.o dist_graph_create_adjacentf.o dist_graph_createf.o dist_graph_neighbors_countf.o dist_graph_neighborsf.o file_openf.o file_closef.o file_deletef.o file_set_sizef.o file_preallocatef.o file_get_sizef.o file_get_groupf.o file_get_amodef.o file_set_infof.o file_get_infof.o file_set_viewf.o file_get_viewf.o file_read_atf.o file_read_at_allf.o file_write_atf.o file_write_at_allf.o file_iread_atf.o file_iwrite_atf.o file_readf.o file_read_allf.o file_writef.o file_write_allf.o file_ireadf.o file_iwritef.o file_seekf.o file_get_positionf.o file_get_byte_offsetf.o file_read_sharedf.o file_write_sharedf.o file_iread_sharedf.o file_iwrite_sharedf.o file_read_orderedf.o file_write_orderedf.o file_seek_sharedf.o file_get_position_sharedf.o file_read_at_all_beginf.o file_read_at_all_endf.o file_write_at_all_beginf.o file_write_at_all_endf.o file_read_all_beginf.o file_read_all_endf.o file_write_all_beginf.o file_write_all_endf.o file_read_ordered_beginf.o file_read_ordered_endf.o file_write_ordered_beginf.o file_write_ordered_endf.o file_get_type_extentf.o register_datarepf.o file_set_atomicityf.o file_get_atomicityf.o file_syncf.o initf.o initthreadf.o pcontrolf.o addressf.o getaddressf.o wtimef.o wtickf.o keyval_createf.o dup_fnf.o null_del_fnf.o null_copy_fnf.o dup_comm_fnf.o null_comm_del_fnf.o null_comm_copy_fnf.o dup_win_fnf.o null_win_del_fnf.o null_win_copy_fnf.o dup_type_fnf.o null_type_del_fnf.o null_type_copy_fnf.o statusf2c.o statusc2f.o setbot.o setbotf.o
  RANLIB          libmpich.a
date > .libstamp2
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f77'
  CC             -D<profiling> ./sendf.c
  CC             -D<profiling> ./recvf.c
  CC             -D<profiling> ./get_countf.c
  CC             -D<profiling> ./bsendf.c
  CC             -D<profiling> ./ssendf.c
  CC             -D<profiling> ./rsendf.c
  CC             -D<profiling> ./bufattachf.c
  CC             -D<profiling> ./bufdetachf.c
  CC             -D<profiling> ./isendf.c
  CC             -D<profiling> ./ibsendf.c
  CC             -D<profiling> ./issendf.c
  CC             -D<profiling> ./irsendf.c
  CC             -D<profiling> ./irecvf.c
  CC             -D<profiling> ./waitf.c
  CC             -D<profiling> ./testf.c
  CC             -D<profiling> ./request_freef.c
  CC             -D<profiling> ./waitanyf.c
  CC             -D<profiling> ./testanyf.c
  CC             -D<profiling> ./waitallf.c
  CC             -D<profiling> ./testallf.c
  CC             -D<profiling> ./waitsomef.c
  CC             -D<profiling> ./testsomef.c
  CC             -D<profiling> ./iprobef.c
  CC             -D<profiling> ./probef.c
  CC             -D<profiling> ./cancelf.c
  CC             -D<profiling> ./testcancelf.c
  CC             -D<profiling> ./send_initf.c
  CC             -D<profiling> ./bsend_initf.c
  CC             -D<profiling> ./ssend_initf.c
  CC             -D<profiling> ./rsend_initf.c
  CC             -D<profiling> ./recv_initf.c
  CC             -D<profiling> ./startf.c
  CC             -D<profiling> ./startallf.c
  CC             -D<profiling> ./sendrecvf.c
  CC             -D<profiling> ./sndrcvrplf.c
  CC             -D<profiling> ./typecontigf.c
  CC             -D<profiling> ./type_vectorf.c
  CC             -D<profiling> ./type_hvectorf.c
  CC             -D<profiling> ./type_indexedf.c
  CC             -D<profiling> ./type_hindexedf.c
  CC             -D<profiling> ./type_structf.c
  CC             -D<profiling> ./type_extentf.c
  CC             -D<profiling> ./type_sizef.c
  CC             -D<profiling> ./type_lbf.c
  CC             -D<profiling> ./type_ubf.c
  CC             -D<profiling> ./type_commitf.c
  CC             -D<profiling> ./type_freef.c
  CC             -D<profiling> ./get_elementsf.c
  CC             -D<profiling> ./packf.c
  CC             -D<profiling> ./unpackf.c
  CC             -D<profiling> ./pack_sizef.c
  CC             -D<profiling> ./barrierf.c
  CC             -D<profiling> ./bcastf.c
  CC             -D<profiling> ./gatherf.c
  CC             -D<profiling> ./gathervf.c
  CC             -D<profiling> ./scatterf.c
  CC             -D<profiling> ./scattervf.c
  CC             -D<profiling> ./allgatherf.c
  CC             -D<profiling> ./allgathervf.c
  CC             -D<profiling> ./alltoallf.c
  CC             -D<profiling> ./alltoallvf.c
  CC             -D<profiling> ./reducef.c
  CC             -D<profiling> ./op_createf.c
  CC             -D<profiling> ./op_freef.c
  CC             -D<profiling> ./allreducef.c
  CC             -D<profiling> ./redscatf.c
  CC             -D<profiling> ./scanf.c
  CC             -D<profiling> ./group_sizef.c
  CC             -D<profiling> ./group_rankf.c
  CC             -D<profiling> ./grouptranksf.c
  CC             -D<profiling> ./group_comparef.c
  CC             -D<profiling> ./comm_groupf.c
  CC             -D<profiling> ./group_unionf.c
  CC             -D<profiling> ./groupinterf.c
  CC             -D<profiling> ./groupdifff.c
  CC             -D<profiling> ./group_inclf.c
  CC             -D<profiling> ./group_exclf.c
  CC             -D<profiling> ./grouprinclf.c
  CC             -D<profiling> ./grouprexclf.c
  CC             -D<profiling> ./group_freef.c
  CC             -D<profiling> ./comm_sizef.c
  CC             -D<profiling> ./comm_rankf.c
  CC             -D<profiling> ./comm_comparef.c
  CC             -D<profiling> ./comm_dupf.c
  CC             -D<profiling> ./comm_createf.c
  CC             -D<profiling> ./comm_splitf.c
  CC             -D<profiling> ./comm_freef.c
  CC             -D<profiling> ./commtesticf.c
  CC             -D<profiling> ./commrsizef.c
  CC             -D<profiling> ./commrgroupf.c
  CC             -D<profiling> ./iccreatef.c
  CC             -D<profiling> ./icmergef.c
  CC             -D<profiling> ./keyval_freef.c
  CC             -D<profiling> ./attr_putf.c
  CC             -D<profiling> ./attr_getf.c
  CC             -D<profiling> ./attr_deletef.c
  CC             -D<profiling> ./topo_testf.c
  CC             -D<profiling> ./cart_createf.c
  CC             -D<profiling> ./dims_createf.c
  CC             -D<profiling> ./graph_createf.c
  CC             -D<profiling> ./graphdims_getf.c
  CC             -D<profiling> ./graph_getf.c
  CC             -D<profiling> ./cartdim_getf.c
  CC             -D<profiling> ./cart_getf.c
  CC             -D<profiling> ./cart_rankf.c
  CC             -D<profiling> ./cart_coordsf.c
  CC             -D<profiling> ./grfnbcountf.c
  CC             -D<profiling> ./grfnbrsf.c
  CC             -D<profiling> ./cart_shiftf.c
  CC             -D<profiling> ./cart_subf.c
  CC             -D<profiling> ./cart_mapf.c
  CC             -D<profiling> ./graph_mapf.c
  CC             -D<profiling> ./getpnamef.c
  CC             -D<profiling> ./get_versionf.c
  CC             -D<profiling> ./errhcreatef.c
  CC             -D<profiling> ./errhsetf.c
  CC             -D<profiling> ./errhgetf.c
  CC             -D<profiling> ./errhfreef.c
  CC             -D<profiling> ./error_stringf.c
  CC             -D<profiling> ./error_classf.c
  CC             -D<profiling> ./finalizef.c
  CC             -D<profiling> ./initializedf.c
  CC             -D<profiling> ./abortf.c
  CC             -D<profiling> ./close_portf.c
  CC             -D<profiling> ./comm_acceptf.c
  CC             -D<profiling> ./comm_connectf.c
  CC             -D<profiling> ./commdiscf.c
  CC             -D<profiling> ./commparentf.c
  CC             -D<profiling> ./comm_joinf.c
  CC             -D<profiling> ./comm_spawnf.c
  CC             -D<profiling> ./spawnmultf.c
  CC             -D<profiling> ./lookup_namef.c
  CC             -D<profiling> ./open_portf.c
  CC             -D<profiling> ./publish_namef.c
  CC             -D<profiling> ./unpubnamef.c
  CC             -D<profiling> ./accumulatef.c
  CC             -D<profiling> ./getf.c
  CC             -D<profiling> ./putf.c
  CC             -D<profiling> ./win_completef.c
  CC             -D<profiling> ./win_createf.c
  CC             -D<profiling> ./win_fencef.c
  CC             -D<profiling> ./win_freef.c
  CC             -D<profiling> ./win_get_groupf.c
  CC             -D<profiling> ./win_lockf.c
  CC             -D<profiling> ./win_postf.c
  CC             -D<profiling> ./win_startf.c
  CC             -D<profiling> ./win_testf.c
  CC             -D<profiling> ./win_unlockf.c
  CC             -D<profiling> ./win_waitf.c
  CC             -D<profiling> ./alltoallwf.c
  CC             -D<profiling> ./exscanf.c
  CC             -D<profiling> ./adderrclassf.c
  CC             -D<profiling> ./adderrcodef.c
  CC             -D<profiling> ./adderrstringf.c
  CC             -D<profiling> ./commcallerrf.c
  CC             -D<profiling> ./commnewkeyf.c
  CC             -D<profiling> ./commdelattrf.c
  CC             -D<profiling> ./commfreekeyf.c
  CC             -D<profiling> ./comm_get_attrf.c
  CC             -D<profiling> ./commgetnamf.c
  CC             -D<profiling> ./comm_set_attrf.c
  CC             -D<profiling> ./comm_set_namef.c
  CC             -D<profiling> ./filecallerrf.c
  CC             -D<profiling> ./greqcompletef.c
  CC             -D<profiling> ./greqstartf.c
  CC             -D<profiling> ./isthrmainf.c
  CC             -D<profiling> ./query_threadf.c
  CC             -D<profiling> ./statgetclf.c
  CC             -D<profiling> ./statsetelf.c
  CC             -D<profiling> ./typenewkeyf.c
  CC             -D<profiling> ./typedelattrf.c
  CC             -D<profiling> ./type_dupf.c
  CC             -D<profiling> ./typefreekeyf.c
  CC             -D<profiling> ./type_get_attrf.c
  CC             -D<profiling> ./typegetcntsf.c
  CC             -D<profiling> ./typegetenvf.c
  CC             -D<profiling> ./typegnamef.c
  CC             -D<profiling> ./typesetattrf.c
  CC             -D<profiling> ./typesetnamef.c
  CC             -D<profiling> ./type_match_sizef.c
  CC             -D<profiling> ./wincallerrf.c
  CC             -D<profiling> ./winnewkeyf.c
  CC             -D<profiling> ./windelattrf.c
  CC             -D<profiling> ./winfreekeyf.c
  CC             -D<profiling> ./win_get_attrf.c
  CC             -D<profiling> ./win_get_namef.c
  CC             -D<profiling> ./win_set_attrf.c
  CC             -D<profiling> ./win_set_namef.c
  CC             -D<profiling> ./alloc_memf.c
  CC             -D<profiling> ./commcreerrf.c
  CC             -D<profiling> ./commgeterrf.c
  CC             -D<profiling> ./commseterrf.c
  CC             -D<profiling> ./filecreerrf.c
  CC             -D<profiling> ./filegeterrf.c
  CC             -D<profiling> ./fileseterrf.c
  CC             -D<profiling> ./finalizedf.c
  CC             -D<profiling> ./free_memf.c
  CC             -D<profiling> ./info_createf.c
  CC             -D<profiling> ./info_deletef.c
  CC             -D<profiling> ./info_dupf.c
  CC             -D<profiling> ./info_freef.c
  CC             -D<profiling> ./info_getf.c
  CC             -D<profiling> ./infognkf.c
  CC             -D<profiling> ./infognthkf.c
  CC             -D<profiling> ./infovallenf.c
  CC             -D<profiling> ./info_setf.c
  CC             -D<profiling> ./pack_externalf.c
  CC             -D<profiling> ./packesizef.c
  CC             -D<profiling> ./reqgetstatf.c
  CC             -D<profiling> ./typedarrayf.c
  CC             -D<profiling> ./typechindf.c
  CC             -D<profiling> ./typechvecf.c
  CC             -D<profiling> ./typecindbf.c
  CC             -D<profiling> ./typecresizef.c
  CC             -D<profiling> ./typecstructf.c
  CC             -D<profiling> ./typecsubarrf.c
  CC             -D<profiling> ./typegetextentf.c
  CC             -D<profiling> ./typegtextf.c
  CC             -D<profiling> ./unpackextf.c
  CC             -D<profiling> ./wincreerrf.c
  CC             -D<profiling> ./wingeterrf.c
  CC             -D<profiling> ./winseterrf.c
  CC             -D<profiling> ./reduce_localf.c
  CC             -D<profiling> ./op_commutativef.c
  CC             -D<profiling> ./reduce_scatter_blockf.c
  CC             -D<profiling> ./dist_graph_create_adjacentf.c
  CC             -D<profiling> ./dist_graph_createf.c
  CC             -D<profiling> ./dist_graph_neighbors_countf.c
  CC             -D<profiling> ./dist_graph_neighborsf.c
  CC             -D<profiling> ./file_openf.c
  CC             -D<profiling> ./file_closef.c
  CC             -D<profiling> ./file_deletef.c
  CC             -D<profiling> ./file_set_sizef.c
  CC             -D<profiling> ./file_preallocatef.c
  CC             -D<profiling> ./file_get_sizef.c
  CC             -D<profiling> ./file_get_groupf.c
  CC             -D<profiling> ./file_get_amodef.c
  CC             -D<profiling> ./file_set_infof.c
  CC             -D<profiling> ./file_get_infof.c
  CC             -D<profiling> ./file_set_viewf.c
  CC             -D<profiling> ./file_get_viewf.c
  CC             -D<profiling> ./file_read_atf.c
  CC             -D<profiling> ./file_read_at_allf.c
  CC             -D<profiling> ./file_write_atf.c
  CC             -D<profiling> ./file_write_at_allf.c
  CC             -D<profiling> ./file_iread_atf.c
  CC             -D<profiling> ./file_iwrite_atf.c
  CC             -D<profiling> ./file_readf.c
  CC             -D<profiling> ./file_read_allf.c
  CC             -D<profiling> ./file_writef.c
  CC             -D<profiling> ./file_write_allf.c
  CC             -D<profiling> ./file_ireadf.c
  CC             -D<profiling> ./file_iwritef.c
  CC             -D<profiling> ./file_seekf.c
  CC             -D<profiling> ./file_get_positionf.c
  CC             -D<profiling> ./file_get_byte_offsetf.c
  CC             -D<profiling> ./file_read_sharedf.c
  CC             -D<profiling> ./file_write_sharedf.c
  CC             -D<profiling> ./file_iread_sharedf.c
  CC             -D<profiling> ./file_iwrite_sharedf.c
  CC             -D<profiling> ./file_read_orderedf.c
  CC             -D<profiling> ./file_write_orderedf.c
  CC             -D<profiling> ./file_seek_sharedf.c
  CC             -D<profiling> ./file_get_position_sharedf.c
  CC             -D<profiling> ./file_read_at_all_beginf.c
  CC             -D<profiling> ./file_read_at_all_endf.c
  CC             -D<profiling> ./file_write_at_all_beginf.c
  CC             -D<profiling> ./file_write_at_all_endf.c
  CC             -D<profiling> ./file_read_all_beginf.c
  CC             -D<profiling> ./file_read_all_endf.c
  CC             -D<profiling> ./file_write_all_beginf.c
  CC             -D<profiling> ./file_write_all_endf.c
  CC             -D<profiling> ./file_read_ordered_beginf.c
  CC             -D<profiling> ./file_read_ordered_endf.c
  CC             -D<profiling> ./file_write_ordered_beginf.c
  CC             -D<profiling> ./file_write_ordered_endf.c
  CC             -D<profiling> ./file_get_type_extentf.c
  CC             -D<profiling> ./register_datarepf.c
  CC             -D<profiling> ./file_set_atomicityf.c
  CC             -D<profiling> ./file_get_atomicityf.c
  CC             -D<profiling> ./file_syncf.c
  CC             -D<profiling> ./initf.c
  CC             -D<profiling> ./initthreadf.c
  CC             -D<profiling> ./pcontrolf.c
  CC             -D<profiling> ./addressf.c
  CC             -D<profiling> ./getaddressf.c
  CC             -D<profiling> ./wtimef.c
  CC             -D<profiling> ./wtickf.c
  CC             -D<profiling> ./keyval_createf.c
  CC             -D<profiling> ./dup_fnf.c
  CC             -D<profiling> ./null_del_fnf.c
  CC             -D<profiling> ./null_copy_fnf.c
  CC             -D<profiling> ./dup_comm_fnf.c
  CC             -D<profiling> ./null_comm_del_fnf.c
  CC             -D<profiling> ./null_comm_copy_fnf.c
  CC             -D<profiling> ./dup_win_fnf.c
  CC             -D<profiling> ./null_win_del_fnf.c
  CC             -D<profiling> ./null_win_copy_fnf.c
  CC             -D<profiling> ./dup_type_fnf.c
  CC             -D<profiling> ./null_type_del_fnf.c
  CC             -D<profiling> ./null_type_copy_fnf.c
  CC             -D<profiling> ./statusf2c.c
  CC             -D<profiling> ./statusc2f.c
  AR cr ../../../lib/libpmpich.a _sendf.o _recvf.o _get_countf.o _bsendf.o _ssendf.o _rsendf.o _bufattachf.o _bufdetachf.o _isendf.o _ibsendf.o _issendf.o _irsendf.o _irecvf.o _waitf.o _testf.o _request_freef.o _waitanyf.o _testanyf.o _waitallf.o _testallf.o _waitsomef.o _testsomef.o _iprobef.o _probef.o _cancelf.o _testcancelf.o _send_initf.o _bsend_initf.o _ssend_initf.o _rsend_initf.o _recv_initf.o _startf.o _startallf.o _sendrecvf.o _sndrcvrplf.o _typecontigf.o _type_vectorf.o _type_hvectorf.o _type_indexedf.o _type_hindexedf.o _type_structf.o _type_extentf.o _type_sizef.o _type_lbf.o _type_ubf.o _type_commitf.o _type_freef.o _get_elementsf.o _packf.o _unpackf.o _pack_sizef.o _barrierf.o _bcastf.o _gatherf.o _gathervf.o _scatterf.o _scattervf.o _allgatherf.o _allgathervf.o _alltoallf.o _alltoallvf.o _reducef.o _op_createf.o _op_freef.o _allreducef.o _redscatf.o _scanf.o _group_sizef.o _group_rankf.o _grouptranksf.o _group_comparef.o _comm_groupf.o _group_unionf.o _groupinterf.o _groupdifff.o _group_inclf.o _group_exclf.o _grouprinclf.o _grouprexclf.o _group_freef.o _comm_sizef.o _comm_rankf.o _comm_comparef.o _comm_dupf.o _comm_createf.o _comm_splitf.o _comm_freef.o _commtesticf.o _commrsizef.o _commrgroupf.o _iccreatef.o _icmergef.o _keyval_freef.o _attr_putf.o _attr_getf.o _attr_deletef.o _topo_testf.o _cart_createf.o _dims_createf.o _graph_createf.o _graphdims_getf.o _graph_getf.o _cartdim_getf.o _cart_getf.o _cart_rankf.o _cart_coordsf.o _grfnbcountf.o _grfnbrsf.o _cart_shiftf.o _cart_subf.o _cart_mapf.o _graph_mapf.o _getpnamef.o _get_versionf.o _errhcreatef.o _errhsetf.o _errhgetf.o _errhfreef.o _error_stringf.o _error_classf.o _finalizef.o _initializedf.o _abortf.o _close_portf.o _comm_acceptf.o _comm_connectf.o _commdiscf.o _commparentf.o _comm_joinf.o _comm_spawnf.o _spawnmultf.o _lookup_namef.o _open_portf.o _publish_namef.o _unpubnamef.o _accumulatef.o _getf.o _putf.o _win_completef.o _win_createf.o _win_fencef.o _win_freef.o _win_get_groupf.o _win_lockf.o _win_postf.o _win_startf.o _win_testf.o _win_unlockf.o _win_waitf.o _alltoallwf.o _exscanf.o _adderrclassf.o _adderrcodef.o _adderrstringf.o _commcallerrf.o _commnewkeyf.o _commdelattrf.o _commfreekeyf.o _comm_get_attrf.o _commgetnamf.o _comm_set_attrf.o _comm_set_namef.o _filecallerrf.o _greqcompletef.o _greqstartf.o _isthrmainf.o _query_threadf.o _statgetclf.o _statsetelf.o _typenewkeyf.o _typedelattrf.o _type_dupf.o _typefreekeyf.o _type_get_attrf.o _typegetcntsf.o _typegetenvf.o _typegnamef.o _typesetattrf.o _typesetnamef.o _type_match_sizef.o _wincallerrf.o _winnewkeyf.o _windelattrf.o _winfreekeyf.o _win_get_attrf.o _win_get_namef.o _win_set_attrf.o _win_set_namef.o _alloc_memf.o _commcreerrf.o _commgeterrf.o _commseterrf.o _filecreerrf.o _filegeterrf.o _fileseterrf.o _finalizedf.o _free_memf.o _info_createf.o _info_deletef.o _info_dupf.o _info_freef.o _info_getf.o _infognkf.o _infognthkf.o _infovallenf.o _info_setf.o _pack_externalf.o _packesizef.o _reqgetstatf.o _typedarrayf.o _typechindf.o _typechvecf.o _typecindbf.o _typecresizef.o _typecstructf.o _typecsubarrf.o _typegetextentf.o _typegtextf.o _unpackextf.o _wincreerrf.o _wingeterrf.o _winseterrf.o _reduce_localf.o _op_commutativef.o _reduce_scatter_blockf.o _dist_graph_create_adjacentf.o _dist_graph_createf.o _dist_graph_neighbors_countf.o _dist_graph_neighborsf.o _file_openf.o _file_closef.o _file_deletef.o _file_set_sizef.o _file_preallocatef.o _file_get_sizef.o _file_get_groupf.o _file_get_amodef.o _file_set_infof.o _file_get_infof.o _file_set_viewf.o _file_get_viewf.o _file_read_atf.o _file_read_at_allf.o _file_write_atf.o _file_write_at_allf.o _file_iread_atf.o _file_iwrite_atf.o _file_readf.o _file_read_allf.o _file_writef.o _file_write_allf.o _file_ireadf.o _file_iwritef.o _file_seekf.o _file_get_positionf.o _file_get_byte_offsetf.o _file_read_sharedf.o _file_write_sharedf.o _file_iread_sharedf.o _file_iwrite_sharedf.o _file_read_orderedf.o _file_write_orderedf.o _file_seek_sharedf.o _file_get_position_sharedf.o _file_read_at_all_beginf.o _file_read_at_all_endf.o _file_write_at_all_beginf.o _file_write_at_all_endf.o _file_read_all_beginf.o _file_read_all_endf.o _file_write_all_beginf.o _file_write_all_endf.o _file_read_ordered_beginf.o _file_read_ordered_endf.o _file_write_ordered_beginf.o _file_write_ordered_endf.o _file_get_type_extentf.o _register_datarepf.o _file_set_atomicityf.o _file_get_atomicityf.o _file_syncf.o _initf.o _initthreadf.o _pcontrolf.o _addressf.o _getaddressf.o _wtimef.o _wtickf.o _keyval_createf.o _dup_fnf.o _null_del_fnf.o _null_copy_fnf.o _dup_comm_fnf.o _null_comm_del_fnf.o _null_comm_copy_fnf.o _dup_win_fnf.o _null_win_del_fnf.o _null_win_copy_fnf.o _dup_type_fnf.o _null_type_del_fnf.o _null_type_copy_fnf.o _statusf2c.o _statusc2f.o
  RANLIB          libpmpich.a
date > .libstamp4
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f77'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f77'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f90'
rm -f mpifnoext.h
sed -e 's/^C/\!/g' -e '/EXTERNAL/d' \
                -e '/REAL\*8/d' \
		-e '/DOUBLE PRECISION/d' \
		-e '/MPI_WTICK/d' ../f77/mpif.h > mpifnoext.h
g95 -O2 -I. -c ./mpi_constants.f90
g95 -O2 -I. -c mpi_sizeofs.f90
g95 -O2 -I. -c mpi_base.f90
g95 -O2 -I. -c ./mpi.f90
  CC              create_f90_int.c
  CC              create_f90_real.c
  CC              create_f90_complex.c
  CC              typef90cmplxf.c
  CC              typef90realf.c
  CC              typef90intf.c
  CC              create_f90_util.c
  AR cr ../../../lib/libmpich.a create_f90_int.o create_f90_real.o create_f90_complex.o typef90cmplxf.o typef90realf.o typef90intf.o create_f90_util.o
  RANLIB          libmpich.a
date > .libstamp0
  AR cr libmpichf90.a mpi.o mpi_constants.o mpi_sizeofs.o mpi_base.o
  RANLIB          libmpichf90.a
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f90'
  CC             -D<profiling> ./create_f90_int.c
  CC             -D<profiling> ./create_f90_real.c
  CC             -D<profiling> ./create_f90_complex.c
  CC             -D<profiling> ./typef90cmplxf.c
  CC             -D<profiling> ./typef90realf.c
  CC             -D<profiling> ./typef90intf.c
  AR cr ../../../lib/libpmpich.a _create_f90_int.o _create_f90_real.o _create_f90_complex.o _typef90cmplxf.o _typef90realf.o _typef90intf.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f90'
make all-postamble
if [ -s libmpichf90.a ] ; then \
	   cp -p libmpichf90.a ../../../lib ; fi
if [ -s libmpichf90.la ] ; then \
	   cp -p libmpichf90.la ../../../lib ; fi
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f90'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/cxx'
  CXX             initcxx.cxx
  AR cr ../../../lib/libmpichcxx.a initcxx.o
  RANLIB          libmpichcxx.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/cxx'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/env'
  CC              mpich2version.c
gcc -O2   -o mpich2version mpich2version.o  \
	../../lib/libmpich.a -lpthread
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/env'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging/pkgconfig'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging/pkgconfig'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging/envmods'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging/envmods'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2'
make --no-print-directory  build_lib_bin
**** Making src/misc ....
make --no-print-directory  mpe_debug_objs
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_nompi.a
gcc -I.. -I../include -I../../.. -I../../../include -O2  -DMPE_NOMPI -o mpehname.no -c mpehname.c
mpehname.c: In function ?MPE_GetHostName?:
mpehname.c:59: warning: initialization discards qualifiers from pointer target type
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_nompi.a mpehname.no
ranlib /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_nompi.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe.a
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I../../.. -I../../../include   -o decomp.po -c decomp.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I../../.. -I../../../include   -o mpe_seq.po -c mpe_seq.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I../../.. -I../../../include   -o dbxerr.po -c dbxerr.c
dbxerr.c: In function ?MPE_DefaultHandler?:
dbxerr.c:429: error: expected ?=?, ?,?, ?;?, ?asm? or ?__attribute__? before ?{? token
dbxerr.c:459: error: expected ?=?, ?,?, ?;?, ?asm? or ?__attribute__? before ?{? token
dbxerr.c:475: error: argument ?sig? doesn?t match prototype
dbxerr.c:407: error: prototype declaration
dbxerr.c:475: error: expected ?{? at end of input
make[7]: *** [dbxerr.po] Error 1
make[6]: *** [default] Error 2
make[5]: *** [build_lib_bin] Error 2
make[4]: *** [all] Error 2
**** Making src/callstack ....
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -o iterator.po -c iterator.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -o fancyprint.po -c fancyprint.c
gcc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include -O2  -o iterator.no -c iterator.c
gcc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include -O2  -o fancyprint.no -c fancyprint.c
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_nompi.a iterator.no fancyprint.no
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe.a iterator.po fancyprint.po
ranlib /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/bin/check_callstack.exe
gcc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include -O2  -o check_callstack.no -c check_callstack.c
cp -f check_callstack.no mpe2tmp.o
gcc  -O2  -o /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/bin/check_callstack.exe mpe2tmp.o \
	                         -L/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib -lmpe_nompi
**** Making src/logging ....
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpi_null.no -c mpi_null.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_util.no -c clog_util.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_timer.no -c clog_timer.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_uuid.no -c clog_uuid.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_commset.no -c clog_commset.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_preamble.no -c clog_preamble.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_record.no -c clog_record.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_sync.no -c clog_sync.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_block.no -c clog_block.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_buffer.no -c clog_buffer.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_merger.no -c clog_merger.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_cache.no -c clog_cache.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_joiner.no -c clog_joiner.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog.no -c clog.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log_thread.no -c mpe_log_thread.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log.no -c mpe_log.c
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log_null.no -c mpe_log_null.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o mpe_log_null.po -c mpe_log_null.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog_util.po -c clog_util.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog_timer.po -c clog_timer.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog_uuid.po -c clog_uuid.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog_commset.po -c clog_commset.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog_preamble.po -c clog_preamble.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog_record.po -c clog_record.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog_sync.po -c clog_sync.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog_block.po -c clog_block.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog_buffer.po -c clog_buffer.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog_merger.po -c clog_merger.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog_cache.po -c clog_cache.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog_joiner.po -c clog_joiner.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o clog.po -c clog.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o mpe_log_thread.po -c mpe_log_thread.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o mpe_log.po -c mpe_log.c
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_nompi.a mpi_null.no clog_util.no clog_timer.no clog_uuid.no clog_commset.no clog_preamble.no clog_record.no clog_sync.no clog_block.no clog_buffer.no clog_merger.no clog_cache.no clog_joiner.no clog.no mpe_log_thread.no mpe_log.no
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_logf.no -c mpe_logf.c
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_nompi_null.a
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_nompi_null.a mpi_null.no mpe_log_null.no
make[8]: `mpe_logf.no' is up to date.
ranlib /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_nompi_null.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_null.a
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_null.a mpe_log_null.po
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include   -o mpe_logf.po -c mpe_logf.c
ranlib /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_null.a
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe.a clog_util.po clog_timer.po clog_uuid.po clog_commset.po clog_preamble.po clog_record.po clog_sync.po clog_block.po clog_buffer.po clog_merger.po clog_cache.po clog_joiner.po clog.po mpe_log_thread.po mpe_log.po
make[8]: `mpe_logf.po' is up to date.
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/bin/clog2_print.exe /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/bin/clog2_join.exe /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/bin/clog2_repair.exe
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_print.no -c clog_print.c
cp -f clog_print.no mpe2tmp1.o
gcc  -O2  -o /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/bin/clog2_print.exe mpe2tmp1.o \
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_join.no -c clog_join.c
cp -f clog_join.no mpe2tmp2.o
gcc  -O2  -o /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/bin/clog2_join.exe mpe2tmp2.o \
gcc -I.. -I../../.. -I../include -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_repair.no -c clog_repair.c
cp -f clog_repair.no mpe2tmp3.o
gcc  -O2  -o /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/bin/clog2_repair.exe mpe2tmp3.o \
**** Making src/wrappers ....
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c log_mpi_util.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c log_mpi_core.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c trace_mpi_core.c
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/liblmpe.a
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/liblmpe.a log_mpi_util.o log_mpi_core.o
ranlib /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/liblmpe.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libtmpe.a
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libtmpe.a trace_mpi_core.o
ranlib /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libtmpe.a
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpif77   -c mpi_f2c_consts.f
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c mpe_proff.c
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_f2cmpi.a mpi_f2c_consts.o log_mpi_util.o mpe_proff.o
ranlib /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_f2cmpi.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/mpe_prof.o
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c mpe_prof.c
make --no-print-directory  linktest_all
make --no-print-directory  linktest_C
make --no-print-directory  linktest_F77
**** Making src/graphics ....
gcc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o mpe_graphics.no -c mpe_graphics.c
gcc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xcolor.no -c xcolor.c
gcc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xframe.no -c xframe.c
gcc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xinit.no -c xinit.c
gcc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xwmap.no -c xwmap.c
gcc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xmouse.no -c xmouse.c
gcc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xkey.no -c xkey.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include    -o mpe_graphics.po -c mpe_graphics.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include    -o xcolor.po -c xcolor.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include    -o xframe.po -c xframe.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include    -o xinit.po -c xinit.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include    -o xwmap.po -c xwmap.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include    -o xmouse.po -c xmouse.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include    -o xkey.po -c xkey.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include    -o visual_mess.po -c visual_mess.c
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_nompi.a mpe_graphics.no xcolor.no xframe.no xinit.no xwmap.no xmouse.no xkey.no
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe.a mpe_graphics.po xcolor.po xframe.po xinit.po xwmap.po xmouse.po xkey.po
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include    -o mpe_graphicsf.po -c mpe_graphicsf.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include    -o xmousef.po -c xmousef.c
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libampe.a
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libampe.a visual_mess.po
ranlib /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libampe.a
**** Making src/collchk ....
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_collchk.a
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c begin.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c err_han.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c is_init.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c check_buff.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c check_dims.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c check_graph.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c check_size.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c same_amode.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c same_call.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c same_dtype.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c same_high_low.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c same_int.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c same_local_leader.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c same_op.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c same_root.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c same_tag.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c same_datarep.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c same_whence.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c allgather.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c allgatherv.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c allreduce.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c alltoall.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c alltoallv.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c barrier.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c bcast.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c cart_create.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c cart_map.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c gather.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c gatherv.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c graph_create.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c graph_map.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c init.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c intercomm_create.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c intercomm_merge.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c reduce.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c reduce_scatter.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c scan.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c scatter.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c scatterv.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c finalize.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c exscan.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c alltoallw.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_open.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_preallocate.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_read_all_begin.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_read_all.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_read_all_end.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_read_at_all_begin.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_read_at_all.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_read_at_all_end.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_read_ordered_begin.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_read_ordered.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_read_ordered_end.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_seek_shared.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_set_atomicity.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_set_size.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_set_view.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_write_all_begin.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_write_all.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_write_all_end.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_write_at_all_begin.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_write_at_all.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_write_at_all_end.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_write_ordered_begin.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_write_ordered.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c file_write_ordered_end.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c add_fh.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c get_fh.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c win_create.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c win_fence.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c add_win.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c get_win.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c comm_accept.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c comm_connect.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c comm_create.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c comm_disconnect.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c comm_dup.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c comm_spawn.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c comm_spawn_multiple.c
/cygdrive/c/cygwin/mpich2-1.4.1/bin/mpicc -I.. -I../include -I/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/include -I../../.. -I../../../include   -c comm_split.c
ar cr /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_collchk.a *.o
ranlib /cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2/lib/libmpe_collchk.a
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pmi'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pmi/simple'
  CC              simple_pmiutil.c
  CC              simple_pmi.c
  AR cr ../../../lib/libmpich.a simple_pmiutil.o simple_pmi.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pmi/simple'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pmi'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
Making all in ../../mpl
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
Making all in .
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
  CC     alloc.lo
  CC     args.lo
  CC     dbg.lo
  CC     env.lo
  CC     launch.lo
  CC     others.lo
  CC     signals.lo
  CC     sock.lo
  CC     string.lo
  CC     topo.lo
  CC     bsci_init.lo
  CC     bsci_finalize.lo
  CC     bsci_launch.lo
  CC     bsci_query_node_list.lo
  CC     bsci_query_job_id.lo
  CC     bsci_query_proxy_id.lo
  CC     bsci_query_native_int.lo
  CC     bsci_wait.lo
  CC     bsci_env.lo
  CC     bscu_wait.lo
  CC     bscu_cb.lo
  CC     external_common.lo
  CC     external_common_launch.lo
  CC     fork_init.lo
  CC     user_init.lo
  CC     manual_init.lo
  CC     rsh_init.lo
  CC     rsh_env.lo
  CC     ssh_init.lo
  CC     ssh.lo
  CC     ssh_env.lo
  CC     ssh_finalize.lo
  CC     slurm_init.lo
  CC     slurm_launch.lo
  CC     slurm_env.lo
  CC     slurm_query_native_int.lo
  CC     slurm_query_node_list.lo
  CC     slurm_query_proxy_id.lo
  CC     slurm_query_jobid.lo
  CC     ll_init.lo
  CC     ll_launch.lo
  CC     ll_query_native_int.lo
  CC     ll_query_node_list.lo
  CC     ll_query_proxy_id.lo
  CC     ll_env.lo
  CC     lsf_init.lo
  CC     lsf_query_native_int.lo
  CC     lsf_query_node_list.lo
  CC     lsf_env.lo
  CC     sge_init.lo
  CC     sge_query_native_int.lo
  CC     sge_query_node_list.lo
  CC     sge_env.lo
  CC     pbs_init.lo
  CC     pbs_query_native_int.lo
  CC     pbs_query_node_list.lo
  CC     pbs_query_jobid.lo
  CC     persist_init.lo
  CC     persist_launch.lo
  CC     persist_wait.lo
  CC     ckpoint.lo
  CC     demux.lo
  CC     demux_poll.lo
  CC     demux_select.lo
  CC     debugger.lo
  CC     hydt_ftb_dummy.lo
  CC     uiu.lo
  CCLD   libhydra.la
  CC     pmiserv_pmi.lo
  CC     pmiserv_pmi_v1.lo
  CC     pmiserv_pmi_v2.lo
  CC     pmiserv_pmci.lo
  CC     pmiserv_cb.lo
  CC     pmiserv_utils.lo
  CC     common.lo
  CC     pmi_v2_common.lo
  CCLD   libpm.la
  CC     hydra_persist-persist_server.o
  CCLD   hydra_persist.exe
  CC     hydra_nameserver-hydra_nameserver.o
  CCLD   hydra_nameserver.exe
  CC     hydra_pmi_proxy-pmip.o
  CC     hydra_pmi_proxy-pmip_cb.o
  CC     hydra_pmi_proxy-pmip_utils.o
  CC     hydra_pmi_proxy-pmip_pmi_v1.o
  CC     hydra_pmi_proxy-pmip_pmi_v2.o
  CC     hydra_pmi_proxy-common.o
  CC     hydra_pmi_proxy-pmi_v2_common.o
  CCLD   hydra_pmi_proxy.exe
  CC     mpiexec.o
  CC     utils.o
  CCLD   mpiexec.hydra.exe
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm'
make all-postamble
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src'
for dir in mpl openpa ; do \
	    (cd $dir && make prefix=/cygdrive/c/cygwin/mpich2-1.4.1 exec_prefix=/cygdrive/c/cygwin/mpich2-1.4.1 \
	    bindir=/cygdrive/c/cygwin/mpich2-1.4.1/bin libdir=/cygdrive/c/cygwin/mpich2-1.4.1/lib \
	    includedir=/cygdrive/c/cygwin/mpich2-1.4.1/include docdir=/cygdrive/c/cygwin/mpich2-1.4.1/share/doc install) ; \
	done
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
test -z "/cygdrive/c/cygwin/mpich2-1.4.1/lib" || /usr/bin/mkdir -p "/cygdrive/c/cygwin/mpich2-1.4.1/lib"
 /bin/sh ./libtool   --mode=install /usr/bin/install -c   libmpl.la '/cygdrive/c/cygwin/mpich2-1.4.1/lib'
libtool: install: /usr/bin/install -c .libs/libmpl.lai /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpl.la
libtool: install: /usr/bin/install -c .libs/libmpl.a /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpl.a
libtool: install: chmod 644 /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpl.a
libtool: install: ranlib /cygdrive/c/cygwin/mpich2-1.4.1/lib/libmpl.a
libtool: install: warning: remember to run `libtool --finish /usr/local/lib'
make[4]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
Making install in src
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
 /bin/sh ../libtool   --mode=install /usr/bin/install -c   libopa.la '/cygdrive/c/cygwin/mpich2-1.4.1/lib'
libtool: install: /usr/bin/install -c .libs/libopa.lai /cygdrive/c/cygwin/mpich2-1.4.1/lib/libopa.la
libtool: install: /usr/bin/install -c .libs/libopa.a /cygdrive/c/cygwin/mpich2-1.4.1/lib/libopa.a
libtool: install: chmod 644 /cygdrive/c/cygwin/mpich2-1.4.1/lib/libopa.a
libtool: install: ranlib /cygdrive/c/cygwin/mpich2-1.4.1/lib/libopa.a
test -z "/cygdrive/c/cygwin/mpich2-1.4.1/include" || /usr/bin/mkdir -p "/cygdrive/c/cygwin/mpich2-1.4.1/include"
 /usr/bin/install -c -m 644 opa_config.h opa_primitives.h opa_queue.h opa_util.h '/cygdrive/c/cygwin/mpich2-1.4.1/include'
/usr/bin/mkdir -p '/cygdrive/c/cygwin/mpich2-1.4.1/include/primitives'
 /usr/bin/install -c -m 644  primitives/opa_by_lock.h primitives/opa_emulated.h primitives/opa_gcc_ia64.h primitives/opa_gcc_intel_32_64.h primitives/opa_gcc_intel_32_64_barrier.h primitives/opa_gcc_intel_32_64_ops.h primitives/opa_gcc_intel_32_64_p3.h primitives/opa_gcc_intel_32_64_p3barrier.h primitives/opa_gcc_intrinsics.h primitives/opa_gcc_ppc.h primitives/opa_gcc_sicortex.h primitives/opa_nt_intrinsics.h primitives/opa_sun_atomic_ops.h primitives/opa_unsafe.h '/cygdrive/c/cygwin/mpich2-1.4.1/include/primitives'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
Making install in test
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/test'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/test'
make[5]: Nothing to be done for `install-exec-am'.
make[5]: Nothing to be done for `install-data-am'.
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/test'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/test'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
test -z "/cygdrive/c/cygwin/mpich2-1.4.1/share/doc" || /usr/bin/mkdir -p "/cygdrive/c/cygwin/mpich2-1.4.1/share/doc"
 /usr/bin/install -c -m 644 README '/cygdrive/c/cygwin/mpich2-1.4.1/share/doc'
test -z "/cygdrive/c/cygwin/mpich2-1.4.1/lib/pkgconfig" || /usr/bin/mkdir -p "/cygdrive/c/cygwin/mpich2-1.4.1/lib/pkgconfig"
 /usr/bin/install -c -m 644 openpa.pc '/cygdrive/c/cygwin/mpich2-1.4.1/lib/pkgconfig'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src'
make all-postamble
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1'
( cd examples && make )
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/examples'
  CC              cpi.c
../bin/mpicc   -o cpi cpi.o  -lm
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/examples'
Make completed
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1'
if [ ! -d /usr/local ] ; then mkdir -p /usr/local ; fi
if [ ! -d /usr/local/share ] ; then mkdir -p /usr/local/share ; fi
if [ ! -d /usr/local/share/doc/ ] ; then mkdir -p /usr/local/share/doc/ ; fi
if [ ! -d /usr/local/share/man ] ; then mkdir -p /usr/local/share/man ; fi
if [ ! -d /usr/local/include ] ; then mkdir -p /usr/local/include ; fi
if [ ! -d /usr/local/lib ] ; then mkdir -p /usr/local/lib ; fi
make install-local
if [ "no" = "yes" ] ; then \
	    /usr/bin/install -c -m 644 src/mpi/debugger/libtvmpich2.dll \
			/usr/local/lib/libtvmpich2.dll ; fi
if [ -n "" ] ; then \
	    for pm in  /dev/null ; do \
		if [ -d src/pm/$pm ] ; then \
		     (cd src/pm/$pm && \
		make DESTDIR= prefix=/usr/local bindir=/usr/local/bin install-alt ) ; \
		fi ; \
	    done ; \
	fi
/usr/bin/install -c -m 644  src/include/mpi.h /usr/local/include/mpi.h
/usr/bin/install -c -m 644  ./src/include/mpix.h /usr/local/include/mpix.h
/usr/bin/install -c -m 644  lib/libmpich.a /usr/local/lib/libmpich.a
/usr/bin/install -c -m 644 index.htm /usr/local/share/doc//index.htm
/usr/bin/install -c -m 644 MPI.html /usr/local/share/doc//www1/MPI.html
/usr/bin/install -c -m 644 index.htm /usr/local/share/doc//www1/index.htm
/usr/bin/install -c -m 644 mpicc.html /usr/local/share/doc//www1/mpicc.html
/usr/bin/install -c -m 644 mpicxx.html /usr/local/share/doc//www1/mpicxx.html
/usr/bin/install -c -m 644 mpiexec.html /usr/local/share/doc//www1/mpiexec.html
/usr/bin/install -c -m 644 mpif77.html /usr/local/share/doc//www1/mpif77.html
/usr/bin/install -c -m 644 mpif90.html /usr/local/share/doc//www1/mpif90.html
/usr/bin/install -c -m 644 MPIX_Group_comm_create.html /usr/local/share/doc//www3/MPIX_Group_comm_create.html
/usr/bin/install -c -m 644 MPI_Abort.html /usr/local/share/doc//www3/MPI_Abort.html
/usr/bin/install -c -m 644 MPI_Accumulate.html /usr/local/share/doc//www3/MPI_Accumulate.html
/usr/bin/install -c -m 644 MPI_Add_error_class.html /usr/local/share/doc//www3/MPI_Add_error_class.html
/usr/bin/install -c -m 644 MPI_Add_error_code.html /usr/local/share/doc//www3/MPI_Add_error_code.html
/usr/bin/install -c -m 644 MPI_Add_error_string.html /usr/local/share/doc//www3/MPI_Add_error_string.html
/usr/bin/install -c -m 644 MPI_Address.html /usr/local/share/doc//www3/MPI_Address.html
/usr/bin/install -c -m 644 MPI_Allgather.html /usr/local/share/doc//www3/MPI_Allgather.html
/usr/bin/install -c -m 644 MPI_Allgatherv.html /usr/local/share/doc//www3/MPI_Allgatherv.html
/usr/bin/install -c -m 644 MPI_Alloc_mem.html /usr/local/share/doc//www3/MPI_Alloc_mem.html
/usr/bin/install -c -m 644 MPI_Allreduce.html /usr/local/share/doc//www3/MPI_Allreduce.html
/usr/bin/install -c -m 644 MPI_Alltoall.html /usr/local/share/doc//www3/MPI_Alltoall.html
/usr/bin/install -c -m 644 MPI_Alltoallv.html /usr/local/share/doc//www3/MPI_Alltoallv.html
/usr/bin/install -c -m 644 MPI_Alltoallw.html /usr/local/share/doc//www3/MPI_Alltoallw.html
/usr/bin/install -c -m 644 MPI_Attr_delete.html /usr/local/share/doc//www3/MPI_Attr_delete.html
/usr/bin/install -c -m 644 MPI_Attr_get.html /usr/local/share/doc//www3/MPI_Attr_get.html
/usr/bin/install -c -m 644 MPI_Attr_put.html /usr/local/share/doc//www3/MPI_Attr_put.html
/usr/bin/install -c -m 644 MPI_Barrier.html /usr/local/share/doc//www3/MPI_Barrier.html
/usr/bin/install -c -m 644 MPI_Bcast.html /usr/local/share/doc//www3/MPI_Bcast.html
/usr/bin/install -c -m 644 MPI_Bsend.html /usr/local/share/doc//www3/MPI_Bsend.html
/usr/bin/install -c -m 644 MPI_Bsend_init.html /usr/local/share/doc//www3/MPI_Bsend_init.html
/usr/bin/install -c -m 644 MPI_Buffer_attach.html /usr/local/share/doc//www3/MPI_Buffer_attach.html
/usr/bin/install -c -m 644 MPI_Buffer_detach.html /usr/local/share/doc//www3/MPI_Buffer_detach.html
/usr/bin/install -c -m 644 MPI_Cancel.html /usr/local/share/doc//www3/MPI_Cancel.html
/usr/bin/install -c -m 644 MPI_Cart_coords.html /usr/local/share/doc//www3/MPI_Cart_coords.html
/usr/bin/install -c -m 644 MPI_Cart_create.html /usr/local/share/doc//www3/MPI_Cart_create.html
/usr/bin/install -c -m 644 MPI_Cart_get.html /usr/local/share/doc//www3/MPI_Cart_get.html
/usr/bin/install -c -m 644 MPI_Cart_map.html /usr/local/share/doc//www3/MPI_Cart_map.html
/usr/bin/install -c -m 644 MPI_Cart_rank.html /usr/local/share/doc//www3/MPI_Cart_rank.html
/usr/bin/install -c -m 644 MPI_Cart_shift.html /usr/local/share/doc//www3/MPI_Cart_shift.html
/usr/bin/install -c -m 644 MPI_Cart_sub.html /usr/local/share/doc//www3/MPI_Cart_sub.html
/usr/bin/install -c -m 644 MPI_Cartdim_get.html /usr/local/share/doc//www3/MPI_Cartdim_get.html
/usr/bin/install -c -m 644 MPI_Close_port.html /usr/local/share/doc//www3/MPI_Close_port.html
/usr/bin/install -c -m 644 MPI_Comm_accept.html /usr/local/share/doc//www3/MPI_Comm_accept.html
/usr/bin/install -c -m 644 MPI_Comm_call_errhandler.html /usr/local/share/doc//www3/MPI_Comm_call_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_compare.html /usr/local/share/doc//www3/MPI_Comm_compare.html
/usr/bin/install -c -m 644 MPI_Comm_connect.html /usr/local/share/doc//www3/MPI_Comm_connect.html
/usr/bin/install -c -m 644 MPI_Comm_create.html /usr/local/share/doc//www3/MPI_Comm_create.html
/usr/bin/install -c -m 644 MPI_Comm_create_errhandler.html /usr/local/share/doc//www3/MPI_Comm_create_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_create_keyval.html /usr/local/share/doc//www3/MPI_Comm_create_keyval.html
/usr/bin/install -c -m 644 MPI_Comm_delete_attr.html /usr/local/share/doc//www3/MPI_Comm_delete_attr.html
/usr/bin/install -c -m 644 MPI_Comm_disconnect.html /usr/local/share/doc//www3/MPI_Comm_disconnect.html
/usr/bin/install -c -m 644 MPI_Comm_dup.html /usr/local/share/doc//www3/MPI_Comm_dup.html
/usr/bin/install -c -m 644 MPI_Comm_free.html /usr/local/share/doc//www3/MPI_Comm_free.html
/usr/bin/install -c -m 644 MPI_Comm_free_keyval.html /usr/local/share/doc//www3/MPI_Comm_free_keyval.html
/usr/bin/install -c -m 644 MPI_Comm_get_attr.html /usr/local/share/doc//www3/MPI_Comm_get_attr.html
/usr/bin/install -c -m 644 MPI_Comm_get_errhandler.html /usr/local/share/doc//www3/MPI_Comm_get_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_get_name.html /usr/local/share/doc//www3/MPI_Comm_get_name.html
/usr/bin/install -c -m 644 MPI_Comm_get_parent.html /usr/local/share/doc//www3/MPI_Comm_get_parent.html
/usr/bin/install -c -m 644 MPI_Comm_group.html /usr/local/share/doc//www3/MPI_Comm_group.html
/usr/bin/install -c -m 644 MPI_Comm_join.html /usr/local/share/doc//www3/MPI_Comm_join.html
/usr/bin/install -c -m 644 MPI_Comm_rank.html /usr/local/share/doc//www3/MPI_Comm_rank.html
/usr/bin/install -c -m 644 MPI_Comm_remote_group.html /usr/local/share/doc//www3/MPI_Comm_remote_group.html
/usr/bin/install -c -m 644 MPI_Comm_remote_size.html /usr/local/share/doc//www3/MPI_Comm_remote_size.html
/usr/bin/install -c -m 644 MPI_Comm_set_attr.html /usr/local/share/doc//www3/MPI_Comm_set_attr.html
/usr/bin/install -c -m 644 MPI_Comm_set_errhandler.html /usr/local/share/doc//www3/MPI_Comm_set_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_set_name.html /usr/local/share/doc//www3/MPI_Comm_set_name.html
/usr/bin/install -c -m 644 MPI_Comm_size.html /usr/local/share/doc//www3/MPI_Comm_size.html
/usr/bin/install -c -m 644 MPI_Comm_spawn.html /usr/local/share/doc//www3/MPI_Comm_spawn.html
/usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.html /usr/local/share/doc//www3/MPI_Comm_spawn_multiple.html
/usr/bin/install -c -m 644 MPI_Comm_split.html /usr/local/share/doc//www3/MPI_Comm_split.html
/usr/bin/install -c -m 644 MPI_Comm_test_inter.html /usr/local/share/doc//www3/MPI_Comm_test_inter.html
/usr/bin/install -c -m 644 MPI_Dims_create.html /usr/local/share/doc//www3/MPI_Dims_create.html
/usr/bin/install -c -m 644 MPI_Dist_graph_create.html /usr/local/share/doc//www3/MPI_Dist_graph_create.html
/usr/bin/install -c -m 644 MPI_Dist_graph_create_adjacent.html /usr/local/share/doc//www3/MPI_Dist_graph_create_adjacent.html
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors.html /usr/local/share/doc//www3/MPI_Dist_graph_neighbors.html
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors_count.html /usr/local/share/doc//www3/MPI_Dist_graph_neighbors_count.html
/usr/bin/install -c -m 644 MPI_Errhandler_create.html /usr/local/share/doc//www3/MPI_Errhandler_create.html
/usr/bin/install -c -m 644 MPI_Errhandler_free.html /usr/local/share/doc//www3/MPI_Errhandler_free.html
/usr/bin/install -c -m 644 MPI_Errhandler_get.html /usr/local/share/doc//www3/MPI_Errhandler_get.html
/usr/bin/install -c -m 644 MPI_Errhandler_set.html /usr/local/share/doc//www3/MPI_Errhandler_set.html
/usr/bin/install -c -m 644 MPI_Error_class.html /usr/local/share/doc//www3/MPI_Error_class.html
/usr/bin/install -c -m 644 MPI_Error_string.html /usr/local/share/doc//www3/MPI_Error_string.html
/usr/bin/install -c -m 644 MPI_Exscan.html /usr/local/share/doc//www3/MPI_Exscan.html
/usr/bin/install -c -m 644 MPI_File_c2f.html /usr/local/share/doc//www3/MPI_File_c2f.html
/usr/bin/install -c -m 644 MPI_File_call_errhandler.html /usr/local/share/doc//www3/MPI_File_call_errhandler.html
/usr/bin/install -c -m 644 MPI_File_close.html /usr/local/share/doc//www3/MPI_File_close.html
/usr/bin/install -c -m 644 MPI_File_create_errhandler.html /usr/local/share/doc//www3/MPI_File_create_errhandler.html
/usr/bin/install -c -m 644 MPI_File_delete.html /usr/local/share/doc//www3/MPI_File_delete.html
/usr/bin/install -c -m 644 MPI_File_f2c.html /usr/local/share/doc//www3/MPI_File_f2c.html
/usr/bin/install -c -m 644 MPI_File_get_amode.html /usr/local/share/doc//www3/MPI_File_get_amode.html
/usr/bin/install -c -m 644 MPI_File_get_atomicity.html /usr/local/share/doc//www3/MPI_File_get_atomicity.html
/usr/bin/install -c -m 644 MPI_File_get_byte_offset.html /usr/local/share/doc//www3/MPI_File_get_byte_offset.html
/usr/bin/install -c -m 644 MPI_File_get_errhandler.html /usr/local/share/doc//www3/MPI_File_get_errhandler.html
/usr/bin/install -c -m 644 MPI_File_get_group.html /usr/local/share/doc//www3/MPI_File_get_group.html
/usr/bin/install -c -m 644 MPI_File_get_info.html /usr/local/share/doc//www3/MPI_File_get_info.html
/usr/bin/install -c -m 644 MPI_File_get_position.html /usr/local/share/doc//www3/MPI_File_get_position.html
/usr/bin/install -c -m 644 MPI_File_get_position_shared.html /usr/local/share/doc//www3/MPI_File_get_position_shared.html
/usr/bin/install -c -m 644 MPI_File_get_size.html /usr/local/share/doc//www3/MPI_File_get_size.html
/usr/bin/install -c -m 644 MPI_File_get_type_extent.html /usr/local/share/doc//www3/MPI_File_get_type_extent.html
/usr/bin/install -c -m 644 MPI_File_get_view.html /usr/local/share/doc//www3/MPI_File_get_view.html
/usr/bin/install -c -m 644 MPI_File_iread.html /usr/local/share/doc//www3/MPI_File_iread.html
/usr/bin/install -c -m 644 MPI_File_iread_at.html /usr/local/share/doc//www3/MPI_File_iread_at.html
/usr/bin/install -c -m 644 MPI_File_iread_shared.html /usr/local/share/doc//www3/MPI_File_iread_shared.html
/usr/bin/install -c -m 644 MPI_File_iwrite.html /usr/local/share/doc//www3/MPI_File_iwrite.html
/usr/bin/install -c -m 644 MPI_File_iwrite_at.html /usr/local/share/doc//www3/MPI_File_iwrite_at.html
/usr/bin/install -c -m 644 MPI_File_iwrite_shared.html /usr/local/share/doc//www3/MPI_File_iwrite_shared.html
/usr/bin/install -c -m 644 MPI_File_open.html /usr/local/share/doc//www3/MPI_File_open.html
/usr/bin/install -c -m 644 MPI_File_preallocate.html /usr/local/share/doc//www3/MPI_File_preallocate.html
/usr/bin/install -c -m 644 MPI_File_read.html /usr/local/share/doc//www3/MPI_File_read.html
/usr/bin/install -c -m 644 MPI_File_read_all.html /usr/local/share/doc//www3/MPI_File_read_all.html
/usr/bin/install -c -m 644 MPI_File_read_all_begin.html /usr/local/share/doc//www3/MPI_File_read_all_begin.html
/usr/bin/install -c -m 644 MPI_File_read_all_end.html /usr/local/share/doc//www3/MPI_File_read_all_end.html
/usr/bin/install -c -m 644 MPI_File_read_at.html /usr/local/share/doc//www3/MPI_File_read_at.html
/usr/bin/install -c -m 644 MPI_File_read_at_all.html /usr/local/share/doc//www3/MPI_File_read_at_all.html
/usr/bin/install -c -m 644 MPI_File_read_at_all_begin.html /usr/local/share/doc//www3/MPI_File_read_at_all_begin.html
/usr/bin/install -c -m 644 MPI_File_read_at_all_end.html /usr/local/share/doc//www3/MPI_File_read_at_all_end.html
/usr/bin/install -c -m 644 MPI_File_read_ordered.html /usr/local/share/doc//www3/MPI_File_read_ordered.html
/usr/bin/install -c -m 644 MPI_File_read_ordered_begin.html /usr/local/share/doc//www3/MPI_File_read_ordered_begin.html
/usr/bin/install -c -m 644 MPI_File_read_ordered_end.html /usr/local/share/doc//www3/MPI_File_read_ordered_end.html
/usr/bin/install -c -m 644 MPI_File_read_shared.html /usr/local/share/doc//www3/MPI_File_read_shared.html
/usr/bin/install -c -m 644 MPI_File_seek.html /usr/local/share/doc//www3/MPI_File_seek.html
/usr/bin/install -c -m 644 MPI_File_seek_shared.html /usr/local/share/doc//www3/MPI_File_seek_shared.html
/usr/bin/install -c -m 644 MPI_File_set_atomicity.html /usr/local/share/doc//www3/MPI_File_set_atomicity.html
/usr/bin/install -c -m 644 MPI_File_set_errhandler.html /usr/local/share/doc//www3/MPI_File_set_errhandler.html
/usr/bin/install -c -m 644 MPI_File_set_info.html /usr/local/share/doc//www3/MPI_File_set_info.html
/usr/bin/install -c -m 644 MPI_File_set_size.html /usr/local/share/doc//www3/MPI_File_set_size.html
/usr/bin/install -c -m 644 MPI_File_set_view.html /usr/local/share/doc//www3/MPI_File_set_view.html
/usr/bin/install -c -m 644 MPI_File_sync.html /usr/local/share/doc//www3/MPI_File_sync.html
/usr/bin/install -c -m 644 MPI_File_write.html /usr/local/share/doc//www3/MPI_File_write.html
/usr/bin/install -c -m 644 MPI_File_write_all.html /usr/local/share/doc//www3/MPI_File_write_all.html
/usr/bin/install -c -m 644 MPI_File_write_all_begin.html /usr/local/share/doc//www3/MPI_File_write_all_begin.html
/usr/bin/install -c -m 644 MPI_File_write_all_end.html /usr/local/share/doc//www3/MPI_File_write_all_end.html
/usr/bin/install -c -m 644 MPI_File_write_at.html /usr/local/share/doc//www3/MPI_File_write_at.html
/usr/bin/install -c -m 644 MPI_File_write_at_all.html /usr/local/share/doc//www3/MPI_File_write_at_all.html
/usr/bin/install -c -m 644 MPI_File_write_at_all_begin.html /usr/local/share/doc//www3/MPI_File_write_at_all_begin.html
/usr/bin/install -c -m 644 MPI_File_write_at_all_end.html /usr/local/share/doc//www3/MPI_File_write_at_all_end.html
/usr/bin/install -c -m 644 MPI_File_write_ordered.html /usr/local/share/doc//www3/MPI_File_write_ordered.html
/usr/bin/install -c -m 644 MPI_File_write_ordered_begin.html /usr/local/share/doc//www3/MPI_File_write_ordered_begin.html
/usr/bin/install -c -m 644 MPI_File_write_ordered_end.html /usr/local/share/doc//www3/MPI_File_write_ordered_end.html
/usr/bin/install -c -m 644 MPI_File_write_shared.html /usr/local/share/doc//www3/MPI_File_write_shared.html
/usr/bin/install -c -m 644 MPI_Finalize.html /usr/local/share/doc//www3/MPI_Finalize.html
/usr/bin/install -c -m 644 MPI_Finalized.html /usr/local/share/doc//www3/MPI_Finalized.html
/usr/bin/install -c -m 644 MPI_Free_mem.html /usr/local/share/doc//www3/MPI_Free_mem.html
/usr/bin/install -c -m 644 MPI_Gather.html /usr/local/share/doc//www3/MPI_Gather.html
/usr/bin/install -c -m 644 MPI_Gatherv.html /usr/local/share/doc//www3/MPI_Gatherv.html
/usr/bin/install -c -m 644 MPI_Get.html /usr/local/share/doc//www3/MPI_Get.html
/usr/bin/install -c -m 644 MPI_Get_address.html /usr/local/share/doc//www3/MPI_Get_address.html
/usr/bin/install -c -m 644 MPI_Get_count.html /usr/local/share/doc//www3/MPI_Get_count.html
/usr/bin/install -c -m 644 MPI_Get_elements.html /usr/local/share/doc//www3/MPI_Get_elements.html
/usr/bin/install -c -m 644 MPI_Get_processor_name.html /usr/local/share/doc//www3/MPI_Get_processor_name.html
/usr/bin/install -c -m 644 MPI_Get_version.html /usr/local/share/doc//www3/MPI_Get_version.html
/usr/bin/install -c -m 644 MPI_Graph_create.html /usr/local/share/doc//www3/MPI_Graph_create.html
/usr/bin/install -c -m 644 MPI_Graph_get.html /usr/local/share/doc//www3/MPI_Graph_get.html
/usr/bin/install -c -m 644 MPI_Graph_map.html /usr/local/share/doc//www3/MPI_Graph_map.html
/usr/bin/install -c -m 644 MPI_Graph_neighbors.html /usr/local/share/doc//www3/MPI_Graph_neighbors.html
/usr/bin/install -c -m 644 MPI_Graph_neighbors_count.html /usr/local/share/doc//www3/MPI_Graph_neighbors_count.html
/usr/bin/install -c -m 644 MPI_Graphdims_get.html /usr/local/share/doc//www3/MPI_Graphdims_get.html
/usr/bin/install -c -m 644 MPI_Grequest_complete.html /usr/local/share/doc//www3/MPI_Grequest_complete.html
/usr/bin/install -c -m 644 MPI_Grequest_start.html /usr/local/share/doc//www3/MPI_Grequest_start.html
/usr/bin/install -c -m 644 MPI_Group_compare.html /usr/local/share/doc//www3/MPI_Group_compare.html
/usr/bin/install -c -m 644 MPI_Group_difference.html /usr/local/share/doc//www3/MPI_Group_difference.html
/usr/bin/install -c -m 644 MPI_Group_excl.html /usr/local/share/doc//www3/MPI_Group_excl.html
/usr/bin/install -c -m 644 MPI_Group_free.html /usr/local/share/doc//www3/MPI_Group_free.html
/usr/bin/install -c -m 644 MPI_Group_incl.html /usr/local/share/doc//www3/MPI_Group_incl.html
/usr/bin/install -c -m 644 MPI_Group_intersection.html /usr/local/share/doc//www3/MPI_Group_intersection.html
/usr/bin/install -c -m 644 MPI_Group_range_excl.html /usr/local/share/doc//www3/MPI_Group_range_excl.html
/usr/bin/install -c -m 644 MPI_Group_range_incl.html /usr/local/share/doc//www3/MPI_Group_range_incl.html
/usr/bin/install -c -m 644 MPI_Group_rank.html /usr/local/share/doc//www3/MPI_Group_rank.html
/usr/bin/install -c -m 644 MPI_Group_size.html /usr/local/share/doc//www3/MPI_Group_size.html
/usr/bin/install -c -m 644 MPI_Group_translate_ranks.html /usr/local/share/doc//www3/MPI_Group_translate_ranks.html
/usr/bin/install -c -m 644 MPI_Group_union.html /usr/local/share/doc//www3/MPI_Group_union.html
/usr/bin/install -c -m 644 MPI_Ibsend.html /usr/local/share/doc//www3/MPI_Ibsend.html
/usr/bin/install -c -m 644 MPI_Info_create.html /usr/local/share/doc//www3/MPI_Info_create.html
/usr/bin/install -c -m 644 MPI_Info_delete.html /usr/local/share/doc//www3/MPI_Info_delete.html
/usr/bin/install -c -m 644 MPI_Info_dup.html /usr/local/share/doc//www3/MPI_Info_dup.html
/usr/bin/install -c -m 644 MPI_Info_free.html /usr/local/share/doc//www3/MPI_Info_free.html
/usr/bin/install -c -m 644 MPI_Info_get.html /usr/local/share/doc//www3/MPI_Info_get.html
/usr/bin/install -c -m 644 MPI_Info_get_nkeys.html /usr/local/share/doc//www3/MPI_Info_get_nkeys.html
/usr/bin/install -c -m 644 MPI_Info_get_nthkey.html /usr/local/share/doc//www3/MPI_Info_get_nthkey.html
/usr/bin/install -c -m 644 MPI_Info_get_valuelen.html /usr/local/share/doc//www3/MPI_Info_get_valuelen.html
/usr/bin/install -c -m 644 MPI_Info_set.html /usr/local/share/doc//www3/MPI_Info_set.html
/usr/bin/install -c -m 644 MPI_Init.html /usr/local/share/doc//www3/MPI_Init.html
/usr/bin/install -c -m 644 MPI_Init_thread.html /usr/local/share/doc//www3/MPI_Init_thread.html
/usr/bin/install -c -m 644 MPI_Initialized.html /usr/local/share/doc//www3/MPI_Initialized.html
/usr/bin/install -c -m 644 MPI_Intercomm_create.html /usr/local/share/doc//www3/MPI_Intercomm_create.html
/usr/bin/install -c -m 644 MPI_Intercomm_merge.html /usr/local/share/doc//www3/MPI_Intercomm_merge.html
/usr/bin/install -c -m 644 MPI_Iprobe.html /usr/local/share/doc//www3/MPI_Iprobe.html
/usr/bin/install -c -m 644 MPI_Irecv.html /usr/local/share/doc//www3/MPI_Irecv.html
/usr/bin/install -c -m 644 MPI_Irsend.html /usr/local/share/doc//www3/MPI_Irsend.html
/usr/bin/install -c -m 644 MPI_Is_thread_main.html /usr/local/share/doc//www3/MPI_Is_thread_main.html
/usr/bin/install -c -m 644 MPI_Isend.html /usr/local/share/doc//www3/MPI_Isend.html
/usr/bin/install -c -m 644 MPI_Issend.html /usr/local/share/doc//www3/MPI_Issend.html
/usr/bin/install -c -m 644 MPI_Keyval_create.html /usr/local/share/doc//www3/MPI_Keyval_create.html
/usr/bin/install -c -m 644 MPI_Keyval_free.html /usr/local/share/doc//www3/MPI_Keyval_free.html
/usr/bin/install -c -m 644 MPI_Lookup_name.html /usr/local/share/doc//www3/MPI_Lookup_name.html
/usr/bin/install -c -m 644 MPI_Op_commute.html /usr/local/share/doc//www3/MPI_Op_commute.html
/usr/bin/install -c -m 644 MPI_Op_create.html /usr/local/share/doc//www3/MPI_Op_create.html
/usr/bin/install -c -m 644 MPI_Op_free.html /usr/local/share/doc//www3/MPI_Op_free.html
/usr/bin/install -c -m 644 MPI_Open_port.html /usr/local/share/doc//www3/MPI_Open_port.html
/usr/bin/install -c -m 644 MPI_Pack.html /usr/local/share/doc//www3/MPI_Pack.html
/usr/bin/install -c -m 644 MPI_Pack_external.html /usr/local/share/doc//www3/MPI_Pack_external.html
/usr/bin/install -c -m 644 MPI_Pack_external_size.html /usr/local/share/doc//www3/MPI_Pack_external_size.html
/usr/bin/install -c -m 644 MPI_Pack_size.html /usr/local/share/doc//www3/MPI_Pack_size.html
/usr/bin/install -c -m 644 MPI_Pcontrol.html /usr/local/share/doc//www3/MPI_Pcontrol.html
/usr/bin/install -c -m 644 MPI_Probe.html /usr/local/share/doc//www3/MPI_Probe.html
/usr/bin/install -c -m 644 MPI_Publish_name.html /usr/local/share/doc//www3/MPI_Publish_name.html
/usr/bin/install -c -m 644 MPI_Put.html /usr/local/share/doc//www3/MPI_Put.html
/usr/bin/install -c -m 644 MPI_Query_thread.html /usr/local/share/doc//www3/MPI_Query_thread.html
/usr/bin/install -c -m 644 MPI_Recv.html /usr/local/share/doc//www3/MPI_Recv.html
/usr/bin/install -c -m 644 MPI_Recv_init.html /usr/local/share/doc//www3/MPI_Recv_init.html
/usr/bin/install -c -m 644 MPI_Reduce.html /usr/local/share/doc//www3/MPI_Reduce.html
/usr/bin/install -c -m 644 MPI_Reduce_local.html /usr/local/share/doc//www3/MPI_Reduce_local.html
/usr/bin/install -c -m 644 MPI_Reduce_scatter.html /usr/local/share/doc//www3/MPI_Reduce_scatter.html
/usr/bin/install -c -m 644 MPI_Reduce_scatter_block.html /usr/local/share/doc//www3/MPI_Reduce_scatter_block.html
/usr/bin/install -c -m 644 MPI_Register_datarep.html /usr/local/share/doc//www3/MPI_Register_datarep.html
/usr/bin/install -c -m 644 MPI_Request_free.html /usr/local/share/doc//www3/MPI_Request_free.html
/usr/bin/install -c -m 644 MPI_Request_get_status.html /usr/local/share/doc//www3/MPI_Request_get_status.html
/usr/bin/install -c -m 644 MPI_Rsend.html /usr/local/share/doc//www3/MPI_Rsend.html
/usr/bin/install -c -m 644 MPI_Rsend_init.html /usr/local/share/doc//www3/MPI_Rsend_init.html
/usr/bin/install -c -m 644 MPI_Scan.html /usr/local/share/doc//www3/MPI_Scan.html
/usr/bin/install -c -m 644 MPI_Scatter.html /usr/local/share/doc//www3/MPI_Scatter.html
/usr/bin/install -c -m 644 MPI_Scatterv.html /usr/local/share/doc//www3/MPI_Scatterv.html
/usr/bin/install -c -m 644 MPI_Send.html /usr/local/share/doc//www3/MPI_Send.html
/usr/bin/install -c -m 644 MPI_Send_init.html /usr/local/share/doc//www3/MPI_Send_init.html
/usr/bin/install -c -m 644 MPI_Sendrecv.html /usr/local/share/doc//www3/MPI_Sendrecv.html
/usr/bin/install -c -m 644 MPI_Sendrecv_replace.html /usr/local/share/doc//www3/MPI_Sendrecv_replace.html
/usr/bin/install -c -m 644 MPI_Ssend.html /usr/local/share/doc//www3/MPI_Ssend.html
/usr/bin/install -c -m 644 MPI_Ssend_init.html /usr/local/share/doc//www3/MPI_Ssend_init.html
/usr/bin/install -c -m 644 MPI_Start.html /usr/local/share/doc//www3/MPI_Start.html
/usr/bin/install -c -m 644 MPI_Startall.html /usr/local/share/doc//www3/MPI_Startall.html
/usr/bin/install -c -m 644 MPI_Status_set_cancelled.html /usr/local/share/doc//www3/MPI_Status_set_cancelled.html
/usr/bin/install -c -m 644 MPI_Status_set_elements.html /usr/local/share/doc//www3/MPI_Status_set_elements.html
/usr/bin/install -c -m 644 MPI_Test.html /usr/local/share/doc//www3/MPI_Test.html
/usr/bin/install -c -m 644 MPI_Test_cancelled.html /usr/local/share/doc//www3/MPI_Test_cancelled.html
/usr/bin/install -c -m 644 MPI_Testall.html /usr/local/share/doc//www3/MPI_Testall.html
/usr/bin/install -c -m 644 MPI_Testany.html /usr/local/share/doc//www3/MPI_Testany.html
/usr/bin/install -c -m 644 MPI_Testsome.html /usr/local/share/doc//www3/MPI_Testsome.html
/usr/bin/install -c -m 644 MPI_Topo_test.html /usr/local/share/doc//www3/MPI_Topo_test.html
/usr/bin/install -c -m 644 MPI_Type_commit.html /usr/local/share/doc//www3/MPI_Type_commit.html
/usr/bin/install -c -m 644 MPI_Type_contiguous.html /usr/local/share/doc//www3/MPI_Type_contiguous.html
/usr/bin/install -c -m 644 MPI_Type_create_darray.html /usr/local/share/doc//www3/MPI_Type_create_darray.html
/usr/bin/install -c -m 644 MPI_Type_create_hindexed.html /usr/local/share/doc//www3/MPI_Type_create_hindexed.html
/usr/bin/install -c -m 644 MPI_Type_create_hvector.html /usr/local/share/doc//www3/MPI_Type_create_hvector.html
/usr/bin/install -c -m 644 MPI_Type_create_indexed_block.html /usr/local/share/doc//www3/MPI_Type_create_indexed_block.html
/usr/bin/install -c -m 644 MPI_Type_create_keyval.html /usr/local/share/doc//www3/MPI_Type_create_keyval.html
/usr/bin/install -c -m 644 MPI_Type_create_resized.html /usr/local/share/doc//www3/MPI_Type_create_resized.html
/usr/bin/install -c -m 644 MPI_Type_create_struct.html /usr/local/share/doc//www3/MPI_Type_create_struct.html
/usr/bin/install -c -m 644 MPI_Type_create_subarray.html /usr/local/share/doc//www3/MPI_Type_create_subarray.html
/usr/bin/install -c -m 644 MPI_Type_delete_attr.html /usr/local/share/doc//www3/MPI_Type_delete_attr.html
/usr/bin/install -c -m 644 MPI_Type_dup.html /usr/local/share/doc//www3/MPI_Type_dup.html
/usr/bin/install -c -m 644 MPI_Type_extent.html /usr/local/share/doc//www3/MPI_Type_extent.html
/usr/bin/install -c -m 644 MPI_Type_free.html /usr/local/share/doc//www3/MPI_Type_free.html
/usr/bin/install -c -m 644 MPI_Type_free_keyval.html /usr/local/share/doc//www3/MPI_Type_free_keyval.html
/usr/bin/install -c -m 644 MPI_Type_get_attr.html /usr/local/share/doc//www3/MPI_Type_get_attr.html
/usr/bin/install -c -m 644 MPI_Type_get_contents.html /usr/local/share/doc//www3/MPI_Type_get_contents.html
/usr/bin/install -c -m 644 MPI_Type_get_envelope.html /usr/local/share/doc//www3/MPI_Type_get_envelope.html
/usr/bin/install -c -m 644 MPI_Type_get_extent.html /usr/local/share/doc//www3/MPI_Type_get_extent.html
/usr/bin/install -c -m 644 MPI_Type_get_name.html /usr/local/share/doc//www3/MPI_Type_get_name.html
/usr/bin/install -c -m 644 MPI_Type_get_true_extent.html /usr/local/share/doc//www3/MPI_Type_get_true_extent.html
/usr/bin/install -c -m 644 MPI_Type_hindexed.html /usr/local/share/doc//www3/MPI_Type_hindexed.html
/usr/bin/install -c -m 644 MPI_Type_hvector.html /usr/local/share/doc//www3/MPI_Type_hvector.html
/usr/bin/install -c -m 644 MPI_Type_indexed.html /usr/local/share/doc//www3/MPI_Type_indexed.html
/usr/bin/install -c -m 644 MPI_Type_lb.html /usr/local/share/doc//www3/MPI_Type_lb.html
/usr/bin/install -c -m 644 MPI_Type_match_size.html /usr/local/share/doc//www3/MPI_Type_match_size.html
/usr/bin/install -c -m 644 MPI_Type_set_attr.html /usr/local/share/doc//www3/MPI_Type_set_attr.html
/usr/bin/install -c -m 644 MPI_Type_set_name.html /usr/local/share/doc//www3/MPI_Type_set_name.html
/usr/bin/install -c -m 644 MPI_Type_size.html /usr/local/share/doc//www3/MPI_Type_size.html
/usr/bin/install -c -m 644 MPI_Type_struct.html /usr/local/share/doc//www3/MPI_Type_struct.html
/usr/bin/install -c -m 644 MPI_Type_ub.html /usr/local/share/doc//www3/MPI_Type_ub.html
/usr/bin/install -c -m 644 MPI_Type_vector.html /usr/local/share/doc//www3/MPI_Type_vector.html
/usr/bin/install -c -m 644 MPI_Unpack.html /usr/local/share/doc//www3/MPI_Unpack.html
/usr/bin/install -c -m 644 MPI_Unpack_external.html /usr/local/share/doc//www3/MPI_Unpack_external.html
/usr/bin/install -c -m 644 MPI_Unpublish_name.html /usr/local/share/doc//www3/MPI_Unpublish_name.html
/usr/bin/install -c -m 644 MPI_Wait.html /usr/local/share/doc//www3/MPI_Wait.html
/usr/bin/install -c -m 644 MPI_Waitall.html /usr/local/share/doc//www3/MPI_Waitall.html
/usr/bin/install -c -m 644 MPI_Waitany.html /usr/local/share/doc//www3/MPI_Waitany.html
/usr/bin/install -c -m 644 MPI_Waitsome.html /usr/local/share/doc//www3/MPI_Waitsome.html
/usr/bin/install -c -m 644 MPI_Win_call_errhandler.html /usr/local/share/doc//www3/MPI_Win_call_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_complete.html /usr/local/share/doc//www3/MPI_Win_complete.html
/usr/bin/install -c -m 644 MPI_Win_create.html /usr/local/share/doc//www3/MPI_Win_create.html
/usr/bin/install -c -m 644 MPI_Win_create_errhandler.html /usr/local/share/doc//www3/MPI_Win_create_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_create_keyval.html /usr/local/share/doc//www3/MPI_Win_create_keyval.html
/usr/bin/install -c -m 644 MPI_Win_delete_attr.html /usr/local/share/doc//www3/MPI_Win_delete_attr.html
/usr/bin/install -c -m 644 MPI_Win_fence.html /usr/local/share/doc//www3/MPI_Win_fence.html
/usr/bin/install -c -m 644 MPI_Win_free.html /usr/local/share/doc//www3/MPI_Win_free.html
/usr/bin/install -c -m 644 MPI_Win_free_keyval.html /usr/local/share/doc//www3/MPI_Win_free_keyval.html
/usr/bin/install -c -m 644 MPI_Win_get_attr.html /usr/local/share/doc//www3/MPI_Win_get_attr.html
/usr/bin/install -c -m 644 MPI_Win_get_errhandler.html /usr/local/share/doc//www3/MPI_Win_get_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_get_group.html /usr/local/share/doc//www3/MPI_Win_get_group.html
/usr/bin/install -c -m 644 MPI_Win_get_name.html /usr/local/share/doc//www3/MPI_Win_get_name.html
/usr/bin/install -c -m 644 MPI_Win_lock.html /usr/local/share/doc//www3/MPI_Win_lock.html
/usr/bin/install -c -m 644 MPI_Win_post.html /usr/local/share/doc//www3/MPI_Win_post.html
/usr/bin/install -c -m 644 MPI_Win_set_attr.html /usr/local/share/doc//www3/MPI_Win_set_attr.html
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.html /usr/local/share/doc//www3/MPI_Win_set_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_set_name.html /usr/local/share/doc//www3/MPI_Win_set_name.html
/usr/bin/install -c -m 644 MPI_Win_start.html /usr/local/share/doc//www3/MPI_Win_start.html
/usr/bin/install -c -m 644 MPI_Win_test.html /usr/local/share/doc//www3/MPI_Win_test.html
/usr/bin/install -c -m 644 MPI_Win_unlock.html /usr/local/share/doc//www3/MPI_Win_unlock.html
/usr/bin/install -c -m 644 MPI_Win_wait.html /usr/local/share/doc//www3/MPI_Win_wait.html
/usr/bin/install -c -m 644 MPI_Wtick.html /usr/local/share/doc//www3/MPI_Wtick.html
/usr/bin/install -c -m 644 MPI_Wtime.html /usr/local/share/doc//www3/MPI_Wtime.html
/usr/bin/install -c -m 644 index.htm /usr/local/share/doc//www3/index.htm
/usr/bin/install -c -m 644 MPI.1 /usr/local/share/man/man1/MPI.1
/usr/bin/install -c -m 644 mpicc.1 /usr/local/share/man/man1/mpicc.1
/usr/bin/install -c -m 644 mpicxx.1 /usr/local/share/man/man1/mpicxx.1
/usr/bin/install -c -m 644 mpiexec.1 /usr/local/share/man/man1/mpiexec.1
/usr/bin/install -c -m 644 mpif77.1 /usr/local/share/man/man1/mpif77.1
/usr/bin/install -c -m 644 mpif90.1 /usr/local/share/man/man1/mpif90.1
/usr/bin/install -c -m 644 MPIX_Group_comm_create.3 /usr/local/share/man/man3/MPIX_Group_comm_create.3
/usr/bin/install -c -m 644 MPI_Abort.3 /usr/local/share/man/man3/MPI_Abort.3
/usr/bin/install -c -m 644 MPI_Accumulate.3 /usr/local/share/man/man3/MPI_Accumulate.3
/usr/bin/install -c -m 644 MPI_Add_error_class.3 /usr/local/share/man/man3/MPI_Add_error_class.3
/usr/bin/install -c -m 644 MPI_Add_error_code.3 /usr/local/share/man/man3/MPI_Add_error_code.3
/usr/bin/install -c -m 644 MPI_Add_error_string.3 /usr/local/share/man/man3/MPI_Add_error_string.3
/usr/bin/install -c -m 644 MPI_Address.3 /usr/local/share/man/man3/MPI_Address.3
/usr/bin/install -c -m 644 MPI_Allgather.3 /usr/local/share/man/man3/MPI_Allgather.3
/usr/bin/install -c -m 644 MPI_Allgatherv.3 /usr/local/share/man/man3/MPI_Allgatherv.3
/usr/bin/install -c -m 644 MPI_Alloc_mem.3 /usr/local/share/man/man3/MPI_Alloc_mem.3
/usr/bin/install -c -m 644 MPI_Allreduce.3 /usr/local/share/man/man3/MPI_Allreduce.3
/usr/bin/install -c -m 644 MPI_Alltoall.3 /usr/local/share/man/man3/MPI_Alltoall.3
/usr/bin/install -c -m 644 MPI_Alltoallv.3 /usr/local/share/man/man3/MPI_Alltoallv.3
/usr/bin/install -c -m 644 MPI_Alltoallw.3 /usr/local/share/man/man3/MPI_Alltoallw.3
/usr/bin/install -c -m 644 MPI_Attr_delete.3 /usr/local/share/man/man3/MPI_Attr_delete.3
/usr/bin/install -c -m 644 MPI_Attr_get.3 /usr/local/share/man/man3/MPI_Attr_get.3
/usr/bin/install -c -m 644 MPI_Attr_put.3 /usr/local/share/man/man3/MPI_Attr_put.3
/usr/bin/install -c -m 644 MPI_Barrier.3 /usr/local/share/man/man3/MPI_Barrier.3
/usr/bin/install -c -m 644 MPI_Bcast.3 /usr/local/share/man/man3/MPI_Bcast.3
/usr/bin/install -c -m 644 MPI_Bsend.3 /usr/local/share/man/man3/MPI_Bsend.3
/usr/bin/install -c -m 644 MPI_Bsend_init.3 /usr/local/share/man/man3/MPI_Bsend_init.3
/usr/bin/install -c -m 644 MPI_Buffer_attach.3 /usr/local/share/man/man3/MPI_Buffer_attach.3
/usr/bin/install -c -m 644 MPI_Buffer_detach.3 /usr/local/share/man/man3/MPI_Buffer_detach.3
/usr/bin/install -c -m 644 MPI_Cancel.3 /usr/local/share/man/man3/MPI_Cancel.3
/usr/bin/install -c -m 644 MPI_Cart_coords.3 /usr/local/share/man/man3/MPI_Cart_coords.3
/usr/bin/install -c -m 644 MPI_Cart_create.3 /usr/local/share/man/man3/MPI_Cart_create.3
/usr/bin/install -c -m 644 MPI_Cart_get.3 /usr/local/share/man/man3/MPI_Cart_get.3
/usr/bin/install -c -m 644 MPI_Cart_map.3 /usr/local/share/man/man3/MPI_Cart_map.3
/usr/bin/install -c -m 644 MPI_Cart_rank.3 /usr/local/share/man/man3/MPI_Cart_rank.3
/usr/bin/install -c -m 644 MPI_Cart_shift.3 /usr/local/share/man/man3/MPI_Cart_shift.3
/usr/bin/install -c -m 644 MPI_Cart_sub.3 /usr/local/share/man/man3/MPI_Cart_sub.3
/usr/bin/install -c -m 644 MPI_Cartdim_get.3 /usr/local/share/man/man3/MPI_Cartdim_get.3
/usr/bin/install -c -m 644 MPI_Close_port.3 /usr/local/share/man/man3/MPI_Close_port.3
/usr/bin/install -c -m 644 MPI_Comm_accept.3 /usr/local/share/man/man3/MPI_Comm_accept.3
/usr/bin/install -c -m 644 MPI_Comm_call_errhandler.3 /usr/local/share/man/man3/MPI_Comm_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_compare.3 /usr/local/share/man/man3/MPI_Comm_compare.3
/usr/bin/install -c -m 644 MPI_Comm_connect.3 /usr/local/share/man/man3/MPI_Comm_connect.3
/usr/bin/install -c -m 644 MPI_Comm_create.3 /usr/local/share/man/man3/MPI_Comm_create.3
/usr/bin/install -c -m 644 MPI_Comm_create_errhandler.3 /usr/local/share/man/man3/MPI_Comm_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_create_keyval.3 /usr/local/share/man/man3/MPI_Comm_create_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_delete_attr.3 /usr/local/share/man/man3/MPI_Comm_delete_attr.3
/usr/bin/install -c -m 644 MPI_Comm_disconnect.3 /usr/local/share/man/man3/MPI_Comm_disconnect.3
/usr/bin/install -c -m 644 MPI_Comm_dup.3 /usr/local/share/man/man3/MPI_Comm_dup.3
/usr/bin/install -c -m 644 MPI_Comm_free.3 /usr/local/share/man/man3/MPI_Comm_free.3
/usr/bin/install -c -m 644 MPI_Comm_free_keyval.3 /usr/local/share/man/man3/MPI_Comm_free_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_get_attr.3 /usr/local/share/man/man3/MPI_Comm_get_attr.3
/usr/bin/install -c -m 644 MPI_Comm_get_errhandler.3 /usr/local/share/man/man3/MPI_Comm_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_get_name.3 /usr/local/share/man/man3/MPI_Comm_get_name.3
/usr/bin/install -c -m 644 MPI_Comm_get_parent.3 /usr/local/share/man/man3/MPI_Comm_get_parent.3
/usr/bin/install -c -m 644 MPI_Comm_group.3 /usr/local/share/man/man3/MPI_Comm_group.3
/usr/bin/install -c -m 644 MPI_Comm_join.3 /usr/local/share/man/man3/MPI_Comm_join.3
/usr/bin/install -c -m 644 MPI_Comm_rank.3 /usr/local/share/man/man3/MPI_Comm_rank.3
/usr/bin/install -c -m 644 MPI_Comm_remote_group.3 /usr/local/share/man/man3/MPI_Comm_remote_group.3
/usr/bin/install -c -m 644 MPI_Comm_remote_size.3 /usr/local/share/man/man3/MPI_Comm_remote_size.3
/usr/bin/install -c -m 644 MPI_Comm_set_attr.3 /usr/local/share/man/man3/MPI_Comm_set_attr.3
/usr/bin/install -c -m 644 MPI_Comm_set_errhandler.3 /usr/local/share/man/man3/MPI_Comm_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_set_name.3 /usr/local/share/man/man3/MPI_Comm_set_name.3
/usr/bin/install -c -m 644 MPI_Comm_size.3 /usr/local/share/man/man3/MPI_Comm_size.3
/usr/bin/install -c -m 644 MPI_Comm_spawn.3 /usr/local/share/man/man3/MPI_Comm_spawn.3
/usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.3 /usr/local/share/man/man3/MPI_Comm_spawn_multiple.3
/usr/bin/install -c -m 644 MPI_Comm_split.3 /usr/local/share/man/man3/MPI_Comm_split.3
/usr/bin/install -c -m 644 MPI_Comm_test_inter.3 /usr/local/share/man/man3/MPI_Comm_test_inter.3
/usr/bin/install -c -m 644 MPI_Dims_create.3 /usr/local/share/man/man3/MPI_Dims_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create.3 /usr/local/share/man/man3/MPI_Dist_graph_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create_adjacent.3 /usr/local/share/man/man3/MPI_Dist_graph_create_adjacent.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors.3 /usr/local/share/man/man3/MPI_Dist_graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors_count.3 /usr/local/share/man/man3/MPI_Dist_graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Errhandler_create.3 /usr/local/share/man/man3/MPI_Errhandler_create.3
/usr/bin/install -c -m 644 MPI_Errhandler_free.3 /usr/local/share/man/man3/MPI_Errhandler_free.3
/usr/bin/install -c -m 644 MPI_Errhandler_get.3 /usr/local/share/man/man3/MPI_Errhandler_get.3
/usr/bin/install -c -m 644 MPI_Errhandler_set.3 /usr/local/share/man/man3/MPI_Errhandler_set.3
/usr/bin/install -c -m 644 MPI_Error_class.3 /usr/local/share/man/man3/MPI_Error_class.3
/usr/bin/install -c -m 644 MPI_Error_string.3 /usr/local/share/man/man3/MPI_Error_string.3
/usr/bin/install -c -m 644 MPI_Exscan.3 /usr/local/share/man/man3/MPI_Exscan.3
/usr/bin/install -c -m 644 MPI_File_c2f.3 /usr/local/share/man/man3/MPI_File_c2f.3
/usr/bin/install -c -m 644 MPI_File_call_errhandler.3 /usr/local/share/man/man3/MPI_File_call_errhandler.3
/usr/bin/install -c -m 644 MPI_File_close.3 /usr/local/share/man/man3/MPI_File_close.3
/usr/bin/install -c -m 644 MPI_File_create_errhandler.3 /usr/local/share/man/man3/MPI_File_create_errhandler.3
/usr/bin/install -c -m 644 MPI_File_delete.3 /usr/local/share/man/man3/MPI_File_delete.3
/usr/bin/install -c -m 644 MPI_File_f2c.3 /usr/local/share/man/man3/MPI_File_f2c.3
/usr/bin/install -c -m 644 MPI_File_get_amode.3 /usr/local/share/man/man3/MPI_File_get_amode.3
/usr/bin/install -c -m 644 MPI_File_get_atomicity.3 /usr/local/share/man/man3/MPI_File_get_atomicity.3
/usr/bin/install -c -m 644 MPI_File_get_byte_offset.3 /usr/local/share/man/man3/MPI_File_get_byte_offset.3
/usr/bin/install -c -m 644 MPI_File_get_errhandler.3 /usr/local/share/man/man3/MPI_File_get_errhandler.3
/usr/bin/install -c -m 644 MPI_File_get_group.3 /usr/local/share/man/man3/MPI_File_get_group.3
/usr/bin/install -c -m 644 MPI_File_get_info.3 /usr/local/share/man/man3/MPI_File_get_info.3
/usr/bin/install -c -m 644 MPI_File_get_position.3 /usr/local/share/man/man3/MPI_File_get_position.3
/usr/bin/install -c -m 644 MPI_File_get_position_shared.3 /usr/local/share/man/man3/MPI_File_get_position_shared.3
/usr/bin/install -c -m 644 MPI_File_get_size.3 /usr/local/share/man/man3/MPI_File_get_size.3
/usr/bin/install -c -m 644 MPI_File_get_type_extent.3 /usr/local/share/man/man3/MPI_File_get_type_extent.3
/usr/bin/install -c -m 644 MPI_File_get_view.3 /usr/local/share/man/man3/MPI_File_get_view.3
/usr/bin/install -c -m 644 MPI_File_iread.3 /usr/local/share/man/man3/MPI_File_iread.3
/usr/bin/install -c -m 644 MPI_File_iread_at.3 /usr/local/share/man/man3/MPI_File_iread_at.3
/usr/bin/install -c -m 644 MPI_File_iread_shared.3 /usr/local/share/man/man3/MPI_File_iread_shared.3
/usr/bin/install -c -m 644 MPI_File_iwrite.3 /usr/local/share/man/man3/MPI_File_iwrite.3
/usr/bin/install -c -m 644 MPI_File_iwrite_at.3 /usr/local/share/man/man3/MPI_File_iwrite_at.3
/usr/bin/install -c -m 644 MPI_File_iwrite_shared.3 /usr/local/share/man/man3/MPI_File_iwrite_shared.3
/usr/bin/install -c -m 644 MPI_File_open.3 /usr/local/share/man/man3/MPI_File_open.3
/usr/bin/install -c -m 644 MPI_File_preallocate.3 /usr/local/share/man/man3/MPI_File_preallocate.3
/usr/bin/install -c -m 644 MPI_File_read.3 /usr/local/share/man/man3/MPI_File_read.3
/usr/bin/install -c -m 644 MPI_File_read_all.3 /usr/local/share/man/man3/MPI_File_read_all.3
/usr/bin/install -c -m 644 MPI_File_read_all_begin.3 /usr/local/share/man/man3/MPI_File_read_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_all_end.3 /usr/local/share/man/man3/MPI_File_read_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_at.3 /usr/local/share/man/man3/MPI_File_read_at.3
/usr/bin/install -c -m 644 MPI_File_read_at_all.3 /usr/local/share/man/man3/MPI_File_read_at_all.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_begin.3 /usr/local/share/man/man3/MPI_File_read_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_end.3 /usr/local/share/man/man3/MPI_File_read_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_ordered.3 /usr/local/share/man/man3/MPI_File_read_ordered.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_begin.3 /usr/local/share/man/man3/MPI_File_read_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_end.3 /usr/local/share/man/man3/MPI_File_read_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_read_shared.3 /usr/local/share/man/man3/MPI_File_read_shared.3
/usr/bin/install -c -m 644 MPI_File_seek.3 /usr/local/share/man/man3/MPI_File_seek.3
/usr/bin/install -c -m 644 MPI_File_seek_shared.3 /usr/local/share/man/man3/MPI_File_seek_shared.3
/usr/bin/install -c -m 644 MPI_File_set_atomicity.3 /usr/local/share/man/man3/MPI_File_set_atomicity.3
/usr/bin/install -c -m 644 MPI_File_set_errhandler.3 /usr/local/share/man/man3/MPI_File_set_errhandler.3
/usr/bin/install -c -m 644 MPI_File_set_info.3 /usr/local/share/man/man3/MPI_File_set_info.3
/usr/bin/install -c -m 644 MPI_File_set_size.3 /usr/local/share/man/man3/MPI_File_set_size.3
/usr/bin/install -c -m 644 MPI_File_set_view.3 /usr/local/share/man/man3/MPI_File_set_view.3
/usr/bin/install -c -m 644 MPI_File_sync.3 /usr/local/share/man/man3/MPI_File_sync.3
/usr/bin/install -c -m 644 MPI_File_write.3 /usr/local/share/man/man3/MPI_File_write.3
/usr/bin/install -c -m 644 MPI_File_write_all.3 /usr/local/share/man/man3/MPI_File_write_all.3
/usr/bin/install -c -m 644 MPI_File_write_all_begin.3 /usr/local/share/man/man3/MPI_File_write_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_all_end.3 /usr/local/share/man/man3/MPI_File_write_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_at.3 /usr/local/share/man/man3/MPI_File_write_at.3
/usr/bin/install -c -m 644 MPI_File_write_at_all.3 /usr/local/share/man/man3/MPI_File_write_at_all.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_begin.3 /usr/local/share/man/man3/MPI_File_write_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_end.3 /usr/local/share/man/man3/MPI_File_write_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_ordered.3 /usr/local/share/man/man3/MPI_File_write_ordered.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_begin.3 /usr/local/share/man/man3/MPI_File_write_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_end.3 /usr/local/share/man/man3/MPI_File_write_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_write_shared.3 /usr/local/share/man/man3/MPI_File_write_shared.3
/usr/bin/install -c -m 644 MPI_Finalize.3 /usr/local/share/man/man3/MPI_Finalize.3
/usr/bin/install -c -m 644 MPI_Finalized.3 /usr/local/share/man/man3/MPI_Finalized.3
/usr/bin/install -c -m 644 MPI_Free_mem.3 /usr/local/share/man/man3/MPI_Free_mem.3
/usr/bin/install -c -m 644 MPI_Gather.3 /usr/local/share/man/man3/MPI_Gather.3
/usr/bin/install -c -m 644 MPI_Gatherv.3 /usr/local/share/man/man3/MPI_Gatherv.3
/usr/bin/install -c -m 644 MPI_Get.3 /usr/local/share/man/man3/MPI_Get.3
/usr/bin/install -c -m 644 MPI_Get_address.3 /usr/local/share/man/man3/MPI_Get_address.3
/usr/bin/install -c -m 644 MPI_Get_count.3 /usr/local/share/man/man3/MPI_Get_count.3
/usr/bin/install -c -m 644 MPI_Get_elements.3 /usr/local/share/man/man3/MPI_Get_elements.3
/usr/bin/install -c -m 644 MPI_Get_processor_name.3 /usr/local/share/man/man3/MPI_Get_processor_name.3
/usr/bin/install -c -m 644 MPI_Get_version.3 /usr/local/share/man/man3/MPI_Get_version.3
/usr/bin/install -c -m 644 MPI_Graph_create.3 /usr/local/share/man/man3/MPI_Graph_create.3
/usr/bin/install -c -m 644 MPI_Graph_get.3 /usr/local/share/man/man3/MPI_Graph_get.3
/usr/bin/install -c -m 644 MPI_Graph_map.3 /usr/local/share/man/man3/MPI_Graph_map.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors.3 /usr/local/share/man/man3/MPI_Graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors_count.3 /usr/local/share/man/man3/MPI_Graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Graphdims_get.3 /usr/local/share/man/man3/MPI_Graphdims_get.3
/usr/bin/install -c -m 644 MPI_Grequest_complete.3 /usr/local/share/man/man3/MPI_Grequest_complete.3
/usr/bin/install -c -m 644 MPI_Grequest_start.3 /usr/local/share/man/man3/MPI_Grequest_start.3
/usr/bin/install -c -m 644 MPI_Group_compare.3 /usr/local/share/man/man3/MPI_Group_compare.3
/usr/bin/install -c -m 644 MPI_Group_difference.3 /usr/local/share/man/man3/MPI_Group_difference.3
/usr/bin/install -c -m 644 MPI_Group_excl.3 /usr/local/share/man/man3/MPI_Group_excl.3
/usr/bin/install -c -m 644 MPI_Group_free.3 /usr/local/share/man/man3/MPI_Group_free.3
/usr/bin/install -c -m 644 MPI_Group_incl.3 /usr/local/share/man/man3/MPI_Group_incl.3
/usr/bin/install -c -m 644 MPI_Group_intersection.3 /usr/local/share/man/man3/MPI_Group_intersection.3
/usr/bin/install -c -m 644 MPI_Group_range_excl.3 /usr/local/share/man/man3/MPI_Group_range_excl.3
/usr/bin/install -c -m 644 MPI_Group_range_incl.3 /usr/local/share/man/man3/MPI_Group_range_incl.3
/usr/bin/install -c -m 644 MPI_Group_rank.3 /usr/local/share/man/man3/MPI_Group_rank.3
/usr/bin/install -c -m 644 MPI_Group_size.3 /usr/local/share/man/man3/MPI_Group_size.3
/usr/bin/install -c -m 644 MPI_Group_translate_ranks.3 /usr/local/share/man/man3/MPI_Group_translate_ranks.3
/usr/bin/install -c -m 644 MPI_Group_union.3 /usr/local/share/man/man3/MPI_Group_union.3
/usr/bin/install -c -m 644 MPI_Ibsend.3 /usr/local/share/man/man3/MPI_Ibsend.3
/usr/bin/install -c -m 644 MPI_Info_create.3 /usr/local/share/man/man3/MPI_Info_create.3
/usr/bin/install -c -m 644 MPI_Info_delete.3 /usr/local/share/man/man3/MPI_Info_delete.3
/usr/bin/install -c -m 644 MPI_Info_dup.3 /usr/local/share/man/man3/MPI_Info_dup.3
/usr/bin/install -c -m 644 MPI_Info_free.3 /usr/local/share/man/man3/MPI_Info_free.3
/usr/bin/install -c -m 644 MPI_Info_get.3 /usr/local/share/man/man3/MPI_Info_get.3
/usr/bin/install -c -m 644 MPI_Info_get_nkeys.3 /usr/local/share/man/man3/MPI_Info_get_nkeys.3
/usr/bin/install -c -m 644 MPI_Info_get_nthkey.3 /usr/local/share/man/man3/MPI_Info_get_nthkey.3
/usr/bin/install -c -m 644 MPI_Info_get_valuelen.3 /usr/local/share/man/man3/MPI_Info_get_valuelen.3
/usr/bin/install -c -m 644 MPI_Info_set.3 /usr/local/share/man/man3/MPI_Info_set.3
/usr/bin/install -c -m 644 MPI_Init.3 /usr/local/share/man/man3/MPI_Init.3
/usr/bin/install -c -m 644 MPI_Init_thread.3 /usr/local/share/man/man3/MPI_Init_thread.3
/usr/bin/install -c -m 644 MPI_Initialized.3 /usr/local/share/man/man3/MPI_Initialized.3
/usr/bin/install -c -m 644 MPI_Intercomm_create.3 /usr/local/share/man/man3/MPI_Intercomm_create.3
/usr/bin/install -c -m 644 MPI_Intercomm_merge.3 /usr/local/share/man/man3/MPI_Intercomm_merge.3
/usr/bin/install -c -m 644 MPI_Iprobe.3 /usr/local/share/man/man3/MPI_Iprobe.3
/usr/bin/install -c -m 644 MPI_Irecv.3 /usr/local/share/man/man3/MPI_Irecv.3
/usr/bin/install -c -m 644 MPI_Irsend.3 /usr/local/share/man/man3/MPI_Irsend.3
/usr/bin/install -c -m 644 MPI_Is_thread_main.3 /usr/local/share/man/man3/MPI_Is_thread_main.3
/usr/bin/install -c -m 644 MPI_Isend.3 /usr/local/share/man/man3/MPI_Isend.3
/usr/bin/install -c -m 644 MPI_Issend.3 /usr/local/share/man/man3/MPI_Issend.3
/usr/bin/install -c -m 644 MPI_Keyval_create.3 /usr/local/share/man/man3/MPI_Keyval_create.3
/usr/bin/install -c -m 644 MPI_Keyval_free.3 /usr/local/share/man/man3/MPI_Keyval_free.3
/usr/bin/install -c -m 644 MPI_Lookup_name.3 /usr/local/share/man/man3/MPI_Lookup_name.3
/usr/bin/install -c -m 644 MPI_Op_commute.3 /usr/local/share/man/man3/MPI_Op_commute.3
/usr/bin/install -c -m 644 MPI_Op_create.3 /usr/local/share/man/man3/MPI_Op_create.3
/usr/bin/install -c -m 644 MPI_Op_free.3 /usr/local/share/man/man3/MPI_Op_free.3
/usr/bin/install -c -m 644 MPI_Open_port.3 /usr/local/share/man/man3/MPI_Open_port.3
/usr/bin/install -c -m 644 MPI_Pack.3 /usr/local/share/man/man3/MPI_Pack.3
/usr/bin/install -c -m 644 MPI_Pack_external.3 /usr/local/share/man/man3/MPI_Pack_external.3
/usr/bin/install -c -m 644 MPI_Pack_external_size.3 /usr/local/share/man/man3/MPI_Pack_external_size.3
/usr/bin/install -c -m 644 MPI_Pack_size.3 /usr/local/share/man/man3/MPI_Pack_size.3
/usr/bin/install -c -m 644 MPI_Pcontrol.3 /usr/local/share/man/man3/MPI_Pcontrol.3
/usr/bin/install -c -m 644 MPI_Probe.3 /usr/local/share/man/man3/MPI_Probe.3
/usr/bin/install -c -m 644 MPI_Publish_name.3 /usr/local/share/man/man3/MPI_Publish_name.3
/usr/bin/install -c -m 644 MPI_Put.3 /usr/local/share/man/man3/MPI_Put.3
/usr/bin/install -c -m 644 MPI_Query_thread.3 /usr/local/share/man/man3/MPI_Query_thread.3
/usr/bin/install -c -m 644 MPI_Recv.3 /usr/local/share/man/man3/MPI_Recv.3
/usr/bin/install -c -m 644 MPI_Recv_init.3 /usr/local/share/man/man3/MPI_Recv_init.3
/usr/bin/install -c -m 644 MPI_Reduce.3 /usr/local/share/man/man3/MPI_Reduce.3
/usr/bin/install -c -m 644 MPI_Reduce_local.3 /usr/local/share/man/man3/MPI_Reduce_local.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter.3 /usr/local/share/man/man3/MPI_Reduce_scatter.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter_block.3 /usr/local/share/man/man3/MPI_Reduce_scatter_block.3
/usr/bin/install -c -m 644 MPI_Register_datarep.3 /usr/local/share/man/man3/MPI_Register_datarep.3
/usr/bin/install -c -m 644 MPI_Request_free.3 /usr/local/share/man/man3/MPI_Request_free.3
/usr/bin/install -c -m 644 MPI_Request_get_status.3 /usr/local/share/man/man3/MPI_Request_get_status.3
/usr/bin/install -c -m 644 MPI_Rsend.3 /usr/local/share/man/man3/MPI_Rsend.3
/usr/bin/install -c -m 644 MPI_Rsend_init.3 /usr/local/share/man/man3/MPI_Rsend_init.3
/usr/bin/install -c -m 644 MPI_Scan.3 /usr/local/share/man/man3/MPI_Scan.3
/usr/bin/install -c -m 644 MPI_Scatter.3 /usr/local/share/man/man3/MPI_Scatter.3
/usr/bin/install -c -m 644 MPI_Scatterv.3 /usr/local/share/man/man3/MPI_Scatterv.3
/usr/bin/install -c -m 644 MPI_Send.3 /usr/local/share/man/man3/MPI_Send.3
/usr/bin/install -c -m 644 MPI_Send_init.3 /usr/local/share/man/man3/MPI_Send_init.3
/usr/bin/install -c -m 644 MPI_Sendrecv.3 /usr/local/share/man/man3/MPI_Sendrecv.3
/usr/bin/install -c -m 644 MPI_Sendrecv_replace.3 /usr/local/share/man/man3/MPI_Sendrecv_replace.3
/usr/bin/install -c -m 644 MPI_Ssend.3 /usr/local/share/man/man3/MPI_Ssend.3
/usr/bin/install -c -m 644 MPI_Ssend_init.3 /usr/local/share/man/man3/MPI_Ssend_init.3
/usr/bin/install -c -m 644 MPI_Start.3 /usr/local/share/man/man3/MPI_Start.3
/usr/bin/install -c -m 644 MPI_Startall.3 /usr/local/share/man/man3/MPI_Startall.3
/usr/bin/install -c -m 644 MPI_Status_set_cancelled.3 /usr/local/share/man/man3/MPI_Status_set_cancelled.3
/usr/bin/install -c -m 644 MPI_Status_set_elements.3 /usr/local/share/man/man3/MPI_Status_set_elements.3
/usr/bin/install -c -m 644 MPI_Test.3 /usr/local/share/man/man3/MPI_Test.3
/usr/bin/install -c -m 644 MPI_Test_cancelled.3 /usr/local/share/man/man3/MPI_Test_cancelled.3
/usr/bin/install -c -m 644 MPI_Testall.3 /usr/local/share/man/man3/MPI_Testall.3
/usr/bin/install -c -m 644 MPI_Testany.3 /usr/local/share/man/man3/MPI_Testany.3
/usr/bin/install -c -m 644 MPI_Testsome.3 /usr/local/share/man/man3/MPI_Testsome.3
/usr/bin/install -c -m 644 MPI_Topo_test.3 /usr/local/share/man/man3/MPI_Topo_test.3
/usr/bin/install -c -m 644 MPI_Type_commit.3 /usr/local/share/man/man3/MPI_Type_commit.3
/usr/bin/install -c -m 644 MPI_Type_contiguous.3 /usr/local/share/man/man3/MPI_Type_contiguous.3
/usr/bin/install -c -m 644 MPI_Type_create_darray.3 /usr/local/share/man/man3/MPI_Type_create_darray.3
/usr/bin/install -c -m 644 MPI_Type_create_hindexed.3 /usr/local/share/man/man3/MPI_Type_create_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_create_hvector.3 /usr/local/share/man/man3/MPI_Type_create_hvector.3
/usr/bin/install -c -m 644 MPI_Type_create_indexed_block.3 /usr/local/share/man/man3/MPI_Type_create_indexed_block.3
/usr/bin/install -c -m 644 MPI_Type_create_keyval.3 /usr/local/share/man/man3/MPI_Type_create_keyval.3
/usr/bin/install -c -m 644 MPI_Type_create_resized.3 /usr/local/share/man/man3/MPI_Type_create_resized.3
/usr/bin/install -c -m 644 MPI_Type_create_struct.3 /usr/local/share/man/man3/MPI_Type_create_struct.3
/usr/bin/install -c -m 644 MPI_Type_create_subarray.3 /usr/local/share/man/man3/MPI_Type_create_subarray.3
/usr/bin/install -c -m 644 MPI_Type_delete_attr.3 /usr/local/share/man/man3/MPI_Type_delete_attr.3
/usr/bin/install -c -m 644 MPI_Type_dup.3 /usr/local/share/man/man3/MPI_Type_dup.3
/usr/bin/install -c -m 644 MPI_Type_extent.3 /usr/local/share/man/man3/MPI_Type_extent.3
/usr/bin/install -c -m 644 MPI_Type_free.3 /usr/local/share/man/man3/MPI_Type_free.3
/usr/bin/install -c -m 644 MPI_Type_free_keyval.3 /usr/local/share/man/man3/MPI_Type_free_keyval.3
/usr/bin/install -c -m 644 MPI_Type_get_attr.3 /usr/local/share/man/man3/MPI_Type_get_attr.3
/usr/bin/install -c -m 644 MPI_Type_get_contents.3 /usr/local/share/man/man3/MPI_Type_get_contents.3
/usr/bin/install -c -m 644 MPI_Type_get_envelope.3 /usr/local/share/man/man3/MPI_Type_get_envelope.3
/usr/bin/install -c -m 644 MPI_Type_get_extent.3 /usr/local/share/man/man3/MPI_Type_get_extent.3
/usr/bin/install -c -m 644 MPI_Type_get_name.3 /usr/local/share/man/man3/MPI_Type_get_name.3
/usr/bin/install -c -m 644 MPI_Type_get_true_extent.3 /usr/local/share/man/man3/MPI_Type_get_true_extent.3
/usr/bin/install -c -m 644 MPI_Type_hindexed.3 /usr/local/share/man/man3/MPI_Type_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_hvector.3 /usr/local/share/man/man3/MPI_Type_hvector.3
/usr/bin/install -c -m 644 MPI_Type_indexed.3 /usr/local/share/man/man3/MPI_Type_indexed.3
/usr/bin/install -c -m 644 MPI_Type_lb.3 /usr/local/share/man/man3/MPI_Type_lb.3
/usr/bin/install -c -m 644 MPI_Type_match_size.3 /usr/local/share/man/man3/MPI_Type_match_size.3
/usr/bin/install -c -m 644 MPI_Type_set_attr.3 /usr/local/share/man/man3/MPI_Type_set_attr.3
/usr/bin/install -c -m 644 MPI_Type_set_name.3 /usr/local/share/man/man3/MPI_Type_set_name.3
/usr/bin/install -c -m 644 MPI_Type_size.3 /usr/local/share/man/man3/MPI_Type_size.3
/usr/bin/install -c -m 644 MPI_Type_struct.3 /usr/local/share/man/man3/MPI_Type_struct.3
/usr/bin/install -c -m 644 MPI_Type_ub.3 /usr/local/share/man/man3/MPI_Type_ub.3
/usr/bin/install -c -m 644 MPI_Type_vector.3 /usr/local/share/man/man3/MPI_Type_vector.3
/usr/bin/install -c -m 644 MPI_Unpack.3 /usr/local/share/man/man3/MPI_Unpack.3
/usr/bin/install -c -m 644 MPI_Unpack_external.3 /usr/local/share/man/man3/MPI_Unpack_external.3
/usr/bin/install -c -m 644 MPI_Unpublish_name.3 /usr/local/share/man/man3/MPI_Unpublish_name.3
/usr/bin/install -c -m 644 MPI_Wait.3 /usr/local/share/man/man3/MPI_Wait.3
/usr/bin/install -c -m 644 MPI_Waitall.3 /usr/local/share/man/man3/MPI_Waitall.3
/usr/bin/install -c -m 644 MPI_Waitany.3 /usr/local/share/man/man3/MPI_Waitany.3
/usr/bin/install -c -m 644 MPI_Waitsome.3 /usr/local/share/man/man3/MPI_Waitsome.3
/usr/bin/install -c -m 644 MPI_Win_call_errhandler.3 /usr/local/share/man/man3/MPI_Win_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_complete.3 /usr/local/share/man/man3/MPI_Win_complete.3
/usr/bin/install -c -m 644 MPI_Win_create.3 /usr/local/share/man/man3/MPI_Win_create.3
/usr/bin/install -c -m 644 MPI_Win_create_errhandler.3 /usr/local/share/man/man3/MPI_Win_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_create_keyval.3 /usr/local/share/man/man3/MPI_Win_create_keyval.3
/usr/bin/install -c -m 644 MPI_Win_delete_attr.3 /usr/local/share/man/man3/MPI_Win_delete_attr.3
/usr/bin/install -c -m 644 MPI_Win_fence.3 /usr/local/share/man/man3/MPI_Win_fence.3
/usr/bin/install -c -m 644 MPI_Win_free.3 /usr/local/share/man/man3/MPI_Win_free.3
/usr/bin/install -c -m 644 MPI_Win_free_keyval.3 /usr/local/share/man/man3/MPI_Win_free_keyval.3
/usr/bin/install -c -m 644 MPI_Win_get_attr.3 /usr/local/share/man/man3/MPI_Win_get_attr.3
/usr/bin/install -c -m 644 MPI_Win_get_errhandler.3 /usr/local/share/man/man3/MPI_Win_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_get_group.3 /usr/local/share/man/man3/MPI_Win_get_group.3
/usr/bin/install -c -m 644 MPI_Win_get_name.3 /usr/local/share/man/man3/MPI_Win_get_name.3
/usr/bin/install -c -m 644 MPI_Win_lock.3 /usr/local/share/man/man3/MPI_Win_lock.3
/usr/bin/install -c -m 644 MPI_Win_post.3 /usr/local/share/man/man3/MPI_Win_post.3
/usr/bin/install -c -m 644 MPI_Win_set_attr.3 /usr/local/share/man/man3/MPI_Win_set_attr.3
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.3 /usr/local/share/man/man3/MPI_Win_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_set_name.3 /usr/local/share/man/man3/MPI_Win_set_name.3
/usr/bin/install -c -m 644 MPI_Win_start.3 /usr/local/share/man/man3/MPI_Win_start.3
/usr/bin/install -c -m 644 MPI_Win_test.3 /usr/local/share/man/man3/MPI_Win_test.3
/usr/bin/install -c -m 644 MPI_Win_unlock.3 /usr/local/share/man/man3/MPI_Win_unlock.3
/usr/bin/install -c -m 644 MPI_Win_wait.3 /usr/local/share/man/man3/MPI_Win_wait.3
/usr/bin/install -c -m 644 MPI_Wtick.3 /usr/local/share/man/man3/MPI_Wtick.3
/usr/bin/install -c -m 644 MPI_Wtime.3 /usr/local/share/man/man3/MPI_Wtime.3
if [ -s src/mpi/romio/include/mpiof.h ] ; then /usr/bin/install -c -m 644  src/mpi/romio/include/mpiof.h /usr/local/include/mpiof.h ; fi
if [ -s src/mpi/romio/include/mpio.h ] ; then /usr/bin/install -c -m 644  src/mpi/romio/include/mpio.h /usr/local/include/mpio.h ; fi
if [ -s lib/libmpich.a ] ; then /usr/bin/install -c -m 644  lib/libmpich.a /usr/local/lib/libmpich.a ; fi
if [ -s lib/libmpichcxx.a ] ; then /usr/bin/install -c -m 644  lib/libmpichcxx.a /usr/local/lib/libmpichcxx.a ; fi
if [ -s lib/libfmpich.a ] ; then /usr/bin/install -c -m 644  lib/libfmpich.a /usr/local/lib/libfmpich.a ; fi
if [ -s lib/libpmpich.a ] ; then /usr/bin/install -c -m 644  lib/libpmpich.a /usr/local/lib/libpmpich.a ; fi
if [ -s lib/libmpichf90.a ] ; then /usr/bin/install -c -m 644  lib/libmpichf90.a /usr/local/lib/libmpichf90.a ; fi
if [ -s lib/libmpich.dll ] ; then false -version-info 3:2 --mode=install  lib/libmpich.dll /usr/local/lib/libmpich.dll ; fi
if [ -s lib/libpmpich.dll ] ; then false -version-info 3:2 --mode=install  lib/libpmpich.dll /usr/local/lib/libpmpich.dll ; fi
if [ -s lib/libfmpich.dll ] ; then false -version-info 3:2 --mode=install  lib/libfmpich.dll /usr/local/lib/libfmpich.dll ; fi
if [ -s lib/libmpichf90.dll ] ; then false -version-info 3:2 --mode=install  lib/libmpichf90.dll /usr/local/lib/libmpichf90.dll ; fi
if [ -s lib/libmpichcxx.dll ] ; then false -version-info 3:2 --mode=install  lib/libmpichcxx.dll /usr/local/lib/libmpichcxx.dll ; fi
if [ -s ./doc/userguide/user.pdf ] ; then /usr/bin/install -c -m 644  ./doc/userguide/user.pdf /usr/local/share/doc//user.pdf ; fi
if [ -s ./doc/installguide/install.pdf ] ; then /usr/bin/install -c -m 644  ./doc/installguide/install.pdf /usr/local/share/doc//install.pdf ; fi
if [ -s ./doc/smpd/smpd_pmi.pdf ] ; then /usr/bin/install -c -m 644  ./doc/smpd/smpd_pmi.pdf /usr/local/share/doc//smpd_pmi.pdf ; fi
if [ -s ./doc/logging/logging.pdf ] ; then /usr/bin/install -c -m 644  ./doc/logging/logging.pdf /usr/local/share/doc//logging.pdf ; fi
(cd src/env && make INSTALL_STRIP_FLAG= PACKAGE= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/env'
if [ ! -d /usr/local ] ; then mkdir -p /usr/local ; fi
if [ ! -d /usr/local/bin ] ; then mkdir -p /usr/local/bin ; fi
/usr/bin/install -c   mpich2version /usr/local/bin/mpich2version
/usr/bin/install -c  mpicc /usr/local/bin/mpicc
if [ ! -d /usr/local/etc ] ; then mkdir -p /usr/local/etc ; fi
/usr/bin/install -c -m 644  mpixxx_opts.conf /usr/local/etc/mpixxx_opts.conf
/usr/bin/install -c -m 644  mpicc.conf /usr/local/etc/mpicc.conf
if [ -s mpicxx ] ; then /usr/bin/install -c  mpicxx /usr/local/bin/mpicxx ; fi
if [ -s mpif77 ] ; then /usr/bin/install -c  mpif77 /usr/local/bin/mpif77 ; fi
if [ -s mpif90 ] ; then /usr/bin/install -c  mpif90 /usr/local/bin/mpif90 ; fi
if [ -s mpicxx.conf ] ; then /usr/bin/install -c -m 644  mpicxx.conf /usr/local/etc/mpicxx.conf ; fi
if [ -s mpif77.conf ] ; then /usr/bin/install -c -m 644  mpif77.conf /usr/local/etc/mpif77.conf ; fi
if [ -s mpif90.conf ] ; then /usr/bin/install -c -m 644  mpif90.conf /usr/local/etc/mpif90.conf ; fi
make DESTDIR= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install-postamble
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/env'
if [ -x /usr/local/bin/mpicxx ] ; then \
	    cd /usr/local/bin && ln -f -s mpicxx mpic++ ; fi
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/env'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/env'
(cd src/packaging/pkgconfig && make INSTALL_STRIP_FLAG= PACKAGE= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging/pkgconfig'
if [ ! -d /usr/local/lib/pkgconfig ] ; then mkdir -p /usr/local/lib/pkgconfig ; fi
if [ -s mpich2-c.pc ] ; then /usr/bin/install -c -m 644  mpich2-c.pc /usr/local/lib/pkgconfig/mpich2-c.pc ; fi
if [ -s mpich2-cxx.pc ] ; then /usr/bin/install -c -m 644  mpich2-cxx.pc /usr/local/lib/pkgconfig/mpich2-cxx.pc ; fi
if [ -s mpich2-f77.pc ] ; then /usr/bin/install -c -m 644  mpich2-f77.pc /usr/local/lib/pkgconfig/mpich2-f77.pc ; fi
if [ -s mpich2-f90.pc ] ; then /usr/bin/install -c -m 644  mpich2-f90.pc /usr/local/lib/pkgconfig/mpich2-f90.pc ; fi
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging/pkgconfig'
(cd src/packaging/envmods && make INSTALL_STRIP_FLAG= PACKAGE= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging/envmods'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/packaging/envmods'
for dir in  src/binding/f77 src/binding/f90 src/binding/cxx - ; do \
		if [ "$dir" = "-" ] ; then break ; fi ;\
		(cd $dir && make INSTALL_STRIP_FLAG= PACKAGE= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install) ;\
	done
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f77'
if [ ! -d /usr/local/include ] ; then mkdir -p /usr/local/include ; fi
/usr/bin/install -c -m 644  mpif.h /usr/local/include/mpif.h
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f77'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f90'
/usr/bin/install -c -m 644  mpi.mod /usr/local/include/mpi.mod
/usr/bin/install -c -m 644  mpi_constants.mod /usr/local/include/mpi_constants.mod
/usr/bin/install -c -m 644  mpi_base.mod /usr/local/include/mpi_base.mod
/usr/bin/install -c -m 644  mpi_sizeofs.mod /usr/local/include/mpi_sizeofs.mod
if [ ! -d /usr/local/lib ] ; then mkdir -p /usr/local/lib ; fi
/usr/bin/install -c -m 644  libmpichf90.a /usr/local/lib/libmpichf90.a
if [ -s mpimod.pcl ] ; then /usr/bin/install -c -m 644  mpimod.pcl /usr/local/include/mpimod.pcl ; fi
if [ -s mpimod.pc ] ; then /usr/bin/install -c -m 644  mpimod.pc /usr/local/include/mpimod.pc ; fi
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/f90'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/cxx'
/usr/bin/install -c -m 644  mpicxx.h /usr/local/include/mpicxx.h
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/binding/cxx'
for dir in  src/mpl src/openpa src/pm/hydra src/mpe2 - ; do \
	done
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
test -z "/usr/local/lib" || /usr/bin/mkdir -p "/usr/local/lib"
 /bin/sh ./libtool   --mode=install /usr/bin/install -c   libmpl.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libmpl.lai /usr/local/lib/libmpl.la
libtool: install: /usr/bin/install -c .libs/libmpl.a /usr/local/lib/libmpl.a
libtool: install: chmod 644 /usr/local/lib/libmpl.a
libtool: install: ranlib /usr/local/lib/libmpl.a
Libraries have been installed in:
   /usr/local/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-LLIBDIR' linker flag
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
Making install in src
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
 /bin/sh ../libtool   --mode=install /usr/bin/install -c   libopa.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libopa.lai /usr/local/lib/libopa.la
libtool: install: /usr/bin/install -c .libs/libopa.a /usr/local/lib/libopa.a
libtool: install: chmod 644 /usr/local/lib/libopa.a
libtool: install: ranlib /usr/local/lib/libopa.a
   /usr/local/lib
     during execution
     during linking
test -z "/usr/local/include" || /usr/bin/mkdir -p "/usr/local/include"
 /usr/bin/install -c -m 644 opa_config.h opa_primitives.h opa_queue.h opa_util.h '/usr/local/include'
/usr/bin/mkdir -p '/usr/local/include/primitives'
 /usr/bin/install -c -m 644  primitives/opa_by_lock.h primitives/opa_emulated.h primitives/opa_gcc_ia64.h primitives/opa_gcc_intel_32_64.h primitives/opa_gcc_intel_32_64_barrier.h primitives/opa_gcc_intel_32_64_ops.h primitives/opa_gcc_intel_32_64_p3.h primitives/opa_gcc_intel_32_64_p3barrier.h primitives/opa_gcc_intrinsics.h primitives/opa_gcc_ppc.h primitives/opa_gcc_sicortex.h primitives/opa_nt_intrinsics.h primitives/opa_sun_atomic_ops.h primitives/opa_unsafe.h '/usr/local/include/primitives'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/src'
Making install in test
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/test'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/test'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/test'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa/test'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
test -z "/usr/local/share/doc/openpa" || /usr/bin/mkdir -p "/usr/local/share/doc/openpa"
 /usr/bin/install -c -m 644 README '/usr/local/share/doc/openpa'
test -z "/usr/local/lib/pkgconfig" || /usr/bin/mkdir -p "/usr/local/lib/pkgconfig"
 /usr/bin/install -c -m 644 openpa.pc '/usr/local/lib/pkgconfig'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/openpa'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
Making install in ../../mpl
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
   /usr/local/lib
     during execution
     during linking
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpl'
Making install in .
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
test -z "/usr/local/bin" || mkdir -p "/usr/local/bin"
  /bin/sh ./libtool   --mode=install /usr/bin/install -c hydra_persist.exe hydra_nameserver.exe hydra_pmi_proxy.exe mpiexec.hydra.exe '/usr/local/bin'
libtool: install: /usr/bin/install -c .libs/hydra_persist.exe /usr/local/bin/hydra_persist.exe
libtool: install: /usr/bin/install -c .libs/hydra_nameserver.exe /usr/local/bin/hydra_nameserver.exe
libtool: install: /usr/bin/install -c .libs/hydra_pmi_proxy.exe /usr/local/bin/hydra_pmi_proxy.exe
libtool: install: /usr/bin/install -c .libs/mpiexec.hydra.exe /usr/local/bin/mpiexec.hydra.exe
make  install-exec-hook
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
if [ -x /usr/local/bin/mpiexec.hydra ] ; then \
	    cd /usr/local/bin && ln -f -s mpiexec.hydra mpiexec ; \
	    cd /usr/local/bin && ln -f -s mpiexec.hydra mpirun ; \
	fi
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/pm/hydra'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2'
Installing MPE2 include files to /usr/local/include
Replacing existing file /usr/local/include/clog_commset.h...
Replacing existing file /usr/local/include/clog_const.h...
Replacing existing file /usr/local/include/clog_inttypes.h...
Replacing existing file /usr/local/include/clog_uuid.h...
Replacing existing file /usr/local/include/mpe.h...
Replacing existing file /usr/local/include/mpe_callstack.h...
Replacing existing file /usr/local/include/mpe_graphics.h...
Replacing existing file /usr/local/include/mpe_graphicsf.h...
Replacing existing file /usr/local/include/mpe_log.h...
Replacing existing file /usr/local/include/mpe_log_thread.h...
Replacing existing file /usr/local/include/mpe_logf.h...
Replacing existing file /usr/local/include/mpe_misc.h...
Installing MPE2 libraries to /usr/local/lib
Replacing existing file /usr/local/lib/libampe.a...
Replacing existing file /usr/local/lib/liblmpe.a...
Replacing existing file /usr/local/lib/libmpe.a...
Replacing existing file /usr/local/lib/libmpe_collchk.a...
Replacing existing file /usr/local/lib/libmpe_f2cmpi.a...
Replacing existing file /usr/local/lib/libmpe_nompi.a...
Replacing existing file /usr/local/lib/libmpe_nompi_null.a...
Replacing existing file /usr/local/lib/libmpe_null.a...
Replacing existing file /usr/local/lib/libtmpe.a...
Replacing existing file /usr/local/lib/mpe_prof.o...
Installing MPE2 utility programs to /usr/local/bin
Replacing existing file /usr/local/bin/bt2line...
Replacing existing file /usr/local/bin/check_callstack.exe...
Replacing existing file /usr/local/bin/clog2_join.exe...
Replacing existing file /usr/local/bin/clog2_print.exe...
Replacing existing file /usr/local/bin/clog2_repair.exe...
Installing MPE2 configuration files to /usr/local/etc
Installing MPE2 system utility programs to /usr/local/sbin
Replacing existing file /usr/local/sbin/mpecheckinstall...
Replacing existing file /usr/local/share/examples_logging/Makefile...
Replacing existing file /usr/local/share/examples_logging/comm1_isr.c...
Replacing existing file /usr/local/share/examples_logging/comm1_isr_loop.c...
Replacing existing file /usr/local/share/examples_logging/comm2_connect_accept.c...
Replacing existing file /usr/local/share/examples_logging/comm2_spawn_child.c...
Replacing existing file /usr/local/share/examples_logging/comm2_spawn_parent.c...
Replacing existing file /usr/local/share/examples_logging/cpi.c...
Replacing existing file /usr/local/share/examples_logging/cpilog.c...
Replacing existing file /usr/local/share/examples_logging/cpilog_pack.c...
Replacing existing file /usr/local/share/examples_logging/fcomm1_isr.f...
Replacing existing file /usr/local/share/examples_logging/fpilog.f...
Replacing existing file /usr/local/share/examples_logging/fpilog_pack.F...
Replacing existing file /usr/local/share/examples_logging/iotest.c...
Replacing existing file /usr/local/share/examples_logging/log_cost.c...
Replacing existing file /usr/local/share/examples_logging/openmp_mpilog.F...
Replacing existing file /usr/local/share/examples_logging/openmp_sendrecv.c...
Replacing existing file /usr/local/share/examples_logging/pthread_allreduce.c...
Replacing existing file /usr/local/share/examples_logging/pthread_sendrecv.c...
Replacing existing file /usr/local/share/examples_logging/pthread_sendrecv_user.c...
Replacing existing file /usr/local/share/examples_logging/srtest.c...
Replacing existing file /usr/local/share/examples_graphics/Makefile...
Replacing existing file /usr/local/share/examples_graphics/cpi.c...
Replacing existing file /usr/local/share/examples_graphics/cxgraphics.c...
Replacing existing file /usr/local/share/examples_graphics/fxgraphics.f...
Replacing existing file /usr/local/share/examples_collchk/Makefile...
Replacing existing file /usr/local/share/examples_collchk/composite.c...
Replacing existing file /usr/local/share/examples_collchk/scatterv.c...
Replacing existing file /usr/local/share/examples_collchk/time_allreduce.c...
Replacing existing file /usr/local/share/examples_collchk/time_alltoallv.c...
Replacing existing file /usr/local/share/examples_collchk/time_alltoallv0.c...
Replacing existing file /usr/local/share/examples_collchk/time_bcast.c...
Replacing existing file /usr/local/share/examples_collchk/wrong_composite.c...
Replacing existing file /usr/local/share/examples_collchk/wrong_int_byte.c...
Replacing existing file /usr/local/share/examples_collchk/wrong_reals.f...
Replacing existing file /usr/local/share/examples_collchk/wrong_root.c...
Replacing existing file /usr/local/share/examples_collchk/wrong_scatterv.c...
Installing MPE2 man to /usr/local/share/man
Replacing existing file /usr/local/share/man/man4/MPE_Add_RGB_color.4...
Replacing existing file /usr/local/share/man/man4/MPE_CaptureFile.4...
Replacing existing file /usr/local/share/man/man4/MPE_Close_graphics.4...
Replacing existing file /usr/local/share/man/man4/MPE_Comm_global_rank.4...
Replacing existing file /usr/local/share/man/man4/MPE_Decomp1d.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_comm_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_comm_state.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_info_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_info_state.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_state.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_circle.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_line.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_logic.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_point.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_points.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_string.4...
Replacing existing file /usr/local/share/man/man4/MPE_Errors_call_debugger.4...
Replacing existing file /usr/local/share/man/man4/MPE_Fill_circle.4...
Replacing existing file /usr/local/share/man/man4/MPE_Fill_rectangle.4...
Replacing existing file /usr/local/share/man/man4/MPE_Finish_log.4...
Replacing existing file /usr/local/share/man/man4/MPE_GetHostName.4...
Replacing existing file /usr/local/share/man/man4/MPE_GetTags.4...
Replacing existing file /usr/local/share/man/man4/MPE_Get_mouse_press.4...
Replacing existing file /usr/local/share/man/man4/MPE_IO_Stdout_to_file.4...
Replacing existing file /usr/local/share/man/man4/MPE_Iget_mouse_press.4...
Replacing existing file /usr/local/share/man/man4/MPE_Init_log.4...
Replacing existing file /usr/local/share/man/man4/MPE_Initialized_logging.4...
Replacing existing file /usr/local/share/man/man4/MPE_Line_thickness.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_bare_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_comm_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_comm_receive.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_comm_send.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_get_event_number.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_get_solo_eventID.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_get_state_eventIDs.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_info_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_merged_logfilename.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_pack.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_receive.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_send.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_sync_clocks.4...
Replacing existing file /usr/local/share/man/man4/MPE_Make_color_array.4...
Replacing existing file /usr/local/share/man/man4/MPE_Num_colors.4...
Replacing existing file /usr/local/share/man/man4/MPE_Open_graphics.4...
Replacing existing file /usr/local/share/man/man4/MPE_ReturnTags.4...
Replacing existing file /usr/local/share/man/man4/MPE_Seq_begin.4...
Replacing existing file /usr/local/share/man/man4/MPE_Seq_end.4...
Replacing existing file /usr/local/share/man/man4/MPE_Signals_call_debugger.4...
Replacing existing file /usr/local/share/man/man4/MPE_Start_log.4...
Replacing existing file /usr/local/share/man/man4/MPE_Stop_log.4...
Replacing existing file /usr/local/share/man/man4/MPE_TagsEnd.4...
Replacing existing file /usr/local/share/man/man4/MPE_Update.4...
Installing MPE2 html to /usr/local/share/doc/
Replacing existing file /usr/local/share/doc//www4/MPE_Add_RGB_color.html...
Replacing existing file /usr/local/share/doc//www4/MPE_CaptureFile.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Close_graphics.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Comm_global_rank.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Decomp1d.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_comm_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_comm_state.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_info_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_info_state.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_state.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_circle.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_line.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_logic.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_point.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_points.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_string.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Errors_call_debugger.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Fill_circle.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Fill_rectangle.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Finish_log.html...
Replacing existing file /usr/local/share/doc//www4/MPE_GetHostName.html...
Replacing existing file /usr/local/share/doc//www4/MPE_GetTags.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Get_mouse_press.html...
Replacing existing file /usr/local/share/doc//www4/MPE_IO_Stdout_to_file.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Iget_mouse_press.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Init_log.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Initialized_logging.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Line_thickness.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_bare_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_comm_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_comm_receive.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_comm_send.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_get_event_number.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_get_solo_eventID.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_get_state_eventIDs.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_info_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_merged_logfilename.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_pack.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_receive.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_send.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_sync_clocks.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Make_color_array.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Num_colors.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Open_graphics.html...
Replacing existing file /usr/local/share/doc//www4/MPE_ReturnTags.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Seq_begin.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Seq_end.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Signals_call_debugger.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Start_log.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Stop_log.html...
Replacing existing file /usr/local/share/doc//www4/MPE_TagsEnd.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Update.html...
Replacing existing file /usr/local/share/doc//www4/libmpe.cit...
Installed MPE2 in /usr/local
/usr/local/sbin/mpeuninstall may be used to remove the installation
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1/src/mpe2'
