[mpich-discuss] MPICH being blocked
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed Jun 13 17:11:03 CDT 2012
 The register/validate steps should succeed before the user can launch an MPI job.
 The user should specify the domainname if the registered user (Windows username registered with mpiexec) is a domain user.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>, mpich-discuss at mcs.anl.gov
Sent: Wednesday, June 13, 2012 11:20:27 AM
Subject: RE: [mpich-discuss] MPICH being blocked
Thanks Jayesh, I will give that a try.  Just to note, we have registered and reregistered on several occasions the username and password.
So, if it fails, what should I do next?  I only ask because it's difficult to schedule the time with the user to go over the troubleshooting steps.
James Kubli
Product Support Specialist
Autodesk, Inc.
5400 Meadows Rd, Suite 500
Lake Oswego, OR 97035
Direct 503 707-3820
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Wednesday, June 13, 2012 7:06 AM
Cc: James Kubli
Subject: Re: [mpich-discuss] MPICH being blocked
 Please register (mpiexec -register) a valid Windows username/password with mpiexec and let us know if you still have issues. You can check if the registered username/password works using "mpiexec -validate" .
Jayesh
Sent: Tuesday, June 12, 2012 11:58:53 AM
Subject: [mpich-discuss] MPICH being blocked
Hello,
I have installed MPICH on a computer for use with Autodesks Simulation Multiphysics program. However unfortunately it does not appear to be working. When launching through the command prompt (mpiexec –n 1 “c:\Program Files\Autodesk\Simulation 2013\ssap11ld.exe” “ File path ” –run) I get the following message:
Credentials for usernameI rejected connecting to RFDWPSCHNEIDER.eclipsenet.com
Aborting: Unable to connect to RFDWPSCHNEIDER.eclipsenet.com
I have added all necessary programs to the windows firewall exception, disabled win firewall and UAC. Still get the same error message. Any advice would be appreciated.
James Kubli
WS-C&S-Product Support Americas
Autodesk, Inc.
Direct 503 707-3820
Description: Description: Adsk_logo_4_sig_v03_crop.gif
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
