[mpich-discuss] mpich2 some errors..
crgeng_medphys crgeng_medphys at yahoo.cn
Wed Jul 4 10:58:36 CDT 2012
Hi Reuti:
"./configure --prefix
sudo make
sudo make install"
this is the way I installed the MPICH2. The version is MPICH2-1.0.7rc2.
Yes, you are right. I want to build a dynamic library with my application and try to add a static library from MPICH2.
So what can I do with this error?
Thanks and best regards!
geng
2012-07-04
crgeng_medphys
发件人: Reuti
发送时间: 2012-07-04  23:44:10
收件人: mpich-discuss at mcs.anl.gov
抄送:
主题: Re: [mpich-discuss] mpich2 some errors..
Am 04.07.2012 um 09:05 schrieb crgeng_medphys:
> Dear Sir:
> Thanks for your development of MPICH first.
> And I have a problem after I install mpich to compile my application.
How did you install MPICH2 and which version?
Do you want to build a dynamic library with your application and try to add a static library from MPICH2?
-- Reuti
> The error is following,
> /usr/bin/ld: /home/g/mpich2/lib/libmpichcxx.a(initcxx.o): relocation R_X86_64_32S against `vtable for MPI::Datatype' can not be used when making a shared object; recompile with -fPIC
> /home/g/mpich2/lib/libmpichcxx.a: could not read symbols: Bad value
> collect2: ld returned 1 exit status
> It probably means that I should recompile MPI with -fPIC.
> But I cannot understand the definite mean of this error, could you give me some advice?
> Geng
> crgeng_medphys
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120704/c60870e7/attachment.html>
