[mpich-discuss] mpich2 some errors..
Jeff Hammond
jhammond at alcf.anl.gov
Wed Jul 4 11:01:26 CDT 2012
Use the latest version of MPICH2. It's not practical for the
developers to support versions of MPICH2 that are that old.
Jeff
PS You should not need to use sudo to execute make and this is a bad
practice since it can have unpleasant consequences with packages that
have poorly designed buildsystems (MPICH2 is not an example of such a
package though).
On Wed, Jul 4, 2012 at 10:58 AM, crgeng_medphys <crgeng_medphys at yahoo.cn> wrote:
> Hi Reuti:
> "./configure --prefix
> sudo make
> sudo make install"
> this is the way I installed the MPICH2. The version is MPICH2-1.0.7rc2.
> Yes, you are right. I want to build a dynamic library with my application
> and try to add a static library from MPICH2.
> So what can I do with this error?
> Thanks and best regards!
> geng
> 2012-07-04
> ________________________________
> crgeng_medphys
> 发件人: Reuti
> 发送时间: 2012-07-04 23:44:10
> 收件人: mpich-discuss at mcs.anl.gov
> 抄送:
> 主题: Re: [mpich-discuss] mpich2 some errors..
> Am 04.07.2012 um 09:05 schrieb crgeng_medphys:
>> Dear Sir:
>> Thanks for your development of MPICH first.
>> And I have a problem after I install mpich to compile my application.
> How did you install MPICH2 and which version?
> Do you want to build a dynamic library with your application and try to add
> a static library from MPICH2?
> -- Reuti
>> The error is following,
>> /usr/bin/ld: /home/g/mpich2/lib/libmpichcxx.a(initcxx.o): relocation
>> R_X86_64_32S against `vtable for MPI::Datatype' can not be used when making
>> a shared object; recompile with -fPIC
>> /home/g/mpich2/lib/libmpichcxx.a: could not read symbols: Bad value
>> collect2: ld returned 1 exit status
>> It probably means that I should recompile MPI with -fPIC.
>> But I cannot understand the definite mean of this error, could you give me
>> some advice?
>> Geng
>> crgeng_medphys
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
