[mpich-discuss] mpich2 some errors..
Reuti reuti at staff.uni-marburg.de
Wed Jul 4 10:37:39 CDT 2012
Am 04.07.2012 um 09:05 schrieb crgeng_medphys:
> Dear Sir:
> Thanks for your development of MPICH first.
> And I have a problem after I install mpich to compile my application.
How did you install MPICH2 and which version?
Do you want to build a dynamic library with your application and try to add a static library from MPICH2?
-- Reuti
> The error is following,
> /usr/bin/ld: /home/g/mpich2/lib/libmpichcxx.a(initcxx.o): relocation R_X86_64_32S against `vtable for MPI::Datatype' can not be used when making a shared object; recompile with -fPIC
> /home/g/mpich2/lib/libmpichcxx.a: could not read symbols: Bad value
> collect2: ld returned 1 exit status
> It probably means that I should recompile MPI with -fPIC.
> But I cannot understand the definite mean of this error, could you give me some advice?
> Thanks and best regards!
> Geng
> crgeng_medphys
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
