[mpich-discuss] References for FORTRAN
    Jose Marques
    jmarques at itn.pt
    Tue Jan 31 12:21:13 CST 2012
Thanks Gus, that's the level of detail that I needed !
Jose
On 31-01-2012 6:19, Gustavo Correa wrote:
> Hi
> Here are some references in MPI+Fortran.
> 1) The LLNL MPI tutorial has some [light weight] MPI examples in Fortran:
> https://computing.llnl.gov/tutorials/mpi/
> 2) NCCS tutorials&  references:
> http://www.nccs.gov/user-support/training-education/hpcparallel-computing-links/
> http://www.nccs.gov/user-support/training-education/hpcparallel-computing-links/mpi-examples
> An early version in Fortran of Peter Pacheco's book:
> ladon.iqfr.csic.es/docs/MPI_ug_in_FORTRAN.pdf
> 3) Matrix multiplication:
> http://www.mcs.anl.gov/research/projects/mpi/usingmpi/examples/simplempi/main.htm
> http://www.mcs.anl.gov/research/projects/mpi/usingmpi/examples/simplempi/f90/matmat_f90.htm
> 4) 2D Diffusion PDE solved by the Jacobi method [illustrates the use of cartesian
> domain decomposition and PDE solver in MPI+Fortran]:
>   http://beige.ucs.indiana.edu/I590/node71.html
> If you want really to go for large codes [my bias is ocean/atmosphereclimate]
> there are several which are publically available, mostly written in Fortran, with a few bits in C:
> 5) weather forecast:
> http://www.wrf-model.org/index.php
> 6) coupled climate model:
> http://www.cesm.ucar.edu/
> 7) ocean general circulation and regional models:
> http://mitgcm.org/
> http://www.gfdl.noaa.gov/fms
> 8) molecular dynamics:
> http://www.vasp.at/
> http://ambermd.org/
> 9) NAS parallel benchmarks:
> http://www.nas.nasa.gov/publications/npb.html
> I hope this helps.
> Gus Correa
> On Jan 31, 2012, at 10:16 AM, Anthony Chan wrote:
>> Try doing a google search of "MPI Fortran tutorial"....
>> MPI is a communication library, so you can do numerical
>> intensive calculation between communications.
>> A.Chan
>> ----- Original Message -----
>>> Dear all,
>>> Can someone give me good references to exploit MPICH using Fortran
>>> programs ? A tutorial or an example of a calculation-intensive program
>>> would be appreciated.
>>> Thanks,
>>> Jose
>>> _______________________________________________
>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Dr. Jose G. Marques
Reactor Manager
Instituto Tecnologico e Nuclear     phone:  (+351) 219 946 115
Estrada Nacional 10                 fax:    (+351) 219 941 039
P-2686-953 Sacavem, Portugal
