[mpich-discuss] References for FORTRAN
Gustavo Correa gus at ldeo.columbia.edu
Tue Jan 31 12:19:24 CST 2012
Hi
Here are some references in MPI+Fortran.
1) The LLNL MPI tutorial has some [light weight] MPI examples in Fortran:
https://computing.llnl.gov/tutorials/mpi/
2) NCCS tutorials & references:
http://www.nccs.gov/user-support/training-education/hpcparallel-computing-links/
http://www.nccs.gov/user-support/training-education/hpcparallel-computing-links/mpi-examples
An early version in Fortran of Peter Pacheco's book:
ladon.iqfr.csic.es/docs/MPI_ug_in_FORTRAN.pdf
3) Matrix multiplication:
http://www.mcs.anl.gov/research/projects/mpi/usingmpi/examples/simplempi/main.htm
http://www.mcs.anl.gov/research/projects/mpi/usingmpi/examples/simplempi/f90/matmat_f90.htm
4) 2D Diffusion PDE solved by the Jacobi method [illustrates the use of cartesian
domain decomposition and PDE solver in MPI+Fortran]:
 http://beige.ucs.indiana.edu/I590/node71.html
If you want really to go for large codes [my bias is ocean/atmosphereclimate]
there are several which are publically available, mostly written in Fortran, with a few bits in C:
5) weather forecast:
http://www.wrf-model.org/index.php
6) coupled climate model:
http://www.cesm.ucar.edu/
7) ocean general circulation and regional models:
http://mitgcm.org/
http://www.gfdl.noaa.gov/fms
8) molecular dynamics:
http://www.vasp.at/
http://ambermd.org/
9) NAS parallel benchmarks:
http://www.nas.nasa.gov/publications/npb.html
I hope this helps.
Gus Correa
On Jan 31, 2012, at 10:16 AM, Anthony Chan wrote:
> Try doing a google search of "MPI Fortran tutorial"....
> MPI is a communication library, so you can do numerical
> intensive calculation between communications.
> A.Chan
>> Dear all,
>> Can someone give me good references to exploit MPICH using Fortran
>> programs ? A tutorial or an example of a calculation-intensive program
>> would be appreciated.
>> Thanks,
>> Jose
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
