[mpich-discuss] MPICH error
    sc Deng
    dengsc74.sj at gmail.com
    Mon Jan 23 10:13:53 CST 2012
Hello all,
I meet a MPI error now. I modified my previous code (the previous is F77
and OK ) to F90 and the error is given as follows (using 27 processes,but
just get 26 or less processes' information):
 rank=:           0        1780           6
 rank=:           2         656           6
 rank=:           4        1825           6
 rank=:           8         425           6
 rank=:          16        1233           6
 rank=:          12        1859           6
 rank=:           6        1171           6
 rank=:          20         434           6
 rank=:           5         668           6
 rank=:          14         688           6
 rank=:          21        1208           6
 rank=:          18        1174           6
 rank=:          24         779           6
 rank=:           7        1186           6
 rank=:          10        1841           6
 rank=:          17         433           6
 rank=:          11         688           6
 rank=:          22        1216           6
 rank=:          19        1189           6
 rank=:          25         792           6
 rank=:           3        1808           6
 rank=:          15        1213           6
 rank=:          13        1895           6
 rank=:           1        1788           6
 rank=:           9        1815           6
 rank=:          23         441           6
[mpiexec at fn-148-148] ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP
APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15)
it is a particle simulation program, and the corresponding code is:
    !send to upper and receive from bottom
    num = 0 ; num_tmp = 0
    do i = 0 , nx+1
        do j = 0 , ny+1
            p = last_particle_in_cell(i,j,nz)
            do while(p>0)
                num = num + 1
                if(num > num_send) print*, 'Please enlarge the number of
sent ghost - "num_send"' , num , num_send
                send_ghost(num) = particle_vector(p)%basic_particle
                p = particle_pointer(p)
            end do
        end do
    end do
    write(*,*) 'rank=:' , rank , num , 6
    if(mod(cpu_coords(1)+cpu_coords(2)+cpu_coords(3),2) == 0) then
        call MPI_SEND(num     , 1 , MPI_INTEGER , upper_nbr  , tag_tmp6 ,
GRID_COMM , ierror)
        call MPI_RECV(num_tmp , 1 , MPI_INTEGER , bottom_nbr , tag_tmp6 ,
GRID_COMM , stat , ierror)
    end if
    if(mod(cpu_coords(1)+cpu_coords(2)+cpu_coords(3),2) == 1) then
GRID_COMM , ierror)
    end if
    call MPI_BARRIER(GRID_COMM , ierror)
!        if(num > 0) call MPI_SEND(send_ghost , num , ghost_data_mpi ,
upper_nbr , upper_tag , GRID_COMM , ierror)
        call MPI_SEND(send_ghost , num , ghost_data_mpi , upper_nbr ,
!        if(num_tmp > 0) call MPI_RECV(recv_ghost , num_tmp ,
ghost_data_mpi , &
!                        bottom_nbr , upper_tag , GRID_COMM , stat , ierror)
        call MPI_RECV(recv_ghost , num_tmp , ghost_data_mpi , &
    end if
ghost_data_mpi , &
    end if
    if(num_tmp > 0) then
        do i = 1 , num_tmp
            particle_vector(ghost_pointer+i-1)%basic_particle =
recv_ghost(i)
        end do
    end if
    ghost_pointer = ghost_pointer + num_tmp
    write(*,*) 'rank =: ',rank,upper_nbr,' num =: ' , num , ' num_tmp =:' ,
num_tmp
    if(ghost_pointer > max_num_particle_per_cpu+max_num_ghost_per_cpu) then
        print*, 'should enlarge "max_num_ghost_per_cpu" and/or
"max_num_particle_per_cpu"',ghost_pointer,num_tmp
    end if
        left = 1 ; right = 1
        i = ghost_pointer-num_tmp
        do while(i <= ghost_pointer-1)
            if(particle_vector(i)%basic_particle%global_index /= 0) then
                call
get_index(particle_vector(i)%basic_particle%coor(1),rmax,coor_box(1,1),coor_box(1,2),ind(1))
                call
get_index(particle_vector(i)%basic_particle%coor(2),rmax,coor_box(2,1),coor_box(2,2),ind(2))
                call
get_index(particle_vector(i)%basic_particle%coor(3),rmax,coor_box(3,1),coor_box(3,2),ind(3))
                if(ind(3)   ==0 .and. ind(1)>=0 .and. ind(1)<=nx+1 .and.
ind(2)>=0 .and. ind(2)<=ny+1) then
                    call
add_cell_link(max_num_particle_per_cpu+max_num_ghost_per_cpu,nx,ny,nz,left,right,
ind(1), ind(2), ind(3) , &
i,particle_pointer,last_particle_in_cell)
                end if
            end if
            i = i + 1
        end do
    end if
Please someone help me to fix it. Thank you very much.
Your sincerely,
Sc Deng
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120123/f790a601/attachment.htm>
