[mpich-discuss] Howto use MPI_Comm_merge together	with	MPI_Comm_spawn
    Nick Radcliffe
    nradclif at cray.com
    Thu Feb 16 09:38:19 CST 2012
The parent and child's call to MPI_Intercomm_merge have to be distinct. The child should use 'parentcomm' as its intercommunicator argument, and the child should use 'intercomm' as its intercommunicator argument. Also, the flag used should be different, e.g., the parent could use 0 and the child 1, or vice versa. This flag determines how the ranks of each half of the intercommunicator map into ranks for the intracommunicator.
From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] on behalf of Umit [umitcanyilmaz at gmail.com]
Sent: Thursday, February 16, 2012 9:19 AM
Subject: Re: [mpich-discuss] Howto use MPI_Comm_merge together with MPI_Comm_spawn
Hello Nick,
Thank you for your e-mail.
If  I call MPI_Intercomm_merge with all processes like this:
#define NUM_SPAWNS 4
double timer;
int i;
char str[100];
int main( int argc, char *argv[] )
    MPI_Comm parentcomm, intercomm;
    MPI_Comm comm;
    MPI_Init( &argc, &argv );
    MPI_Comm_get_parent( &parentcomm );
    int np = NUM_SPAWNS;
    if (parentcomm == MPI_COMM_NULL)
        int errcodes[np];
        MPI_Comm_spawn( "/home/umit/Desktop/merge/./a.out", MPI_ARGV_NULL, np, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &intercomm, errcodes );
    else
        printf("I'm the spawned.\n");
    MPI_Intercomm_merge( intercomm, 1, &comm );
    MPI_Finalize();
    return 0;
I am getting this time follgende error:
umit at ubuntu:~/Desktop/merge$ mpirun -np 1 ./a.out
I'm the spawned.
Fatal error in MPI_Intercomm_merge: Invalid communicator, error stack:
MPI_Intercomm_merge(288): MPI_Intercomm_merge(comm=0x331ff4, high=1, newintracomm=0xbf9d0720) failed
MPI_Intercomm_merge(93).: Invalid communicator
I'm the spawned.
MPI_Intercomm_merge(288): MPI_Intercomm_merge(comm=0xc71ff4, high=1, newintracomm=0xbffec690) failed
rank 3 in job 56  ubuntu_38267   caused collective abort of all ranks
  exit status of rank 3: killed by signal 9
rank 0 in job 56  ubuntu_38267   caused collective abort of all ranks
  exit status of rank 0: killed by signal 9
Best Regards,
On 16 February 2012 15:56, Nick Radcliffe <nradclif at cray.com<mailto:nradclif at cray.com>> wrote:
One problem is that the spawned child is not calling MPI_INTERCOMM_MERGE. The child needs to call the merge function in the 'else' part of your 'if (parentcomm == MPI_COMM_NULL)'.
-Nick
From: mpich-discuss-bounces at mcs.anl.gov<mailto:mpich-discuss-bounces at mcs.anl.gov> [mpich-discuss-bounces at mcs.anl.gov<mailto:mpich-discuss-bounces at mcs.anl.gov>] on behalf of Umit [umitcanyilmaz at gmail.com<mailto:umitcanyilmaz at gmail.com>]
Sent: Thursday, February 16, 2012 7:06 AM
To: mpich-discuss at mcs.anl.gov<mailto:mpich-discuss at mcs.anl.gov>
Subject: [mpich-discuss] Howto use MPI_Comm_merge together with MPI_Comm_spawn
Hello All,
Can anyone tell me what is wrong with this simple code:
double timer;
int i;
char str[100];
    MPI_Comm comm, scomm;
    int size;
    MPI_Comm_size( MPI_COMM_WORLD , &size );
       scomm = MPI_COMM_WORLD;
       int errcodes[np];
       MPI_Comm_spawn( "/home/test/Desktop/merge/./a.out", MPI_ARGV_NULL, np, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &intercomm, errcodes );
    else
    MPI_Finalize();
    return 0;
I called MPI_Intercomm_merge outside of if statement but I got the same error.
Spawn is successfull. I have especially tested it. If I try to merge, i got the following error:
test at ubuntu:~/Desktop/merge$ mpirun -np 1 ./a.out
I'm the spawned.
I'm the spawned.
I'm the spawned.
I'm the spawned.
Fatal error in MPI_Intercomm_merge: Other MPI error, error stack:
MPI_Intercomm_merge(288)..........: MPI_Intercomm_merge(comm=0x84000000, high=1, newintracomm=0xbf97ff40) failed
MPI_Intercomm_merge(263)..........:
MPIR_Get_contextid(639)...........:
MPI_Allreduce(773)................: MPI_Allreduce(sbuf=MPI_IN_PLACE, rbuf=0xbf97fd18, count=64, MPI_INT, MPI_BAND, comm=0x84000002) failed
MPIR_Allreduce(289)...............:
MPIC_Sendrecv(161)................:
MPIC_Wait(513)....................:
MPIDI_CH3I_Progress(150)..........:
MPID_nem_mpich2_blocking_recv(948):
MPID_nem_tcp_connpoll(1720).......:
state_commrdy_handler(1556).......:
MPID_nem_tcp_recv_handler(1446)...: socket closed
rank 0 in job 21  ubuntu_38267   caused collective abort of all ranks
Thanks In Advance,
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov<mailto:mpich-discuss at mcs.anl.gov>
To manage subscription options or unsubscribe:
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120216/547ca49f/attachment.htm>
