[mpich-discuss] Howto use MPI_Comm_merge together with MPI_Comm_spawn
Umit
umitcanyilmaz at gmail.com
Thu Feb 16 17:54:00 CST 2012
Thank a lot. It worked.
On 16 February 2012 16:38, Nick Radcliffe <nradclif at cray.com> wrote:
> The parent and child's call to MPI_Intercomm_merge have to be distinct.
> The child should use 'parentcomm' as its intercommunicator argument, and
> the child should use 'intercomm' as its intercommunicator argument. Also,
> the flag used should be different, e.g., the parent could use 0 and the
> child 1, or vice versa. This flag determines how the ranks of each half of
> the intercommunicator map into ranks for the intracommunicator.
> *From:* mpich-discuss-bounces at mcs.anl.gov [
> mpich-discuss-bounces at mcs.anl.gov] on behalf of Umit [
> umitcanyilmaz at gmail.com]
> *Sent:* Thursday, February 16, 2012 9:19 AM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [mpich-discuss] Howto use MPI_Comm_merge together with
> MPI_Comm_spawn
> *Hello Nick, *
> *Thank you for your e-mail. *
> *If I call MPI_Intercomm_merge with all processes like this:
> #define NUM_SPAWNS 4
> double timer;
> int i;
> char str[100];
> int main( int argc, char *argv[] )
> MPI_Comm parentcomm, intercomm;
> MPI_Comm comm;
> MPI_Init( &argc, &argv );
> MPI_Comm_get_parent( &parentcomm );
> int np = NUM_SPAWNS;
> if (parentcomm == MPI_COMM_NULL)
> int errcodes[np];
> MPI_Comm_spawn( "/home/umit/Desktop/merge/./a.out", MPI_ARGV_NULL,
> np, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &intercomm, errcodes );
> else
> printf("I'm the spawned.\n");
> *MPI_Intercomm_merge( intercomm, 1, &comm );*
> MPI_Finalize();
> return 0;
> I am getting this time follgende error:*
> umit at ubuntu:~/Desktop/merge$ mpirun -np 1 ./a.out
> I'm the spawned.
> *Fatal error in MPI_Intercomm_merge: Invalid communicator, error stack:*
> MPI_Intercomm_merge(288): MPI_Intercomm_merge(comm=0x331ff4, high=1,
> newintracomm=0xbf9d0720) failed
> MPI_Intercomm_merge(93).: Invalid communicator
> I'm the spawned.
> MPI_Intercomm_merge(288): MPI_Intercomm_merge(comm=0xc71ff4, high=1,
> newintracomm=0xbffec690) failed
> rank 3 in job 56 ubuntu_38267 caused collective abort of all ranks
> exit status of rank 3: killed by signal 9
> rank 0 in job 56 ubuntu_38267 caused collective abort of all ranks
> exit status of rank 0: killed by signal 9
> Best Regards,
> On 16 February 2012 15:56, Nick Radcliffe <nradclif at cray.com> wrote:
>> One problem is that the spawned child is not calling
>> MPI_INTERCOMM_MERGE. The child needs to call the merge function in the
>> 'else' part of your 'if (parentcomm == MPI_COMM_NULL)'.
>> -Nick
>> *Sent:* Thursday, February 16, 2012 7:06 AM
>> *Subject:* [mpich-discuss] Howto use MPI_Comm_merge together with
>> MPI_Comm_spawn
>> Hello All,
>> Can anyone tell me what is wrong with this simple code:
>> double timer;
>> int i;
>> char str[100];
>> MPI_Comm comm, scomm;
>> int size;
>> MPI_Comm_size( MPI_COMM_WORLD , &size );
>> scomm = MPI_COMM_WORLD;
>> int errcodes[np];
>> MPI_Comm_spawn( "/home/test/Desktop/merge/./a.out", MPI_ARGV_NULL,
>> else
>> MPI_Finalize();
>> return 0;
>> I called MPI_Intercomm_merge outside of if statement but I got the same
>> error.
>> Spawn is successfull. I have especially tested it. If I try to merge, i
>> got the following error:
>> test at ubuntu:~/Desktop/merge$ mpirun -np 1 ./a.out
>> I'm the spawned.
>> I'm the spawned.
>> I'm the spawned.
>> I'm the spawned.
>> Fatal error in MPI_Intercomm_merge: Other MPI error, error stack:
>> MPI_Intercomm_merge(288)..........: MPI_Intercomm_merge(comm=0x84000000,
>> high=1, newintracomm=0xbf97ff40) failed
>> MPI_Intercomm_merge(263)..........:
>> MPIR_Get_contextid(639)...........:
>> MPI_Allreduce(773)................: MPI_Allreduce(sbuf=MPI_IN_PLACE,
>> rbuf=0xbf97fd18, count=64, MPI_INT, MPI_BAND, comm=0x84000002) failed
>> MPIR_Allreduce(289)...............:
>> MPIC_Sendrecv(161)................:
>> MPIC_Wait(513)....................:
>> MPIDI_CH3I_Progress(150)..........:
>> MPID_nem_mpich2_blocking_recv(948):
>> MPID_nem_tcp_connpoll(1720).......:
>> state_commrdy_handler(1556).......:
>> MPID_nem_tcp_recv_handler(1446)...: socket closed
>> rank 0 in job 21 ubuntu_38267 caused collective abort of all ranks
>> Thanks In Advance,
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120217/b2489ceb/attachment-0001.htm>
