[mpich-discuss] Howto use MPI_Comm_merge together with	MPI_Comm_spawn
    Rajeev Thakur
    thakur at mcs.anl.gov
    Thu Feb 16 09:31:24 CST 2012
On the children, Intercomm_merge should use parentcomm.
On Feb 16, 2012, at 9:19 AM, Umit wrote:
> Hello Nick,
> Thank you for your e-mail.
> If  I call MPI_Intercomm_merge with all processes like this:
> #define NUM_SPAWNS 4
> double timer;
> int i;
> char str[100];
> int main( int argc, char *argv[] )
>     MPI_Comm parentcomm, intercomm;
>     MPI_Comm comm;
>     MPI_Init( &argc, &argv );
>     MPI_Comm_get_parent( &parentcomm );
>     int np = NUM_SPAWNS;
>     if (parentcomm == MPI_COMM_NULL)
>         int errcodes[np];
>         MPI_Comm_spawn( "/home/umit/Desktop/merge/./a.out", MPI_ARGV_NULL, np, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &intercomm, errcodes );
>     else
>         printf("I'm the spawned.\n");
>     MPI_Intercomm_merge( intercomm, 1, &comm );
>     MPI_Finalize();
>     return 0;
> I am getting this time follgende error:
> umit at ubuntu:~/Desktop/merge$ mpirun -np 1 ./a.out
> I'm the spawned.
> Fatal error in MPI_Intercomm_merge: Invalid communicator, error stack:
> MPI_Intercomm_merge(288): MPI_Intercomm_merge(comm=0x331ff4, high=1, newintracomm=0xbf9d0720) failed
> MPI_Intercomm_merge(93).: Invalid communicator
> I'm the spawned.
> MPI_Intercomm_merge(288): MPI_Intercomm_merge(comm=0xc71ff4, high=1, newintracomm=0xbffec690) failed
> rank 3 in job 56  ubuntu_38267   caused collective abort of all ranks
>   exit status of rank 3: killed by signal 9
> rank 0 in job 56  ubuntu_38267   caused collective abort of all ranks
>   exit status of rank 0: killed by signal 9
> Best Regards,
> On 16 February 2012 15:56, Nick Radcliffe <nradclif at cray.com> wrote:
> One problem is that the spawned child is not calling MPI_INTERCOMM_MERGE. The child needs to call the merge function in the 'else' part of your 'if (parentcomm == MPI_COMM_NULL)'.
> -Nick
> From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] on behalf of Umit [umitcanyilmaz at gmail.com]
> Sent: Thursday, February 16, 2012 7:06 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Howto use MPI_Comm_merge together with MPI_Comm_spawn
> Hello All,
> Can anyone tell me what is wrong with this simple code:
> double timer;
> int i;
> char str[100];
>     MPI_Comm comm, scomm;
>     int size;
>     MPI_Comm_size( MPI_COMM_WORLD , &size );
>        scomm = MPI_COMM_WORLD;
>        int errcodes[np];
>        MPI_Comm_spawn( "/home/test/Desktop/merge/./a.out", MPI_ARGV_NULL, np, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &intercomm, errcodes );
>     else
>     MPI_Finalize();
>     return 0;
> I called MPI_Intercomm_merge outside of if statement but I got the same error.
> Spawn is successfull. I have especially tested it. If I try to merge, i got the following error:
> test at ubuntu:~/Desktop/merge$ mpirun -np 1 ./a.out
> I'm the spawned.
> I'm the spawned.
> I'm the spawned.
> I'm the spawned.
> Fatal error in MPI_Intercomm_merge: Other MPI error, error stack:
> MPI_Intercomm_merge(288)..........: MPI_Intercomm_merge(comm=0x84000000, high=1, newintracomm=0xbf97ff40) failed
> MPI_Intercomm_merge(263)..........:
> MPIR_Get_contextid(639)...........:
> MPI_Allreduce(773)................: MPI_Allreduce(sbuf=MPI_IN_PLACE, rbuf=0xbf97fd18, count=64, MPI_INT, MPI_BAND, comm=0x84000002) failed
> MPIR_Allreduce(289)...............:
> MPIC_Sendrecv(161)................:
> MPIC_Wait(513)....................:
> MPIDI_CH3I_Progress(150)..........:
> MPID_nem_mpich2_blocking_recv(948):
> MPID_nem_tcp_connpoll(1720).......:
> state_commrdy_handler(1556).......:
> MPID_nem_tcp_recv_handler(1446)...: socket closed
> rank 0 in job 21  ubuntu_38267   caused collective abort of all ranks
> Thanks In Advance,
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
