[mpich-discuss] Howto use MPI_Comm_merge together with MPI_Comm_spawn
Umit
umitcanyilmaz at gmail.com
Thu Feb 16 09:19:55 CST 2012
*Hello Nick, *
*Thank you for your e-mail. *
*If I call MPI_Intercomm_merge with all processes like this:
#define NUM_SPAWNS 4
double timer;
int i;
char str[100];
int main( int argc, char *argv[] )
MPI_Comm parentcomm, intercomm;
MPI_Comm comm;
MPI_Init( &argc, &argv );
MPI_Comm_get_parent( &parentcomm );
int np = NUM_SPAWNS;
if (parentcomm == MPI_COMM_NULL)
int errcodes[np];
MPI_Comm_spawn( "/home/umit/Desktop/merge/./a.out", MPI_ARGV_NULL,
np, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &intercomm, errcodes );
else
printf("I'm the spawned.\n");
*MPI_Intercomm_merge( intercomm, 1, &comm );*
MPI_Finalize();
return 0;
I am getting this time follgende error:*
umit at ubuntu:~/Desktop/merge$ mpirun -np 1 ./a.out
I'm the spawned.
*Fatal error in MPI_Intercomm_merge: Invalid communicator, error stack:*
MPI_Intercomm_merge(288): MPI_Intercomm_merge(comm=0x331ff4, high=1,
newintracomm=0xbf9d0720) failed
MPI_Intercomm_merge(93).: Invalid communicator
I'm the spawned.
MPI_Intercomm_merge(288): MPI_Intercomm_merge(comm=0xc71ff4, high=1,
newintracomm=0xbffec690) failed
rank 3 in job 56 ubuntu_38267 caused collective abort of all ranks
exit status of rank 3: killed by signal 9
rank 0 in job 56 ubuntu_38267 caused collective abort of all ranks
exit status of rank 0: killed by signal 9
Best Regards,
On 16 February 2012 15:56, Nick Radcliffe <nradclif at cray.com> wrote:
> One problem is that the spawned child is not calling
> MPI_INTERCOMM_MERGE. The child needs to call the merge function in the
> 'else' part of your 'if (parentcomm == MPI_COMM_NULL)'.
> -Nick
> *From:* mpich-discuss-bounces at mcs.anl.gov [
> mpich-discuss-bounces at mcs.anl.gov] on behalf of Umit [
> umitcanyilmaz at gmail.com]
> *Sent:* Thursday, February 16, 2012 7:06 AM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* [mpich-discuss] Howto use MPI_Comm_merge together with
> MPI_Comm_spawn
> Hello All,
> Can anyone tell me what is wrong with this simple code:
> double timer;
> int i;
> char str[100];
> MPI_Comm comm, scomm;
> int size;
> MPI_Comm_size( MPI_COMM_WORLD , &size );
> scomm = MPI_COMM_WORLD;
> int errcodes[np];
> MPI_Comm_spawn( "/home/test/Desktop/merge/./a.out", MPI_ARGV_NULL,
> else
> MPI_Finalize();
> return 0;
> I called MPI_Intercomm_merge outside of if statement but I got the same
> error.
> Spawn is successfull. I have especially tested it. If I try to merge, i
> got the following error:
> test at ubuntu:~/Desktop/merge$ mpirun -np 1 ./a.out
> I'm the spawned.
> I'm the spawned.
> I'm the spawned.
> I'm the spawned.
> Fatal error in MPI_Intercomm_merge: Other MPI error, error stack:
> MPI_Intercomm_merge(288)..........: MPI_Intercomm_merge(comm=0x84000000,
> high=1, newintracomm=0xbf97ff40) failed
> MPI_Intercomm_merge(263)..........:
> MPIR_Get_contextid(639)...........:
> MPI_Allreduce(773)................: MPI_Allreduce(sbuf=MPI_IN_PLACE,
> rbuf=0xbf97fd18, count=64, MPI_INT, MPI_BAND, comm=0x84000002) failed
> MPIR_Allreduce(289)...............:
> MPIC_Sendrecv(161)................:
> MPIC_Wait(513)....................:
> MPIDI_CH3I_Progress(150)..........:
> MPID_nem_mpich2_blocking_recv(948):
> MPID_nem_tcp_connpoll(1720).......:
> state_commrdy_handler(1556).......:
> MPID_nem_tcp_recv_handler(1446)...: socket closed
> rank 0 in job 21 ubuntu_38267 caused collective abort of all ranks
> Thanks In Advance,
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120216/3fd70a1b/attachment.htm>
