[mpich-discuss] Information about output of slog2print
Fernando Luz fernando_luz at tpn.usp.br
Wed Feb 15 11:51:24 CST 2012
I used MPE in my MPI application and I converted the output (clog2 file
to slog2 file) and after this I converted again to ascii file using
slog2print.
I want to know if have a documentation which describes the output of
slog2print.
I don't understand the meaning of:
Some stuffs in Header, like as:
  - TreeLeafByteSize;
  - MaxTreeDepth;
  - MaxBufferByteSize;
  -  FBinfo(<integer> @ <integer>)
The categorymap is used to define the elements of MPI (send, recv,
etc..) used in MPI execution. Some info inside of brackets I don't know
the meaning, like as:
  - isUsed;
  - width;
  - info_fmt;
  - vis;
  - search;
  - ratios;
  - count;
And, at least, Slog tree directory, make use of categorymap to provide
the graph of execution.
 - How the tree elements makes the graph?
I was ask about this because I'm planned to make a bash script to obtain
the informations in a mpi execution.
This is my output logfile of an execution.
GUI_LIBDIR is set. GUI_LIBDIR = /home/fernando_luz/usr/local/mpich2/lib
         SLOG-2 Header:
version = SLOG 2.0.6
NumOfChildrenPerNode = 2
TreeLeafByteSize = 65536
MaxTreeDepth = 12
MaxBufferByteSize = 210702
Categories  is FBinfo(978 @ 203746012)
MethodDefs  is FBinfo(0 @ 0)
LineIDMaps  is FBinfo(232 @ 203746990)
TreeRoot    is FBinfo(2428 @ 203743584)
TreeDir     is FBinfo(210702 @ 203747222)
Annotations is FBinfo(0 @ 0)
Postamble   is FBinfo(0 @ 0)
         CategoryMap:
1: Category[ index=0, name=message, topo=Arrow,
color=(255,255,255,255,true), isUsed=false, width=3, info_fmt=< msg_tag=
%d, msg_size=%d >, vis=true, search=true, ratios=5.938042E-5,0.0,
count=12 ]
2: Category[ index=71, name=MPI_Irecv, topo=State,
color=(152,251,152,255,true), isUsed=false, width=1, vis=true,
search=true, ratios=4.6330633E-6,4.6330633E-6, count=6 ]
3: Category[ index=76, name=MPI_Pack_size, topo=State,
color=(255,255,255,255,true), isUsed=false, width=1, vis=true,
search=true, ratios=4.7874983E-6,4.7874983E-6, count=76 ]
4: Category[ index=78, name=MPI_Recv, topo=State,
color=(0,255,0,255,true), isUsed=false, width=1, vis=true, search=true,
ratios=1.2596459,1.2596459, count=6 ]
5: Category[ index=281, name=CLOG_Buffer_write2disk, topo=State,
color=(176,48,96,255,true), isUsed=false, width=1, vis=true,
search=true, ratios=0.13866395,0.13866395, count=46 ]
6: Category[ index=73, name=MPI_Isend, topo=State,
color=(135,206,235,255,true), isUsed=false, width=1, vis=true,
search=true, ratios=4.941934E-6,4.941934E-6, count=6 ]
7: Category[ index=105, name=MPI_Unpack, topo=State,
search=true, ratios=6.872377E-6,6.872377E-6, count=76 ]
8: Category[ index=75, name=MPI_Pack, topo=State,
search=true, ratios=5.8685464E-6,5.8685464E-6, count=76 ]
9: Category[ index=252, name=MPE_Irecv_waited, topo=State,
color=(255,140,0,255,true), isUsed=false, width=1, vis=true,
search=true, ratios=6.1774176E-7,6.1774176E-7, count=6 ]
10: Category[ index=184, name=MPI_Free_mem, topo=State,
color=(160,32,240,255,true), isUsed=false, width=1, vis=true,
search=true, ratios=5.7141115E-6,5.7141115E-6, count=60 ]
11: Category[ index=81, name=MPI_Send, topo=State,
color=(0,0,255,255,true), isUsed=false, width=1, vis=true, search=true,
ratios=6.254635E-6,6.254635E-6, count=6 ]
12: Category[ index=25, name=MPI_Comm_rank, topo=State,
search=true, ratios=2.779838E-6,2.779838E-6, count=17 ]
13: Category[ index=88, name=MPI_Test, topo=State,
color=(255,165,0,255,true), isUsed=false, width=1, vis=true,
search=true, ratios=0.56697184,0.50070196, count=6141049 ]
14: Category[ index=183, name=MPI_Alloc_mem, topo=State,
search=true, ratios=9.574997E-6,9.574997E-6, count=60 ]
15: Category[ index=28, name=MPI_Comm_size, topo=State,
search=true, ratios=2.0076607E-6,2.0076607E-6, count=20 ]
16: Category[ index=-3, name=Preview_State, topo=State,
color=(255,255,255,191,true), isUsed=false, width=5, vis=true,
search=true, ratios=0.0,0.0, count=0 ]
17: Category[ index=-2, name=Preview_Arrow, topo=Arrow,
color=(255,255,0,255,true), isUsed=false, width=5, vis=true,
18: Category[ index=302, name=MPE_Comm_finalize, topo=Event,
search=true, ratios=NaN,0.0, count=4 ]
19: Category[ index=-1, name=Preview_Event, topo=Event,
         SLOG-2 Tree Directory
ID(12,0) -> DirVal[ TimeBBox(7.040500640869141E-4,3.0883190631866455),
FBinfo(2428 @ 203743584) ]
ID(11,0) -> DirVal[ TimeBBox(7.040500640869141E-4,2.0137720108032227),
FBinfo(1290 @ 134789844) ]
ID(11,1) -> DirVal[ TimeBBox(2.0137720108032227,3.0883190631866455),
FBinfo(1542 @ 203742042) ]
ID(10,0) -> DirVal[ TimeBBox(7.040500640869141E-4,1.0034620761871338),
FBinfo(1050 @ 67395756) ]
ID(10,1) -> DirVal[ TimeBBox(1.0034620761871338,2.0137720108032227),
FBinfo(670 @ 134789174) ]
ID(10,2) -> DirVal[ TimeBBox(2.0137720108032227,3.016982078552246),
FBinfo(330 @ 202180286) ]
ID(10,3) -> DirVal[ TimeBBox(3.016982078552246,3.0883190631866455),
FBinfo(1400 @ 203740642) ]
ID(9,0) -> DirVal[ TimeBBox(7.040500640869141E-4,0.4991741180419922),
FBinfo(710 @ 33697324) ]
ID(9,1) -> DirVal[ TimeBBox(0.4991741180419922,1.0034620761871338),
FBinfo(670 @ 67395086) ]
ID(9,2) -> DirVal[ TimeBBox(1.0034620761871338,1.5079309940338135),
FBinfo(670 @ 101093858) ]
ID(9,3) -> DirVal[ TimeBBox(1.5079309940338135,2.0137720108032227),
FBinfo(330 @ 134788844) ]
ID(9,4) -> DirVal[ TimeBBox(2.0137720108032227,2.5104100704193115),
FBinfo(330 @ 168485310) ]
ID(9,5) -> DirVal[ TimeBBox(2.5104100704193115,3.016982078552246),
FBinfo(330 @ 202179956) ]
ID(9,6) -> DirVal[ TimeBBox(3.016982078552246,3.0883190631866455),
FBinfo(1400 @ 203739242) ]
Best Regards
Fernando Luz
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120215/2eed719d/attachment.htm>
