[mpich-discuss] Information about output of slog2print
    Anthony Chan
    chan at mcs.anl.gov
    Wed Feb 15 12:02:50 CST 2012
Reading the slog2 paper below
"An Efficient Format for Nearly Constant-Time Access
to Arbitrary Time Intervals in Large Trace Files"
in http://www.mcs.anl.gov/research/projects/perfvis/publications/index.htm
should answer your questions.  If not, ask again.
Also, not all fields in slog2 format is used in jumpshot.
A.Chan
----- Original Message -----
> Hi,
> I used MPE in my MPI application and I converted the output (clog2
> file
> to slog2 file) and after this I converted again to ascii file using
> slog2print.
> I want to know if have a documentation which describes the output of
> slog2print.
> I don't understand the meaning of:
> Some stuffs in Header, like as:
> - TreeLeafByteSize;
> - MaxTreeDepth;
> - MaxBufferByteSize;
> - FBinfo(<integer> @ <integer>)
> The categorymap is used to define the elements of MPI (send, recv,
> etc..) used in MPI execution. Some info inside of brackets I don't
> know
> the meaning, like as:
> - isUsed;
> - width;
> - info_fmt;
> - vis;
> - search;
> - ratios;
> - count;
> And, at least, Slog tree directory, make use of categorymap to provide
> the graph of execution.
> - How the tree elements makes the graph?
> I was ask about this because I'm planned to make a bash script to
> obtain
> the informations in a mpi execution.
> This is my output logfile of an execution.
> GUI_LIBDIR is set. GUI_LIBDIR =
> /home/fernando_luz/usr/local/mpich2/lib
> SLOG-2 Header:
> version = SLOG 2.0.6
> NumOfChildrenPerNode = 2
> TreeLeafByteSize = 65536
> MaxTreeDepth = 12
> MaxBufferByteSize = 210702
> Categories is FBinfo(978 @ 203746012)
> MethodDefs is FBinfo(0 @ 0)
> LineIDMaps is FBinfo(232 @ 203746990)
> TreeRoot is FBinfo(2428 @ 203743584)
> TreeDir is FBinfo(210702 @ 203747222)
> Annotations is FBinfo(0 @ 0)
> Postamble is FBinfo(0 @ 0)
> CategoryMap:
> 1: Category[ index=0, name=message, topo=Arrow,
> color=(255,255,255,255,true), isUsed=false, width=3, info_fmt=<
> msg_tag=
> %d, msg_size=%d >, vis=true, search=true, ratios=5.938042E-5,0.0,
> count=12 ]
> 2: Category[ index=71, name=MPI_Irecv, topo=State,
> color=(152,251,152,255,true), isUsed=false, width=1, vis=true,
> search=true, ratios=4.6330633E-6,4.6330633E-6, count=6 ]
> 3: Category[ index=76, name=MPI_Pack_size, topo=State,
> color=(255,255,255,255,true), isUsed=false, width=1, vis=true,
> search=true, ratios=4.7874983E-6,4.7874983E-6, count=76 ]
> 4: Category[ index=78, name=MPI_Recv, topo=State,
> color=(0,255,0,255,true), isUsed=false, width=1, vis=true,
> search=true,
> ratios=1.2596459,1.2596459, count=6 ]
> 5: Category[ index=281, name=CLOG_Buffer_write2disk, topo=State,
> color=(176,48,96,255,true), isUsed=false, width=1, vis=true,
> search=true, ratios=0.13866395,0.13866395, count=46 ]
> 6: Category[ index=73, name=MPI_Isend, topo=State,
> color=(135,206,235,255,true), isUsed=false, width=1, vis=true,
> search=true, ratios=4.941934E-6,4.941934E-6, count=6 ]
> 7: Category[ index=105, name=MPI_Unpack, topo=State,
> search=true, ratios=6.872377E-6,6.872377E-6, count=76 ]
> 8: Category[ index=75, name=MPI_Pack, topo=State,
> search=true, ratios=5.8685464E-6,5.8685464E-6, count=76 ]
> 9: Category[ index=252, name=MPE_Irecv_waited, topo=State,
> color=(255,140,0,255,true), isUsed=false, width=1, vis=true,
> search=true, ratios=6.1774176E-7,6.1774176E-7, count=6 ]
> 10: Category[ index=184, name=MPI_Free_mem, topo=State,
> color=(160,32,240,255,true), isUsed=false, width=1, vis=true,
> search=true, ratios=5.7141115E-6,5.7141115E-6, count=60 ]
> 11: Category[ index=81, name=MPI_Send, topo=State,
> color=(0,0,255,255,true), isUsed=false, width=1, vis=true,
> search=true,
> ratios=6.254635E-6,6.254635E-6, count=6 ]
> 12: Category[ index=25, name=MPI_Comm_rank, topo=State,
> search=true, ratios=2.779838E-6,2.779838E-6, count=17 ]
> 13: Category[ index=88, name=MPI_Test, topo=State,
> color=(255,165,0,255,true), isUsed=false, width=1, vis=true,
> search=true, ratios=0.56697184,0.50070196, count=6141049 ]
> 14: Category[ index=183, name=MPI_Alloc_mem, topo=State,
> search=true, ratios=9.574997E-6,9.574997E-6, count=60 ]
> 15: Category[ index=28, name=MPI_Comm_size, topo=State,
> search=true, ratios=2.0076607E-6,2.0076607E-6, count=20 ]
> 16: Category[ index=-3, name=Preview_State, topo=State,
> color=(255,255,255,191,true), isUsed=false, width=5, vis=true,
> search=true, ratios=0.0,0.0, count=0 ]
> 17: Category[ index=-2, name=Preview_Arrow, topo=Arrow,
> color=(255,255,0,255,true), isUsed=false, width=5, vis=true,
> 18: Category[ index=302, name=MPE_Comm_finalize, topo=Event,
> search=true, ratios=NaN,0.0, count=4 ]
> 19: Category[ index=-1, name=Preview_Event, topo=Event,
> SLOG-2 Tree Directory
> ID(12,0) -> DirVal[ TimeBBox(7.040500640869141E-4,3.0883190631866455),
> FBinfo(2428 @ 203743584) ]
> ID(11,0) -> DirVal[ TimeBBox(7.040500640869141E-4,2.0137720108032227),
> FBinfo(1290 @ 134789844) ]
> ID(11,1) -> DirVal[ TimeBBox(2.0137720108032227,3.0883190631866455),
> FBinfo(1542 @ 203742042) ]
> ID(10,0) -> DirVal[ TimeBBox(7.040500640869141E-4,1.0034620761871338),
> FBinfo(1050 @ 67395756) ]
> ID(10,1) -> DirVal[ TimeBBox(1.0034620761871338,2.0137720108032227),
> FBinfo(670 @ 134789174) ]
> ID(10,2) -> DirVal[ TimeBBox(2.0137720108032227,3.016982078552246),
> FBinfo(330 @ 202180286) ]
> ID(10,3) -> DirVal[ TimeBBox(3.016982078552246,3.0883190631866455),
> FBinfo(1400 @ 203740642) ]
> ID(9,0) -> DirVal[ TimeBBox(7.040500640869141E-4,0.4991741180419922),
> FBinfo(710 @ 33697324) ]
> ID(9,1) -> DirVal[ TimeBBox(0.4991741180419922,1.0034620761871338),
> FBinfo(670 @ 67395086) ]
> ID(9,2) -> DirVal[ TimeBBox(1.0034620761871338,1.5079309940338135),
> FBinfo(670 @ 101093858) ]
> ID(9,3) -> DirVal[ TimeBBox(1.5079309940338135,2.0137720108032227),
> FBinfo(330 @ 134788844) ]
> ID(9,4) -> DirVal[ TimeBBox(2.0137720108032227,2.5104100704193115),
> FBinfo(330 @ 168485310) ]
> ID(9,5) -> DirVal[ TimeBBox(2.5104100704193115,3.016982078552246),
> FBinfo(330 @ 202179956) ]
> ID(9,6) -> DirVal[ TimeBBox(3.016982078552246,3.0883190631866455),
> FBinfo(1400 @ 203739242) ]
> Best Regards
> Fernando Luz
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
