[mpich-discuss] Mapping process to specific node
Fernando Luz
fernando_luz at tpn.usp.br
Mon Feb 6 10:57:34 CST 2012
Hi Pavan,
I will do now.
Fernando Luz
On Dom, 2012-02-05 at 14:19 -0600, Pavan Balaji wrote:
> This might be a bug in the Hydra code. I looked through the code. I
> didn't specifically try the example reported, but I think I know what's
> going wrong here.
> Fernando: can you please create a ticket for this?
> https://trac.mcs.anl.gov/projects/mpich2/newticket
> Thanks,
> -- Pavan
> On 02/05/2012 02:15 PM, Rajeev Thakur wrote:
> > Not sure what the problem is. You may want to check with the SLURM folks. Does it work without the -f host.txt?
> > Rajeev
> > On Feb 3, 2012, at 2:53 PM, Fernando Luz wrote:
> >> Hi again,
> >> Another information, I'm using slurm, and if I execute without reservation the nodes, I'm successful .
> >> With slurm, first I made salloc reservation.
> >> $ salloc -N 3 --exclusive
> >> And I receive a 3 nodes with 8 cores.
> >> $ echo $SLURM_NODELIST
> >> machine01
> >> machine02
> >> machine03
> >> and if I run mpiexec
> >> $ mpiexec -n 10 -f host.txt ./hostname_test
> >> srun: error: Only allocated 3 nodes asked for 6
> >> Regards
> >> Fernando Luz
> >> On Sex, 2012-02-03 at 18:31 -0200, Fernando Luz wrote:
> >>> Hello,
> >>> I create the follow program:
> >>> #include "mpi.h"
> >>> # include<cstdlib>
> >>> # include<iostream>
> >>> # include<iomanip>
> >>> # include<ctime>
> >>> int main ( int argc, char *argv[] )
> >>> int rank;
> >>> int size;
> >>> char hostname[255];
> >>> int size_hostname;
> >>> double wtime;
> >>> MPI::Init ( argc, argv );
> >>> size = MPI::COMM_WORLD.Get_size();
> >>> rank = MPI::COMM_WORLD.Get_rank();
> >>> MPI::Get_processor_name(hostname, size_hostname);
> >>> if ( rank == 0 ){
> >>> std::cout<< " print size = "<< size<< std::endl;
> >>> std::cout<< "I am rank="<< rank<< " and my hostname="<< hostname<< std::endl;
> >>> MPI::Finalize();
> >>> return 0;
> >>> In my execution test, I was planned run this program using this command-line
> >>> and the host.txt
> >>> machine01 # rank 0 run in machine01
> >>> machine02 # rank 1 run in machine02
> >>> machine03 # rank 2 run in machine03
> >>> machine03 # rank 3 run in machine03
> >>> machine02 # rank 4 run in machine02
> >>> machine03 # rank 5 run in machine03
> >>> machine01 # rank 6 run in machine01
> >>> machine01 # rank 7 run in machine01
> >>> machine03 # rank 8 run in machine03
> >>> machine01 # rank 9 run in machine01
> >>> But I don't have success.
> >>> It's possible to select a process to run in a specific node?
> >>> Regards
> >>> Fernando Luz
> >>> _______________________________________________
> >>> mpich-discuss mailing list
> >>> mpich-discuss at mcs.anl.gov
> >>> To manage subscription options or unsubscribe:
> >>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> >> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120206/3e704a01/attachment-0001.htm>
