[mpich-discuss] problem with mpiexec while running parallel	execution
    Elie M
    elie.moujaes at hotmail.co.uk
    Sun Feb  5 16:03:45 CST 2012
Dear sir/madam,
I am running a
parallel execution (pw.x) on a SLURM LINUX interface  and once I run the command
sbatch filename.srm, the calculation starts running and then stops with the
follwing error:
"mpiexec_veredas5: cannot connect to local mpd
 (/tmp/mpd2.console_sushil);
possible causes:
  1. no mpd
is running on this host
 2. an mpd is
running but was started without a "console" (-n option)
 In case 1, you
can start an mpd on this host with:
    mpd
 and you will be
able to run jobs just on this host.
 For more details
on starting mpds on a set of hosts, see
 the MPICH2
Installation Guide."
The script is executed using the package of quantum Espresso (QE). You will find below the script I am using to run the QE: The architecture is an INTEL based cluster.
" #!/bin/bash
#SBATCH -o
/home_cluster/fis718/eliemouj/espresso-4.3.2/GB72/GB72-script.scf.out
#SBATCH -N 1
#SBATCH --nodelist=veredas13
#SBATCH -J scf-GB72-ph
#SBATCH --account=fis718
#SBATCH --partition=long
#SBATCH --get-user-env
#SBATCH -e GB72ph.scf.fit.err
/opt/mpi/mpibull2-1.3.9-18.s/bin/mpiexec /home_cluster/fis718eliemouj/espresso-4.3-2/bin/pw.x
<GB72ph.scf.in >GB72ph.scf.out"
Please can anyone tell me what might be going wrong and how to fix this. I am not that professional in LINUX; I would appreciate a rather detailed solution for the problem or if possible where can I find such a solution. Hope to hear from you soon.
Regards
Elie Moujaes
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120205/aed595a5/attachment.htm>
