[mpich-discuss] Mapping process to specific node
Pavan Balaji
balaji at mcs.anl.gov
Sun Feb 5 14:19:41 CST 2012
This might be a bug in the Hydra code. I looked through the code. I
didn't specifically try the example reported, but I think I know what's
going wrong here.
Fernando: can you please create a ticket for this?
https://trac.mcs.anl.gov/projects/mpich2/newticket
-- Pavan
On 02/05/2012 02:15 PM, Rajeev Thakur wrote:
> Not sure what the problem is. You may want to check with the SLURM folks. Does it work without the -f host.txt?
> Rajeev
> On Feb 3, 2012, at 2:53 PM, Fernando Luz wrote:
>> Hi again,
>> Another information, I'm using slurm, and if I execute without reservation the nodes, I'm successful .
>> With slurm, first I made salloc reservation.
>> $ salloc -N 3 --exclusive
>> And I receive a 3 nodes with 8 cores.
>> $ echo $SLURM_NODELIST
>> machine01
>> machine02
>> machine03
>> and if I run mpiexec
>> $ mpiexec -n 10 -f host.txt ./hostname_test
>> srun: error: Only allocated 3 nodes asked for 6
>> Regards
>> Fernando Luz
>> On Sex, 2012-02-03 at 18:31 -0200, Fernando Luz wrote:
>>> Hello,
>>> I create the follow program:
>>> #include "mpi.h"
>>> # include<cstdlib>
>>> # include<iostream>
>>> # include<iomanip>
>>> # include<ctime>
>>> int main ( int argc, char *argv[] )
>>> int rank;
>>> int size;
>>> char hostname[255];
>>> int size_hostname;
>>> double wtime;
>>> MPI::Init ( argc, argv );
>>> size = MPI::COMM_WORLD.Get_size();
>>> rank = MPI::COMM_WORLD.Get_rank();
>>> MPI::Get_processor_name(hostname, size_hostname);
>>> if ( rank == 0 ){
>>> std::cout<< " print size = "<< size<< std::endl;
>>> std::cout<< "I am rank="<< rank<< " and my hostname="<< hostname<< std::endl;
>>> MPI::Finalize();
>>> return 0;
>>> In my execution test, I was planned run this program using this command-line
>>> and the host.txt
>>> machine01 # rank 0 run in machine01
>>> machine02 # rank 1 run in machine02
>>> machine03 # rank 2 run in machine03
>>> machine03 # rank 3 run in machine03
>>> machine02 # rank 4 run in machine02
>>> machine03 # rank 5 run in machine03
>>> machine01 # rank 6 run in machine01
>>> machine01 # rank 7 run in machine01
>>> machine03 # rank 8 run in machine03
>>> machine01 # rank 9 run in machine01
>>> But I don't have success.
>>> It's possible to select a process to run in a specific node?
>>> Regards
>>> Fernando Luz
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
