[mpich-discuss] Problems with terminal-IO and mpiexec
Titianingrum - 08.5831 at stis.ac.id
Fri Aug 31 02:23:02 CDT 2012
mpi program run hiden on slave side, so how to input there?
that's I know that mpi program not run well while need input.
On Mon, Aug 27, 2012 at 3:07 PM, Dr. Wilfried Jakob (IAI) <
wilfried.jakob at kit.edu> wrote:
> Hi,
> as I did not receive any reply  to my email from 31.7.2012 I post it again
> and really hope that somebody can help me.
> I want to have a communication on the root process (rank=0) in such a way
> that single characters are read from the terminal.
> This is achieved in plain C by using  termios.h and the functions
> tcgetattr() and tcsetattr() as shown in the attached test program. With
> gcc  and  Debian Linux this works fine.
> I translated the program with mpicc without any problems and started it
> directly from the command line: it worked well.
> Then I started it with
>     mpiexec -f nodes -n 2  tioTestMPI
> and received the following:
> Waiting for input ...
>   error with cbreak
>   error with cbreak
> A more detailed analysis shows that the call to "tcgetattr" yields the
> error "Invalid argument". This was obtained by a subsequent call to perror.
> A version including prior calls to
>    MPI_Init(&argc, &argv);
>    MPI_Comm_rank(MPI_COMM_WORLD, &rank);
>    MPI_Comm_size(MPI_COMM_WORLD, &size);
> is given by the second program. It yields the same results:
>   error with cbreak
> lazy slave
> Thanks in advance
> Wilfried Jakob
> Here is the source code of the test program 1:
> #include <stdio.h>
> #include <stdlib.h>
> #include <termios.h>
> #include <unistd.h>
> static struct termios new_io;
> static struct termios old_io;
> int cbreak(int fd) {
>    /* save old terminal settings */
>    if((tcgetattr(fd, &old_io)) == -1)
>       return -1;
>    new_io = old_io;
>    /* change terminal settings */
>    new_io.c_lflag = new_io.c_lflag & ~(ECHO|ICANON);
>    new_io.c_cc[VMIN] = 1;
>    new_io.c_cc[VTIME]= 0;
>    /* set new settings */
>    if((tcsetattr(fd, TCSAFLUSH, &new_io)) == -1)
>       return -1;
>    return 1;
> int getch(void) {
>    int c;
>    if(cbreak(STDIN_FILENO) == -1) {
>       printf("  error with cbreak \n");
>       exit(EXIT_FAILURE);
>    c = getchar();
>    /* restore old terminal settings */
>    tcsetattr(STDIN_FILENO, TCSANOW, &old_io);
>    return c;
> int main (int argc, char** argv)
>    int  ii;
>    printf ("Waiting for input ...\n");
>    ii = getch ();
>    printf ("  read: \"%c\" = %d\n", (char)ii, ii);
>    ii = getch ();
>    printf ("\nfinished!\n");
>    return 0;
> Here is the source code of the test program 2:
> #include <stdio.h>
> #include <stdlib.h>
> #include <unistd.h>
> #include "mpi.h"
>       return -1;
>    new_io = old_io;
>       return -1;
>    return 1;
> int getch(void) {
>    int c;
>       printf("  error with cbreak\n");
>       exit(EXIT_FAILURE);
>    c = getchar();
>    return c;
>    int  ii, rank, size;
>    if (rank == 0) { /* master */
>       ii = getch ();
>       ii = getch ();
>    } /* master */
>    else
>       printf ("lazy slave\n");
>    MPI_Finalize();
>    return 0;
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
titia
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120831/34a5ebf7/attachment-0001.html>
