[mpich-discuss] Problems with terminal-IO and mpiexec
Dr. Wilfried Jakob (IAI) wilfried.jakob at kit.edu
Mon Aug 27 03:07:22 CDT 2012
as I did not receive any reply  to my email from 31.7.2012 I post it
again and really hope that somebody can help me.
I want to have a communication on the root process (rank=0) in such a
way that single characters are read from the terminal.
This is achieved in plain C by using  termios.h and the functions
tcgetattr() and tcsetattr() as shown in the attached test program. With
gcc  and  Debian Linux this works fine.
I translated the program with mpicc without any problems and started it
directly from the command line: it worked well.
Then I started it with
     mpiexec -f nodes -n 2  tioTestMPI
and received the following:
Waiting for input ...
   error with cbreak
   error with cbreak
A more detailed analysis shows that the call to "tcgetattr" yields the
error "Invalid argument". This was obtained by a subsequent call to perror.
A version including prior calls to
    MPI_Init(&argc, &argv);
    MPI_Comm_rank(MPI_COMM_WORLD, &rank);
    MPI_Comm_size(MPI_COMM_WORLD, &size);
is given by the second program. It yields the same results:
   error with cbreak
lazy slave
Thanks in advance
Wilfried Jakob
Here is the source code of the test program 1:
#include <stdio.h>
#include <stdlib.h>
#include <termios.h>
#include <unistd.h>
static struct termios new_io;
static struct termios old_io;
int cbreak(int fd) {
    /* save old terminal settings */
    if((tcgetattr(fd, &old_io)) == -1)
       return -1;
    new_io = old_io;
    /* change terminal settings */
    new_io.c_lflag = new_io.c_lflag & ~(ECHO|ICANON);
    new_io.c_cc[VMIN] = 1;
    new_io.c_cc[VTIME]= 0;
    /* set new settings */
    if((tcsetattr(fd, TCSAFLUSH, &new_io)) == -1)
       return -1;
    return 1;
int getch(void) {
    int c;
    if(cbreak(STDIN_FILENO) == -1) {
       printf("  error with cbreak \n");
       exit(EXIT_FAILURE);
    c = getchar();
    /* restore old terminal settings */
    tcsetattr(STDIN_FILENO, TCSANOW, &old_io);
    return c;
int main (int argc, char** argv)
    int  ii;
    printf ("Waiting for input ...\n");
    ii = getch ();
    printf ("  read: \"%c\" = %d\n", (char)ii, ii);
    ii = getch ();
    printf ("\nfinished!\n");
    return 0;
Here is the source code of the test program 2:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include "mpi.h"
       return -1;
    new_io = old_io;
       return -1;
    return 1;
int getch(void) {
    int c;
       printf("  error with cbreak\n");
       exit(EXIT_FAILURE);
    c = getchar();
    return c;
    int  ii, rank, size;
    if (rank == 0) { /* master */
       ii = getch ();
       ii = getch ();
    } /* master */
    else
       printf ("lazy slave\n");
    MPI_Finalize();
    return 0;
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120827/0043a2c7/attachment.html>
