[mpich-discuss] Problems with terminal-IO and mpiexec
Dr. Wilfried Jakob (IAI)
wilfried.jakob at kit.edu
Fri Aug 31 02:57:56 CDT 2012
Thanks a loot for the first reaction on my question.
I do not perform any terminal input on slaves. Terminal input is
restricted to the root process without any exception. The basic idea is
to use two threads for the root-process: one for user-I/O and one for
handling the slaves.
I hoped that this is possible ... ?
Cheers
Wilfried
Am 31.08.2012 09:23, schrieb Titianingrum -:
> mpi program run hiden on slave side, so how to input there?
> that's I know that mpi program not run well while need input.
> On Mon, Aug 27, 2012 at 3:07 PM, Dr. Wilfried Jakob (IAI)
> <wilfried.jakob at kit.edu <mailto:wilfried.jakob at kit.edu>> wrote:
> Hi,
> as I did not receive any reply to my email from 31.7.2012 I post
> it again and really hope that somebody can help me.
> I want to have a communication on the root process (rank=0) in
> such a way that single characters are read from the terminal.
> This is achieved in plain C by using termios.h and the functions
> tcgetattr() and tcsetattr() as shown in the attached test program.
> With gcc and Debian Linux this works fine.
> I translated the program with mpicc without any problems and
> started it directly from the command line: it worked well.
> Then I started it with
> mpiexec -f nodes -n 2 tioTestMPI
> and received the following:
> Waiting for input ...
> error with cbreak
> error with cbreak
> A more detailed analysis shows that the call to "tcgetattr" yields
> the error "Invalid argument". This was obtained by a subsequent
> call to perror.
> A version including prior calls to
> MPI_Init(&argc, &argv);
> MPI_Comm_rank(MPI_COMM_WORLD, &rank);
> MPI_Comm_size(MPI_COMM_WORLD, &size);
> is given by the second program. It yields the same results:
> error with cbreak
> lazy slave
> Thanks in advance
> Wilfried Jakob
> Here is the source code of the test program 1:
> #include <stdio.h>
> #include <stdlib.h>
> #include <termios.h>
> #include <unistd.h>
> static struct termios new_io;
> static struct termios old_io;
> int cbreak(int fd) {
> /* save old terminal settings */
> if((tcgetattr(fd, &old_io)) == -1)
> return -1;
> new_io = old_io;
> /* change terminal settings */
> new_io.c_lflag = new_io.c_lflag & ~(ECHO|ICANON);
> new_io.c_cc[VMIN] = 1;
> new_io.c_cc[VTIME]= 0;
> /* set new settings */
> if((tcsetattr(fd, TCSAFLUSH, &new_io)) == -1)
> return -1;
> return 1;
> int getch(void) {
> int c;
> if(cbreak(STDIN_FILENO) == -1) {
> printf(" error with cbreak \n");
> exit(EXIT_FAILURE);
> c = getchar();
> /* restore old terminal settings */
> tcsetattr(STDIN_FILENO, TCSANOW, &old_io);
> return c;
> int main (int argc, char** argv)
> int ii;
> printf ("Waiting for input ...\n");
> ii = getch ();
> printf (" read: \"%c\" = %d\n", (char)ii, ii);
> ii = getch ();
> printf ("\nfinished!\n");
> return 0;
> Here is the source code of the test program 2:
> #include <stdio.h>
> #include <stdlib.h>
> #include <unistd.h>
> #include "mpi.h"
> return -1;
> new_io = old_io;
> return -1;
> return 1;
> int getch(void) {
> int c;
> printf(" error with cbreak\n");
> exit(EXIT_FAILURE);
> c = getchar();
> return c;
> int ii, rank, size;
> if (rank == 0) { /* master */
> ii = getch ();
> ii = getch ();
> } /* master */
> else
> printf ("lazy slave\n");
> MPI_Finalize();
> return 0;
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> <mailto:mpich-discuss at mcs.anl.gov>
> To manage subscription options or unsubscribe:
> titia
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120831/f12fe66b/attachment.html>
