[mpich-discuss] client server application on windows7
toufik hadjazi h_toufik7 at hotmail.fr
Sun Apr 8 04:30:11 CDT 2012
Hi,  i tried to do like you told me ( save the port name into a text file and read it back as an alternative for mpi_publish/lookup_name) but i encountred a problem, when i run the program it gives me the message: "job aborted" ! and when i observed the operation i found that the file pointer on fopen is NULL, so, i'm confused what the problem could be? one more thing, when i was reading some documentation, i found that we could specify a range for MPI_Open_port with the envirenment variable MPI_PORT_RANGE so i thought maybe i could fix the port using this variable as an example : 2033..2033 in order to have the port 2033 but i don't know how to do that! thanks & regards,Toufik
 > Date: Mon, 2 Apr 2012 14:44:22 -0500
> From: jayesh at mcs.anl.gov
> To: h_toufik7 at hotmail.fr
> CC: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] client server application on windows7
> Hi,
>  Please install MPICH2 on all the machines/nodes where your job (MPI processes) is launched and run your job (Specify the list of nodes using a machine file - See Windows developers guide,http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs, for details).
> Regards,
> Jayesh
> From: "toufik hadjazi" <h_toufik7 at hotmail.fr>
> To: jayesh at mcs.anl.gov
> Sent: Monday, April 2, 2012 12:41:14 PM
> Subject: RE: [mpich-discuss] client server application on windows7
> Hi Jayesh,
> thanks for your answer, but the problem is my application will be used in a cluster so the client and the server won't be on the same pc. so, i'm wondering if there is another implmentation of MPI that support this functionnality?
> > Date: Mon, 2 Apr 2012 12:27:49 -0500
> > To: mpich-discuss at mcs.anl.gov
> > CC: h_toufik7 at hotmail.fr
> > Hi,
> > The process manager with MPICH2 on Windows (SMPD) does not support publish/lookup across different jobs. You will have to publish/lookup the port name yourself (Write port string from MPI_Open_port() to a text file and read it etc.).
> > Regards,
> > Jayesh
> > Sent: Monday, April 2, 2012 11:54:13 AM
> > Subject: [mpich-discuss] client server application on windows7
> > Hi guys,
> > I am trying to build a simple client/server application on windows 7 using Visual Studio where the server and the client are run by two different mpiexec and it worked well, but when i introduced mpi_publish_name and mpi_lookup_name the client couldn't find the port associated with the name service, knowing that these tow functions work well when they are in the same programme, i thought that maybe there is a kind of scope for those functions.
> > so, could any body help me with it.
> > and thanks.
> > _______________________________________________
> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120408/8b603714/attachment-0001.htm>
