[mpich-discuss] client server application on windows7
Jayesh Krishna
jayesh at mcs.anl.gov
Mon Apr 2 14:44:22 CDT 2012
Please install MPICH2 on all the machines/nodes where your job (MPI processes) is launched and run your job (Specify the list of nodes using a machine file - See Windows developers guide,http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs, for details).
Jayesh
----- Original Message -----
To: jayesh at mcs.anl.gov
Sent: Monday, April 2, 2012 12:41:14 PM
Subject: RE: [mpich-discuss] client server application on windows7
Hi Jayesh,
thanks for your answer, but the problem is my application will be used in a cluster so the client and the server won't be on the same pc. so, i'm wondering if there is another implmentation of MPI that support this functionnality?
> Date: Mon, 2 Apr 2012 12:27:49 -0500
> From: jayesh at mcs.anl.gov
> To: mpich-discuss at mcs.anl.gov
> CC: h_toufik7 at hotmail.fr
> Subject: Re: [mpich-discuss] client server application on windows7
> Hi,
> The process manager with MPICH2 on Windows (SMPD) does not support publish/lookup across different jobs. You will have to publish/lookup the port name yourself (Write port string from MPI_Open_port() to a text file and read it etc.).
> Regards,
> Jayesh
> From: "toufik hadjazi" <h_toufik7 at hotmail.fr>
> Sent: Monday, April 2, 2012 11:54:13 AM
> Subject: [mpich-discuss] client server application on windows7
> Hi guys,
> I am trying to build a simple client/server application on windows 7 using Visual Studio where the server and the client are run by two different mpiexec and it worked well, but when i introduced mpi_publish_name and mpi_lookup_name the client couldn't find the port associated with the name service, knowing that these tow functions work well when they are in the same programme, i thought that maybe there is a kind of scope for those functions.
> so, could any body help me with it.
> and thanks.
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
