[mpich-discuss] error ruuning mpirun
    Anthony Chan
    chan at mcs.anl.gov
    Wed Sep 28 11:44:47 CDT 2011
mpich2-1.2.1 is pretty old, the latest release is 1.4.1p1.
Since you compiled from the source, you should use the latest
if you can.
A.Chan
----- Original Message -----
> Thank you!
> >What version of mpich2 are you using. The default process manager is
> >hydra
> >not mpd in the recent releases of mpich2. Did you install mpich2 in
> >/usr ?
> The version is mpich2-1.2.1 and I installed it in /usr
> I re-compiled the source file and installed it ,then it can run now
> ------------------ Original ------------------
> From: "Anthony Chan"<chan at mcs.anl.gov>;
> Date: Wed, Sep 28, 2011 12:07 PM
> To: "mpich-discuss"<mpich-discuss at mcs.anl.gov>;
> Subject: Re: [mpich-discuss] error ruuning mpirun
> > hi,
> > I have installed mpich2, but I got a problem when running mpirun:
> > "mpirun -np X XXX"
> > the program got stuck and showed " /usr/bin/mpdroot: open failed for
> > root's mpd conf filempiexec_localhost (__init5 "
> hydra
> /usr ?
> > It seems that the problem is caused because of error with the
> > configure file, but i got no idea to solve the problem.
> > Looking forward for you help, thank you!
> If there is problem in your configure, please send configure and make
> outputs
> as stated in the top-level README file.
> A.Chan
> > Zicheng Zhao
> > _______________________________________________
> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
