[mpich-discuss] install mpich2 on windows7 64bit
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed Sep 28 10:29:25 CDT 2011
 Good to know MPICH2 is working for you now.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Tuesday, September 27, 2011 8:25:36 PM
Subject: Re:Re: [mpich-discuss] install mpich2 on windows7 64bit
Hi
I use 32bit mpich2 on 64bit win7, It works.Thank you very much.
lizhen
At 2011-09-27 23:05:01,"Jayesh Krishna" <jayesh at mcs.anl.gov> wrote:
>Hi,
> MPICH2 currently does not support heterogeneous systems. So you cannot run your job across 32-bit and 64-bit systems.
>Regards,
>Jayesh
>From: "李朕" <lizhen870704 at 126.com>
>Sent: Monday, September 26, 2011 8:03:37 PM
>Hi
>Thaks for your reply.
>I try to run cpi.exe.
>I use two computers. One is win7 64bit(ip:172.18.14.25), the other is win xp 32 bit(ip:172.18.14.13).
>Firstly, I can't find both of them in the domain as workgroup ,though I set both of them in workgroup.( May be the bug between win7 and winxp?)
>on the win7 host I using the mpiexec from the command line :( mpiexec -hosts 1 172.18.14.25 c:\Progra~1\MPICH2\examples\cpi.exe or mpiexec -hosts 1 172.18.14.25 c:\Progra~1\MPICH2\examples\cpi.exe) it works. but ( mpiexec -hosts 2 172.18.14.25 172.18.14.13 c:\Progra~1\MPICH2\examples\cpi.exe) it does't work.
>running on the win xp is the same as on win7.
>I also use two laptops to test. one is win7 64bit the other is win7 32bit. It doesn't work ,either.
>At 2011-09-26 22:36:00,"Jayesh Krishna" < jayesh at mcs.anl.gov > wrote:
>>Hi,
>> The wrapper utils (wmpi*) have some bugs that have not been fixed. So they may not work as expected. However mpiexec and the libraries should work.
>> Are you able to run your job using mpiexec from the command line (mpiexec -n 2 c:\Progra~1\MPICH2\examples\cpi.exe) ?
>>Regards,
>>Jayesh
>>From: "李朕" < lizhen870704 at 126.com >
>>To: mpich-discuss at mcs.anl.gov >Sent: Sunday, September 25, 2011 9:18:47 AM
>>Subject: [mpich-discuss] install mpich2 on windows7 64bit
>>Hello Sir,
>>I used mpich2 on windows xp . Recently ,I try to install mpich2 on windows7 64bit. When I used mpich2 on windows xp,I started the wmpiconfig.exe and chosed the Domain:Group.Then I click "scan Hosts", the name of the computer which had installed mpich2 successfully would turn green. But on windows, the smpd work as service. And I can see the smpd.exe in the taskmgr. But if I do what as I did on windows xp, the name didn't turn green.
>>Could anybody give me some suggestion?
>>Kind regards
>>lizhen
>>_______________________________________________
>>mpich-discuss mailing list mpich-discuss at mcs.anl.gov >To manage subscription options or unsubscribe:
>>https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
