[mpich-discuss] error ruuning mpirun
    alias
    980782417 at qq.com
    Wed Sep 28 00:54:00 CDT 2011
Thank you!
 >What version of mpich2 are you using.  The default process manager is hydra
>not mpd in the recent releases of mpich2.  Did you install mpich2 in /usr ?
 The version is  mpich2-1.2.1 and I installed it in /usr
I re-compiled the source file and installed it ,then it can run now
  ------------------ Original ------------------
 Date:  Wed, Sep 28, 2011 12:07 PM
 To:  "mpich-discuss"<mpich-discuss at mcs.anl.gov>;
 Subject:  Re: [mpich-discuss] error ruuning mpirun
----- Original Message -----
> hi,
> I have installed mpich2, but I got a problem when running mpirun:
> "mpirun -np X XXX"
> the program got stuck and showed " /usr/bin/mpdroot: open failed for
> root's mpd conf filempiexec_localhost (__init5 "
> It seems that the problem is caused because of error with the
> configure file, but i got no idea to solve the problem.
> Looking forward for you help, thank you!
If there is problem in your configure, please send configure and make outputs
as stated in the top-level README file.
A.Chan
> Zicheng Zhao
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110928/c4e02ffc/attachment.htm>
