[mpich-discuss] mpich-1.4.1p1
    Gus Correa
    gus at ldeo.columbia.edu
    Wed Sep 21 14:10:45 CDT 2011
Hi Anthony, Carolina
Anthony:
How about non-ascii characters? e.g. Ã (A with an accent)
Are they OK in Linux directory and file names?
Do they require some specific locale setting, UTF-8 character set,
or other?
Does autoconf digest them right?
Carolina:
I'd stay on the safe side and stick to very conventional
file and directory names made only of:
1)  upper and lower case letters [a to z, and A to Z, without any
accents, be careful with your Brazilian ABNT/ABNT-2 keyboard!],
2) digits [0 to 9],
3) underscore (_) [e.g. my_file], and
4) period (.) [e.g. my_program.f90]
And use the slash (/) *only* for directory name separator.
No blanks of course [which is a Windows thing].
My two cents,
Gus Correa
Anthony Chan wrote:
> Carolina,
> Here are lines that in config.log shows the problem:
> configure:11770: gcc -c      -I/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include -I/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include -I/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src -I/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src conftest.c >&5
> gcc: de: No such file or directory
> gcc: Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include: No such file or directory
> gcc: Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src: No such file or directory
> Notice your mpich2 source is located in "/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/"
> which contains blank character.  Many unix tools including autoconf cannot handle blanks in
> pathname well, so move mpich2 source tree to a directory whose pathname does NOT contain any
> blank or white space characters.  The same for the build and install directories.
> A.Chan
>> Hello,
>> I'm trying to install mpich2-1.4.1p1 in my computer and it's not
>> working.
>> The following message appear:
>> "configure: error: **** Incompatible Fortran and C Object File Types!
>> F77 Object File Type produced by "gfortran -O2" is : : ELF 64-bit LSB
>> relocatable, x86-64, version 1 (SYSV), not stripped.
>> C Object File Type produced by "gcc " is : : ERROR: cannot open `' (No
>> such file or directory)."
>> I have gfortran and gcc installed in my computer.
>> I tried to use ./configure --disable-f77, because I don't require
>> support
>> for Fortran 77, just for Fortran 90, but it didn't work either:
>> "Fortran 90 support requires compatible Fortran 77 support.
>> To force the use of the Fortran 90 compiler for Fortran 77,
>> do not use configure option --disable-f77, and set the environment
>> variable F77 to the name of the Fortran 90 compiler, or $FC.
>> If you do not want any Fortran support, use configure options
>> --disable-f77 and --disable-fc."
>> Can you help me? I don't know what to do, and I need this very
>> quickly.
>> Thank you for your attencion,
>> Carolina Moura.
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
