[mpich-discuss] mpich-1.4.1p1
    Carolina Carneiro
    carol07 at astro.ufrj.br
    Wed Sep 21 14:06:22 CDT 2011
A. Chan,
I can't believe it wasn't work because of this. Now it's working.
Thank you very much.
Carolina.
2011/9/21 Anthony Chan <chan at mcs.anl.gov>
> Carolina,
> Here are lines that in config.log shows the problem:
> configure:11770: gcc -c      -I/home/carol/Ã rea de
> Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include -I/home/carol/Ã rea de
> Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src -I/home/carol/Ã rea de
> Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src conftest.c >&5
> gcc: de: No such file or directory
> gcc: Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include: No such file or
> directory
> directory
> gcc: Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src: No such file or
> directory
> directory
> Notice your mpich2 source is located in "/home/carol/Ã rea de
> Trabalho/Mocassin/mpich2-1.4.1p1/"
> which contains blank character.  Many unix tools including autoconf cannot
> handle blanks in
> pathname well, so move mpich2 source tree to a directory whose pathname
> does NOT contain any
> blank or white space characters.  The same for the build and install
> directories.
> A.Chan
> > Hello,
> > I'm trying to install mpich2-1.4.1p1 in my computer and it's not
> > working.
> > The following message appear:
> > "configure: error: **** Incompatible Fortran and C Object File Types!
> > F77 Object File Type produced by "gfortran -O2" is : : ELF 64-bit LSB
> > relocatable, x86-64, version 1 (SYSV), not stripped.
> > C Object File Type produced by "gcc " is : : ERROR: cannot open `' (No
> > such file or directory)."
> > I have gfortran and gcc installed in my computer.
> > I tried to use ./configure --disable-f77, because I don't require
> > support
> > for Fortran 77, just for Fortran 90, but it didn't work either:
> > "Fortran 90 support requires compatible Fortran 77 support.
> > To force the use of the Fortran 90 compiler for Fortran 77,
> > do not use configure option --disable-f77, and set the environment
> > variable F77 to the name of the Fortran 90 compiler, or $FC.
> > If you do not want any Fortran support, use configure options
> > --disable-f77 and --disable-fc."
> > Can you help me? I don't know what to do, and I need this very
> > quickly.
> > Thank you for your attencion,
> > Carolina Moura.
> > _______________________________________________
> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110921/f14cc3fd/attachment.htm>
