[mpich-discuss] mpich-1.4.1p1
    Carolina Carneiro
    carol07 at astro.ufrj.br
    Wed Sep 21 14:19:20 CDT 2011
Hi Gus,
Thanks for the clue. I'll do that now.
Carolina.
2011/9/21 Gus Correa <gus at ldeo.columbia.edu>
> Hi Anthony, Carolina
> Anthony:
> How about non-ascii characters? e.g. Ã  (A with an accent)
> Are they OK in Linux directory and file names?
> Do they require some specific locale setting, UTF-8 character set,
> or other?
> Does autoconf digest them right?
> Carolina:
> I'd stay on the safe side and stick to very conventional
> file and directory names made only of:
> 1)  upper and lower case letters [a to z, and A to Z, without any accents,
> be careful with your Brazilian ABNT/ABNT-2 keyboard!],
> 2) digits [0 to 9],
> 3) underscore (_) [e.g. my_file], and
> 4) period (.) [e.g. my_program.f90]
> And use the slash (/) *only* for directory name separator.
> No blanks of course [which is a Windows thing].
> My two cents,
> Gus Correa
> Anthony Chan wrote:
>> Carolina,
>> Here are lines that in config.log shows the problem:
>> configure:11770: gcc -c      -I/home/carol/Ã rea de
>> Trabalho/Mocassin/mpich2-1.4.**1p1/src/mpl/include -I/home/carol/Ã rea de
>> Trabalho/Mocassin/mpich2-1.4.**1p1/src/openpa/src -I/home/carol/Ã rea de
>> Trabalho/Mocassin/mpich2-1.4.**1p1/src/openpa/src conftest.c >&5
>> gcc: de: No such file or directory
>> gcc: Trabalho/Mocassin/mpich2-1.4.**1p1/src/mpl/include: No such file or
>> directory
>> directory
>> gcc: Trabalho/Mocassin/mpich2-1.4.**1p1/src/openpa/src: No such file or
>> directory
>> directory
>> Notice your mpich2 source is located in "/home/carol/Ã rea de
>> Trabalho/Mocassin/mpich2-1.4.**1p1/"
>> which contains blank character.  Many unix tools including autoconf cannot
>> handle blanks in
>> pathname well, so move mpich2 source tree to a directory whose pathname
>> does NOT contain any
>> blank or white space characters.  The same for the build and install
>> directories.
>> A.Chan
>> ----- Original Message -----
>>> Hello,
>>> I'm trying to install mpich2-1.4.1p1 in my computer and it's not
>>> working.
>>> The following message appear:
>>> "configure: error: **** Incompatible Fortran and C Object File Types!
>>> F77 Object File Type produced by "gfortran -O2" is : : ELF 64-bit LSB
>>> relocatable, x86-64, version 1 (SYSV), not stripped.
>>> C Object File Type produced by "gcc " is : : ERROR: cannot open `' (No
>>> such file or directory)."
>>> I have gfortran and gcc installed in my computer.
>>> I tried to use ./configure --disable-f77, because I don't require
>>> support
>>> for Fortran 77, just for Fortran 90, but it didn't work either:
>>> "Fortran 90 support requires compatible Fortran 77 support.
>>> To force the use of the Fortran 90 compiler for Fortran 77,
>>> do not use configure option --disable-f77, and set the environment
>>> variable F77 to the name of the Fortran 90 compiler, or $FC.
>>> If you do not want any Fortran support, use configure options
>>> --disable-f77 and --disable-fc."
>>> Can you help me? I don't know what to do, and I need this very
>>> quickly.
>>> Thank you for your attencion,
>>> Carolina Moura.
>>> ______________________________**_________________
>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110921/8087c9a4/attachment-0001.htm>
