[mpich-discuss] mpich-1.4.1p1
    Anthony Chan
    chan at mcs.anl.gov
    Wed Sep 21 13:45:11 CDT 2011
Carolina,
Here are lines that in config.log shows the problem:
configure:11770: gcc -c      -I/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include -I/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include -I/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src -I/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src conftest.c >&5
gcc: de: No such file or directory
gcc: Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include: No such file or directory
gcc: Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src: No such file or directory
Notice your mpich2 source is located in "/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/"
which contains blank character.  Many unix tools including autoconf cannot handle blanks in
pathname well, so move mpich2 source tree to a directory whose pathname does NOT contain any
blank or white space characters.  The same for the build and install directories.
A.Chan
----- Original Message -----
> Hello,
> I'm trying to install mpich2-1.4.1p1 in my computer and it's not
> working.
> The following message appear:
> "configure: error: **** Incompatible Fortran and C Object File Types!
> F77 Object File Type produced by "gfortran -O2" is : : ELF 64-bit LSB
> relocatable, x86-64, version 1 (SYSV), not stripped.
> C Object File Type produced by "gcc " is : : ERROR: cannot open `' (No
> such file or directory)."
> I have gfortran and gcc installed in my computer.
> I tried to use ./configure --disable-f77, because I don't require
> support
> for Fortran 77, just for Fortran 90, but it didn't work either:
> "Fortran 90 support requires compatible Fortran 77 support.
> To force the use of the Fortran 90 compiler for Fortran 77,
> do not use configure option --disable-f77, and set the environment
> variable F77 to the name of the Fortran 90 compiler, or $FC.
> If you do not want any Fortran support, use configure options
> --disable-f77 and --disable-fc."
> Can you help me? I don't know what to do, and I need this very
> quickly.
> Thank you for your attencion,
> Carolina Moura.
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
