[mpich-discuss] mpich compilation issue
    akshar bhosale
    akshar.bhosale at gmail.com
    Wed Sep 14 22:14:32 CDT 2011
please check the config log in detail with options passed as export
FC=gfortran. It has not created mpif90 nor mpif77. Where things are going
wrong?
On Wed, Sep 14, 2011 at 10:46 PM, Gus Correa <gus at ldeo.columbia.edu> wrote:
> akshar bhosale wrote:
> > No, it is not bug because the same code is running in other machine.
> Hi Akshar
> The devilish thing with MPI programs is that success in one machine,
> or with a certain number of processes, or in a specific network,
> doesn't mean that the program is bug free.
> It may still fail in a different environment.
> [Actually, even sequential programs are like that.
> In one computer, with a certain compiler, etc,
> say, a segmentation fault may not appear, may not break
> at run time, but in another machine/OS/compiler it may.]
> "It works" is a necessary but not sufficient condition for
> "being bug-free"
> The error message you've got is pretty clear.
> There is a deadlock.
> See Pavan's suggestion in his email.
> I hope this helps,
> Gus Correa
>>    Can something be done so that even if mpif77 does not get created,
>>    no issues; but mpif90 (mpich-1.2.7p1, gfortran) should get created
>>    and fortran helloworld should run without any issues.
>> Thank you
>> Akshar.
>> On Tue, Sep 13, 2011 at 10:39 PM, Gus Correa <gus at ldeo.columbia.edu<mailto:
>> gus at ldeo.columbia.edu>**> wrote:
>>  Hi Akshar
>>    It sounds as a bug in the program,
>>    which causes a deadlock, not a problem with MPICH2.
>>    Your error message:
>>     > MPID_Send(57): DEADLOCK: attempting to send a message to the local
>>     > process without a prior matching receive
>>    If you post the code, the list may help you.
>>    Gus Correa
>>        sorry for not answering why not mpich2.
>>        We have tried to compile our code using mpich2, it compiles but
>>        while running the executable generated, it runs and in between
>>        it comes out giving some mpi send error. The code compiled with
>>        mpif90 (mpich-1.2.7p1) using gfortran on other machine runs fine.
>>        Error is as follows:
>>         3  aft MPI_SEND           2           7           2           0
>>                  3  call MPI_SEND           2           8           2
>>              0
>>                  3  aft MPI_SEND           2           8           2
>>            0
>>                  3  call MPI_SEND           2           9           2
>>              0
>>                  3  aft MPI_SEND           2           9           2
>>            0
>>                  3  call MPI_SEND           2          10           2
>>              0
>>                  3  aft MPI_SEND           2          10           2
>>            0
>>                  3  call MPI_SEND           3           1           3
>>              0
>>        [cli_3]: aborting job:
>>        Fatal error in MPI_Send: Other MPI error, error stack:
>>        MPI_Send(175): MPI_Send(buf=0x2aaab2af2018, count=1,
>>        dtype=USER<vector>, dest=3, tag=30003, MPI_COMM_WORLD) failed
>>        local process without a prior matching receive
>>        -akshar
>>        On Tue, Sep 13, 2011 at 10:02 PM, akshar bhosale
>>        <akshar.bhosale at gmail.com <mailto:akshar.bhosale at gmail.**com<akshar.bhosale at gmail.com>
>>        <mailto:akshar.bhosale at gmail._**_com
>>        <mailto:akshar.bhosale at gmail.**com <akshar.bhosale at gmail.com>>>>
>> wrote:
>>           thanks for reply.
>>           Goal is to generate mpif90 using mpich-1.2.7p1 using gfortran
>>        which
>>           will generate executable from our fortran code.
>>           source files to be compiled are .f and .f90 files.
>>           f2c flag is given because mp[if90 was not getting generated. no
>>           other reason. we want mpif90.
>>           Now we have tried giving only FC=gfortran and no other flag of
>>           option except prefix, but still it is not generating mpif90
>>        nor mpif77.
>>           mpif90 generated  by using [export
>> F90=fortran;F90FLAGS="-ff2c".]
>>           options if tries to compile our code, it throws error
>>           <path to mpif90>/mpif90 -f90=gfortran -Wl -o ../output_code.x
>>        set.o
>>           inp.o otp.o bvsol.o user_kg.o mpi_util.o mpi_communication.o
>>           mpi_memalloc.o driver.o rxn.o advdi_1d_finitediff_mf.o
>>         aq_lib.o \
>>                   -L/ioapi/Linux2_x86_64gfort -lioapi
>>           -L/np_cs/netcdf/INSTALL/lib -lnetcdf -L/usr/lib64/
>>            -lgomp /np_cs/lapack/lapack-3.2.1/__**lapack_LINUX.a
>>           /np_cs/lapack/lapack-3.2.1/__**blas_LINUX.a
>>           /build/lib/libmpich.a(farg.o): In function `mpir_iargc__':
>>           farg.f:(.text+0x6): undefined reference to `f__xargc'
>>           /build/lib/libmpich.a(farg.o): In function `mpir_getarg__':
>>           farg.f:(.text+0x38): undefined reference to `getarg_'
>>           collect2: ld returned 1 exit status
>>           make: *** [../output_code.x] Error 1
>>           -akshar
>>           On Tue, Sep 13, 2011 at 8:52 PM, Gus Correa
>>        <gus at ldeo.columbia.edu <mailto:gus at ldeo.columbia.edu>
>>        <mailto:gus at ldeo.columbia.edu>**>__> wrote:
>>               Hi Pavan and Akshar
>>               I see, it's MPICH-1.
>>               May I ask why?
>>               Would a workaround perhaps be to build only mpif77 (no
>>        mpif90),
>>               replace 'use mpi' by '#include "mpif.h"' in the
>>        application code,
>>               and recompile it with mpif77?
>>               I wonder if -ff2c works at all with Fortran90.
>>               (See man page detail below.)
>>               Anyway, I remember that there were complaints of runtime
>>               errors (P4 errors) with mpich-1,
>>               reported on this and other mailing lists,
>>               when running on current Linux kernels.
>>               Even with simple codes like the cpi example.
>>               Using MPICH-1 may be an uphill battle.
>>               I hope this helps,
>>               Gus Correa
>>                >From man gfortran (4.1.2):
>>                     -ff2c
>>                         Generate code designed to be compatible with code
>>               generated by g77 and f2c.
>>                         The calling conventions used by g77 (originally
>>               implemented in f2c) require functions that return type
>>        default
>>               "REAL" to actually return the C type
>>                         "double", and functions that return type
>>        "COMPLEX" to
>>               return the values via an extra argument in the calling
>>        sequence
>>               that points to where to store the
>>                         return value.  Under the default GNU calling
>>               conventions, such functions simply return their results
>>        as they
>>               would in GNU C -- default "REAL" functions
>>                         return the C type "float", and "COMPLEX" functions
>>               return the GNU C type "complex".  Additionally, this option
>>               implies the -fsecond-underscore option,
>>                         unless -fno-second-underscore is explicitly
>>        requested.
>>                         This does not affect the generation of code that
>>               interfaces with the libgfortran library.
>>                         Caution: It is not a good idea to mix Fortran code
>>               compiled with "-ff2c" with code compiled with the default
>>               "-fno-f2c" calling conventions as, calling
>>                         "COMPLEX" or default "REAL" functions between
>>        program
>>               parts which were compiled with different calling conventions
>>               will break at execution time.
>>                         Caution: This will break code which passes
>>        intrinsic
>>               functions of type default "REAL" or "COMPLEX" as actual
>>               arguments, as the library implementations
>>                         use the -fno-f2c calling conventions.
>>               Pavan Balaji wrote:
>>                   Gus: He doesn't want to use MPICH2. He's using MPICH-1.
>>                          -- Pavan
>>                   On 09/13/2011 09:51 AM, Gus Correa wrote:
>>                       Hi Akshar
>>                       Maybe the F90FLAGS="-ff2c" flag is causing the
>>        problem?
>>                       What if you remove it and use gfortran for F77
>>        and FC?
>>                       Also, my 'configure -help' (a bit old, MPICH2
>>        1.3.2p1)
>>                       mentions FC, not F90, as the environment variable
>>        to be set.
>>                       For what it is worth, MPICH2 builds fine for us,
>> with
>>                       gcc, g++ and gfortran (for F77 and FC).
>>                       My two cents,
>>                       Gus Correa
>>                           Hi,
>>                              If i specify F77 anf F90 as gfortran, it
>>        doesn't
>>                           create mpif90 and
>>                           mpif77 at all.
>>                           Please see attached config log
>>                           If i specify F90=gfortran and
>>        F90FLAGS="-ff2c", the
>>                           it creates mpif90
>>                           and mpif77 but is generating below issue.
>>                           Kindly help.
>>                           -akshar
>>                           On Tue, Sep 13, 2011 at 9:46 AM, Rajeev
>>                           Thakur<thakur at mcs.anl.gov
>>        <mailto:thakur at mcs.anl.gov> <mailto:thakur at mcs.anl.gov
>>        <mailto:thakur at mcs.anl.gov>>
>>        <mailto:thakur at mcs.anl.gov>>>>  wrote:
>>                               In the configure step, if you specify
>>        both F77
>>                           and F90 as gfortran,
>>                               it should work.
>>                               Rajeev
>>                               On Sep 12, 2011, at 9:49 PM, akshar
>>        bhosale wrote:
>>                                >  Hi,
>>                                >  thanks.
>>                                >  but, in case of mpicc, it can be
>> ignored,
>>                           but in case of mpif90,
>>                               it is still an issue.
>>                                >  e.g. hello_mpi.f90 program
>>                                >  program main
>>                                >     use mpi
>>                                >  ! implicit none
>>                                >    integer error
>>                                >    integer id
>>                                >    integer p
>>                                >    real ( kind = 8 ) wtime
>>                                >  !  Initialize MPI.
>>                                >    call MPI_Init ( error )
>>                                >  !  Get the number of processes.
>>                                >    call MPI_Comm_size ( MPI_COMM_WORLD,
>> p,
>>                           error )
>>                                >  !  Get the individual process ID.
>>                                >    call MPI_Comm_rank (
>>        MPI_COMM_WORLD, id,
>>                           error )
>>                                >  !  Print a message.
>>                                >    if ( id == 0 ) then
>>                                >      wtime = MPI_Wtime ( )
>>                                >      write ( *, '(a)' ) ' '
>>                                >      write ( *, '(a)' ) 'HELLO_MPI -
>>        Master
>>                           process:'
>>         FORTRAN90/MPI version'
>>                                >      write ( *, '(a)' ) '  An MPI test
>>        program.'
>>                                >      write ( *, '(a,i8)' ) '  The
>>        number of
>>                           processes is ', p
>>                                >    end if
>>                                >    write ( *, '(a,i8,a)' ) '  Process
>>        ', id,
>>                           ' says "Hello, world!"'
>>                                >    if ( id == 0 ) then
>>        Master
>>                           process:'
>>                                >      write ( *, '(a)' ) '  Normal end of
>>                           execution: "Goodbye,
>>                               world!".'
>>                                >      wtime = MPI_Wtime ( ) - wtime
>>                                >      write ( *, '(a,g14.6,a)' ) '
>>  Elapsed
>>                           wall clock time = ',
>>                               wtime, ' seconds.'
>>                                >     end if
>>                                >   !  Shut down MPI.
>>                                >    call MPI_Finalize ( error )
>>                                >    stop
>>                                >    end
>>                                >  $ ../../../build/bin/mpif90
>> hello_mpi.f90
>>                                   /scratch1/np_cs/trial1/build/_**
>> ___lib/libmpich.a(farg.o):
>>                           In function
>>                               `mpir_iargc__':
>>        reference to
>>                           `f__xargc'
>>                           In function
>>                               `mpir_getarg__':
>>        reference to
>>                           `getarg_'
>>                                >  On Mon, Sep 12, 2011 at 9:42 AM,
>>        Rajeev Thakur
>>        <mailto:thakur at mcs.anl.gov>><_**_mailto:tha__kur at mcs.anl.gov
>>        <mailto:tha__kur at mcs.anl.gov>
>>                                >  Ignore that. Compile a real program
>>        as mpicc
>>                           foo.c.
>>                                >  On Sep 11, 2011, at 8:38 PM, akshar
>>        bhosale
>>                           wrote:
>>                                >  >  Hi,
>>                                >  >  thank you for reply.
>>                                >  >  I tried to install it make it using
>>                           following options now and i
>>                               get following error with undefined
>>        reference to
>>                           main. options given
>>                               while configuring the same are :
>>                                >  >  export F90=fortran;F90FLAGS="-ff2c".
>>                                >  >  but error of undefined reference
>>        to main
>>                           is observed in every
>>                               executable like :
>>                                >  >  ./mpicc -v
>>                                >  >  mpicc for 1.2.7 (release) of :
>>        2005/06/22
>>                           16:33:49
>>                                >  >  Using built-in specs.
>>                                >  >  Target: x86_64-redhat-linux
>>                                >  >  Configured with: ../configure
>>        --prefix=/usr
>>                               --mandir=/usr/share/man
>>                           --infodir=/usr/share/info --enable-shared
>>                               --enable-threads=posix
>>        --enable-checking=release
>>                           --with-system-zlib
>>                               --enable-__cxa_atexit
>>        --disable-libunwind-exceptions
>>                               --enable-libgcj-multifile
>> --enable-languages=c,c++,objc,**____obj-c++,java,fortran,ada
>>                               --enable-java-awt=gtk --disable-dssi
>>                           --disable-plugin
>> --with-java-home=/usr/lib/jvm/**____java-1.4.2-gcj-1.4.2.0/jre
>>                               --with-cpu=generic
>> --host=x86_64-redhat-linux
>>                                >  >  Thread model: posix
>>                                >  >  gcc version 4.1.2 20080704 (Red
>>        Hat 4.1.2-50)
>> /usr/libexec/gcc/x86_64-____**redhat-linux/4.1.2/collect2
>>                               --eh-frame-hdr -m elf_x86_64
>> --hash-style=gnu
>>                           -dynamic-linker
>>                               /lib64/ld-linux-x86-64.so.2
>> /usr/lib/gcc/x86_64-redhat-___**_linux/4.1.2/../../../../**
>> lib64/____crt1.o
>> lib64/____crti.o
>> _linux/4.1.2/crtbegin.o
>>                               -L/scratch1/np_cs/trial2/____**build/lib
>>                               -L/opt/intel/mkl/10.2.2.025/__**__lib/em64t<http://10.2.2.025/____lib/em64t>
>>        <http://10.2.2.025/__lib/em64t**>
>>                                  <http://10.2.2.025/lib/em64t><**__
>> http://10.2.2.025/__lib/**em64t <http://10.2.2.025/__lib/em64t>
>>                           <http://10.2.2.025/lib/em64t>>
>>                               -L/usr/lib/gcc/x86_64-redhat-_**
>> ___linux/4.1.2
>> ___linux/4.1.2
>> -L/usr/lib/gcc/x86_64-redhat-_**___linux/4.1.2/../../../../**lib64
>>                               -L/lib/../lib64 -L/usr/lib/../lib64 -lmpich
>>                           -lpthread -lrt -lgcc
>>                               --as-needed -lgcc_s --no-as-needed -lc -lgcc
>>                           --as-needed -lgcc_s
>>                               --no-as-needed
>> _linux/4.1.2/crtend.o
>> lib64/____crtn.o
>> lib64/____crt1.o:
>>                           In
>>                               function `_start':
>>                                >  >  (.text+0x20): undefined reference
>>        to `main'
>>                                >  >  ./mpif90 -v
>>                                >  >  mpif90 for 1.2.7 (release) of :
>>                           2005/06/22 16:33:49
>>                                >  >  Driving: gfortran
>>                           -L/scratch1/np_cs/trial2/____**build/lib -v
>>                               -lmpichf90 -lmpich -lpthread -lrt
>>                           -lgfortranbegin -lgfortran -lm
>>                               -shared-libgcc
>>        --prefix=/usr
>>                           --with-system-zlib
>>                           --disable-plugin
>>                               --with-cpu=generic
>>                                >  >  Thread model: posix
>>        Hat 4.1.2-50)
>> --hash-style=gnu
>>                           -dynamic-linker
>> lib64/____crt1.o
>> lib64/____crti.o
>> ___linux/4.1.2
>> ___linux/4.1.2
>>        -lmpichf90
>>                           -lmpich -lpthread
>>                               -lrt -lgfortranbegin -lgfortran -lm -lgcc_s
>>                           -lgcc -lc -lgcc_s -lgcc
>> lib64/____crtn.o
>> /usr/lib/gcc/x86_64-redhat-___**_linux/4.1.2/libgfortranbegin.**
>> ____a(fmain.o):
>>                               In function `main':
>>                                >  >  (.text+0xa): undefined reference
>>        to `MAIN__'
>>                                >  >  Am i missing somethin?
>>                                >  >  thank you
>>                                >  >  -akshar
>>                                >  >  On Mon, Sep 12, 2011 at 1:24 AM,
>>        William
>>                           Gropp
>>                               <wgropp at illinois.edu
>>        <mailto:wgropp at illinois.edu>
>>        <mailto:wgropp at illinois.edu>><**__mailto:wg__ropp at illinois.edu
>>        <mailto:wg__ropp at illinois.edu>
>>        <mailto:wgropp at illinois.edu>>>**>  wrote:
>>                                >  >  You can use gfortran for F77 and
>>        F90.  If
>>                           your requirement is
>>                               to use gfortran for F77 and a different
>>        fortran
>>                           for F90, then they
>>                               will need to use consistent linker names,
>>                           calling conventions, data
>>                               sizes, and libraries.  The config.log
>>        file will
>>                           have details on why
>>                               configure decided that the Fortran 77 and
>>                           Fortran 90 compilers were
>>                               not compatible.
>>                                >  >  Bill
>>                                >  >  On Sep 9, 2011, at 4:28 PM, akshar
>>                           bhosale wrote:
>>                                >  >  hi,
>>                                >  >  we have requirement of mpich-1.2.7
>>        with
>>                           gfortran. We have fiven
>>                               flags as :
>>        CC=gcc;F90=fortran;F77=____**gfortran;
>>                           and tried to configure,
>>                               it throws error as configure: error:
>>        Fortran 90
>>                           and Fortran 77
>>                               compilers are not compatible..
>>                                >  >  We have to do it using gfortran
>>        only. os
>>                           is rhel5.1 64 bit
>>                                >  >  what extran flags settings we have
>>        to do?
>>                                >  >  -akshar
>>                                   ______________________________**
>>                                >  >  mpich-discuss mailing list
>>                     mpich-discuss at mcs.anl.gov
>>        <mailto:mpich-discuss at mcs.anl.**gov <mpich-discuss at mcs.anl.gov>>
>>                           <mailto:mpich-discuss at mcs.anl.**__gov
>>        <mailto:mpich-discuss at mcs.anl.**gov <mpich-discuss at mcs.anl.gov>>>
>>        <mailto:mpich-discuss at mcs.anl.**>____gov
>>        <mailto:mpich-discuss at mcs.anl.**gov <mpich-discuss at mcs.anl.gov>>>>
>>                                >  >  To manage subscription options or
>>                           unsubscribe:
>>                                   https://lists.mcs.anl.gov/____**
>> mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/____mailman/listinfo/mpich-discuss>
>>        <https://lists.mcs.anl.gov/__**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/__mailman/listinfo/mpich-discuss>
>>        <https://lists.mcs.anl.gov/**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
>> **>__>
>>                                >  >  William Gropp
>>                                >  >  Director, Parallel Computing
>> Institute
>>                                >  >  Deputy Director for Research
>>                                >  >  Institute for Advanced Computing
>>                           Applications and Technologies
>>                                >  >  Paul and Cynthia Saylor Professor of
>>                           Computer Science
>>                                >  >  University of Illinois
>>        Urbana-Champaign
>>                           unsubscribe:
>> **>__>
>>        unsubscribe:
>> **>__>
>>        unsubscribe:
>> **>__>
>>        unsubscribe:
>> https://lists.mcs.anl.gov/____**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/____mailman/listinfo/mpich-discuss>
>> **>__>
>> ____--------------------------**--__--__------------
>>         mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.**gov<mpich-discuss at mcs.anl.gov>
>>                           To manage subscription options or unsubscribe:
>> **>__>
>> **>__>
>>               ______________________________**_____________________
>>               mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> **>__>
>>        ------------------------------**__----------------------------**
>> --__------------
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110915/1ca51c37/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110915/1ca51c37/attachment-0001.obj>
