[mpich-discuss] mpich compilation issue
    Gus Correa
    gus at ldeo.columbia.edu
    Wed Sep 14 12:16:22 CDT 2011
akshar bhosale wrote:
 > No, it is not bug because the same code is running in other machine.
Hi Akshar
The devilish thing with MPI programs is that success in one machine,
or with a certain number of processes, or in a specific network,
doesn't mean that the program is bug free.
It may still fail in a different environment.
[Actually, even sequential programs are like that.
In one computer, with a certain compiler, etc,
say, a segmentation fault may not appear, may not break
at run time, but in another machine/OS/compiler it may.]
"It works" is a necessary but not sufficient condition for
"being bug-free"
The error message you've got is pretty clear.
There is a deadlock.
See Pavan's suggestion in his email.
I hope this helps,
Gus Correa
>     Can something be done so that even if mpif77 does not get created,
>     no issues; but mpif90 (mpich-1.2.7p1, gfortran) should get created
>     and fortran helloworld should run without any issues.
> Thank you
> Akshar.
> On Tue, Sep 13, 2011 at 10:39 PM, Gus Correa <gus at ldeo.columbia.edu
> <mailto:gus at ldeo.columbia.edu>> wrote:
>  Hi Akshar
>     It sounds as a bug in the program,
>     which causes a deadlock, not a problem with MPICH2.
>     Your error message:
>      > MPID_Send(57): DEADLOCK: attempting to send a message to the local
>      > process without a prior matching receive
>     If you post the code, the list may help you.
>     Gus Correa
>         sorry for not answering why not mpich2.
>         We have tried to compile our code using mpich2, it compiles but
>         while running the executable generated, it runs and in between
>         it comes out giving some mpi send error. The code compiled with
>         mpif90 (mpich-1.2.7p1) using gfortran on other machine runs fine.
>         Error is as follows:
>          3  aft MPI_SEND           2           7           2           0
>                   3  call MPI_SEND           2           8           2
>                 0
>                   3  aft MPI_SEND           2           8           2
>                 0
>                   3  call MPI_SEND           2           9           2
>                 0
>                   3  aft MPI_SEND           2           9           2
>                 0
>                   3  call MPI_SEND           2          10           2
>                 0
>                   3  aft MPI_SEND           2          10           2
>                 0
>                   3  call MPI_SEND           3           1           3
>                 0
>         [cli_3]: aborting job:
>         Fatal error in MPI_Send: Other MPI error, error stack:
>         MPI_Send(175): MPI_Send(buf=0x2aaab2af2018, count=1,
>         dtype=USER<vector>, dest=3, tag=30003, MPI_COMM_WORLD) failed
>         local process without a prior matching receive
>         -akshar
>         On Tue, Sep 13, 2011 at 10:02 PM, akshar bhosale
>         <akshar.bhosale at gmail.com <mailto:akshar.bhosale at gmail.com>
>         <mailto:akshar.bhosale at gmail.__com
>         <mailto:akshar.bhosale at gmail.com>>> wrote:
>            thanks for reply.
>            Goal is to generate mpif90 using mpich-1.2.7p1 using gfortran
>         which
>            will generate executable from our fortran code.
>            source files to be compiled are .f and .f90 files.
>            f2c flag is given because mp[if90 was not getting generated. no
>            other reason. we want mpif90.
>            Now we have tried giving only FC=gfortran and no other flag of
>            option except prefix, but still it is not generating mpif90
>         nor mpif77.
>            mpif90 generated  by using [export F90=fortran;F90FLAGS="-ff2c".]
>            options if tries to compile our code, it throws error
>            <path to mpif90>/mpif90 -f90=gfortran -Wl -o ../output_code.x
>         set.o
>            inp.o otp.o bvsol.o user_kg.o mpi_util.o mpi_communication.o
>            mpi_memalloc.o driver.o rxn.o advdi_1d_finitediff_mf.o
>          aq_lib.o \
>                    -L/ioapi/Linux2_x86_64gfort -lioapi
>            -L/np_cs/netcdf/INSTALL/lib -lnetcdf -L/usr/lib64/
>             -lgomp /np_cs/lapack/lapack-3.2.1/__lapack_LINUX.a
>            /np_cs/lapack/lapack-3.2.1/__blas_LINUX.a
>            /build/lib/libmpich.a(farg.o): In function `mpir_iargc__':
>            farg.f:(.text+0x6): undefined reference to `f__xargc'
>            /build/lib/libmpich.a(farg.o): In function `mpir_getarg__':
>            farg.f:(.text+0x38): undefined reference to `getarg_'
>            collect2: ld returned 1 exit status
>            make: *** [../output_code.x] Error 1
>            -akshar
>            On Tue, Sep 13, 2011 at 8:52 PM, Gus Correa
>         <gus at ldeo.columbia.edu <mailto:gus at ldeo.columbia.edu>
>         <mailto:gus at ldeo.columbia.edu>>__> wrote:
>                Hi Pavan and Akshar
>                I see, it's MPICH-1.
>                May I ask why?
>                Would a workaround perhaps be to build only mpif77 (no
>         mpif90),
>                replace 'use mpi' by '#include "mpif.h"' in the
>         application code,
>                and recompile it with mpif77?
>                I wonder if -ff2c works at all with Fortran90.
>                (See man page detail below.)
>                Anyway, I remember that there were complaints of runtime
>                errors (P4 errors) with mpich-1,
>                reported on this and other mailing lists,
>                when running on current Linux kernels.
>                Even with simple codes like the cpi example.
>                Using MPICH-1 may be an uphill battle.
>                I hope this helps,
>                Gus Correa
>                 >From man gfortran (4.1.2):
>                      -ff2c
>                          Generate code designed to be compatible with code
>                generated by g77 and f2c.
>                          The calling conventions used by g77 (originally
>                implemented in f2c) require functions that return type
>         default
>                "REAL" to actually return the C type
>                          "double", and functions that return type
>         "COMPLEX" to
>                return the values via an extra argument in the calling
>         sequence
>                that points to where to store the
>                          return value.  Under the default GNU calling
>                conventions, such functions simply return their results
>         as they
>                would in GNU C -- default "REAL" functions
>                          return the C type "float", and "COMPLEX" functions
>                return the GNU C type "complex".  Additionally, this option
>                implies the -fsecond-underscore option,
>                          unless -fno-second-underscore is explicitly
>         requested.
>                          This does not affect the generation of code that
>                interfaces with the libgfortran library.
>                          Caution: It is not a good idea to mix Fortran code
>                compiled with "-ff2c" with code compiled with the default
>                "-fno-f2c" calling conventions as, calling
>                          "COMPLEX" or default "REAL" functions between
>         program
>                parts which were compiled with different calling conventions
>                will break at execution time.
>                          Caution: This will break code which passes
>         intrinsic
>                functions of type default "REAL" or "COMPLEX" as actual
>                arguments, as the library implementations
>                          use the -fno-f2c calling conventions.
>                Pavan Balaji wrote:
>                    Gus: He doesn't want to use MPICH2. He's using MPICH-1.
>                           -- Pavan
>                    On 09/13/2011 09:51 AM, Gus Correa wrote:
>                        Hi Akshar
>                        Maybe the F90FLAGS="-ff2c" flag is causing the
>         problem?
>                        What if you remove it and use gfortran for F77
>         and FC?
>                        Also, my 'configure -help' (a bit old, MPICH2
>         1.3.2p1)
>                        mentions FC, not F90, as the environment variable
>         to be set.
>                        For what it is worth, MPICH2 builds fine for us, with
>                        gcc, g++ and gfortran (for F77 and FC).
>                        My two cents,
>                        Gus Correa
>                            Hi,
>                               If i specify F77 anf F90 as gfortran, it
>         doesn't
>                            create mpif90 and
>                            mpif77 at all.
>                            Please see attached config log
>                            If i specify F90=gfortran and
>         F90FLAGS="-ff2c", the
>                            it creates mpif90
>                            and mpif77 but is generating below issue.
>                            Kindly help.
>                            -akshar
>                            On Tue, Sep 13, 2011 at 9:46 AM, Rajeev
>                            Thakur<thakur at mcs.anl.gov
>         <mailto:thakur at mcs.anl.gov> <mailto:thakur at mcs.anl.gov
>         <mailto:thakur at mcs.anl.gov>>
>         <mailto:thakur at mcs.anl.gov>>>>  wrote:
>                                In the configure step, if you specify
>         both F77
>                            and F90 as gfortran,
>                                it should work.
>                                Rajeev
>                                On Sep 12, 2011, at 9:49 PM, akshar
>         bhosale wrote:
>                                 >  Hi,
>                                 >  thanks.
>                                 >  but, in case of mpicc, it can be ignored,
>                            but in case of mpif90,
>                                it is still an issue.
>                                 >  e.g. hello_mpi.f90 program
>                                 >  program main
>                                 >     use mpi
>                                 >  ! implicit none
>                                 >    integer error
>                                 >    integer id
>                                 >    integer p
>                                 >    real ( kind = 8 ) wtime
>                                 >  !  Initialize MPI.
>                                 >    call MPI_Init ( error )
>                                 >  !  Get the number of processes.
>                                 >    call MPI_Comm_size ( MPI_COMM_WORLD, p,
>                            error )
>                                 >  !  Get the individual process ID.
>                                 >    call MPI_Comm_rank (
>         MPI_COMM_WORLD, id,
>                            error )
>                                 >  !  Print a message.
>                                 >    if ( id == 0 ) then
>                                 >      wtime = MPI_Wtime ( )
>                                 >      write ( *, '(a)' ) ' '
>                                 >      write ( *, '(a)' ) 'HELLO_MPI -
>         Master
>                            process:'
>          FORTRAN90/MPI version'
>                                 >      write ( *, '(a)' ) '  An MPI test
>         program.'
>                                 >      write ( *, '(a,i8)' ) '  The
>         number of
>                            processes is ', p
>                                 >    end if
>                                 >    write ( *, '(a,i8,a)' ) '  Process
>         ', id,
>                            ' says "Hello, world!"'
>                                 >    if ( id == 0 ) then
>         Master
>                            process:'
>                                 >      write ( *, '(a)' ) '  Normal end of
>                            execution: "Goodbye,
>                                world!".'
>                                 >      wtime = MPI_Wtime ( ) - wtime
>                                 >      write ( *, '(a,g14.6,a)' ) '  Elapsed
>                            wall clock time = ',
>                                wtime, ' seconds.'
>                                 >     end if
>                                 >   !  Shut down MPI.
>                                 >    call MPI_Finalize ( error )
>                                 >    stop
>                                 >    end
>                                 >  $ ../../../build/bin/mpif90 hello_mpi.f90
>         /scratch1/np_cs/trial1/build/____lib/libmpich.a(farg.o):
>                            In function
>                                `mpir_iargc__':
>         reference to
>                            `f__xargc'
>                            In function
>                                `mpir_getarg__':
>         reference to
>                            `getarg_'
>                                 >  On Mon, Sep 12, 2011 at 9:42 AM,
>         Rajeev Thakur
>         <mailto:thakur at mcs.anl.gov>><__mailto:tha__kur at mcs.anl.gov
>         <mailto:tha__kur at mcs.anl.gov>
>                                 >  Ignore that. Compile a real program
>         as mpicc
>                            foo.c.
>                                 >  On Sep 11, 2011, at 8:38 PM, akshar
>         bhosale
>                            wrote:
>                                 >  >  Hi,
>                                 >  >  thank you for reply.
>                                 >  >  I tried to install it make it using
>                            following options now and i
>                                get following error with undefined
>         reference to
>                            main. options given
>                                while configuring the same are :
>                                 >  >  but error of undefined reference
>         to main
>                            is observed in every
>                                executable like :
>                                 >  >  ./mpicc -v
>                                 >  >  mpicc for 1.2.7 (release) of :
>         2005/06/22
>                            16:33:49
>                                 >  >  Using built-in specs.
>                                 >  >  Target: x86_64-redhat-linux
>                                 >  >  Configured with: ../configure
>         --prefix=/usr
>                                --mandir=/usr/share/man
>                            --infodir=/usr/share/info --enable-shared
>                                --enable-threads=posix
>         --enable-checking=release
>                            --with-system-zlib
>                                --enable-__cxa_atexit
>         --disable-libunwind-exceptions
>                                --enable-libgcj-multifile
>         --enable-languages=c,c++,objc,____obj-c++,java,fortran,ada
>                                --enable-java-awt=gtk --disable-dssi
>                            --disable-plugin
>         --with-java-home=/usr/lib/jvm/____java-1.4.2-gcj-1.4.2.0/jre
>                                --with-cpu=generic --host=x86_64-redhat-linux
>                                 >  >  Thread model: posix
>                                 >  >  gcc version 4.1.2 20080704 (Red
>         Hat 4.1.2-50)
>          /usr/libexec/gcc/x86_64-____redhat-linux/4.1.2/collect2
>                                --eh-frame-hdr -m elf_x86_64 --hash-style=gnu
>                            -dynamic-linker
>                                /lib64/ld-linux-x86-64.so.2
>         /usr/lib/gcc/x86_64-redhat-____linux/4.1.2/../../../../lib64/____crt1.o
>         /usr/lib/gcc/x86_64-redhat-____linux/4.1.2/../../../../lib64/____crti.o
>          /usr/lib/gcc/x86_64-redhat-____linux/4.1.2/crtbegin.o
>                                -L/scratch1/np_cs/trial2/____build/lib
>                                -L/opt/intel/mkl/10.2.2.025/____lib/em64t
>         <http://10.2.2.025/__lib/em64t>
>          <http://10.2.2.025/lib/em64t><__http://10.2.2.025/__lib/em64t
>                            <http://10.2.2.025/lib/em64t>>
>                                -L/usr/lib/gcc/x86_64-redhat-____linux/4.1.2
>         -L/usr/lib/gcc/x86_64-redhat-____linux/4.1.2/../../../../lib64
>                                -L/lib/../lib64 -L/usr/lib/../lib64 -lmpich
>                            -lpthread -lrt -lgcc
>                                --as-needed -lgcc_s --no-as-needed -lc -lgcc
>                            --as-needed -lgcc_s
>                                --no-as-needed
>          /usr/lib/gcc/x86_64-redhat-____linux/4.1.2/crtend.o
>         /usr/lib/gcc/x86_64-redhat-____linux/4.1.2/../../../../lib64/____crtn.o
>         /usr/lib/gcc/x86_64-redhat-____linux/4.1.2/../../../../lib64/____crt1.o:
>                            In
>                                function `_start':
>                                 >  >  (.text+0x20): undefined reference
>         to `main'
>                                 >  >  ./mpif90 -v
>                                 >  >  mpif90 for 1.2.7 (release) of :
>                            2005/06/22 16:33:49
>                                 >  >  Driving: gfortran
>                            -L/scratch1/np_cs/trial2/____build/lib -v
>                                -lmpichf90 -lmpich -lpthread -lrt
>                            -lgfortranbegin -lgfortran -lm
>                                -shared-libgcc
>         --prefix=/usr
>                            --with-system-zlib
>                            --disable-plugin
>                                 >  >  Thread model: posix
>         Hat 4.1.2-50)
>                            -dynamic-linker
>         -lmpichf90
>                            -lmpich -lpthread
>                                -lrt -lgfortranbegin -lgfortran -lm -lgcc_s
>                            -lgcc -lc -lgcc_s -lgcc
>         /usr/lib/gcc/x86_64-redhat-____linux/4.1.2/libgfortranbegin.____a(fmain.o):
>                                In function `main':
>                                 >  >  (.text+0xa): undefined reference
>         to `MAIN__'
>                                 >  >  Am i missing somethin?
>                                 >  >  thank you
>                                 >  >  -akshar
>                                 >  >  On Mon, Sep 12, 2011 at 1:24 AM,
>         William
>                            Gropp
>                                <wgropp at illinois.edu
>         <mailto:wgropp at illinois.edu>
>         <mailto:wgropp at illinois.edu>><__mailto:wg__ropp at illinois.edu
>         <mailto:wg__ropp at illinois.edu>
>         <mailto:wgropp at illinois.edu>>>>  wrote:
>                                 >  >  You can use gfortran for F77 and
>         F90.  If
>                            your requirement is
>                                to use gfortran for F77 and a different
>         fortran
>                            for F90, then they
>                                will need to use consistent linker names,
>                            calling conventions, data
>                                sizes, and libraries.  The config.log
>         file will
>                            have details on why
>                                configure decided that the Fortran 77 and
>                            Fortran 90 compilers were
>                                not compatible.
>                                 >  >  Bill
>                                 >  >  On Sep 9, 2011, at 4:28 PM, akshar
>                            bhosale wrote:
>                                 >  >  hi,
>                                 >  >  we have requirement of mpich-1.2.7
>         with
>                            gfortran. We have fiven
>                                flags as :
>         CC=gcc;F90=fortran;F77=____gfortran;
>                            and tried to configure,
>                                it throws error as configure: error:
>         Fortran 90
>                            and Fortran 77
>                                compilers are not compatible..
>                                 >  >  We have to do it using gfortran
>         only. os
>                            is rhel5.1 64 bit
>                                 >  >  what extran flags settings we have
>         to do?
>                                 >  >  -akshar
>         ___________________________________________________
>                                 >  >  mpich-discuss mailing list
>                        mpich-discuss at mcs.anl.gov
>         <mailto:mpich-discuss at mcs.anl.gov>
>                            <mailto:mpich-discuss at mcs.anl.__gov
>         <mailto:mpich-discuss at mcs.anl.gov>>
>         <mailto:mpich-discuss at mcs.anl.>____gov
>         <mailto:mpich-discuss at mcs.anl.gov>>>
>                                 >  >  To manage subscription options or
>                            unsubscribe:
>         https://lists.mcs.anl.gov/____mailman/listinfo/mpich-discuss
>         <https://lists.mcs.anl.gov/__mailman/listinfo/mpich-discuss>
>         <https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>__>
>                                 >  >  William Gropp
>                                 >  >  Director, Parallel Computing Institute
>                                 >  >  Deputy Director for Research
>                                 >  >  Institute for Advanced Computing
>                            Applications and Technologies
>                                 >  >  Paul and Cynthia Saylor Professor of
>                            Computer Science
>                                 >  >  University of Illinois
>         Urbana-Champaign
>                            unsubscribe:
>         unsubscribe:
>         unsubscribe:
>         unsubscribe:
>          ------------------------------____----------------------------__--__------------
>              mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>                            To manage subscription options or unsubscribe:
>                mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>         ------------------------------__------------------------------__------------
